[BPI-R3] Reboot from NAND throws "Block erasure failed at address"
I booted from NAND to retrieve the installed packages, didn’t do anything else but to reboot. During the reboot sequence I faced these concerning errors:
root@OpenWrt:/# reboot
[  177.522049] nmbm nmbm_spim_nand: Block erasure failed at address 0x03800000
[  177.529004] nmbm nmbm_spim_nand: Block 448 [0x03800000] will be marked bad
[  177.536189] nmbm nmbm_spim_nand: Logic block 448 mapped to physical blcok 1022
[  178.739426] nmbm nmbm_spim_nand: Block erasure failed at address 0x07860000
[  178.746374] nmbm nmbm_spim_nand: Block 963 [0x07860000] will be marked bad
[  179.948892] nmbm nmbm_spim_nand: Block erasure failed at address 0x07880000
[  179.955846] nmbm nmbm_spim_nand: Block 964 [0x07880000] will be marked bad
[  181.158402] nmbm nmbm_spim_nand: Block erasure failed at address 0x078a0000
[  181.165352] nmbm nmbm_spim_nand: Block 965 [0x078a0000] will be marked bad
[  182.367945] nmbm nmbm_spim_nand: Block erasure failed at address 0x078c0000
[  182.374892] nmbm nmbm_spim_nand: Block 966 [0x078c0000] will be marked bad
[  183.577538] nmbm nmbm_spim_nand: Block erasure failed at address 0x078e0000
[  183.584485] nmbm nmbm_spim_nand: Block 967 [0x078e0000] will be marked bad
[  184.787194] nmbm nmbm_spim_nand: Block erasure failed at address 0x07900000
[  184.794141] nmbm nmbm_spim_nand: Block 968 [0x07900000] will be marked bad
[  185.996871] nmbm nmbm_spim_nand: Block erasure failed at address 0x07920000
[  186.003818] nmbm nmbm_spim_nand: Block 969 [0x07920000] will be marked bad
[  187.206604] nmbm nmbm_spim_nand: Block erasure failed at address 0x07940000
[  187.213552] nmbm nmbm_spim_nand: Block 970 [0x07940000] will be marked bad
[  188.416388] nmbm nmbm_spim_nand: Block erasure failed at address 0x07960000
[  188.423335] nmbm nmbm_spim_nand: Block 971 [0x07960000] will be marked bad
[  189.626200] nmbm nmbm_spim_nand: Block erasure failed at address 0x07980000
[  189.633148] nmbm nmbm_spim_nand: Block 972 [0x07980000] will be marked bad
[  190.836058] nmbm nmbm_spim_nand: Block erasure failed at address 0x079a0000
[  190.843004] nmbm nmbm_spim_nand: Block 973 [0x079a0000] will be marked bad
[  191.841456] 7986@C12L1ra0,rt28xx_ap_ioctl() 870: interface is down, cmd [8be2] return!!!
[  191.885067] br-lan: port 5(lan5) entered disabled state
[  191.901598] device lan1 left promiscuous mode
[  191.906038] br-lan: port 1(lan1) entered disabled state
[  191.940013] device lan2 left promiscuous mode
[  191.944441] br-lan: port 2(lan2) entered disabled state
[  191.979538] device lan3 left promiscuous mode
[  191.983958] br-lan: port 3(lan3) entered disabled state
[  192.031254] device lan4 left promiscuous mode
[  192.035679] br-lan: port 4(lan4) entered disabled state
[  192.045957] nmbm nmbm_spim_nand: Block erasure failed at address 0x079c0000
[  192.052905] nmbm nmbm_spim_nand: Block 974 [0x079c0000] will be marked bad
[  192.067031] device lan5 left promiscuous mode
[  192.071441] br-lan: port 5(lan5) entered disabled state
[  192.095773] mt7530 mdio-bus:1f lan5: Link is Down
[  192.242510] br-wan: port 2(eth1) entered disabled state
[  192.247795] br-wan: port 1(lan0) entered disabled state
[  192.263578] device eth1 left promiscuous mode
[  192.267993] br-wan: port 2(eth1) entered disabled state
[  192.286830] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[  192.294083] device lan0 left promiscuous mode
[  192.298461] device eth0 left promiscuous mode
[  192.302936] br-wan: port 1(lan0) entered disabled state
[  192.334369] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[  192.347025] mt7530 mdio-bus:1f lan0: Link is Down
[  193.255942] nmbm nmbm_spim_nand: Block erasure failed at address 0x079e0000
[  193.262966] nmbm nmbm_spim_nand: Block 975 [0x079e0000] will be marked bad
[  194.465873] nmbm nmbm_spim_nand: Block erasure failed at address 0x07a00000
[  194.472826] nmbm nmbm_spim_nand: Block 976 [0x07a00000] will be marked bad
[  195.675886] nmbm nmbm_spim_nand: Block erasure failed at address 0x07a20000
[  195.682832] nmbm nmbm_spim_nand: Block 977 [0x07a20000] will be marked bad
[  196.885928] nmbm nmbm_spim_nand: Block erasure failed at address 0x07a40000
[  196.892874] nmbm nmbm_spim_nand: Block 978 [0x07a40000] will be marked bad
[  198.096018] nmbm nmbm_spim_nand: Block erasure failed at address 0x07a60000
[  198.102965] nmbm nmbm_spim_nand: Block 979 [0x07a60000] will be marked bad
[  199.306157] nmbm nmbm_spim_nand: Block erasure failed at address 0x07a80000
[  199.313103] nmbm nmbm_spim_nand: Block 980 [0x07a80000] will be marked bad
[  200.516321] nmbm nmbm_spim_nand: Block erasure failed at address 0x07aa0000
[  200.523267] nmbm nmbm_spim_nand: Block 981 [0x07aa0000] will be marked bad
[  201.726501] nmbm nmbm_spim_nand: Block erasure failed at address 0x07ac0000
[  201.733447] nmbm nmbm_spim_nand: Block 982 [0x07ac0000] will be marked bad
[  202.936730] nmbm nmbm_spim_nand: Block erasure failed at address 0x07ae0000
[  202.943676] nmbm nmbm_spim_nand: Block 983 [0x07ae0000] will be marked bad
[  204.146994] nmbm nmbm_spim_nand: Block erasure failed at address 0x07b00000
[  204.153940] nmbm nmbm_spim_nand: Block 984 [0x07b00000] will be marked bad
[  205.357293] nmbm nmbm_spim_nand: Block erasure failed at address 0x07b20000
[  205.364239] nmbm nmbm_spim_nand: Block 985 [0x07b20000] will be marked bad
[  206.567626] nmbm nmbm_spim_nand: Block erasure failed at address 0x07b40000
[  206.574572] nmbm nmbm_spim_nand: Block 986 [0x07b40000] will be marked bad
[  207.777980] nmbm nmbm_spim_nand: Block erasure failed at address 0x07b60000
[  207.784926] nmbm nmbm_spim_nand: Block 987 [0x07b60000] will be marked bad
[  208.988368] nmbm nmbm_spim_nand: Block erasure failed at address 0x07b80000
[  208.995314] nmbm nmbm_spim_nand: Block 988 [0x07b80000] will be marked bad
[  210.198800] nmbm nmbm_spim_nand: Block erasure failed at address 0x07ba0000
[  210.205747] nmbm nmbm_spim_nand: Block 989 [0x07ba0000] will be marked bad
[  211.409239] nmbm nmbm_spim_nand: Block erasure failed at address 0x07bc0000
[  211.416185] nmbm nmbm_spim_nand: Block 990 [0x07bc0000] will be marked bad
[  212.619731] nmbm nmbm_spim_nand: Block erasure failed at address 0x07be0000
[  212.626676] nmbm nmbm_spim_nand: Block 991 [0x07be0000] will be marked bad
[  213.830229] nmbm nmbm_spim_nand: Block erasure failed at address 0x07c00000
[  213.837174] nmbm nmbm_spim_nand: Block 992 [0x07c00000] will be marked bad
[  215.040765] nmbm nmbm_spim_nand: Block erasure failed at address 0x07c20000
[  215.047711] nmbm nmbm_spim_nand: Block 993 [0x07c20000] will be marked bad
[  216.251331] nmbm nmbm_spim_nand: Block erasure failed at address 0x07c40000
[  216.258277] nmbm nmbm_spim_nand: Block 994 [0x07c40000] will be marked bad
[  217.461921] nmbm nmbm_spim_nand: Block erasure failed at address 0x07c60000
[  217.468867] nmbm nmbm_spim_nand: Block 995 [0x07c60000] will be marked bad
[  218.672545] nmbm nmbm_spim_nand: Block erasure failed at address 0x07c80000
[  218.679490] nmbm nmbm_spim_nand: Block 996 [0x07c80000] will be marked bad
[  219.883181] nmbm nmbm_spim_nand: Block erasure failed at address 0x07ca0000
[  219.890127] nmbm nmbm_spim_nand: Block 997 [0x07ca0000] will be marked bad
I then pulled the plug …
Best Mike
