I have just flashed mtk-bpi-r3mini-EMMC-20230912.img and bl2_emmc-r3mini.img from Google Drive. I have followed the official instruction. But it failed to bootup. Here is the kernel logs from serial console(USB-C)
[    0.000000] Linux version 5.4.171 ([email protected]) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 unknown)) #0 SMP Fri Jan 21 07:09:07 2022
[    0.000000] Machine model: Bananapi BPI-R3MINI
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000011002000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] On node 0 totalpages: 523280
[    0.000000]   DMA32 zone: 8192 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 523280 pages, LIFO batch:63
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 20 pages/cpu s43800 r8192 d29928 u81920
[    0.000000] pcpu-alloc: s43800 r8192 d29928 u81920 alloc=20*4096
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 515088
[    0.000000] Kernel command line: console=ttyS0,115200n1 loglevel=8           earlycon=uart8250,mmio32,0x11002000             earlyprintk block2mtd.block2mtd=/dev/mmcblk0,65536 mtdparts=mmcblk0:4608K(BL2)ro,2M(RF),2M(FIP)ro,32M(Kernel),1024M(rootfs),2048M(usrdata),-(bmtpool) rootfstype=squashfs,jffs2
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Memory: 2041452K/2093120K available (7678K kernel code, 554K rwdata, 2244K rodata, 448K init, 285K bss, 51668K reserved, 0K cma-reserved)
…too many words to be written…
[   19.699495] mt_wifi: module license 'Proprietary' taints kernel.
[   19.705519] Disabling lock debugging due to kernel taint
[   19.743674] conninfra@(conninfra_pwr_on:120) [conninfra_pwr_on] drv=[3]
[   19.751232] conninfra@(_consys_polling_chipid_int:459) Read CONNSYS HW IP version successfully! (0x02070000)
[   19.769140] Adie Type: 0x7976
[   19.769142] SKU Type: One_Adie_DBDC
[   19.773073] conninfra@(opfunc_power_on_internal:241) [Conninfra Pwr On] BT=[0] FM=[0] GPS=[0] WF=[1] CONNINFRA=[1]
[   19.787939] WiFi@C12L1,get_dbg_setting_by_profile() 4373: debug level setting=INDEX0_debug_level not found!!
[   19.797811] WiFi@C12L1,get_dbg_setting_by_profile() 4396: debug option setting=INDEX0_debug_option not found!!
[   19.807905] mt_rbus 0000:00:00.0: runtime IRQ mapping not provided by arch
[   19.821430] mt7986_init()-->
[   19.824374]  sku:0x7, ADIE=MT7976
[   19.828743] <--mt7986_init()
[   19.831652] RtmpRaDevCtrlInit(): MCS_LUT not used becasue MacTb size(544) > 128!
[   19.839136] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX1
[   19.846461] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX2
[   19.853787] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX3
[   19.861114] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX4
[   19.868436] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX5
[   19.875769] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX6
[   19.883093] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX7
[   19.890412] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX8
[   19.897735] WiFi@C12L1,match_index_by_chipname() 566: not find chip name INDEX9
[   19.905042] WiFi@C12L2,match_index_by_chipname() 571: Not find slot id, back to old rule.
[   19.913310] msta_ifname not found
[   19.924660] -->mtfwd_init(ver:2.0)
[   19.924704] <--
[   19.928651] mtk_warp_proxy: module uses symbols from proprietary module mt_wifi, inheriting taint.
[   19.940677] -->mtqos_init(), mtqos ver:1.0
[   19.940722] <--
[   19.973752] PPP MPPE Compression module registered
[   19.979688] PPTP driver version 0.8.5
[   19.984607] Bluetooth: RFCOMM TTY layer initialized
[   19.989553] Bluetooth: RFCOMM socket layer initialized
[   19.994713] Bluetooth: RFCOMM ver 1.11
[   20.000034] usbcore: registered new interface driver usblp
[   20.021132] xt_time: kernel timezone is -0000
[   20.027011] kmodloader: done loading kernel modules from /etc/modules.d/*
[   22.336675] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[   22.353373] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[   22.361871] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[   22.362983] br-lan: port 1(eth0) entered blocking state
[   22.375727] br-lan: port 1(eth0) entered disabled state
[   22.381173] device eth0 entered promiscuous mode
[   22.386923] br-lan: port 1(eth0) entered blocking state
[   22.392163] br-lan: port 1(eth0) entered forwarding state
[   22.402525] mtk_soc_eth 15100000.ethernet eth1: configuring for fixed/2500base-x link mode
[   22.410954] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
[   22.411319] br-wan: port 1(eth1) entered blocking state
[   22.424636] br-wan: port 1(eth1) entered disabled state
[   22.430048] device eth1 entered promiscuous mode
[   22.436315] br-wan: port 1(eth1) entered blocking state
[   22.441578] br-wan: port 1(eth1) entered forwarding state
[   22.635762] 7986@C12L1,rt28xx_ap_ioctl() 866: interface is down, cmd [8be2] return!!!
[   22.677458] 7986@C01L2,RTMP_COM_IoctlHandle() 1514: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
[   22.685912] msta_ifname not found
[   22.689787] warp_cap_support(): chip_id=7986 is in WHNAT support list
[   22.696363] warp_entry_acquire(): bus slot:0, hook to WARP, entry id=0, entry: 000000007cb566de
[   22.705086] client_hif_specific_get(): hw->base_phy_addr 0x18000000!!
[   22.711687] warp_entry_get_by_pdev(): return entry[0]
[   22.716939] warp_msg_register():warp,pid,4405,id,0,wed_idx,0
[   22.722640] warp_dev0 15010000.wed: Using 32bit DMA for streaming map
[   22.729106] warp_dev0 15010000.wed: Using 32bit DMA for coherent map
[   22.735517] wed_init(0): res_start = 0x15010000, size = 1000, irq=6,base_addr=0xffffffc011375000
[   22.744812] wed_ring_init(): wed tx ring init result = 0
[   22.750812] wed_ring_init(): wed rx ring init result = 0
[   22.760471] GetEntryFromFreeList: allocated new pool
[   22.767131] GetEntryFromFreeList: allocated new pool
[   22.773982] GetEntryFromFreeList: allocated new pool
[   22.780632] GetEntryFromFreeList: allocated new pool
[   22.787984] create wed ok!!!
[   22.790966] wdma_init(): wdma(0) base_addr=0xffffffc01137d800, base_phy_addr=0x15104800
[   22.799865] warp_woif_bus_init_hw(): bus:00000000b46bf184, txring: 20, pa: 0x00000000b9784000, 0x00000000b9784000, 24, 28, 3c
[   22.811192] warp_woif_bus_init_hw(): bus:00000000b46bf184, rxring: 50, pa: 0x00000000b9786000, 0x00000000b9786000, 54, 58, 6c
[   22.822563] get_region_info(): wed_idx = 0, base_addr = 0x00000000c99313c2, size = 0x40000, res.start = 0x4fd00000, shared:0
[   22.833840] get_region_info(): wed_idx = 0, base_addr = 0x00000000e1b8b518, size = 0x8000, res.start = 0x151e0000, shared:0
[   22.845053] get_region_info(): wed_idx = 0, base_addr = 0x00000000ea27c815, size = 0x240000, res.start = 0x4fd80000, shared:1
[   22.856548] get_region_info(): wed_idx = 0, base_addr = 0x00000000b262ccdd, size = 0x1000, res.start = 0x15194000, shared:0
[   22.867719] warp_fwdl_mcu_mode(): mcu mode, need fwdl
[   22.902465] ########## WO Firmware ##########
[   22.906837] Chip ID: 0x0000
[   22.909620] ECO version:0
[   22.912282] Version: DEV_000000
[   22.915439] Build date: 20221208175748
[   22.919198] Total region:3
[   22.921891] #################################
[   22.926246] Parsing tailer region 0
[   22.929723]  Target address: 0x151e0000
[   22.933563]  Download size: 20768
[   22.936906] Parsing tailer region 1
[   22.940404]  Target address: 0x4fd00000
[   22.944247]  Download size: 87584
[   22.947660] Parsing tailer region 2
[   22.951153]  Target address: 0x4fd80000
[   22.954993]  Download size: 2319824
[   22.961169] warp_fwdl_ready_check_mcu_mode(): waiting for wocpu
[   22.985167] warp_fwdl_ready_check_mcu_mode(): wocpu is ready
[   22.991181] warp_woctrl_init_state(), wo_state: WO_STATE_ENABLE
[   22.997147] wo_proc_init done  00000000256c50dc
[   23.001718] wo_exep_proc_init done  00000000256c50dc
[   23.006720] wo_exception_init(0): exp log= 0x00000000b2d2b382, phy_addr= 0x00000000a89c0000 size= 32768
[   23.016289] warp_probe(): probe fail since warp is full!
