All startup logs
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.149 (ghhc@ghhccghk-pc) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 11.3.0 r0-eb3e9ad2) 11.3.0, GNU ld (GNU Binutils) 2.37) #0 SMP Wed Feb 28 14:06:42 2024
[ 0.000000] Machine model: Bananapi BPI-R3
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
[ 0.000000] node 0: [mem 0x0000000043030000-0x000000004fbfffff]
[ 0.000000] node 0: [mem 0x000000004fc00000-0x000000004ffbffff]
[ 0.000000] node 0: [mem 0x000000004ffc0000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 17 pages/cpu s30040 r8192 d31400 u69632
[ 0.000000] pcpu-alloc: s30040 r8192 d31400 u69632 alloc=17*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: root=/dev/mmcblk0p65
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Memory: 2040072K/2097152K available (8512K kernel code, 934K rwdata, 2280K rodata, 448K init, 293K bss, 57080K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 640 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000129] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000137] pid_max: default: 32768 minimum: 301
[ 0.000222] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000234] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001140] rcu: Hierarchical SRCU implementation.
[ 0.001229] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.001425] smp: Bringing up secondary CPUs ...
[ 0.001660] Detected VIPT I-cache on CPU1
[ 0.001684] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.001710] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.001974] Detected VIPT I-cache on CPU2
[ 0.001987] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.001999] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.002230] Detected VIPT I-cache on CPU3
[ 0.002240] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.002249] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.002275] smp: Brought up 1 node, 4 CPUs
[ 0.002289] SMP: Total of 4 processors activated.
[ 0.002292] CPU features: detected: 32-bit EL0 Support
[ 0.002296] CPU features: detected: CRC32 instructions
[ 0.002372] CPU: All CPU(s) started at EL2
[ 0.002382] alternatives: patching kernel code
[ 0.004670] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.004692] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.004804] pinctrl core: initialized pinctrl subsystem
[ 0.005374] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.005592] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.005622] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.005649] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.005880] thermal_sys: Registered thermal governor 'fair_share'
[ 0.005883] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.005886] thermal_sys: Registered thermal governor 'step_wise'
[ 0.005889] thermal_sys: Registered thermal governor 'user_space'
[ 0.006065] ASID allocator initialised with 65536 entries
[ 0.006329] pstore: Registered ramoops as persistent store backend
[ 0.006334] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.015254] cryptd: max_cpu_qlen set to 1000
[ 0.016732] 1.8vd: supplied by 12vd
[ 0.016888] 3.3vd: supplied by 12vd
[ 0.017112] SCSI subsystem initialized
[ 0.017195] libata version 3.00 loaded.
[ 0.017954] clocksource: Switched to clocksource arch_sys_counter
[ 0.018367] NET: Registered PF_INET protocol family
[ 0.018482] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.019052] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.019071] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.019080] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.019146] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.019308] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.019428] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[ 0.019484] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.019512] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.019611] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.019630] PCI: CLS 0 bytes, default 64
[ 0.021294] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.023299] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.023313] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.044677] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.045687] pwm-mediatek 10048000.pwm: clock: top fail: -517
[ 0.045934] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.045952] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.045960] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 0.046037] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
[ 0.046047] mtk-pcie-gen3 11280000.pcie: failed to get clocks
[ 0.048624] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.049197] printk: console [ttyS0] disabled
[ 0.069341] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
[ 0.762481] printk: console [ttyS0] enabled
[ 0.787211] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
[ 0.816928] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 124, base_baud = 1625000) is a ST16650V2
[ 0.826746] mtk_rng 1020f000.rng: registered RNG driver
[ 0.826805] hwrng: no data available
[ 0.835569] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.843483] loop: module loaded
[ 0.846630] Loading iSCSI transport class v2.0-870.
[ 0.852662] spi spi0.0: setup: ignoring unsupported mode bits a00
[ 0.858998] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.864296] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.872540] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.878938] Creating 4 MTD partitions on "spi0.0":
[ 0.883712] 0x000000580000-0x000008000000 : "ubi"
[ 1.015260] 0x000000380000-0x000000580000 : "fip"
[ 1.022323] 0x000000080000-0x000000380000 : "reserved"
[ 1.030733] 0x000000000000-0x000000080000 : "bl2"
[ 1.171012] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009780000, irq 136
[ 1.180745] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009780000, irq 136
[ 1.190286] i2c_dev: i2c /dev entries driver
[ 1.196002] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.204411] NET: Registered PF_INET6 protocol family
[ 1.210070] Segment Routing with IPv6
[ 1.213743] In-situ OAM (IOAM) with IPv6
[ 1.217680] NET: Registered PF_PACKET protocol family
[ 1.222754] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.235811] 8021q: 802.1Q VLAN Support v1.8
[ 1.240791] pstore: Using crash dump compression: deflate
