Is it possible to power the board via PoE ? There is a poe adapter and a 1 Gbit poe splitter, will the port be damaged when connected ? I really don’t want to run high voltage on a 14m mast…
So, I asked myself, I answered myself!
NL-SW-AFG-ING300 POE Injector
I am having the same doubt, did you power it using the adapter you bought at aliexpress? did you solder the 4th lan port? or you used any of the three available?