[   23.021639] warp_dev0: probe of 15010000.wed2 failed with error -1
[   23.028007] 7986@C01L3,mt_wifi_open() 345: whnat_en=1
[   23.039447] 7986@C00L1,hc_init_ChCtrl() 2161: Clear ChCtrl Band[0] (caller:UserCfgInit+0x710/0x1a18 [mt_wifi])
[   23.049719] 7986@C00L1,hc_init_ChCtrl() 2161: Clear ChCtrl Band[1] (caller:UserCfgInit+0x710/0x1a18 [mt_wifi])
[   23.111077] 7986@C00L1,hc_init_ChCtrl() 2161: Clear ChCtrl Band[0] (caller:RTMPSetProfileParameters+0x90/0x11498 [mt_wifi])
[   23.122466] 7986@C00L1,hc_init_ChCtrl() 2161: Clear ChCtrl Band[1] (caller:RTMPSetProfileParameters+0x90/0x11498 [mt_wifi])
[   23.135236] 7986@C12L1,RTMPWirelessModeCfg() 610: Init: BSS0 PhyMode=78
[   23.141837] 7986@C12L1,RTMPWirelessModeCfg() 610: Init: BSS1 PhyMode=177
[   23.148725] 7986@C23L3,auto_ch_select_set_cfg() 3466: BandIdx0, AutoChannelAtBootup=0, AutoChannelAlg = 0
[   23.158272] 7986@C23L3,auto_ch_select_set_cfg() 3466: BandIdx1, AutoChannelAtBootup=0, AutoChannelAlg = 0
[   23.175943] 7986@C12L1,SCS_Enable_set_cfg() 734: SCSEnable [0]= 1
[   23.182022] 7986@C12L1,SCS_Enable_set_cfg() 734: SCSEnable [0]= 1
[   23.207405] 7986@C15L1,Set_PMFMFPC_Proc() 1722: [PMF] :: apidx=0, Desired MFPC=1
[   23.214785] WiFi@C15L1,Set_PMFMFPC_Proc() 1722: [PMF] :: apidx=1, Desired MFPC=1
[   23.223457] WiFi@C12L1,RTMPSetProfileParameters() 8646: ra0, QoSMgmtCapa=0
[   23.230321] WiFi@C12L1,RTMPSetProfileParameters() 8646: (null), QoSMgmtCapa=0
[   23.240274] WiFi@C12L1,rtmp_read_ap_client_from_file() 1638: APCLI[0] ApCliMuMimoDlEnable = 0
[   23.248780] WiFi@C12L1,rtmp_read_ap_client_from_file() 1638: APCLI[1] ApCliMuMimoDlEnable = 0
[   23.257390] WiFi@C12L1,rtmp_read_ap_client_from_file() 1657: APCLI[0] ApCliMuMimoUlEnable = 0
[   23.265897] WiFi@C12L1,rtmp_read_ap_client_from_file() 1657: APCLI[1] ApCliMuMimoUlEnable = 0
[   23.275594] WiFi@C03L1,AndesSendCmdMsg() 754: Could not send in band command due to diablefRTMP_ADAPTER_MCU_SEND_IN_BAND_CMD
[   23.286790] WiFi@C03L2,AndesSendCmdMsg() 765: Command type = ed, Extension command type = 48
[   23.295221] WiFi@C03L1,AndesSendCmdMsg() 754: Could not send in band command due to diablefRTMP_ADAPTER_MCU_SEND_IN_BAND_CMD
[   23.306413] WiFi@C03L2,AndesSendCmdMsg() 765: Command type = ed, Extension command type = 48
[   23.366727] wdma_dma_ctrl(): WDMA_GLO_CFG=50404e70, txrx = 0
[   23.378485] wdma_dma_ctrl(): WDMA_GLO_CFG=40404e70, txrx = 0
[   23.393768] warp_tx_ring_init_hw(): configure ring 0 setting
[   23.399434] warp_tx_ring_init_hw(): wed:00000000889dd829 wifi:000000004fbef129: 24420=aa930000,24424=2048,24428=0
[   23.409689] warp_tx_ring_init_hw(): configure ring 1 setting
[   23.415358] warp_tx_ring_init_hw(): wed:00000000889dd829 wifi:000000004fbef129: 24430=aa938000,24434=2048,24438=0
[   23.425747] set_rrocfg,0
[   23.451225] wdma_dma_ctrl(): WDMA_GLO_CFG=40404e74, txrx = 3
[   23.456912]  sku:0x7, ADIE=MT7976
[   23.461297] using E1 ROM patch
[   23.464376] using E1 RAM
[   23.466933] current sync CR = 0x1
[   23.480919]  Built date: 20221216134650a
[   23.484882]  Platform: ALPS
[   23.487712]  HW/SW version: 0x8a108a10
[   23.491492]  Patch version: 0xffffffff
[   23.501076] current sync CR = 0x1
[   23.623288]  Chip ID: 0x0f
[   23.625992]  Eco version: 0x00
[   23.629049]  Region number: 0x0b
[   23.632268]  Format version: 0x02
[   23.635571]  Format flag: 0x01
[   23.638613]  Ram version: ____000000
[   23.642174]  Built date: 20221216134711
[   23.646003]  Common crc: 0xf62b0b61
[   23.649483]  Release info: header tag = 0, total length = 80
[   23.655128]  tag 1, padding length = 1, tag length = 75
[   23.660336]  payload: t-neptune-main-2111-7986-imp-MT7986_E1_ASIC_ROM_RAM_REBB_IMP-20221216134601
[   23.723067]  Chip ID: 0x00
[   23.725773]  Eco version: 0x00
[   23.728831]  Region number: 0x03
[   23.732048]  Format version: 0x02
[   23.735351]  Format flag: 0x01
[   23.738396]  Ram version: DEV_000000
[   23.741957]  Built date: 20221216134910
[   23.745784]  Common crc: 0xd2876be7
[   23.749261]  Release info: header tag = 0, total length = 0
[   23.817141] /dev/mmcblk0p6: Can't open blockdev
[   23.849644] current sync CR = 0x7
[   23.853056] efuse_probe: efuse = deaddead
[   23.862837]  sku:0x7, ADIE=MT7976
[   23.868902] WiFi@C02L1,is_cal_free_ic() 1009: is_cal_free_ic(1009) offset:0, c,0
[   23.877129]  sku:0x7, ADIE=MT7976
[   23.895709] WiFi@C02L1,is_cal_free_ic() 1028:  iCal free
[   23.901829]  sku:0x7, ADIE=MT7976
[   26.876592] WiFi@C17L1,RTMPReadTxPwrPerRate() 450: (450): Don't Support this now!
[   26.884097] WiFi@C01L1,AntCfgInit() 3126: Not support for HIF_MT yet!
[   26.904432] ch_switch_monitor_state_machine_init:: enter
[   26.909745] ch_switch_monitor_cfg_reset:: enter
[   26.914266] ch_switch_monitor_cfg_reset:: enter
[   26.919091] WiFi@C17L1,tx_pwr_comp_init() 641: NotSupportYet!
[   26.924858] WiFi@C12L1,SCS_init() 880: INIT SCSEnable [0]= 1
[   26.930511] WiFi@C12L1,SCS_init() 887: INIT SCSEnable [1]= 1
[   26.936254] WiFi@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[   26.941728] WiFi@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[   26.947158] WiFi@C14L1,IPMacTable_init() 348: IPMacTable already inited!
[   26.973965] wdma_dma_ctrl(): WDMA_GLO_CFG=50804e75, txrx = 3
[   26.979698] WiFi@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[   26.985173] WiFi@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[   26.990594] WiFi@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[   27.000491] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13535: DAT config band(0) cck_timeout Fail!
[   27.009169] WiFi@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[   27.019061] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13546: DAT config band(0) ofdm_timeout Fail!
[   27.027826] WiFi@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[   27.037716] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13557: DAT config band(0) ofdma_timeout Fail!
[   27.046568] WiFi@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[   27.056460] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13535: DAT config band(1) cck_timeout Fail!
[   27.065139] WiFi@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[   27.075030] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13546: DAT config band(1) ofdm_timeout Fail!
[   27.083794] WiFi@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[   27.093686] WiFi@C00L1,set_datcfg_ack_cts_timeout() 13557: DAT config band(1) ofdma_timeout Fail!
[   27.103483] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
[   27.111855] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
[   27.320430] :(op = 1)
[   27.327738] 7986@C00L1,FastPathCheckMIC() 1010: (ret = 0)(op:1)
[   27.333731] 7986@C00L2,red_tail_drop_init() 83: red_tail_drop_init: available token:8192, whnat_en:1
[   27.342970] 7986@C00L1,MtCmdCr4RedSet() 914: MtCmdCr4RedSet: (ret = 0)
[   27.349522] 7986@C00L1,SendRedCmd() 1049: SendRedCmd:(ret = 1)
[   27.355464] 7986@C01L2,RTMP_COM_IoctlHandle() 1491:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
[   27.363487] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 0
[   27.369094] 7986@C18L3,BuildChannelList() 484:
[   27.373658] 7986@C00L3,BuildChannelList() 514: BandIdx = 0, PhyMode = 78, ChListNum = 11:
[   27.381860] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.388232] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.394679] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.401035] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.407482] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.413846] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.420302] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.426654] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.433100] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.439457] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.445906] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.452265] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.458712] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.465078] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.471532] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.477895] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.484353] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.490706] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.497158] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.503513] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.509965] 7986@C14L1,vht80_channel_group() 1584: invalid ch_band 0
[   27.516331] 7986@C14L1,vht160_channel_group() 1655: invalid ch_band 0
[   27.522775] 7986@C23L1,DfsBuildChannelList() 3839: [RDM]: wdev is not 5G.
[   27.529597] 7986@C23L3,RadarStateCheck() 250: Zero Wait State: 0
[   27.535613] 7986@C23L3,DfsRadarChannelCheck() 3228: [DfsRadarChannelCheck]: wdev is not 5G
[   27.543882] 7986@C23L3,operate_loader_phy() 360: oper_cfg: prim_ch(6), ht_bw(1), extcha(1), vht_bw(0), cen_ch_2(0), PhyMode=78!
[   27.555378] 7986@C23L3,operate_loader_phy() 374: oper_dev after adjust: bw(1), prim_ch(6), cen_ch_1(8), cen_ch_2(0),ext_cha(1)!
[   27.566852] 7986@C23L3,operate_loader_phy() 393: oper_dev after decision: bw(1), prim_ch(6), cen_ch_1(8), cen_ch_2(0)!
[   27.577544] 7986@C23L3,DfsRadarChannelCheck() 3228: [DfsRadarChannelCheck]: wdev is not 5G
[   27.585817] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:1 vht_bw:0 bw:1 extcha:1
[   27.596344] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:6 cench1:8 cench2:0 rxstream:2 ap_bw:0 apCenCh:0 Scan:0
[   27.608098] 7986@C00L1,mt7986_apply_dpd_flatness_data() 566: Currently not in FLASH or BIN MODE,return.
[   27.617519] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=6, ctrl_ch2=0, cent_ch=8 DBDCIdx=0, ChBand=0, BW=1, TXStream=4, RXStream=4, scan(0)
[   31.006214] 7986@C03L2,AndesSendCmdMsg() 871: FWCmdTimeout: command (ed), ext_cmd_type (5a), seq(7), timeout(3000ms)
[   31.016722] 7986@C03L2,AndesSendCmdMsg() 873: pAd->Flags  = 0x11202006
[   31.023241] 7986@C03L2,AndesSendCmdMsg() 875: txq qlen = 0
[   31.028714] 7986@C03L2,AndesSendCmdMsg() 877: rxq qlen = 0
[   31.034188] 7986@C03L2,AndesSendCmdMsg() 879: kickq qlen = 0
[   31.039833] 7986@C03L2,AndesSendCmdMsg() 881: ackq qlen = 2
[   31.045390] 7986@C03L2,AndesSendCmdMsg() 883: tx_doneq.qlen = 0
[   31.051296] 7986@C03L2,AndesSendCmdMsg() 885: rx_done qlen = 0
[   31.057117] 7986@C03L2,AndesSendCmdMsg() 902: msg state = 8
[   31.062674] 7986@C03L2,AndesSendCmdMsg() 904: msg->retry_times = 2
[   31.068839] 7986@C03L2,AndesSendCmdMsg() 906: FwCmdTimeoutCnt  = 1
[   31.075008] FW is exception
[   31.075008]
[   31.075008]
[   31.075008]
[   31.082270] ================FW DBG INFO===================
[   31.087739]        exp_assert_proc_entry_cnt = 0x1
[   31.092515]        exp_assert_state = 0xa
[   31.096512]        COS_Interrupt_Count = 0x0
[   31.100768]        processing_irqx = 0x0
[   31.104677]        processing_lisr = 0x0
[   31.108586]        Current_Task_Id = 0x22027b8
[   31.113015]        Current_Task_Indx = 0x0
[   31.117097]        last_dequeued_msg_id = 100
[   31.121439]        km_irq_info_idx = 0xd
[   31.125349]        km_eint_info_idx = 0x5
[   31.129344]        km_sched_info_idx = 0x11
[   31.133513]        g_sched_history_num = 32
[   31.137682]        km_sched_trace_ptr = 0x2206bc0
[   31.142371]
[   31.142371]         <1>print sched trace
[   31.147764]        (sched_info_17)sched_t=0x0, sched_start=253556, PC=0x806d34
[   31.154977]        (sched_info_18)sched_t=0x2, sched_start=253558, PC=0x0
[   31.161759]        (sched_info_19)sched_t=0x0, sched_start=253921, PC=0x806d34
[   31.168971]        (sched_info_20)sched_t=0x2, sched_start=253923, PC=0x0
[   31.175750]        (sched_info_21)sched_t=0x0, sched_start=254286, PC=0x806d34
[   31.182963]        (sched_info_22)sched_t=0x2, sched_start=254288, PC=0x0
[   31.189742]        (sched_info_23)sched_t=0x0, sched_start=254408, PC=0x806d34
[   31.196955]        (sched_info_24)sched_t=0x2, sched_start=254437, PC=0x0
[   31.203734]        (sched_info_25)sched_t=0x0, sched_start=254438, PC=0x806d34
[   31.210947]        (sched_info_26)sched_t=0x2, sched_start=254467, PC=0x0
[   31.217726]        (sched_info_27)sched_t=0x0, sched_start=254651, PC=0x806d34
[   31.224939]        (sched_info_28)sched_t=0x2, sched_start=254653, PC=0x0
[   31.231718]        (sched_info_29)sched_t=0x0, sched_start=255016, PC=0x806d34
[   31.238930]        (sched_info_30)sched_t=0x2, sched_start=255018, PC=0x0
[   31.245710]        (sched_info_31)sched_t=0x0, sched_start=255381, PC=0x806d34
[   31.252922]        (sched_info_0)sched_t=0x3ef91, sched_start=8417850, PC=0x0
[   31.260050]        (sched_info_1)sched_t=0x0, sched_start=255746, PC=0x806d34
[   31.267177]        (sched_info_2)sched_t=0x2, sched_start=255748, PC=0x0
[   31.273870]        (sched_info_3)sched_t=0x0, sched_start=256111, PC=0x806d34
[   31.280997]        (sched_info_4)sched_t=0x2, sched_start=256114, PC=0x0
[   31.287689]        (sched_info_5)sched_t=0x0, sched_start=256477, PC=0x806d34
[   31.294814]        (sched_info_6)sched_t=0x2, sched_start=256479, PC=0x0
[   31.301507]        (sched_info_7)sched_t=0x0, sched_start=256842, PC=0x806d34
[   31.308633]        (sched_info_8)sched_t=0x2, sched_start=256844, PC=0x0
[   31.315326]        (sched_info_9)sched_t=0x0, sched_start=256978, PC=0x806d34
[   31.322453]        (sched_info_10)sched_t=0x2, sched_start=257008, PC=0x0
[   31.329232]        (sched_info_11)sched_t=0x0, sched_start=257207, PC=0x806d34
[   31.336445]        (sched_info_12)sched_t=0x2, sched_start=257209, PC=0x0
[   31.343223]        (sched_info_13)sched_t=0x0, sched_start=257572, PC=0x806d34
[   31.350435]        (sched_info_14)sched_t=0x2, sched_start=257574, PC=0x0
[   31.357214]        (sched_info_15)sched_t=0x0, sched_start=257707, PC=0x806d34
[   31.364426]        (sched_info_16)sched_t=0x0, sched_start=257937, PC=0x80ad6e
[   31.371630]
[   31.371630]         <2>print irq trace
[   31.376848]        (irq_info_13)irq_t=0, sched_start=253921
[   31.382411]        (irq_info_14)irq_t=0, sched_start=254286
[   31.387974]        (irq_info_15)irq_t=a, sched_start=254408
[   31.393536]        (irq_info_0)irq_t=a, sched_start=254438
[   31.399013]        (irq_info_1)irq_t=0, sched_start=254651
[   31.404489]        (irq_info_2)irq_t=0, sched_start=255016
[   31.409965]        (irq_info_3)irq_t=0, sched_start=255381
[   31.415441]        (irq_info_4)irq_t=0, sched_start=255746
[   31.420916]        (irq_info_5)irq_t=0, sched_start=256111
[   31.426393]        (irq_info_6)irq_t=0, sched_start=256477
[   31.431869]        (irq_info_7)irq_t=0, sched_start=256842
[   31.437345]        (irq_info_8)irq_t=a, sched_start=256978
[   31.442820]        (irq_info_9)irq_t=0, sched_start=257207
[   31.448296]        (irq_info_10)irq_t=0, sched_start=257572
[   31.453858]        (irq_info_11)irq_t=a, sched_start=257707
[   31.459420]        (irq_info_12)irq_t=0, sched_start=257937
[   31.464976]
[   31.464976]        <3>task q_id.read q_id.write
[   31.470964]        (WIFI )1 0x72a 0x72b
[   31.474922]        (WIFI2 )2 0x0 0x0
[   31.478489]
[   31.478489]        <4>TASK STACK INFO (size in byte)
[   31.484912]        TASK  START       END       SIZE  PEAK  INTEGRITY
[   31.491259]        WIFI  0x2202fc0  0x2203fbc  4096
[   31.496133]        WIFI2  0x2203fc0  0x22049bc  2560
[   31.501082]
[   31.501082]        <5>fw state
[   31.505598]        exp_type : Assert
[   31.509161]        FW in Task , Task id(0x22027b8) Task index(0x0)
[   31.515330]        EXCP_CNT = 0x1
[   31.518633]        EXCP_TYPE = 0x5
[   31.522021]        CPU_ITYPE = 0x143
[   31.525587]        CPU_EVA = 0x80ad6e
[   31.529239]        CPU_IPC = 0x80ad6e
[   31.532890]        PC = 0x803838
[   31.532890]
[   31.532890]
[   31.539058]        lp history (from old to new):
[   31.543664]        0: 0xe001895a
[   31.546884]        1: 0xe001948e
[   31.550098]        2: 0xe000e804
[   31.553317]        3: 0xe000e8a0
[   31.556538]        4: 0xe000e38a
[   31.559756]        5: 0x80add4
[   31.562802]        6: 0x80ae06
[   31.565843]        7: 0xe000e38a
[   31.569062]        8: 0xe000e8a0
[   31.572283]        9: 0xe000ebdc
[   31.575502]        10: 0xe000ebe6
[   31.578809]        11: 0xe002188a
[   31.582110]        12: 0xe00218a0
[   31.585416]        13: 0x80050e
[   31.588549]        14: 0x80118c
[   31.591681]        15: 0x803aea
[   31.594814]
[   31.594814]
[   31.594814]
[   31.594814]        Irq Idx (Dis=6 Res=6):
[   31.603359]
[   31.603359]        Dis Irq history (from old to new):
[   31.609869]       [6].LP = 0x80ab1c   time=257931
[   31.614559]       [7].LP = 0x80ab1c   time=257931
[   31.619248]       [8].LP = 0x80ab1c   time=257931
[   31.623940]       [9].LP = 0x80ab1c   time=257932
[   31.628630]       [0].LP = 0x80ab1c   time=122339
[   31.633320]       [1].LP = 0x807242   time=257937
[   31.638011]       [2].LP = 0x801c00   time=257937
[   31.642700]       [3].LP = 0x806bb6   time=257937
[   31.647390]       [4].LP = 0x807242   time=257937
[   31.652079]       [5].LP = 0x8072d0   time=257937
[   31.656769]
[   31.656769]        Restore Irq history (from old to new):
[   31.663626]       [6].LP = 0x80ad1c   time=257931
[   31.668315]       [7].LP = 0x80ad1c   time=257931
[   31.673004]       [8].LP = 0x80ad1c   time=257932
[   31.677694]       [9].LP = 0x80ad1c   time=257932
[   31.682456]       [0].LP = 0x807216   time=257937
[   31.687147]       [1].LP = 0x807260   time=257937
[   31.691838]       [2].LP = 0x801c54   time=257937
[   31.696527]       [3].LP = 0x806c46   time=257937
[   31.701216]       [4].LP = 0x807260   time=257937
[   31.705905]       [5].LP = 0x807302   time=257937
[   31.710599]
[   31.710599]
[   31.710599]        cpu ultility
[   31.716675]        Busy:1771544608% Peak:-1543244042%
[   31.716675]
[   31.723882]        msg trace:
[   31.726840]        format: t_id=task_id/task_prempt_cnt/msg_read_idx
[   31.733178]        (m_6)t_id=0/1818/1803, m_id=1, ts_en=248903, ts_de = 248903, ts_fin=248905, wait=0, exe=2
[   31.742985]        (m_7)t_id=0/1819/1804, m_id=100, ts_en=249148, ts_de = 249148, ts_fin=249168, wait=0, exe=20
[   31.753050]        (m_8)t_id=0/1820/1805, m_id=1, ts_en=249268, ts_de = 249268, ts_fin=249270, wait=0, exe=2
[   31.762854]        (m_9)t_id=0/1821/1806, m_id=1, ts_en=249534, ts_de = 249534, ts_fin=249536, wait=0, exe=2
[   31.772662]        (m_10)t_id=0/1822/1807, m_id=1, ts_en=249603, ts_de = 249603, ts_fin=249605, wait=0, exe=2
[   31.782555]        (m_11)t_id=0/1823/1808, m_id=1, ts_en=249968, ts_de = 249968, ts_fin=249970, wait=0, exe=2
[   31.792449]        (m_12)t_id=0/1824/1809, m_id=1, ts_en=250333, ts_de = 250333, ts_fin=250335, wait=0, exe=2
[   31.802341]        (m_13)t_id=0/1825/1810, m_id=1, ts_en=250698, ts_de = 250698, ts_fin=250700, wait=0, exe=2
[   31.812232]        (m_14)t_id=0/1826/1811, m_id=1, ts_en=251063, ts_de = 251063, ts_fin=251065, wait=0, exe=2
[   31.822123]        (m_15)t_id=0/1827/1812, m_id=1, ts_en=251428, ts_de = 251428, ts_fin=251430, wait=0, exe=2
[   31.832015]        (m_16)t_id=0/1828/1813, m_id=1, ts_en=251793, ts_de = 251793, ts_fin=251795, wait=0, exe=2
[   31.841905]        (m_17)t_id=0/1829/1814, m_id=1, ts_en=252158, ts_de = 252158, ts_fin=252160, wait=0, exe=2
[   31.851796]        (m_18)t_id=0/1830/1815, m_id=1, ts_en=252457, ts_de = 252457, ts_fin=252459, wait=0, exe=2
[   31.861688]        (m_19)t_id=0/1831/1816, m_id=1, ts_en=252493, ts_de = 252493, ts_fin=252495, wait=0, exe=2
[   31.871579]        (m_20)t_id=0/1832/1817, m_id=1, ts_en=252825, ts_de = 252825, ts_fin=252827, wait=0, exe=2
[   31.881470]        (m_21)t_id=0/1833/1818, m_id=1, ts_en=253191, ts_de = 253191, ts_fin=253193, wait=0, exe=2
[   31.891360]        (m_22)t_id=0/1834/1819, m_id=1, ts_en=253556, ts_de = 253556, ts_fin=253558, wait=0, exe=2
[   31.901253]        (m_23)t_id=0/1835/1820, m_id=1, ts_en=253921, ts_de = 253921, ts_fin=253923, wait=0, exe=2
[   31.911145]        (m_24)t_id=0/1836/1821, m_id=1, ts_en=254286, ts_de = 254286, ts_fin=254288, wait=0, exe=2
[   31.921036]        (m_25)t_id=0/1837/1822, m_id=100, ts_en=254408, ts_de = 254408, ts_fin=254437, wait=0, exe=29
[   31.931187]        (m_26)t_id=0/1838/1823, m_id=100, ts_en=254438, ts_de = 254438, ts_fin=254467, wait=0, exe=29
[   31.941337]        (m_27)t_id=0/1839/1824, m_id=1, ts_en=254651, ts_de = 254651, ts_fin=254653, wait=0, exe=2
[   31.951228]        (m_28)t_id=0/1840/1825, m_id=1, ts_en=255016, ts_de = 255016, ts_fin=255018, wait=0, exe=2
[   31.961119]        (m_29)t_id=0/1841/1826, m_id=1, ts_en=255381, ts_de = 255381, ts_fin=255383, wait=0, exe=2
[   31.971010]        (m_30)t_id=0/1842/1827, m_id=1, ts_en=255746, ts_de = 255746, ts_fin=255748, wait=0, exe=2
[   31.980901]        (m_31)t_id=0/1843/1828, m_id=1, ts_en=256111, ts_de = 256111, ts_fin=256113, wait=0, exe=2
[   31.990791]        (m_0)t_id=0/1844/1829, m_id=1, ts_en=256477, ts_de = 256477, ts_fin=256479, wait=0, exe=2
[   32.000595]        (m_1)t_id=0/1845/1830, m_id=1, ts_en=256842, ts_de = 256842, ts_fin=256844, wait=0, exe=2
[   32.010407]        (m_2)t_id=0/1846/1831, m_id=100, ts_en=256978, ts_de = 256978, ts_fin=257008, wait=0, exe=30
[   32.020474]        (m_3)t_id=0/1847/1832, m_id=1, ts_en=257207, ts_de = 257207, ts_fin=257209, wait=0, exe=2
[   32.030282]        (m_4)t_id=0/1848/1833, m_id=1, ts_en=257572, ts_de = 257572, ts_fin=257574, wait=0, exe=2
[   32.040088]        (m_5)t_id=0/1849/1834, m_id=100, ts_en=257707, ts_de = 257707, ts_fin=0, wait=0, exe=-257707
[   32.050210]
[   32.050210]
[   32.050210]
[   32.050210]        TASK    XTIME    RATIO    PREMPT CNT
[   32.059893]        WIFI       109027    89       1850
[   32.064986]        WIFI2       0    0       0
[   32.070123]        program trace:
[   32.073427]        (p_2)t_id=0/1822, m_id=100, LP=0xe0009036, name=cmd_1, ts2=254410, diff2=NA,
[   32.082195]        (p_3)t_id=0/1822, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=254410, diff2=       0
[   32.091306]        (p_4)t_id=0/1822, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=254410, diff2=       0
[   32.100420]        (p_5)t_id=0/1822, m_id=100, LP=0xe0009166, name=cmd_5, ts2=254410, diff2=       0
[   32.109531]        (p_6)t_id=0/1822, m_id=100, LP=0xe0009036, name=cmd_1, ts2=254436, diff2=      26
[   32.118645]        (p_7)t_id=0/1822, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=254436, diff2=       0
[   32.127757]        (p_8)t_id=0/1822, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=254436, diff2=       0
[   32.136871]        (p_9)t_id=0/1822, m_id=100, LP=0xe00092be, name=cmd_6, ts2=254436, diff2=       0
[   32.145982]        (p_10)t_id=0/1823, m_id=100, LP=0xe0009036, name=cmd_1, ts2=254439, diff2=NA,
[   32.154834]        (p_11)t_id=0/1823, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=254439, diff2=       0
[   32.164031]        (p_12)t_id=0/1823, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=254439, diff2=       0
[   32.173230]        (p_13)t_id=0/1823, m_id=100, LP=0xe0009166, name=cmd_5, ts2=254439, diff2=       0
[   32.182427]        (p_14)t_id=0/1823, m_id=100, LP=0xe0009036, name=cmd_1, ts2=254465, diff2=      26
[   32.191627]        (p_15)t_id=0/1823, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=254465, diff2=       0
[   32.200825]        (p_16)t_id=0/1823, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=254465, diff2=       0
[   32.210025]        (p_17)t_id=0/1823, m_id=100, LP=0xe00092be, name=cmd_6, ts2=254465, diff2=       0
[   32.219222]        (p_18)t_id=0/1831, m_id=100, LP=0xe0009036, name=cmd_1, ts2=256979, diff2=NA,
[   32.228074]        (p_19)t_id=0/1831, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=256979, diff2=       0
[   32.237270]        (p_20)t_id=0/1831, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=256979, diff2=       0
[   32.246470]        (p_21)t_id=0/1831, m_id=100, LP=0xe0009166, name=cmd_5, ts2=256980, diff2=       1
[   32.255668]        (p_22)t_id=0/1831, m_id=100, LP=0xe0009036, name=cmd_1, ts2=256998, diff2=      18
[   32.264868]        (p_23)t_id=0/1831, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=256998, diff2=       0
[   32.274065]        (p_24)t_id=0/1831, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=256998, diff2=       0
[   32.283264]        (p_25)t_id=0/1831, m_id=100, LP=0xe0009166, name=cmd_5, ts2=256999, diff2=       1
[   32.292463]        (p_26)t_id=0/1831, m_id=100, LP=0xe0009036, name=cmd_1, ts2=257006, diff2=       7
[   32.301662]        (p_27)t_id=0/1831, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=257006, diff2=       0