[ 1.251326] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 1.258671] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 1.264924] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 1.355471] mmc0: new MMC card at address 0001
[ 1.360680] mmcblk0: mmc0:0001 008GB0 7.28 GiB
[ 1.372138] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
[ 1.381183] FIT: kernel sub-image 0x00001000 - 0x00536afc "kernel-1" (ARM64 OpenWrt Linux-5.15.149)
[ 1.391173] FIT: flat_dt sub-image 0x00537000 - 0x0053eb67 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 1.402461] FIT: flat_dt sub-image 0x0053f000 - 0x0053f1dd "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
[ 1.417615] mtk-pcie-gen3 11280000.pcie: set MEM trans window[0]: cpu_addr = 0x20000000, pci_addr = 0x20000000, size = 0x10000000
[ 1.418862] FIT: flat_dt sub-image 0x00540000 - 0x00540393 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
[ 1.430596] mtk-pcie-gen3 11280000.pcie: PCI host bridge to bus 0000:00
[ 1.446869] FIT: flat_dt sub-image 0x00541000 - 0x00541390 "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 1.453454] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.469676] FIT: flat_dt sub-image 0x00542000 - 0x00542147 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
[ 1.475127] pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
[ 1.491172] FIT: filesystem sub-image 0x00543000 - 0x08f06000 "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 1.498017] pci_bus 0000:00: scanning bus
[ 1.508684] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 1.512699] pci 0000:00:00.0: [14c3:1f32] type 01 class 0x060400
[ 1.519962] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p65(rootfs-1) p66(rootfs_data) p8
[ 1.525955] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[ 1.534172] mmcblk0boot0: mmc0:0001 008GB0 4.00 MiB
[ 1.539802] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 1.545485] mmcblk0boot1: mmc0:0001 008GB0 4.00 MiB
[ 1.550774] pci 0000:00:00.0: PME# disabled
[ 1.555915] mmcblk0rpmb: mmc0:0001 008GB0 4.00 MiB, chardev (250:0)
[ 1.560674] pci_bus 0000:00: fixups for bus
[ 1.570313] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[ 1.576994] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.584987] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[ 1.591732] pci_bus 0000:01: scanning bus
[ 1.595764] pci 0000:01:00.0: [14c3:4d75] type 00 class 0x0d4000
[ 1.601784] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit pref]
[ 1.609005] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x007fffff 64bit]
[ 1.615787] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x007fffff 64bit pref]
[ 1.623114] pci 0000:01:00.0: supports D1 D2
[ 1.627367] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.633966] pci 0000:01:00.0: PME# disabled
[ 1.638190] pci 0000:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[ 1.678577] pci_bus 0000:01: fixups for bus
[ 1.682748] pci_bus 0000:01: bus scan returning with max=01
[ 1.688309] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.694907] pci_bus 0000:00: bus scan returning with max=01
[ 1.700477] pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x207fffff]
[ 1.707246] pci 0000:00:00.0: BAR 9: assigned [mem 0x20800000-0x213fffff 64bit pref]
[ 1.714971] pci 0000:00:00.0: BAR 0: assigned [mem 0x21400000-0x21407fff 64bit]
[ 1.722269] pci 0000:01:00.0: BAR 2: assigned [mem 0x20000000-0x207fffff 64bit]
[ 1.729571] pci 0000:01:00.0: BAR 4: assigned [mem 0x20800000-0x20ffffff 64bit pref]
[ 1.737303] pci 0000:01:00.0: BAR 0: assigned [mem 0x21000000-0x21007fff 64bit pref]
[ 1.745040] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.749991] pci 0000:00:00.0: bridge window [mem 0x20000000-0x207fffff]
[ 1.756759] pci 0000:00:00.0: bridge window [mem 0x20800000-0x213fffff 64bit pref]
[ 1.764590] pcieport 0000:00:00.0: assign IRQ: got 144
[ 1.769722] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.775806] pcieport 0000:00:00.0: enabling bus mastering
[ 1.781519] mtk-pcie-gen3 11280000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11280c00 data 0
[ 1.789945] mtk-pcie-gen3 11280000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11280c00 data 1
[ 1.798365] mtk-pcie-gen3 11280000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11280c00 data 2
[ 1.806779] mtk-pcie-gen3 11280000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11280c00 data 3
[ 1.815196] mtk-pcie-gen3 11280000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11280c00 data 4
[ 1.823612] mtk-pcie-gen3 11280000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11280c00 data 5
[ 1.832029] mtk-pcie-gen3 11280000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11280c00 data 6
[ 1.840446] mtk-pcie-gen3 11280000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11280c00 data 7
[ 1.848862] mtk-pcie-gen3 11280000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11280c00 data 8
[ 1.857275] mtk-pcie-gen3 11280000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11280c00 data 9
[ 1.865691] mtk-pcie-gen3 11280000.pcie: msi#0xa address_hi 0x0 address_lo 0x11280c00 data 10
[ 1.874194] mtk-pcie-gen3 11280000.pcie: msi#0xb address_hi 0x0 address_lo 0x11280c00 data 11
[ 1.882697] mtk-pcie-gen3 11280000.pcie: msi#0xc address_hi 0x0 address_lo 0x11280c00 data 12
[ 1.891200] mtk-pcie-gen3 11280000.pcie: msi#0xd address_hi 0x0 address_lo 0x11280c00 data 13
[ 1.899703] mtk-pcie-gen3 11280000.pcie: msi#0xe address_hi 0x0 address_lo 0x11280c00 data 14
[ 1.908206] mtk-pcie-gen3 11280000.pcie: msi#0xf address_hi 0x0 address_lo 0x11280c00 data 15
[ 1.916706] mtk-pcie-gen3 11280000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11280c00 data 16
[ 1.925298] mtk-pcie-gen3 11280000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11280c00 data 17
[ 1.933889] mtk-pcie-gen3 11280000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11280c00 data 18
[ 1.942479] mtk-pcie-gen3 11280000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11280c00 data 19
[ 1.951068] mtk-pcie-gen3 11280000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11280c00 data 20
[ 1.959657] mtk-pcie-gen3 11280000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11280c00 data 21
[ 1.968247] mtk-pcie-gen3 11280000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11280c00 data 22
[ 1.976833] mtk-pcie-gen3 11280000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11280c00 data 23
[ 1.985423] mtk-pcie-gen3 11280000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11280c00 data 24
[ 1.994013] mtk-pcie-gen3 11280000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11280c00 data 25
[ 2.002603] mtk-pcie-gen3 11280000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11280c00 data 26
[ 2.011198] mtk-pcie-gen3 11280000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11280c00 data 27
[ 2.019789] mtk-pcie-gen3 11280000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11280c00 data 28
[ 2.028379] mtk-pcie-gen3 11280000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11280c00 data 29
[ 2.036966] mtk-pcie-gen3 11280000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11280c00 data 30
[ 2.045559] mtk-pcie-gen3 11280000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11280c00 data 31
[ 2.054459] mtk-pcie-gen3 11280000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11280c00 data 0
[ 2.062973] pcieport 0000:00:00.0: PME: Signaling with IRQ 145
[ 2.068965] pcieport 0000:00:00.0: AER: enabled with IRQ 145
[ 2.074663] pcieport 0000:00:00.0: saving config space at offset 0x0 (reading 0x1f3214c3)
[ 2.082828] pcieport 0000:00:00.0: saving config space at offset 0x4 (reading 0x100406)
[ 2.090813] pcieport 0000:00:00.0: saving config space at offset 0x8 (reading 0x6040001)
[ 2.098883] pcieport 0000:00:00.0: saving config space at offset 0xc (reading 0x10000)
[ 2.106776] pcieport 0000:00:00.0: saving config space at offset 0x10 (reading 0x21400004)
[ 2.115019] pcieport 0000:00:00.0: saving config space at offset 0x14 (reading 0x0)
[ 2.122655] pcieport 0000:00:00.0: saving config space at offset 0x18 (reading 0x10100)
[ 2.130640] pcieport 0000:00:00.0: saving config space at offset 0x1c (reading 0x1f1)
[ 2.138450] pcieport 0000:00:00.0: saving config space at offset 0x20 (reading 0x20702000)
[ 2.146690] pcieport 0000:00:00.0: saving config space at offset 0x24 (reading 0x21312081)
[ 2.154933] pcieport 0000:00:00.0: saving config space at offset 0x28 (reading 0x0)
[ 2.162571] pcieport 0000:00:00.0: saving config space at offset 0x2c (reading 0x0)
[ 2.170208] pcieport 0000:00:00.0: saving config space at offset 0x30 (reading 0x0)
[ 2.177841] pcieport 0000:00:00.0: saving config space at offset 0x34 (reading 0x80)
[ 2.185563] pcieport 0000:00:00.0: saving config space at offset 0x38 (reading 0x0)
[ 2.193199] pcieport 0000:00:00.0: saving config space at offset 0x3c (reading 0x20190)
[ 2.223180] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 2.232312] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 2.240996] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=146)
[ 2.261202] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=147)
[ 2.281210] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=148)
[ 2.301193] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=149)
[ 2.321163] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=150)
[ 2.332213] DSA: tree 0 setup
[ 2.337365] UBI: auto-attach mtd0
[ 2.340693] ubi0: default fastmap pool size: 45
[ 2.345206] ubi0: default fastmap WL pool size: 22
[ 2.349983] ubi0: attaching mtd0
[ 5.963922] ubi0: scanning is finished
[ 6.008207] ubi0 error: ubi_read_volume_table: not enough PEBs, required 984, available 980
[ 6.016610] ubi0 error: ubi_attach_mtd_dev: failed to attach mtd0, error -28
[ 6.023673] UBI error: cannot attach mtd0
[ 6.033086] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
[ 6.040390] Freeing unused kernel memory: 448K
[ 6.067996] Run /sbin/init as init process
[ 6.072075] with arguments:
[ 6.075026] /sbin/init
[ 6.077717] with environment:
[ 6.080854] HOME=/
[ 6.083199] TERM=linux
[ 6.464851] init: Console is alive
[ 6.468373] init: - watchdog -
[ 8.801485] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 8.916317] Key type encrypted registered
[ 8.921828] pps_core: LinuxPPS API ver. 1 registered
[ 8.926792] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 8.938273] PTP clock support registered
[ 8.945445] usbcore: registered new interface driver usbfs
[ 8.951023] usbcore: registered new interface driver hub
[ 8.956353] usbcore: registered new device driver usb
[ 8.965474] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: [email protected]
[ 8.977527] raid6: skip pq benchmark and using algorithm neonx8
[ 8.983466] raid6: using neon recovery algorithm
[ 8.988903] xor: measuring software checksum speed
[ 8.996178] 8regs : 3951 MB/sec
[ 9.002637] 32regs : 4678 MB/sec
[ 9.009443] arm64_neon : 3995 MB/sec
[ 9.013782] xor: using function: 32regs (4678 MB/sec)
[ 9.026663] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 9.044015] SGI XFS with security attributes, no debug enabled
[ 9.051548] mt7986a-pinctrl 1001f000.pinctrl: pin GPIO_4 already requested by 11280000.pcie; cannot claim for pinctrl_moore:420
[ 9.063047] mt7986a-pinctrl 1001f000.pinctrl: pin-9 (pinctrl_moore:420) status -22
[ 9.070608] gpio-keys: probe of gpio-keys failed with error -22
[ 9.078769] igb: Intel(R) Gigabit Ethernet Network Driver
[ 9.084167] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 9.090996] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 9.099322] fsl-ehci: Freescale EHCI Host controller driver
[ 9.105564] ehci-platform: EHCI generic platform driver
[ 9.120297] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 9.127101] ohci-platform: OHCI generic platform driver
[ 9.133360] uhci_hcd: USB Universal Host Controller Interface driver
[ 9.142737] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 9.150152] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 9.158271] xhci-mtk 11200000.usb: xHCI Host Controller
[ 9.163490] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 9.173957] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 9.183107] xhci-mtk 11200000.usb: irq 128, io mem 0x11200000
[ 9.188934] xhci-mtk 11200000.usb: xHCI Host Controller
[ 9.194145] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 9.201529] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 9.209065] hub 1-0:1.0: USB hub found
[ 9.212824] hub 1-0:1.0: 2 ports detected
[ 9.217055] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 9.225369] hub 2-0:1.0: USB hub found
[ 9.229138] hub 2-0:1.0: 1 port detected
[ 9.237077] Error: Driver 'gpio-keys' is already registered, aborting...
[ 9.358393] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 9.449194] usbcore: registered new interface driver usb-storage
[ 9.456121] usbcore: registered new interface driver uas
[ 9.461961] Error: Driver 'gpio-keys' is already registered, aborting...
[ 9.608326] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 9.688150] kmodloader: 2 modules could not be probed
[ 9.693247] kmodloader: - gpio_keys - 0
[ 9.697089] kmodloader: - gpio_keys_polled - 0
[ 9.697958] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 9.705636] init: - preinit -
[ 9.888811] hub 1-1:1.0: USB hub found
[ 9.890431] random: procd: uninitialized urandom read (4 bytes read)
[ 9.892614] hub 1-1:1.0: 4 ports detected
[ 10.834273] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 10.842755] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 10.851388] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.008400] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 11.368205] random: crng init done
[ 11.852970] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.860898] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
[ 15.242257] mount_root: loading kmods from internal overlay
[ 15.270332] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 15.281869] Error: Driver 'gpio-keys' is already registered, aborting...
[ 15.378316] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 15.458130] kmodloader: 2 modules could not be probed
[ 15.463217] kmodloader: - gpio_keys - 0
[ 15.467059] kmodloader: - gpio_keys_polled - 0
[ 16.830788] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = 470a933d
[ 16.838014] block: attempting to load /tmp/f2fs_cfg/upper/etc/config/fstab
[ 16.856161] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 16.866437] mount_root: switched to extroot
[ 16.878869] urandom-seed: Seeding with /etc/urandom.seed
[ 16.997882] mt7530-mdio mdio-bus:1f lan1: Link is Down
[ 17.005916] procd: - early -
[ 17.008862] procd: - watchdog -
[ 17.644361] procd: - watchdog -
[ 17.666193] procd: - ubus -
[ 17.826291] procd: - init -
[ 18.938554] urngd: v1.0.2 started.
[ 19.018971] kmodloader: loading kernel modules from /etc/modules.d/*
[ 19.077902] NET: Registered PF_ALG protocol family
[ 19.086506] io scheduler bfq registered
[ 19.095793] zram: Added device: zram0
[ 19.107544] async_tx: api initialized (async)
[ 19.119905] aoe: AoE v85 initialised.
[ 19.125123] NET: Registered PF_ATMPVC protocol family
[ 19.130192] NET: Registered PF_ATMSVC protocol family
[ 19.137140] Key type dns_resolver registered
[ 19.148286] Key type cifs.idmap registered
[ 19.160154] RPC: Registered named UNIX socket transport module.
[ 19.166071] RPC: Registered udp transport module.
[ 19.170791] RPC: Registered tcp transport module.
[ 19.175486] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 19.185024] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 19.192006] NET: Registered PF_KEY protocol family
[ 19.198679] Initializing XFRM netlink socket
[ 19.229920] tun: Universal TUN/TAP device driver, 1.6
[ 19.237435] device-mapper: raid: Loading target version 1.15.1
[ 19.253914] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 19.267251] l2tp_core: L2TP core driver, V2.0
[ 19.272573] l2tp_netlink: L2TP netlink interface
[ 19.281414] sctp: Hash tables configured (bind 256/256)
[ 19.288053] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 19.297514] nat46: module (version 95ca1c3b99376da2d0306919f2df4a8d3c9bb78b) loaded.
[ 19.312781] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver
[ 19.318916] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 19.334692] gre: GRE over IPv4 demultiplexor driver
[ 19.340753] ip_gre: GRE over IPv4 tunneling driver
[ 19.360530] Installing knfsd (copyright (C) 1996 [email protected]).
[ 19.370167] PPP generic driver version 2.4.2
[ 19.381106] NFS: Registering the id_resolver key type
[ 19.386176] Key type id_resolver registered
[ 19.390358] Key type id_legacy registered
[ 19.413089] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[ 19.437772] cryptodev: driver 1.13 loaded.
[ 19.455676] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
[ 19.462320] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
[ 19.476330] hid: raw HID events driver (C) Jiri Kosina
[ 19.484488] GACT probability on
[ 19.488456] Mirror/redirect action on
[ 19.496990] u32 classifier
[ 19.499713] input device check on
[ 19.503357] Actions configured
[ 19.514082] ntfs3: Max link count 4000
[ 19.517835] ntfs3: Enabled Linux POSIX ACLs support
[ 19.525810] fuse: init (API version 7.34)
[ 19.535090] GobiNet: Quectel_Linux&Android_GobiNet_Driver_V1.6.3
[ 19.541183] usbcore: registered new interface driver GobiNet
[ 19.548811] usbcore: registered new interface driver cdc_wdm
[ 19.555899] usbcore: registered new interface driver qmi_wwan_q
[ 19.564824] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 19.571902] usbcore: registered new interface driver qmi_wwan_f
[ 19.579941] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
[ 19.595266] mhi_init Quectel_Linux_PCIE_MHI_Driver_V1.3.4
[ 19.603001] {natflow}:natflow_init(): natflow_major=240, natflow_minor=0
[ 19.609825] {natflow}:natflow_zone_init(): natflow_zone_major=239, natflow_zone_minor=0
[ 19.617971] {natflow}:natflow_user_init(): natflow_user_major=238, natflow_user_minor=0
[ 19.626066] {natflow}:userinfo_init(): userinfo_major=237, userinfo_minor=0
[ 19.633182] {natflow}:userinfo_event_init(): userinfo_event_major=236, userinfo_event_minor=0
[ 19.641815] {natflow}:qos_init(): qos_major=235, qos_minor=0
[ 19.647550] {natflow}:conntrackinfo_init(): conntrackinfo_major=234, conntrackinfo_minor=0
[ 19.655967] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=eth0(tso=1,1,hw_csum=1,1), add ingress hook
[ 19.666777] {natflow}:natflow_urllogger_init(): urllogger_major=511, urllogger_minor=0
[ 19.686711] Bluetooth: Core ver 2.22
[ 19.690400] NET: Registered PF_BLUETOOTH protocol family
[ 19.695696] Bluetooth: HCI device and connection manager initialized
[ 19.702053] Bluetooth: HCI socket layer initialized
[ 19.706922] Bluetooth: L2CAP socket layer initialized
[ 19.711988] Bluetooth: SCO socket layer initialized
[ 19.717776] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.723101] Bluetooth: BNEP filters: protocol multicast
[ 19.728319] Bluetooth: BNEP socket layer initialized
[ 19.743499] Bridge firewalling registered
[ 19.755491] usbcore: registered new interface driver btusb
[ 19.763034] usbcore: registered new interface driver cdc_acm
[ 19.768719] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 19.778243] usbcore: registered new interface driver cdc_ether
[ 19.785875] usbcore: registered new interface driver cdc_ncm
[ 19.792233] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
[ 19.799728] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
[ 19.811114] Error: Driver 'gpio-keys' is already registered, aborting...
