BPI-R3 SD card start-up Can't find the USB drive
root@OpenWrt:/# df Filesystem 1K-blocks Used Available Use% Mounted on tmpfs 1021820 20408 1001412 2% / tmpfs 1021820 52 1021768 0% /tmp tmpfs 512 0 512 0% /dev
root@OpenWrt:/# ls bin init mnt rom sys var dev lib overlay root tmp www etc lib64 proc sbin usr root@OpenWrt:/#
  • The USB drive was also replaced
Which image? Maybe driver for it is missing…
#modprobe configs
zgrep -i usb /proc/config.gz
bananapi_bpi-r3-sdcard.img.gz
So openwrt snapshot…what is the output of command above? Which kind of usb-stick (usb1.1,2,3). What says lsusb -v and dmesg after plugging it
No more tossing, this version still has to load the file inside the tftp to start, replace the file provided by https://wiki.banana-pi.org/Banana_Pi_BPI-R3 can start smoothly
Do you have something in the m.2 slot?
not have :joy::joy::joy::joy:
