Hi
it noticed removed, because i put the sfp on the other sfp cage to test.
So, i have use your device tree, without modifications.
here the dmesg :
# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.0-rc6-diagbox (root@workstation) (aarch64-linux-gnu-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #1 SMP Thu Dec 8 22:35:12 CET 2022
[ 0.000000] Machine model: Bananapi BPI-R3
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000011002000 (options '')
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'wmcpu-reserved@4fc00000': base 0x000000004fc00000, size 1 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
[ 0.000000] node 0: [mem 0x0000000043030000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 27 pages/cpu s70760 r8192 d31640 u110592
[ 0.000000] pcpu-alloc: s70760 r8192 d31640 u110592 alloc=27*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: board=DiagBox earlycon=uart8250,mmio32,0x11002000 debug=7 initrd=0x48000000,550M
[ 0.000000] Unknown kernel command line parameters "board=DiagBox", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Memory: 1469856K/2097152K available (12736K kernel code, 2254K rwdata, 3784K rodata, 3968K init, 438K bss, 627296K reserved, 0K cma-reserved)
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 640 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.008291] Console: colour dummy device 80x25
[ 0.012756] printk: console [tty0] enabled
[ 0.016871] printk: bootconsole [uart8250] disabled
[ 0.021798] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.021811] pid_max: default: 32768 minimum: 301
[ 0.021905] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.021920] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.022502] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.022803] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.022814] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.022911] rcu: Hierarchical SRCU implementation.
[ 0.022917] rcu: Max phase no-delay instances is 1000.
[ 0.023368] EFI services will not be available.
[ 0.023524] smp: Bringing up secondary CPUs ...
[ 0.023845] Detected VIPT I-cache on CPU1
[ 0.023901] cacheinfo: Unable to detect cache hierarchy for CPU 1
[ 0.023909] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.023943] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.024280] Detected VIPT I-cache on CPU2
[ 0.024315] cacheinfo: Unable to detect cache hierarchy for CPU 2
[ 0.024320] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.024334] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.024613] Detected VIPT I-cache on CPU3
[ 0.024649] cacheinfo: Unable to detect cache hierarchy for CPU 3
[ 0.024654] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.024665] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.024700] smp: Brought up 1 node, 4 CPUs
[ 0.024749] SMP: Total of 4 processors activated.
[ 0.024756] CPU features: detected: 32-bit EL0 Support
[ 0.024762] CPU features: detected: CRC32 instructions
[ 0.024805] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.024816] CPU: All CPU(s) started at EL2
[ 0.024821] alternatives: applying system-wide alternatives
[ 0.026571] devtmpfs: initialized
[ 0.028937] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.028971] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.029087] pinctrl core: initialized pinctrl subsystem
[ 0.029390] DMI not present or invalid.
[ 0.029799] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.030097] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.030132] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.030164] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.030589] thermal_sys: Registered thermal governor 'fair_share'
[ 0.030592] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.030599] thermal_sys: Registered thermal governor 'step_wise'
[ 0.030605] thermal_sys: Registered thermal governor 'user_space'
[ 0.030688] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.030752] ASID allocator initialised with 65536 entries
[ 0.042856] cryptd: max_cpu_qlen set to 1000
[ 0.043802] iommu: Default domain type: Translated
[ 0.043825] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.043961] SCSI subsystem initialized
[ 0.044079] libata version 3.00 loaded.
[ 0.044179] usbcore: registered new interface driver usbfs
[ 0.044205] usbcore: registered new interface driver hub
[ 0.044230] usbcore: registered new device driver usb
[ 0.044483] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
[ 0.044602] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
[ 0.044650] pps_core: LinuxPPS API ver. 1 registered
[ 0.044657] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.044672] PTP clock support registered
[ 0.045585] vgaarb: loaded
[ 0.065887] clocksource: Switched to clocksource arch_sys_counter
[ 0.070008] NET: Registered PF_INET protocol family
[ 0.070205] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.071273] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.071325] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.071339] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.071417] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.071816] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.071950] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.071999] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.072189] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.072876] PCI: CLS 0 bytes, default 64
[ 0.073062] Unpacking initramfs...
[ 0.085852] Initialise system trusted keyrings
[ 0.086035] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.089333] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.089424] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.111855] Key type asymmetric registered
[ 0.111892] Asymmetric key parser 'x509' registered
[ 0.111995] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.112006] io scheduler mq-deadline registered
[ 0.112012] io scheduler kyber registered
[ 0.145127] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.166802] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 2500000) is a ST16650V2
[ 0.995043] printk: console [ttyS0] enabled
[ 1.020469] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 117, base_baud = 1625000) is a ST16650V2
[ 1.050904] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 118, base_baud = 1625000) is a ST16650V2
[ 1.061155] mtk_rng 1020f000.rng: registered RNG driver
[ 1.066825] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.076618] loop: module loaded
[ 1.081657] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.087012] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 2.438212] Initramfs unpacking failed: invalid magic at start of compressed archive
[ 2.642034] Freeing initrd memory: 563200K
[ 2.661270] 4 fixed-partitions partitions found on MTD device spi0.0
[ 2.667652] Creating 4 MTD partitions on "spi0.0":
[ 2.672432] 0x000000580000-0x000008000000 : "ubi"
[ 2.815723] 0x000000380000-0x000000580000 : "fip"
[ 2.823176] 0x000000080000-0x000000380000 : "reserved"
[ 2.832504] 0x000000000000-0x000000080000 : "bl2"
[ 2.839740] sfp sfp-1: Host maximum power 1.0W
[ 2.844720] sfp sfp-2: Host maximum power 1.0W
[ 2.867174] mtk_soc_eth 15100000.ethernet: generated random MAC address 9e:75:21:bc:e6:80
[ 2.875662] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc00b900000, irq 121
[ 2.884840] mtk_soc_eth 15100000.ethernet: generated random MAC address 1e:89:47:d4:97:84
[ 2.893269] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc00b900000, irq 121
[ 2.902815] usbcore: registered new interface driver usb-storage
[ 2.909034] i2c_dev: i2c /dev entries driver
[ 2.915488] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 2.924346] SMCCC: SOC_ID: ID = jep106:0426:7986 Revision = 0x00000000
[ 2.931010] usbcore: registered new interface driver usbhid
[ 2.936596] usbhid: USB HID core driver
[ 2.941351] xt_time: kernel timezone is -0000
[ 2.945726] IPVS: Registered protocols ()
[ 2.949803] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 2.957214] IPVS: ipvs loaded.
[ 2.960316] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 2.966202] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[ 2.972687] Initializing XFRM netlink socket
[ 2.977045] NET: Registered PF_PACKET protocol family
[ 2.982106] NET: Registered PF_KEY protocol family
[ 2.987071] 8021q: 802.1Q VLAN Support v1.8
[ 2.991297] Key type dns_resolver registered
[ 2.996015] Loading compiled-in X.509 certificates
[ 3.006610] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.009819] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 3.016474] mmc0: new high speed SDHC card at address 0001
[ 3.021927] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 3.028402] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 3.033643] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 3.044588] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 3.185710] sfp sfp-2: module RAD Data Comm. SFP-30H rev 1.0 sn OP18060400248 dc 180604
[ 3.265897] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.active (0x1000001)
[ 3.275299] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 3.300368] mt7530 mdio-bus:1f: no interrupt support
[ 3.335306] mt7530 mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 3.342479] mt7530 mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 3.351675] mt7530 mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.371416] mt7530 mdio-bus:1f lan0 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.390989] mt7530 mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.410564] mt7530 mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.430139] mt7530 mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.440839] device eth0 entered promiscuous mode
[ 3.445484] DSA: tree 0 setup
[ 3.448862] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 3.456278] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 3.464658] xhci-mtk 11200000.usb: xHCI Host Controller
[ 3.469905] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 3.480289] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 3.489452] xhci-mtk 11200000.usb: irq 127, io mem 0x11200000
[ 3.495293] xhci-mtk 11200000.usb: xHCI Host Controller
[ 3.500517] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 3.507908] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 3.515435] hub 1-0:1.0: USB hub found
[ 3.519218] hub 1-0:1.0: 2 ports detected
[ 3.523526] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.531989] hub 2-0:1.0: USB hub found
[ 3.535763] hub 2-0:1.0: 1 port detected
[ 3.540870] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.556800] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.566945] Freeing unused kernel memory: 3968K
[ 3.635958] Run /init as init process
[ 3.639625] with arguments:
[ 3.642582] /init
[ 3.644843] with environment:
[ 3.647983] HOME=/
[ 3.650331] TERM=linux
[ 3.653025] board=DiagBox
[ 3.751017] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 3.823127] EXT4-fs (mmcblk0p6): recovery complete
[ 3.837649] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Quota mode: disabled.
[ 3.856830] F2FS-fs (mmcblk0p7): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 3.864062] F2FS-fs (mmcblk0p7): Can't find valid F2FS filesystem in 1th superblock
[ 3.872321] F2FS-fs (mmcblk0p7): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 3.879541] F2FS-fs (mmcblk0p7): Can't find valid F2FS filesystem in 2th superblock
[ 3.965964] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 3.990710] udevd[1311]: starting version 3.2.9
[ 4.146624] hub 1-1:1.0: USB hub found
[ 4.150451] hub 1-1:1.0: 4 ports detected
[ 4.565907] usb 1-1.1: new high-speed USB device number 3 using xhci-mtk
[ 11.366153] random: crng init done
[ 11.377833] udevd[1332]: starting eudev-3.2.9
[ 11.410569] usbcore: registered new interface driver usbserial_generic
[ 11.415138] usbcore: registered new interface driver cdc_wdm
[ 11.417736] usbserial: USB Serial support registered for generic
[ 11.438614] usbcore: registered new interface driver option
[ 11.444750] usbserial: USB Serial support registered for GSM modem (1-port)
[ 11.452227] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
[ 11.459957] qmi_wwan 1-1.1:1.4 wwan0: register 'qmi_wwan' at usb-11200000.usb-1.1, WWAN/QMI device, 82:9a:85:eb:93:d9
[ 11.471213] option 1-1.1:1.0: GSM modem (1-port) converter detected
[ 11.476003] usbcore: registered new interface driver qmi_wwan
[ 11.491828] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
[ 11.499045] option 1-1.1:1.1: GSM modem (1-port) converter detected
[ 11.505723] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
[ 11.513170] option 1-1.1:1.2: GSM modem (1-port) converter detected
[ 11.519982] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
[ 11.527586] option 1-1.1:1.3: GSM modem (1-port) converter detected
[ 11.534199] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
[ 11.559215] mtdblock: MTD device 'fip' is NAND, please consider using UBI block devices instead.