[   32.310859]        (p_28)t_id=0/1831, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=257006, diff2=       0
[   32.320058]        (p_29)t_id=0/1831, m_id=100, LP=0xe00092be, name=cmd_6, ts2=257006, diff2=       0
[   32.329255]        (p_30)t_id=0/1834, m_id=100, LP=0xe0009036, name=cmd_1, ts2=257709, diff2=NA,
[   32.338108]        (p_31)t_id=0/1834, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=257709, diff2=       0
[   32.347304]        (p_0)t_id=0/1834, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=257709, diff2=       0
[   32.356418]        (p_1)t_id=0/1834, m_id=100, LP=0xe0009166, name=cmd_5, ts2=257709, diff2=       0
[   32.365553]
[   32.365553]
[   32.368508]        Assert line
[   32.371552]        Disable Cache
[   32.371552] <ASSERT> build/csp/7986/asic1.0/projects/wifi_rebb_ram/../../../../../../wifi/base/7986/prj/exthal/cal/7976/hal_ca
[   32.386122] ============================================
[   32.391421] =================================================
[   32.397151] Isr1=3443, Isr2=0, Isr3=0, Isr4=0, IsrRxCntNoClear=0, IsrRx1CntNoClear=1703
[   32.405133] =================================================
[   32.410863] =================================================
[   32.416620] TxRing Configuration
[   32.419838]  Idx     Attr      Reg       Base    Cnt   CIDX   DIDX   QCnt FreeCnt
[   32.427304]    0     DATA    24420   abab0000    800      0      0      0    7ff
[   32.434683]    1     DATA    24430   abab8000    800      0      0      0    7ff
[   32.442062]    2     FWDL    24400   ab966000     80     15     15      0     7f
[   32.449440]    3   CMD_WM    24410   ab967000    100     10     10      0     ff
[   32.456819]    4      CMD    24440   ab674000    200    105    105      0    1ff
[   32.464197] RxRing Configuration
[   32.467414]  Idx     Attr      Reg       Base    Cnt   CIDX   DIDX   QCnt
[   32.474187]    0     DATA    24540   ab010000    600    5ff      0      0
[   32.480958]    1     DATA    24550   ab018000    600    5ff      0      0
[   32.487730]    2    EVENT    24500   ab676000    200      f     10      0
[   32.494501]    3    EVENT    24510   ab064000    200     d2     d3      0
[   32.501271]    4    EVENT    24520   ab16c000    400    3ff      0      0
[   32.508042]    5    EVENT    24530   ab066000    200    1ff      0      0
[   32.514812] =================================================
[   32.520542] Isr1=3443, Isr2=0, Isr3=0, Isr4=0, IsrRxCntNoClear=0, IsrRx1CntNoClear=1703
[   32.528526] =================================================
[   32.534260] HOST_DMA Configuration
[   32.537645]        DMA     IntCSR    IntMask     Glocfg    Tx/RxEn  Tx/RxBusy
[   32.544975]      Merge          0   bef0000f
[   32.549242]       DMA0          0   bef0000f   1030b875    1/    1    0/    0
[   32.556358] HOST_DMA0 Ring Configuration
[   32.560269]                   Name       Base        Cnt       CIDX       DIDX       QCnt
[   32.568432]               T16:FWDL   ab966000         80         15         15          0
[   32.576593]         T17:Cmd (H2WM)   ab967000        100         10         10          0
[   32.584754]         T18:TXD (H2WA)   aa930000        800          0          0          0
[   32.592914]        T19:TXD1 (H2WA)   aa938000        800          0          0          0
[   32.601075]         T20:Cmd (H2WA)   ab674000        200        108        107          1
[   32.609234]        R0:Event (WM2H)   ab676000        200          f         10          0
[   32.617395]        R1:Event (WA2H)   ab064000        200         d2         d3          0
[   32.625556]       R2:TxDone (WA2H)   ab16c000        400        3ff          0          0
[   32.633716]      R3:TxDone1 (WA2H)   ab066000        200        1ff          0          0
[   32.641877]        R4:Data (MAC2H)   aa958000        600        5ff          0          0
[   32.650037]       R5:Data1 (MAC2H)   aa980000        600        5ff          0          0
[   32.658194] MCU_DMA Configuration
[   32.661492]        DMA     IntCSR    IntMask     Glocfg    Tx/RxEn  Tx/RxBusy
[   32.668609]       DMA0     400030   83c8000e   10703875    1/    1    0/    0
[   32.675723] MCU_DMA0 Ring Configuration
[   32.679547]                   Name       Base        Cnt       CIDX       DIDX       QCnt
[   32.687708]        T0:Event (WM2H)    2315600          4          0          0          0
[   32.695867]        T1:Event (WA2H)   102314c0          8          3          3          0
[   32.704026]       T2:TxDone (WA2H)   10231540          8          0          0          0
[   32.712185]      T3:TxDone1 (WA2H)   102315c0          8          0          0          0
[   32.720344]        T4:TXD (WM2MAC)    2315640          4          0          0          0
[   32.728504]      T5:TXCMD (WM2MAC)    2315680          8          0          0          0
[   32.736663]        T6:TXD (WA2MAC)   10231640         40          0          0          0
[   32.744822]                R0:FWDL          0        200          0          0        1ff
[   32.752981]          R1:Cmd (H2WM)    2315380          4          3          0          0
[   32.761141]          R2:TXD (H2WA)   1022ff40         a0         9f          0          0
[   32.769300]         R3:TXD1 (H2WA)   10230940         a0         9f          0          0
[   32.777460]          R4:Cmd (H2WA)   10231340          8          7          7          7
[   32.785620]       R5:Data (MAC2WM)    23153c0          8          7          0          0
[   32.793778] R6:TxDone/STS (MAC2WM)    2315440          8          7          0          0
[   32.801937]        R7:RPT (MAC2WM)    23154c0         10          f          0          0
[   32.802200] 7986@C03L2,AndesSendCmdMsg() 871: FWCmdTimeout: command (ed), ext_cmd_type (8), seq(6), timeout(5000ms)
[   32.810097] R8:TxDone/STS (MAC2WA)   102313c0          8          7          0          0
[   32.810102]      R9:Data1 (MAC2WM)          0        200          0          0        1ff
[   32.820508] 7986@C03L2,AndesSendCmdMsg() 873: pAd->Flags  = 0x11202006
[   32.828662] MEM_DMA Configuration
[   32.836816] 7986@C03L2,AndesSendCmdMsg() 875: txq qlen = 0
[   32.843322]        DMA     IntCSR    IntMask     Glocfg    Tx/RxEn  Tx/RxBusy
[   32.843326]        MEM         32    1000003   18003075    1/    1    0/    0
[   32.846625] 7986@C03L2,AndesSendCmdMsg() 877: rxq qlen = 0
[   32.852090] MEM_DMA Ring Configuration
[   32.852092]                   Name       Base        Cnt       CIDX       DIDX       QCnt
[   32.852097]    T0:CmdEvent (WM2WA)    2315700          4          0          0          0
[   32.859208] 7986@C03L2,AndesSendCmdMsg() 879: kickq qlen = 0
[   32.866326]    T1:CmdEvent (WA2WM)   10231a40          4          2          3          3
[   32.871791] 7986@C03L2,AndesSendCmdMsg() 881: ackq qlen = 1
[   32.875528]    R0:CmdEvent (WM2WA)   10231440          8          7          0          0
[   32.883679] 7986@C03L2,AndesSendCmdMsg() 883: tx_doneq.qlen = 0
[   32.891836]    R1:CmdEvent (WA2WM)    23155c0          4          3          3          3
[   32.897473] 7986@C03L2,AndesSendCmdMsg() 885: rx_done qlen = 0
[   32.905625] =================================================
[   32.905628] Isr1=3445, Isr2=0, Isr3=0, Isr4=0, IsrRxCntNoClear=0, IsrRx1CntNoClear=1703
[   32.911182] 7986@C03L2,AndesSendCmdMsg() 902: msg state = 8
[   32.919333] =================================================
[   32.924377] /etc/_ROM.bin.bin open success  addr:0x800000
[   32.925236] 7986@C03L2,AndesSendCmdMsg() 904: msg->retry_times = 2
[   32.975763] 7986@C03L2,AndesSendCmdMsg() 906: FwCmdTimeoutCnt  = 2
[   32.981955] FW is exception
[   32.981955]
[   32.981955]
[   32.981955]
[   32.989241] ================FW DBG INFO===================
[   32.994730]        exp_assert_proc_entry_cnt = 0x1