[ 19.928949] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 20.039582] Bluetooth: HCI UART driver ver 2.3
[ 20.044031] Bluetooth: HCI UART protocol H4 registered
[ 20.049179] Bluetooth: HCI UART protocol BCSP registered
[ 20.054639] Bluetooth: HCI UART protocol Broadcom registered
[ 20.060328] Bluetooth: HCI UART protocol QCA registered
[ 20.067645] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 20.073598] Bluetooth: HIDP socket layer initialized
[ 20.079516] usbcore: registered new interface driver huawei_cdc_ncm
[ 20.089207] i40e: Intel(R) Ethernet Connection XL710 Network Driver
[ 20.095474] i40e: Copyright (c) 2013 - 2019 Intel Corporation.
[ 20.105265] ice: Intel(R) Ethernet Connection E800 Series Linux Driver
[ 20.111819] ice: Copyright (c) 2018, Intel Corporation.
[ 20.208102] PPP MPPE Compression module registered
[ 20.214081] NET: Registered PF_PPPOX protocol family
[ 20.220056] PPTP driver version 0.8.5
[ 20.225821] usbcore: registered new interface driver qmi_wwan
[ 20.233216] NET: Registered PF_QIPCRTR protocol family
[ 20.242714] usbcore: registered new device driver r8152-cfgselector
[ 20.249058] usbcore: registered new interface driver r8152
[ 20.261861] Bluetooth: RFCOMM TTY layer initialized
[ 20.266752] Bluetooth: RFCOMM socket layer initialized
[ 20.271923] Bluetooth: RFCOMM ver 1.11
[ 20.277689] usbcore: registered new interface driver rndis_host
[ 20.286817] usbcore: registered new interface driver rtl8150
[ 20.296304] Solarflare NET driver
[ 20.302123] Solarflare Falcon driver v4.1
[ 20.307719] sfp sfp-1: Host maximum power 3.0W
[ 20.312947] sfp sfp-2: Host maximum power 3.0W
[ 20.319575] usbcore: registered new interface driver sierra_net
[ 20.336669] usbcore: registered new interface driver ums-alauda
[ 20.344423] usbcore: registered new interface driver ums-cypress
[ 20.352237] usbcore: registered new interface driver ums-datafab
[ 20.360060] usbcore: registered new interface driver ums-freecom
[ 20.368001] usbcore: registered new interface driver ums-isd200
[ 20.375897] usbcore: registered new interface driver ums-jumpshot
[ 20.383801] usbcore: registered new interface driver ums-karma
[ 20.391756] usbcore: registered new interface driver ums-sddr09
[ 20.399584] usbcore: registered new interface driver ums-sddr55
[ 20.407408] usbcore: registered new interface driver ums-usbat
[ 20.417861] usbcore: registered new device driver usbip-host
[ 20.426159] usbcore: registered new interface driver usblp
[ 20.436273] usbcore: registered new interface driver usbserial_generic
[ 20.442849] usbserial: USB Serial support registered for generic
[ 20.451616] vhci_hcd vhci_hcd.0: USB/IP Virtual Host Controller
[ 20.457535] vhci_hcd vhci_hcd.0: new USB bus registered, assigned bus number 3
[ 20.464776] vhci_hcd: created sysfs vhci_hcd.0
[ 20.469642] hub 3-0:1.0: USB hub found
[ 20.473432] hub 3-0:1.0: 8 ports detected
[ 20.477935] vhci_hcd vhci_hcd.0: USB/IP Virtual Host Controller
[ 20.483876] vhci_hcd vhci_hcd.0: new USB bus registered, assigned bus number 4
[ 20.491253] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 20.499753] hub 4-0:1.0: USB hub found
[ 20.503519] hub 4-0:1.0: 8 ports detected
[ 20.540231] xt_time: kernel timezone is -0000
[ 20.546591] usbcore: registered new interface driver cdc_mbim
[ 20.583422] usbcore: registered new interface driver ch341
[ 20.588995] usbserial: USB Serial support registered for ch341-uart
[ 20.598347] usbcore: registered new interface driver cp210x
[ 20.603948] usbserial: USB Serial support registered for cp210x
[ 20.611432] usbcore: registered new interface driver cypress_m8
[ 20.617374] usbserial: USB Serial support registered for DeLorme Earthmate USB
[ 20.624610] usbserial: USB Serial support registered for HID->COM RS232 Adapter
[ 20.631923] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
[ 20.642266] iscsi: registered transport (tcp)
[ 20.647546] sfp sfp-1: module ALCATELLUCENT G010SP rev 10 sn ALCLFAB7BD2D dc 171023
[ 20.657422] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 20.689771] usbcore: registered new interface driver mct_u232
[ 20.695587] usbserial: USB Serial support registered for MCT U232
[ 20.704720] usbcore: registered new interface driver mos7720
[ 20.710473] usbserial: USB Serial support registered for Moschip 2 port adapter
[ 20.719739] usbcore: registered new interface driver mos7840
[ 20.725451] usbserial: USB Serial support registered for Moschip 7840/7820 USB Serial Driver
[ 20.760796] mt798x-wmac 18000000.wifi: attaching wed device 0 version 2
[ 20.811622] platform 15010000.wed: MTK WED WO Firmware Version: DEV_000000, Build Time: 20221012175005
[ 20.820959] platform 15010000.wed: MTK WED WO Chip ID 00 Region 3
[ 21.619765] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[ 21.619765]
[ 21.788239] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805
[ 21.873228] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[ 24.344696] EXT4-fs (mmcblk0p8): recovery complete
[ 24.349501] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: . Quota mode: disabled.
