BPI-R3 | not wifi with snapshot image
I use the bpi-r3 board, no uart connect, and no wifi antenna, only SD card, check log after startup, wifi failed
error log:
[ 12.220291] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805 [ 12.320172] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937 [ 32.489131] mt798x-wmac 18000000.wifi: Message 00000002 (seq 9) timeout [ 32.495744] mt798x-wmac 18000000.wifi: Failed to start WA firmware [ 32.502058] mt798x-wmac: probe of 18000000.wifi failed with error -110
snapshot image url: https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/openwrt-mediatek-filogic-bananapi_bpi-r3-sdcard.img.gz
how to use Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P) ?
V1.1 board , I did’t do anything else
can you check if its also a dhcp problem with logread? noticed that on the r4 too ([BPI-R4] dhcp for wireless broken on linux 6.6)
seems like you were updating the answer while i was writing :wink: in that case i assume its a different error. will check if i have something like that in my logs too.
Seem different. I did’t find any error with DHCP.
Have cold booted without uart connected?
hi frank,
I tried to insert the sd card, without uart, and then connect the power to start. still wifi failed error.
Maybe try other power supply?