[   32.999522]        exp_assert_state = 0xa
[   33.003535]        COS_Interrupt_Count = 0x0
[   33.007807]        processing_irqx = 0x0
[   33.011734]        processing_lisr = 0x0
[   33.015660]        Current_Task_Id = 0x22027b8
[   33.020108]        Current_Task_Indx = 0x0
[   33.024211]        last_dequeued_msg_id = 100
[   33.028570]        km_irq_info_idx = 0xd
[   33.032495]        km_eint_info_idx = 0x5
[   33.036509]        km_sched_info_idx = 0x11
[   33.040696]        g_sched_history_num = 32
[   33.044883]        km_sched_trace_ptr = 0x2206bc0
[   33.049589]
[   33.049589]         <1>print sched trace
[   33.054999]        (sched_info_17)sched_t=0x0, sched_start=253556, PC=0x806d34
[   33.062233]        (sched_info_18)sched_t=0x2, sched_start=253558, PC=0x0
[   33.069042]        (sched_info_19)sched_t=0x0, sched_start=253921, PC=0x806d34
[   33.076280]        (sched_info_20)sched_t=0x2, sched_start=253923, PC=0x0
[   33.083081]        (sched_info_21)sched_t=0x0, sched_start=254286, PC=0x806d34
[   33.090317]        (sched_info_22)sched_t=0x2, sched_start=254288, PC=0x0
[   33.097122]        (sched_info_23)sched_t=0x0, sched_start=254408, PC=0x806d34
[   33.104359]        (sched_info_24)sched_t=0x2, sched_start=254437, PC=0x0
[   33.111158]        (sched_info_25)sched_t=0x0, sched_start=254438, PC=0x806d34
[   33.118383]        (sched_info_26)sched_t=0x2, sched_start=254467, PC=0x0
[   33.125189]        (sched_info_27)sched_t=0x0, sched_start=254651, PC=0x806d34
[   33.132422]        (sched_info_28)sched_t=0x2, sched_start=254653, PC=0x0
[   33.139224]        (sched_info_29)sched_t=0x0, sched_start=255016, PC=0x806d34
[   33.146451]        (sched_info_30)sched_t=0x2, sched_start=255018, PC=0x0
[   33.153258]        (sched_info_31)sched_t=0x0, sched_start=255381, PC=0x806d34
[   33.160493]        (sched_info_0)sched_t=0x3ef91, sched_start=8417850, PC=0x0
[   33.167639]        (sched_info_1)sched_t=0x0, sched_start=255746, PC=0x806d34
[   33.174783]        (sched_info_2)sched_t=0x2, sched_start=255748, PC=0x0
[   33.181495]        (sched_info_3)sched_t=0x0, sched_start=256111, PC=0x806d34
[   33.188643]        (sched_info_4)sched_t=0x2, sched_start=256114, PC=0x0
[   33.195356]        (sched_info_5)sched_t=0x0, sched_start=256477, PC=0x806d34
[   33.202496]        (sched_info_6)sched_t=0x2, sched_start=256479, PC=0x0
[   33.209211]        (sched_info_7)sched_t=0x0, sched_start=256842, PC=0x806d34
[   33.216361]        (sched_info_8)sched_t=0x2, sched_start=256844, PC=0x0
[   33.223067]        (sched_info_9)sched_t=0x0, sched_start=256978, PC=0x806d34
[   33.230216]        (sched_info_10)sched_t=0x2, sched_start=257008, PC=0x0
[   33.237022]        (sched_info_11)sched_t=0x0, sched_start=257207, PC=0x806d34
[   33.244258]        (sched_info_12)sched_t=0x2, sched_start=257209, PC=0x0
[   33.251057]        (sched_info_13)sched_t=0x0, sched_start=257572, PC=0x806d34
[   33.258282]        (sched_info_14)sched_t=0x2, sched_start=257574, PC=0x0
[   33.265082]        (sched_info_15)sched_t=0x0, sched_start=257707, PC=0x806d34
[   33.272321]        (sched_info_16)sched_t=0x0, sched_start=257937, PC=0x80ad6e
[   33.279541]
[   33.279541]         <2>print irq trace
[   33.284773]        (irq_info_13)irq_t=0, sched_start=253921
[   33.290348]        (irq_info_14)irq_t=0, sched_start=254286
[   33.295932]        (irq_info_15)irq_t=a, sched_start=254408
[   33.301522]        (irq_info_0)irq_t=a, sched_start=254438
[   33.307015]        (irq_info_1)irq_t=0, sched_start=254651
[   33.312513]        (irq_info_2)irq_t=0, sched_start=255016
[   33.318006]        (irq_info_3)irq_t=0, sched_start=255381
[   33.323503]        (irq_info_4)irq_t=0, sched_start=255746
[   33.329000]        (irq_info_5)irq_t=0, sched_start=256111
[   33.334489]        (irq_info_6)irq_t=0, sched_start=256477
[   33.339983]        (irq_info_7)irq_t=0, sched_start=256842
[   33.345476]        (irq_info_8)irq_t=a, sched_start=256978
[   33.350967]        (irq_info_9)irq_t=0, sched_start=257207
[   33.356464]        (irq_info_10)irq_t=0, sched_start=257572
[   33.362048]        (irq_info_11)irq_t=a, sched_start=257707
[   33.367628]        (irq_info_12)irq_t=0, sched_start=257937
[   33.373204]
[   33.373204]        <3>task q_id.read q_id.write
[   33.379206]        (WIFI )1 0x72a 0x72b
[   33.383043]        (WIFI2 )2 0x0 0x0
[   33.386614]
[   33.386614]        <4>TASK STACK INFO (size in byte)
[   33.393056]        TASK  START       END       SIZE  PEAK  INTEGRITY
[   33.399422]        WIFI  0x2202fc0  0x2203fbc  4096
[   33.404317]        WIFI2  0x2203fc0  0x22049bc  2560
[   33.409283]
[   33.409283]        <5>fw state
[   33.413816]        exp_type : Assert
[   33.417400]        FW in Task , Task id(0x22027b8) Task index(0x0)
[   33.423587]        EXCP_CNT = 0x1
[   33.426905]        EXCP_TYPE = 0x5
[   33.430310]        CPU_ITYPE = 0x143
[   33.433877]        CPU_EVA = 0x80ad6e
[   33.437550]        CPU_IPC = 0x80ad6e
[   33.441216]        PC = 0x803838
[   33.441216]
[   33.441216]
[   33.447405]        lp history (from old to new):
[   33.452040]        0: 0xe001895a
[   33.455286]        1: 0xe001948e
[   33.458519]        2: 0xe000e804
[   33.461738]        3: 0xe000e8a0
[   33.464980]        4: 0xe000e38a
[   33.468223]        5: 0x80add4
[   33.471283]        6: 0x80ae06
[   33.474333]        7: 0xe000e38a
[   33.477547]        8: 0xe000e8a0
[   33.480769]        9: 0xe000ebdc
[   33.483993]        10: 0xe000ebe6
[   33.487306]        11: 0xe002188a
[   33.490624]        12: 0xe00218a0
[   33.493930]        13: 0x80050e
[   33.497073]        14: 0x80118c
[   33.500210]        15: 0x803aea
[   33.503345]
[   33.503345]
[   33.503345]
[   33.503345]        Irq Idx (Dis=6 Res=6):
[   33.511906]
[   33.511906]        Dis Irq history (from old to new):
[   33.518428]       [6].LP = 0x80ab1c   time=257931
[   33.523127]       [7].LP = 0x80ab1c   time=257931
[   33.527828]       [8].LP = 0x80ab1c   time=257931
[   33.532532]       [9].LP = 0x80ab1c   time=257932
[   33.537242]       [0].LP = 0x80ab1c   time=122339
[   33.541953]       [1].LP = 0x807242   time=257937
[   33.546653]       [2].LP = 0x801c00   time=257937
[   33.551352]       [3].LP = 0x806bb6   time=257937
[   33.556044]       [4].LP = 0x807242   time=257937
[   33.560740]       [5].LP = 0x8072d0   time=257937
[   33.565434]
[   33.565434]        Restore Irq history (from old to new):
[   33.572301]       [6].LP = 0x80ad1c   time=257931
[   33.576995]       [7].LP = 0x80ad1c   time=257931
[   33.581686]       [8].LP = 0x80ad1c   time=257932
[   33.586376]       [9].LP = 0x80ad1c   time=257932
[   33.591073]       [0].LP = 0x807216   time=257937
[   33.595776]       [1].LP = 0x807260   time=257937
[   33.600475]       [2].LP = 0x801c54   time=257937
[   33.605181]       [3].LP = 0x806c46   time=257937
[   33.609889]       [4].LP = 0x807260   time=257937
[   33.614589]       [5].LP = 0x807302   time=257937
[   33.619293]
[   33.619293]
[   33.619293]        cpu ultility
[   33.625391]        Busy:1771544608% Peak:-1543244042%
[   33.625391]
[   33.632617]        msg trace:
[   33.635591]        format: t_id=task_id/task_prempt_cnt/msg_read_idx
[   33.641950]        (m_6)t_id=0/1818/1803, m_id=1, ts_en=248903, ts_de = 248903, ts_fin=248905, wait=0, exe=2
[   33.651775]        (m_7)t_id=0/1819/1804, m_id=100, ts_en=249148, ts_de = 249148, ts_fin=249168, wait=0, exe=20
[   33.661853]        (m_8)t_id=0/1820/1805, m_id=1, ts_en=249268, ts_de = 249268, ts_fin=249270, wait=0, exe=2
[   33.671676]        (m_9)t_id=0/1821/1806, m_id=1, ts_en=249534, ts_de = 249534, ts_fin=249536, wait=0, exe=2
[   33.681501]        (m_10)t_id=0/1822/1807, m_id=1, ts_en=249603, ts_de = 249603, ts_fin=249605, wait=0, exe=2