[ 24.635409] usbcore: registered new interface driver oti6858
[ 24.641112] usbserial: USB Serial support registered for oti6858
[ 24.649044] usbcore: registered new interface driver pl2303
[ 24.654646] usbserial: USB Serial support registered for pl2303
[ 24.674461] usbcore: registered new interface driver sierra
[ 24.680130] usbserial: USB Serial support registered for Sierra USB modem
[ 24.693986] usbcore: registered new interface driver snd-usb-audio
[ 24.703023] usbcore: registered new interface driver ti_usb_3410_5052
[ 24.709633] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[ 24.717388] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
[ 24.731451] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 24.739325] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[ 24.751596] usbcore: registered new interface driver ar5523
[ 24.787370] usbcore: registered new interface driver ath6kl_usb
[ 24.818300] usbcore: registered new interface driver option
[ 24.823914] usbserial: USB Serial support registered for GSM modem (1-port)
[ 24.832385] usbcore: registered new interface driver qcserial
[ 24.838195] usbserial: USB Serial support registered for Qualcomm USB modem
[ 24.867564] usbcore: registered new interface driver ath9k_htc
[ 24.877845] Error: Driver 'gpio-keys' is already registered, aborting...
[ 24.979775] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 25.078192] kmodloader: 2 modules could not be probed
[ 25.083296] kmodloader: - gpio_keys - 0
[ 25.087133] kmodloader: - gpio_keys_polled - 0
[ 33.496380] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 33.506847] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 33.515271] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 33.515335] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=eth0(tso=1,1,hw_csum=1,1), add ingress hook
[ 33.535358] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 33.542362] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 33.550120] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=lan1(tso=1,1,hw_csum=1,1), add ingress hook
[ 33.561319] br-lan: port 1(lan1) entered blocking state
[ 33.566541] br-lan: port 1(lan1) entered disabled state
[ 33.573349] device lan1 entered promiscuous mode
[ 33.577992] device eth0 entered promiscuous mode
[ 33.590455] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 33.598084] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=lan2(tso=1,1,hw_csum=1,1), add ingress hook
[ 33.602267] mt7530-mdio mdio-bus:1f lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[ 33.609431] br-lan: port 2(lan2) entered blocking state
[ 33.622177] br-lan: port 2(lan2) entered disabled state
[ 33.629079] device lan2 entered promiscuous mode
[ 33.637254] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[ 33.644882] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=lan3(tso=1,1,hw_csum=1,1), add ingress hook
[ 33.655976] br-lan: port 3(lan3) entered blocking state
[ 33.661211] br-lan: port 3(lan3) entered disabled state
[ 33.668296] device lan3 entered promiscuous mode
[ 33.674814] br-lan: port 2(lan2) entered blocking state
[ 33.680058] br-lan: port 2(lan2) entered listening state
[ 33.688103] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
[ 33.695665] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=lan4(tso=1,1,hw_csum=1,1), add ingress hook
[ 33.706754] br-lan: port 4(lan4) entered blocking state
[ 33.711999] br-lan: port 4(lan4) entered disabled state
[ 33.719253] device lan4 entered promiscuous mode
[ 33.727756] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
[ 33.737215] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=sfp2(tso=1,1,hw_csum=1,1), add ingress hook
[ 33.748320] br-lan: port 5(sfp2) entered blocking state
[ 33.753550] br-lan: port 5(sfp2) entered disabled state
[ 33.761015] device sfp2 entered promiscuous mode
[ 33.768838] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[ 33.778515] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=eth1(tso=1,1,hw_csum=1,1), add ingress hook
[ 33.790390] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=eth1.41(tso=1,1,hw_csum=1,1), add ingress hook
[ 33.802537] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=eth1.46(tso=1,1,hw_csum=1,1), add ingress hook
[ 34.010331] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=SQM_IFB_2d177
[ 34.139047] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=SQM_IFB_49d8f
[ 34.238199] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=wlan0
[ 34.341461] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=wlan1
[ 34.436602] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=SQM_IFB_e7983
[ 34.587909] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=SQM_IFB_905b9
[ 35.297394] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=wlan1(tso=0,0,hw_csum=0,0), add ingress hook
[ 35.309034] br-lan: port 6(wlan1) entered blocking state
[ 35.314377] br-lan: port 6(wlan1) entered disabled state
[ 35.319908] device wlan1 entered promiscuous mode
[ 35.324686] br-lan: port 6(wlan1) entered blocking state
[ 35.329993] br-lan: port 6(wlan1) entered listening state
[ 35.339769] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=SQM_IFB_9f964
[ 35.431731] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=SQM_IFB_b987e
[ 35.581852] br-lan: port 6(wlan1) entered disabled state
[ 35.687973] br-lan: port 2(lan2) entered learning state
[ 35.796875] hwmon hwmon4: temp1_input not attached to any thermal zone
[ 36.222427] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 36.296215] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=wlan0(tso=0,0,hw_csum=0,0), add ingress hook
[ 36.307367] br-lan: port 1(lan1) entered blocking state
[ 36.312650] br-lan: port 1(lan1) entered listening state
[ 36.318307] br-lan: port 7(wlan0) entered blocking state
[ 36.323619] br-lan: port 7(wlan0) entered disabled state
[ 36.329108] device wlan0 entered promiscuous mode
[ 36.333892] br-lan: port 7(wlan0) entered blocking state
[ 36.339197] br-lan: port 7(wlan0) entered listening state
[ 36.588056] br-lan: port 7(wlan0) entered disabled state
[ 36.816160] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 36.822732] br-lan: port 6(wlan1) entered blocking state
[ 36.828093] br-lan: port 6(wlan1) entered listening state
[ 37.767971] br-lan: port 2(lan2) entered forwarding state
[ 37.773386] br-lan: topology change detected, propagating
[ 37.779515] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 38.337955] br-lan: port 1(lan1) entered learning state
[ 38.887981] br-lan: port 6(wlan1) entered learning state
[ 40.407980] br-lan: port 1(lan1) entered forwarding state
[ 40.413422] br-lan: topology change detected, propagating
[ 40.967984] br-lan: port 6(wlan1) entered forwarding state
[ 40.973501] br-lan: topology change detected, propagating
[ 42.867277] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=ipsec0(tso=0,0,hw_csum=0,0), add ingress hook
[ 43.075437] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=tun0(tso=0,0,hw_csum=0,0), add ingress hook
[ 44.826006] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
[ 44.834473] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 44.841065] IPv6: ADDRCONF(NETDEV_CHANGE): eth1.41: link becomes ready
[ 44.847731] IPv6: ADDRCONF(NETDEV_CHANGE): eth1.46: link becomes ready
[ 46.762087] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 46.768588] br-lan: port 7(wlan0) entered blocking state
[ 46.773896] br-lan: port 7(wlan0) entered listening state
[ 48.808798] br-lan: port 7(wlan0) entered learning state
[ 50.887970] br-lan: port 7(wlan0) entered forwarding state
[ 50.893465] br-lan: topology change detected, propagating
[ 60.365035] {natflow}:natflow_netdev_event(): catch NETDEV_UNREGISTER event for dev=eth1.41
[ 60.539446] warning: (zone_netdev_event:379)dev=eth1.41 set zone=1 type=0
[ 60.546238] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=eth1.41(tso=1,1,hw_csum=1,1), add ingress hook
[ 60.918687] pppoe-WAN1: renamed from ppp0
[ 63.969194] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=pppoe-WAN1 : set flags IFF_PPPOE
[ 63.979071] {natflow}:natflow_netdev_event(): catch NETDEV_UP event for dev=pppoe-WAN1(tso=0,0,hw_csum=0,0), add ingress hook
[ 697.313223] pci 0000:01:00.0: saving config space at offset 0x0 (reading 0x4d7514c3)
[ 697.320967] pci 0000:01:00.0: saving config space at offset 0x4 (reading 0x100000)
[ 697.328578] pci 0000:01:00.0: saving config space at offset 0x8 (reading 0xd400001)
[ 697.336236] pci 0000:01:00.0: saving config space at offset 0xc (reading 0x0)
[ 697.343373] pci 0000:01:00.0: saving config space at offset 0x10 (reading 0x2100000c)
[ 697.351196] pci 0000:01:00.0: saving config space at offset 0x14 (reading 0x0)
[ 697.358401] pci 0000:01:00.0: saving config space at offset 0x18 (reading 0x20000004)
[ 697.366215] pci 0000:01:00.0: saving config space at offset 0x1c (reading 0x0)
[ 697.373426] pci 0000:01:00.0: saving config space at offset 0x20 (reading 0x2080000c)
[ 697.381250] pci 0000:01:00.0: saving config space at offset 0x24 (reading 0x0)
[ 697.388459] pci 0000:01:00.0: saving config space at offset 0x28 (reading 0x0)
[ 697.395685] pci 0000:01:00.0: saving config space at offset 0x2c (reading 0x35001cf8)
[ 697.403506] pci 0000:01:00.0: saving config space at offset 0x30 (reading 0x0)
[ 697.410710] pci 0000:01:00.0: saving config space at offset 0x34 (reading 0x80)
[ 697.418005] pci 0000:01:00.0: saving config space at offset 0x38 (reading 0x0)
[ 697.425216] pci 0000:01:00.0: saving config space at offset 0x3c (reading 0x100)
[ 697.470956] pcieport 0000:00:00.0: waiting 100 ms for downstream link
[ 698.538925] pci 0000:01:00.0: restoring config space at offset 0x3c (was 0x0, writing 0x100)
[ 698.696754] pci 0000:01:00.0: restoring config space at offset 0x34 (was 0x0, writing 0x80)
[ 698.854615] pci 0000:01:00.0: restoring config space at offset 0x2c (was 0x0, writing 0x35001cf8)
[ 699.062364] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 699.171256] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 699.280135] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 699.389020] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 699.497906] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 699.606793] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 699.715672] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 699.824557] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 699.933442] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 700.042329] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 700.151213] pci 0000:01:00.0: restoring config space at offset 0x20 (was 0x0, writing 0x2080000c)
[ 700.309040] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 700.417929] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 700.526810] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 700.635694] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 700.744581] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 700.853464] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 700.962348] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 701.071234] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 701.180118] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 701.289001] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 701.397885] pci 0000:01:00.0: restoring config space at offset 0x18 (was 0x0, writing 0x20000004)
[ 701.555716] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 701.664605] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 701.773494] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 701.882370] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 701.991255] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 702.100139] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 702.209023] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 702.317908] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 702.426800] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 702.535674] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 702.644559] pci 0000:01:00.0: restoring config space at offset 0x10 (was 0x0, writing 0x2100000c)
[ 702.802388] pci 0000:01:00.0: restoring config space at offset 0x8 (was 0x0, writing 0xd400001)
