[BPI-R3] No wifi
Hi All!
I am new to RPI-R3 and trying to get it working. Have big problem with wifi - not working at all on any version. Error I get is:
[ 9.093786] mt798x-wmac 18000000.wifi: Direct firmware load for mediatek/mt7986_rom_patch_mt7975.bin failed with error -2
[ 9.104745] mt798x-wmac 18000000.wifi: Falling back to sysfs fallback for: mediatek/mt7986_rom_patch_mt7975.bin
[ 9.130350] mt798x-wmac: probe of 18000000.wifi failed with error -12
Tried with and without UART debug connected - no difference. Any idea how to fix it?
which image, have you wifi firmware installed?
Tried many including current one from the link below, SDCARD version.
https://firmware-selector.openwrt.org/?version=SNAPSHOT&target=mediatek%2Ffilogic&id=bananapi_bpi-r3
https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/openwrt-mediatek-filogic-bananapi_bpi-r3-sdcard.img.gz
Do you think OpenWRT itself is not enough and I need a separate wifi firmware? I couldn’t find such info in sources available.
Weird. The file should be there. What’s the output of ls /lib/firmware/mediatek/
No such directory.
root@OpenWrt:/# ls /lib/firmware/mediatek/
ls: /lib/firmware/mediatek/: No such file or directory
inside-secure regulatory.db
Have you uart disconnected the full bootup? Which adapter do you have?
I have some CH340, tried to boot with it connected and without - no difference.
I have seen threads about it but behavior is a bit different.
Started original firmware from NAND and here I can see below errors, but wifi network is visible by default. Not sure why it’s AX6000 in the file name.
[ 151.602687] Use default BIN from:/lib/firmware/MT7986_iPAiLNA_EEPROM_AX6000.bin.
[ 151.610105] WiFi@C01L1,RtmpOSFileOpen() 1006: Error 2 opening /lib/firmware/MT7986_iPAiLNA_EEPROM_AX6000.bin
[ 151.619915] 7986@C02L1apclix0,rtmp_ee_flash_reset() 275: → Error opening file /lib/firmware/MT7986_iPAiLNA_EEPROM_AX6000.bin
[ 151.631288] 7986@C02L1apclix0,rtmp_ee_flash_init() 430: The EEPROM in Flash is wrong, use default
root@OpenWrt:/# cat /etc/os-release
NAME=“OpenWrt”
VERSION=“21.02-SNAPSHOT”
ID=“openwrt”
ID_LIKE=“lede openwrt”
PRETTY_NAME=“OpenWrt 21.02-SNAPSHOT”
VERSION_ID=“21.02-snapshot”
HOME_URL=“https://openwrt.org/”
BUG_URL=“https://bugs.openwrt.org/”
SUPPORT_URL=“https://forum.openwrt.org/”
BUILD_ID=“unknown”
OPENWRT_BOARD=“mediatek/mt7986”
OPENWRT_ARCH=“aarch64_cortex-a53”
OPENWRT_TAINTS=“no-all busybox”
OPENWRT_DEVICE_MANUFACTURER=“OpenWrt”
OPENWRT_DEVICE_MANUFACTURER_URL=“https://openwrt.org/”
OPENWRT_DEVICE_PRODUCT=“Generic”
OPENWRT_DEVICE_REVISION=“v0”
OPENWRT_RELEASE=“OpenWrt 21.02-SNAPSHOT unknown”
How do you write to sdcard?
Win32 Disk Imager