[   33.691403]        (m_11)t_id=0/1823/1808, m_id=1, ts_en=249968, ts_de = 249968, ts_fin=249970, wait=0, exe=2
[   33.701313]        (m_12)t_id=0/1824/1809, m_id=1, ts_en=250333, ts_de = 250333, ts_fin=250335, wait=0, exe=2
[   33.711228]        (m_13)t_id=0/1825/1810, m_id=1, ts_en=250698, ts_de = 250698, ts_fin=250700, wait=0, exe=2
[   33.721139]        (m_14)t_id=0/1826/1811, m_id=1, ts_en=251063, ts_de = 251063, ts_fin=251065, wait=0, exe=2
[   33.731046]        (m_15)t_id=0/1827/1812, m_id=1, ts_en=251428, ts_de = 251428, ts_fin=251430, wait=0, exe=2
[   33.740959]        (m_16)t_id=0/1828/1813, m_id=1, ts_en=251793, ts_de = 251793, ts_fin=251795, wait=0, exe=2
[   33.750864]        (m_17)t_id=0/1829/1814, m_id=1, ts_en=252158, ts_de = 252158, ts_fin=252160, wait=0, exe=2
[   33.760775]        (m_18)t_id=0/1830/1815, m_id=1, ts_en=252457, ts_de = 252457, ts_fin=252459, wait=0, exe=2
[   33.770678]        (m_19)t_id=0/1831/1816, m_id=1, ts_en=252493, ts_de = 252493, ts_fin=252495, wait=0, exe=2
[   33.780589]        (m_20)t_id=0/1832/1817, m_id=1, ts_en=252825, ts_de = 252825, ts_fin=252827, wait=0, exe=2
[   33.790491]        (m_21)t_id=0/1833/1818, m_id=1, ts_en=253191, ts_de = 253191, ts_fin=253193, wait=0, exe=2
[   33.800399]        (m_22)t_id=0/1834/1819, m_id=1, ts_en=253556, ts_de = 253556, ts_fin=253558, wait=0, exe=2
[   33.810304]        (m_23)t_id=0/1835/1820, m_id=1, ts_en=253921, ts_de = 253921, ts_fin=253923, wait=0, exe=2
[   33.820216]        (m_24)t_id=0/1836/1821, m_id=1, ts_en=254286, ts_de = 254286, ts_fin=254288, wait=0, exe=2
[   33.830127]        (m_25)t_id=0/1837/1822, m_id=100, ts_en=254408, ts_de = 254408, ts_fin=254437, wait=0, exe=29
[   33.840297]        (m_26)t_id=0/1838/1823, m_id=100, ts_en=254438, ts_de = 254438, ts_fin=254467, wait=0, exe=29
[   33.850460]        (m_27)t_id=0/1839/1824, m_id=1, ts_en=254651, ts_de = 254651, ts_fin=254653, wait=0, exe=2
[   33.860372]        (m_28)t_id=0/1840/1825, m_id=1, ts_en=255016, ts_de = 255016, ts_fin=255018, wait=0, exe=2
[   33.870274]        (m_29)t_id=0/1841/1826, m_id=1, ts_en=255381, ts_de = 255381, ts_fin=255383, wait=0, exe=2
[   33.880174]        (m_30)t_id=0/1842/1827, m_id=1, ts_en=255746, ts_de = 255746, ts_fin=255748, wait=0, exe=2
[   33.890081]        (m_31)t_id=0/1843/1828, m_id=1, ts_en=256111, ts_de = 256111, ts_fin=256113, wait=0, exe=2
[   33.899988]        (m_0)t_id=0/1844/1829, m_id=1, ts_en=256477, ts_de = 256477, ts_fin=256479, wait=0, exe=2
[   33.909812]        (m_1)t_id=0/1845/1830, m_id=1, ts_en=256842, ts_de = 256842, ts_fin=256844, wait=0, exe=2
[   33.919634]        (m_2)t_id=0/1846/1831, m_id=100, ts_en=256978, ts_de = 256978, ts_fin=257008, wait=0, exe=30
[   33.929717]        (m_3)t_id=0/1847/1832, m_id=1, ts_en=257207, ts_de = 257207, ts_fin=257209, wait=0, exe=2
[   33.939538]        (m_4)t_id=0/1848/1833, m_id=1, ts_en=257572, ts_de = 257572, ts_fin=257574, wait=0, exe=2
[   33.949352]        (m_5)t_id=0/1849/1834, m_id=100, ts_en=257707, ts_de = 257707, ts_fin=0, wait=0, exe=-257707
[   33.959483]
[   33.959483]
[   33.959483]
[   33.959483]        TASK    XTIME    RATIO    PREMPT CNT
[   33.969204]        WIFI       109027    89       1850
[   33.974306]        WIFI2       0    0       0
[   33.979459]        program trace:
[   33.982778]        (p_2)t_id=0/1822, m_id=100, LP=0xe0009036, name=cmd_1, ts2=254410, diff2=NA,
[   33.991564]        (p_3)t_id=0/1822, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=254410, diff2=       0
[   34.000698]        (p_4)t_id=0/1822, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=254410, diff2=       0
[   34.009825]        (p_5)t_id=0/1822, m_id=100, LP=0xe0009166, name=cmd_5, ts2=254410, diff2=       0
[   34.018953]        (p_6)t_id=0/1822, m_id=100, LP=0xe0009036, name=cmd_1, ts2=254436, diff2=      26
[   34.028085]        (p_7)t_id=0/1822, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=254436, diff2=       0
[   34.037214]        (p_8)t_id=0/1822, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=254436, diff2=       0
[   34.046338]        (p_9)t_id=0/1822, m_id=100, LP=0xe00092be, name=cmd_6, ts2=254436, diff2=       0
[   34.055470]        (p_10)t_id=0/1823, m_id=100, LP=0xe0009036, name=cmd_1, ts2=254439, diff2=NA,
[   34.064346]        (p_11)t_id=0/1823, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=254439, diff2=       0
[   34.073562]        (p_12)t_id=0/1823, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=254439, diff2=       0
[   34.082776]        (p_13)t_id=0/1823, m_id=100, LP=0xe0009166, name=cmd_5, ts2=254439, diff2=       0
[   34.091984]        (p_14)t_id=0/1823, m_id=100, LP=0xe0009036, name=cmd_1, ts2=254465, diff2=      26
[   34.101192]        (p_15)t_id=0/1823, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=254465, diff2=       0
[   34.110402]        (p_16)t_id=0/1823, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=254465, diff2=       0
[   34.119616]        (p_17)t_id=0/1823, m_id=100, LP=0xe00092be, name=cmd_6, ts2=254465, diff2=       0
[   34.128837]        (p_18)t_id=0/1831, m_id=100, LP=0xe0009036, name=cmd_1, ts2=256979, diff2=NA,
[   34.137711]        (p_19)t_id=0/1831, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=256979, diff2=       0
[   34.146923]        (p_20)t_id=0/1831, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=256979, diff2=       0
[   34.156140]        (p_21)t_id=0/1831, m_id=100, LP=0xe0009166, name=cmd_5, ts2=256980, diff2=       1
[   34.165363]        (p_22)t_id=0/1831, m_id=100, LP=0xe0009036, name=cmd_1, ts2=256998, diff2=      18
[   34.174572]        (p_23)t_id=0/1831, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=256998, diff2=       0
[   34.183787]        (p_24)t_id=0/1831, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=256998, diff2=       0
[   34.193006]        (p_25)t_id=0/1831, m_id=100, LP=0xe0009166, name=cmd_5, ts2=256999, diff2=       1
[   34.202220]        (p_26)t_id=0/1831, m_id=100, LP=0xe0009036, name=cmd_1, ts2=257006, diff2=       7
[   34.211435]        (p_27)t_id=0/1831, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=257006, diff2=       0
[   34.220657]        (p_28)t_id=0/1831, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=257006, diff2=       0
[   34.229890]        (p_29)t_id=0/1831, m_id=100, LP=0xe00092be, name=cmd_6, ts2=257006, diff2=       0
[   34.239108]        (p_30)t_id=0/1834, m_id=100, LP=0xe0009036, name=cmd_1, ts2=257709, diff2=NA,
[   34.247986]        (p_31)t_id=0/1834, m_id=100, LP=0xe00090cc, name=cmd_2, ts2=257709, diff2=       0
[   34.257206]        (p_0)t_id=0/1834, m_id=100, LP=0xe00090e6, name=cmd_4, ts2=257709, diff2=       0
[   34.266333]        (p_1)t_id=0/1834, m_id=100, LP=0xe0009166, name=cmd_5, ts2=257709, diff2=       0
[   34.275481]
[   34.275481]
[   34.278444]        Assert line
[   34.281488]        Disable Cache
[   34.281488] <ASSERT> build/csp/7986/asic1.0/projects/wifi_rebb_ram/../../../../../../wifi/base/7986/prj/exthal/cal/7976/hal_ca
[   34.296076] ============================================
[   34.301395] =================================================
[   34.307142] Isr1=3445, Isr2=0, Isr3=0, Isr4=0, IsrRxCntNoClear=0, IsrRx1CntNoClear=1703
[   34.315142] =================================================
[   34.320890] =================================================
[   34.326662] TxRing Configuration
[   34.329881]  Idx     Attr      Reg       Base    Cnt   CIDX   DIDX   QCnt FreeCnt
[   34.337359]    0     DATA    24420   abab0000    800      0      0      0    7ff
[   34.344758]    1     DATA    24430   abab8000    800      0      0      0    7ff
[   34.352165]    2     FWDL    24400   ab966000     80     15     15      0     7f
[   34.359565]    3   CMD_WM    24410   ab967000    100     10     10      0     ff