[ 702.910280] pci 0000:01:00.0: restoring config space at offset 0x4 (was 0x0, writing 0x100000)
[ 703.018163] pci 0000:01:00.0: restoring config space at offset 0x0 (was 0x0, writing 0x4d7514c3)
[ 703.126072] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.135566] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.146687] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.155029] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.161806] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.168502] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.175699] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.181532] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.191013] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.202127] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.210462] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.217240] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.223922] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.231075] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.236903] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.247163] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.258277] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.266615] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.273394] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.280089] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.287263] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.293083] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.303343] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.314458] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.322790] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.329569] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.336267] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.343421] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.349253] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.359514] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.370628] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.378968] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.385750] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.392437] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.399602] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.405435] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.414912] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.426022] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.434355] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.441139] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.447854] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.455039] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.460878] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.471146] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.482261] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.490597] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.497376] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.504062] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.511209] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.517045] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.526526] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.537632] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.545967] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.552744] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.559438] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.566606] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.572434] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.581913] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.593028] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.601365] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.608145] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.614833] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.621987] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.627824] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.638086] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.649198] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.657535] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.664316] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.671004] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.678174] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.684014] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.693492] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.704603] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.712935] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.719720] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.726414] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.733578] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.739398] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.749658] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.760769] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.769108] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.775895] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.782579] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.789740] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.795577] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.805836] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.816944] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.825277] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.832054] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.838745] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.845903] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.851721] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.861200] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.872312] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.880656] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.887445] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.894135] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.901286] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.907118] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.917378] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.928487] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.936826] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.943606] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 703.950287] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 703.957467] pcieport 0000:00:00.0: AER: device recovery failed
[ 703.963302] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 703.973556] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 703.984665] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 703.992999] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 703.999781] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.006469] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.013620] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.019444] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.028922] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.040029] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.048368] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.055147] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.061830] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.068990] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.074831] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.085093] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.096208] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.104547] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.111320] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.118008] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.125168] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.130989] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.141243] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.152361] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.160697] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.167475] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.174166] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.181324] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.187156] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.197413] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.208523] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.216860] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.223638] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.230325] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.237491] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.243327] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.252800] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.263917] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.272250] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.279028] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.285722] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.292887] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.298706] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.308186] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.319306] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.327643] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.334425] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.341112] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.348268] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.354096] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.364348] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.375467] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.383812] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.390585] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.397277] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.404437] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.410256] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.420515] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.431626] sched: RT throttling activated
[ 704.435715] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.444051] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.450828] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.457531] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.464700] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.470528] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.480790] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.491903] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.500247] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.507028] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.513714] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.520864] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.526698] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.536957] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.548089] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.556452] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.563247] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.569946] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.577119] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.582949] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.593208] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.604330] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.612672] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.619453] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.626150] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.633318] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.639139] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.649403] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.660525] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.668867] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.675655] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.682348] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.689504] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.695345] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.705606] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.716714] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.725057] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.731832] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.738518] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.745673] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.751499] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.760981] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.772093] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.780432] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.787212] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.793899] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.801061] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.806899] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.816371] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.827484] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.835822] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.842599] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.849286] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.856449] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.862278] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.872539] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.883649] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.891982] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.898758] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.905451] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.912608] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.918426] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.928685] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.939812] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 704.948168] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 704.954959] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 704.961644] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 704.968812] pcieport 0000:00:00.0: AER: device recovery failed
[ 704.974650] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 704.984908] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 704.996022] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.004362] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.011134] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.017823] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.024985] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.030806] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.041061] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.052176] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.060506] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.067284] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.073977] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.081127] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.086956] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.097206] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.108312] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.116658] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.123442] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.130125] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.137282] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.143106] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.153361] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.164471] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.172806] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.179577] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.186263] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.193416] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.199240] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.209500] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.220610] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.228948] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.235731] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.242425] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.249576] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.255408] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.265667] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.276777] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.285115] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.291895] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.298580] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.305743] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.311581] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.321844] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.332964] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.341302] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.348086] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.354775] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.361935] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.367755] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.378015] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.389132] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.397472] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.404251] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.410933] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.418101] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.423941] pcieport 0000:00:00.0: AER: Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.433423] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.444549] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.452892] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.459668] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.466363] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.473526] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.479351] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.489605] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.500719] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.509058] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.515846] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.522538] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.529689] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.535531] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.545801] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.556916] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.565255] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.572036] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.578719] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.585881] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.591713] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.601974] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.613086] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.621425] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.628201] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.634892] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.642054] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.647881] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.658140] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.669252] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.677589] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.684367] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.691054] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.698218] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.704057] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.714318] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.725435] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.733778] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.740553] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.747244] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.754403] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.760221] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.770477] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.781594] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.789936] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.796740] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.803451] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.810608] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.816451] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.826714] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.837826] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.846165] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.852945] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.859627] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.866791] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.872627] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.882890] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.894007] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.902349] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.909123] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.915816] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.922980] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.928803] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.939062] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 705.950181] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 705.958524] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 705.965308] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 705.971997] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 705.979156] pcieport 0000:00:00.0: AER: device recovery failed
[ 705.984988] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 705.995249] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 706.006362] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 706.014705] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 706.021487] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 706.028176] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 706.035342] pcieport 0000:00:00.0: AER: device recovery failed
[ 706.041180] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 706.051439] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 706.062555] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 706.070893] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 706.077665] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 706.084357] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 706.091521] pcieport 0000:00:00.0: AER: device recovery failed
[ 706.097342] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 706.107601] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 706.118720] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 706.127070] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 706.133862] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 706.140554] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 706.147706] pcieport 0000:00:00.0: AER: device recovery failed
[ 706.153546] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 706.163807] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 706.174916] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 706.183258] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 706.190031] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 706.196718] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 706.203884] pcieport 0000:00:00.0: AER: device recovery failed
[ 706.209712] pcieport 0000:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error message received from 0000:00:00.0
[ 706.219974] pcieport 0000:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 706.231087] pcieport 0000:00:00.0: device [14c3:1f32] error status/mask=00004000/00400000
[ 706.239419] pcieport 0000:00:00.0: [14] CmpltTO (First)
[ 706.246201] pcieport 0000:00:00.0: AER: broadcast error_detected message
[ 706.252893] pci 0000:01:00.0: AER: can't recover (no error_detected callback)
[ 706.260055] pcieport 0000:00:00.0: AER: device recovery failed
