I have short question about BPi-R3:
Anybody tried to enable CONFIG_NVME_HWMON=y kernel conf option to get NVME temperatures directly with /sys/class/hwmon and sensors?
It is available since linux kernel version 5.5 but i don’t know how it is supported on archs and devices different than x86. ‘Big’ distros have it enabled and it makes nvme temperature monitoring much easier than using smartctl or nvme-cli.
i have not tested it yet, but i guess this is not specific to bananapi and should work…i would say just test if it works and report back…then i can add this option to my defconfig
Can confirm, works fine, for me at least, didn’t it test it for stability etc., but it just reads temperature.
Any chance that this option could land in upstream OpenWRT?
Some config and output, maybe it will be helpful:
sensors output"
for installed ssd
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM951/PM951 (rev 01)
and /sys/class/nvme
root@OpenWrt:/sys/class/nvme/nvme0# ls
address dev firmware_rev kato ng0n1 nvme0n1 queue_count reset_controller sqsize subsysnqn transport
cntlid device hwmon4 model numa_node power rescan_controller serial state subsystem uevent
root@OpenWrt:/sys/class/nvme/nvme0# ls hwmon4
device name of_node power subsystem temp1_alarm temp1_input temp1_label uevent
root@OpenWrt:/sys/class/nvme/nvme0# cat hwmon4/temp1_input
46850
build for Linux OpenWrt 5.15.118 #0 SMP Mon Jun 26 11:20:39 2023 aarch64 GNU/Linux OpenWRT v23.05.0-rc2 sources, just CONFIG_NVME_HWMON=y
# NVME Support
CONFIG_NVME_CORE=m
CONFIG_BLK_DEV_NVME=m
# CONFIG_NVME_MULTIPATH is not set
CONFIG_NVME_HWMON=y
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TCP is not set
# CONFIG_NVME_TARGET is not set
# end of NVME Support
Sorry, That will not work, I need to figure out a way to monitor SSD temp on OpenWrt and BPi-R3. I have already cut a hole in the bottom of case to let some air in.