[   34.366959]    4      CMD    24440   ab674000    200    10b    107      4    1fb
[   34.374343] RxRing Configuration
[   34.377563]  Idx     Attr      Reg       Base    Cnt   CIDX   DIDX   QCnt
[   34.384353]    0     DATA    24540   ab010000    600    5ff      0      0
[   34.391145]    1     DATA    24550   ab018000    600    5ff      0      0
[   34.397932]    2    EVENT    24500   ab676000    200      f     10      0
[   34.404723]    3    EVENT    24510   ab064000    200     d2     d3      0
[   34.411515]    4    EVENT    24520   ab16c000    400    3ff      0      0
[   34.418301]    5    EVENT    24530   ab066000    200    1ff      0      0
[   34.425085] =================================================
[   34.430828] Isr1=3445, Isr2=0, Isr3=0, Isr4=0, IsrRxCntNoClear=0, IsrRx1CntNoClear=1703
[   34.438821] =================================================
[   34.444575] HOST_DMA Configuration
[   34.447989]        DMA     IntCSR    IntMask     Glocfg    Tx/RxEn  Tx/RxBusy
[   34.455125]      Merge          0   bef0000f
[   34.459398]       DMA0          0   bef0000f   1030b875    1/    1    0/    0
[   34.466526] HOST_DMA0 Ring Configuration
[   34.470447]                   Name       Base        Cnt       CIDX       DIDX       QCnt
[   34.478625]               T16:FWDL   ab966000         80         15         15          0
[   34.486811]         T17:Cmd (H2WM)   ab967000        100         10         10          0
[   34.494990]         T18:TXD (H2WA)   aa930000        800          0          0          0
[   34.503171]        T19:TXD1 (H2WA)   aa938000        800          0          0          0
[   34.511352]         T20:Cmd (H2WA)   ab674000        200        10b        107          4
[   34.519532]        R0:Event (WM2H)   ab676000        200          f         10          0
[   34.527709]        R1:Event (WA2H)   ab064000        200         d2         d3          0
[   34.535890]       R2:TxDone (WA2H)   ab16c000        400        3ff          0          0
[   34.544078]      R3:TxDone1 (WA2H)   ab066000        200        1ff          0          0
[   34.552257]        R4:Data (MAC2H)   aa958000        600        5ff          0          0
[   34.560444]       R5:Data1 (MAC2H)   aa980000        600        5ff          0          0
[   34.568620] MCU_DMA Configuration
[   34.571945]        DMA     IntCSR    IntMask     Glocfg    Tx/RxEn  Tx/RxBusy
[   34.579080]       DMA0     400030   83c8000e   10703875    1/    1    0/    0
[   34.586206] MCU_DMA0 Ring Configuration
[   34.590031]                   Name       Base        Cnt       CIDX       DIDX       QCnt
[   34.598213]        T0:Event (WM2H)    2315600          4          0          0          0
[   34.606388]        T1:Event (WA2H)   102314c0          8          3          3          0
[   34.614560]       T2:TxDone (WA2H)   10231540          8          0          0          0
[   34.622735]      T3:TxDone1 (WA2H)   102315c0          8          0          0          0
[   34.630914]        T4:TXD (WM2MAC)    2315640          4          0          0          0
[   34.639097]      T5:TXCMD (WM2MAC)    2315680          8          0          0          0
[   34.647271]        T6:TXD (WA2MAC)   10231640         40          0          0          0
[   34.655447]                R0:FWDL          0        200          0          0        1ff
[   34.663621]          R1:Cmd (H2WM)    2315380          4          3          0          0
[   34.671790]          R2:TXD (H2WA)   1022ff40         a0         9f          0          0
[   34.679955]         R3:TXD1 (H2WA)   10230940         a0         9f          0          0
[   34.688122]          R4:Cmd (H2WA)   10231340          8          7          7          7
[   34.696291]       R5:Data (MAC2WM)    23153c0          8          7          0          0
[   34.704456] R6:TxDone/STS (MAC2WM)    2315440          8          7          0          0
[   34.712630]        R7:RPT (MAC2WM)    23154c0         10          f          0          0
[   34.720802] R8:TxDone/STS (MAC2WA)   102313c0          8          7          0          0
[   34.728978]      R9:Data1 (MAC2WM)          0        200          0          0        1ff
[   34.737150] MEM_DMA Configuration
[   34.740461]        DMA     IntCSR    IntMask     Glocfg    Tx/RxEn  Tx/RxBusy
[   34.747592]        MEM         32    1000003   18003075    1/    1    0/    0
[   34.754714] MEM_DMA Ring Configuration
[   34.758457]                   Name       Base        Cnt       CIDX       DIDX       QCnt
[   34.766625]    T0:CmdEvent (WM2WA)    2315700          4          0          0          0
[   34.774795]    T1:CmdEvent (WA2WM)   10231a40          4          2          3          3
[   34.782963]    R0:CmdEvent (WM2WA)   10231440          8          7          0          0
[   34.791132]    R1:CmdEvent (WA2WM)    23155c0          4          3          3          3
[   34.799295] =================================================
[   34.805035] Isr1=3445, Isr2=0, Isr3=0, Isr4=0, IsrRxCntNoClear=0, IsrRx1CntNoClear=1703
[   34.813026] =================================================
[   34.823770] /../mt_wifi/embedded/mcu/andes_core.c:960 assert FALSEfailed
[   34.830462] CPU: 1 PID: 4333 Comm: ifconfig Tainted: P                  5.4.171 #0
[   34.838008] Hardware name: Bananapi BPI-R3MINI (DT)
[   34.842867] Call trace:
[   34.845312]  dump_backtrace+0x0/0x120
[   34.848962]  show_stack+0x14/0x20
[   34.852265]  dump_stack+0xb4/0xf4
[   34.855779]  AndesSendCmdMsg+0x72c/0xdd0 [mt_wifi]
[   34.860754]  chip_cmd_tx+0x40/0x50 [mt_wifi]
[   34.865167]  MtCmdChannelSwitch+0x5a8/0x870 [mt_wifi]
[   34.870376]  mt7986_apply_dpd_flatness_data+0x65c/0x6b8 [mt_wifi]
[   34.876624]  MtfAsicSwitchChannel+0x4c/0xa0 [mt_wifi]
[   34.881779]  AsicSwitchChannel+0x1c0/0x370 [mt_wifi]
[   34.886817]  hc_radio_res_request+0x268/0x308 [mt_wifi]
[   34.892155]  operate_loader_phy+0xd4/0x420 [mt_wifi]
[   34.897263]  wlan_operate_init+0x9c/0x148 [mt_wifi]
[   34.902314]  HcAcquireRadioForWdev+0xa4/0xf8 [mt_wifi]
[   34.907623]  wdev_attr_update+0x1c/0x180 [mt_wifi]
[   34.912594]  wifi_sys_open+0x194/0x3d0 [mt_wifi]
[   34.917398]  ap_inf_open+0x6c/0x560 [mt_wifi]
[   34.921939]  wdev_do_open+0x20/0x38 [mt_wifi]
[   34.926577]  virtual_if_up_handler+0x124/0x1f8 [mt_wifi]
[   34.932101]  RTMP_COM_IoctlHandle+0x8a4/0x1a00 [mt_wifi]
[   34.937617]  main_virtual_if_open+0xb8/0x1c0 [mt_wifi]
[   34.942746]  __dev_open+0xcc/0x150
[   34.946132]  __dev_change_flags+0x134/0x198
[   34.950299]  dev_change_flags+0x20/0x60
[   34.954123]  devinet_ioctl+0x3e8/0x748
[   34.957858]  inet_ioctl+0x1f4/0x370
[   34.961334]  sock_do_ioctl+0x48/0x2c0
[   34.964982]  sock_ioctl+0x318/0x518
[   34.968459]  do_vfs_ioctl+0xa4/0xb28
[   34.972021]  ksys_ioctl+0x44/0x90
[   34.975324]  __arm64_sys_ioctl+0x1c/0xb8
[   34.979234]  el0_svc_common.constprop.2+0x7c/0x110
[   34.984009]  el0_svc_handler+0x20/0x80
[   34.987745]  el0_svc+0x8/0x1c8
[   40.222237] 7986@C03L2,AndesSendCmdMsg() 871: FWCmdTimeout: command (ed), ext_cmd_type (8), seq(6), timeout(5000ms)
[   40.232683] 7986@C03L2,AndesSendCmdMsg() 873: pAd->Flags  = 0x11202006
[   40.239226] 7986@C03L2,AndesSendCmdMsg() 875: txq qlen = 0
[   40.244726] 7986@C03L2,AndesSendCmdMsg() 877: rxq qlen = 0
[   40.250216] 7986@C03L2,AndesSendCmdMsg() 879: kickq qlen = 0
[   40.255882] 7986@C03L2,AndesSendCmdMsg() 881: ackq qlen = 1
[   40.261463] 7986@C03L2,AndesSendCmdMsg() 883: tx_doneq.qlen = 0
[   40.267390] 7986@C03L2,AndesSendCmdMsg() 885: rx_done qlen = 0
[   40.273233] 7986@C03L2,AndesSendCmdMsg() 902: msg state = 8
[   40.278810] 7986@C03L2,AndesSendCmdMsg() 904: msg->retry_times = 1
[   40.284993] 7986@C03L2,AndesSendCmdMsg() 906: FwCmdTimeoutCnt  = 3
[   40.291176] FW is exception
with no WIFI ssid.