[ 11.559833] mtdblock: MTD device 'reserved' is NAND, please consider using UBI block devices instead.
[ 11.562690] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[ 11.572248] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[ 12.792045] br-wire: port 1(lan0) entered blocking state
[ 12.797399] br-wire: port 1(lan0) entered disabled state
[ 12.818379] device lan0 entered promiscuous mode
[ 12.825339] br-wire: port 2(lan1) entered blocking state
[ 12.830658] br-wire: port 2(lan1) entered disabled state
[ 12.856973] device lan1 entered promiscuous mode
[ 12.863055] br-wire: port 3(lan2) entered blocking state
[ 12.868365] br-wire: port 3(lan2) entered disabled state
[ 12.886976] device lan2 entered promiscuous mode
[ 12.893033] br-wire: port 4(lan3) entered blocking state
[ 12.898342] br-wire: port 4(lan3) entered disabled state
[ 12.916969] device lan3 entered promiscuous mode
[ 15.036128] mt7986-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20220113162701a
[ 15.036128]
[ 15.062671] mt7986-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20220113162756
[ 15.104139] mt7986-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20220113163034
[ 19.333819] br-wifi: port 1(wlan0) entered blocking state
[ 19.339253] br-wifi: port 1(wlan0) entered disabled state
[ 19.344764] device wlan0 entered promiscuous mode
[ 19.349567] br-wifi: port 1(wlan0) entered blocking state
[ 19.354956] br-wifi: port 1(wlan0) entered forwarding state
[ 19.365936] br-wifi: port 1(wlan0) entered disabled state
[ 19.663548] br-wifi: port 1(wlan0) entered blocking state
[ 19.668974] br-wifi: port 1(wlan0) entered forwarding state
[ 20.082012] br-wifi: port 2(wlan1) entered blocking state
[ 20.087458] br-wifi: port 2(wlan1) entered disabled state
[ 20.092985] device wlan1 entered promiscuous mode
[ 20.097758] br-wifi: port 2(wlan1) entered blocking state
[ 20.103145] br-wifi: port 2(wlan1) entered forwarding state
[ 47.940623] sfp sfp-2: module removed
[ 50.935712] sfp sfp-1: module RAD Data Comm. SFP-30H rev 1.0 sn OP18060400248 dc 180604
[ 76.847889] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[ 76.926031] mtk_soc_eth 15100000.ethernet eth1: switched to inband/sgmii link mode
[ 77.102876] mtk_soc_eth 15100000.ethernet eth1: PHY [i2c:sfp-1:16] driver [Marvell 88E1111] (irq=POLL)
Here another commands (ip a and ethtool for eth1) :
# ip a
2: eth0: <BROADCAST,MULTICAST> mtu 1504 qdisc noop state DOWN group default qlen 1000
link/ether 9e:75:21:bc:e6:80 brd ff:ff:ff:ff:ff:ff
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 1e:89:47:d4:97:84 brd ff:ff:ff:ff:ff:ff
4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/ipip 0.0.0.0 brd 0.0.0.0
5: wan@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN group default qlen 1000
6: lan0@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop master br-wire state DOWN group default qlen 1000
7: lan1@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop master br-wire state DOWN group default qlen 1000
8: lan2@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop master br-wire state DOWN group default qlen 1000
9: lan3@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop master br-wire state DOWN group default qlen 1000
10: lan4@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN group default qlen 1000
11: wwan0: <POINTOPOINT,MULTICAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/none
12: br-wire: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
inet 10.0.0.1/24 scope global br-wire
13: br-wifi: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:0c:43:26:60:00 brd ff:ff:ff:ff:ff:ff
inet 10.0.1.1/24 scope global br-wifi
14: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-wifi state UP group default qlen 1000
15: wlan1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-wifi state UP group default qlen 1000
link/ether 82:0c:43:26:60:00 brd ff:ff:ff:ff:ff:ff
# ethtool eth1
Settings for eth1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
1000baseX/Full
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseX/Full
Link partner advertised link modes: 100baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 22
Transceiver: external
MDI-X: Unknown
Link detected: no
Always this line with ethtool command :
