Are there any chance to restore original firmware to NAND?
For the moment I do have working system on emmc and heve issues with OS on NAND.
# cat /proc/mtd
dev: size erasesize name
mtd0: 00200000 00020000 "bl2"
mtd1: 07e00000 00020000 "ubi"
# cat /proc/partitions
major minor #blocks name
31 0 2048 mtdblock0
31 1 129024 mtdblock1
179 0 7634944 mmcblk0
179 1 512 mmcblk0p1
179 2 2048 mmcblk0p2
179 3 4096 mmcblk0p3
179 4 32768 mmcblk0p4
179 5 307200 mmcblk0p5
259 0 4079 mmcblk0p128
179 8 4096 mmcblk0boot0
179 16 4096 mmcblk0boot1
259 1 8444 fit0
259 2 291252 fitrw
254 0 44764 ubiblock0_1
Official manual is telling us that we can use single image to restore NANS content
mtd erase /dev/mtd0
dd if=mtk-bpi-r3mini-NAND-20230719-single-image.bin of=/dev/mtdblock0
but the problem is that /dev/mtdblock0 is RO.
Only using USB2TTL nand cam be resorted?
frank-w
(Frank W.)
July 15, 2024, 8:21am
2
Why not install up2date openwrt on nand?
What is that? Im not a big expert in OpenWrt and have a huge gap in knowledge … I just need somehow to have working OS that can start from Nand.
frank-w
(Frank W.)
July 15, 2024, 2:49pm
4
I thought emmc uboot has nand install commands,but it does not seems to
But you can try to do like it is defined in nand environment
https://git.openwrt.org/?p=openwrt/openwrt.git;a=blob;f=package/boot/uboot-mediatek/patches/442-add-bpi-r3-mini.patch;h=5409f7fa0de71ed406727c1d53cc5a1e733afdeb;hb=HEAD#l456
I’m no expert in openwrt too…but if there is a newer system i do not want to install an older one
Were able to reinstall to NAND.
Here is what I did to do that
insmod mtd-rw.ko i_want_a_brick=1
mtd erase bl2 && mtd write openwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-preloader.bin bl2
umount /mnt/ubi0* 2> /dev/null
ubidetach -p /dev/mtd1 2> /dev/null
mtd erase ubi
ubiformat -y /dev/mtd1
ubiattach -p /dev/mtd1
ubimkvol /dev/ubi0 -n 0 -N ubootenv -s 128KiB
ubimkvol /dev/ubi0 -n 1 -N ubootenv2 -s 128KiB
# Install uboot
volsize=$(wc -c < openwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip)
ubimkvol /dev/ubi0 -N fip -n 2 -s $volsize -t static && \
ubiupdatevol /dev/ubi0_2 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-snand-bl31-uboot.fip
# Install en8811h-fw
cat /lib/firmware/airoha/EthMD32.dm.bin /lib/firmware/airoha/EthMD32.DSP.bin > ./en8811h-fw.bin
ubimkvol /dev/ubi0 -N en8811h-fw -n 3 -s $volsize -t static && \
ubiupdatevol /dev/ubi0_3 /tmp/en8811h-fw.bin
# Install recovery
volsize=$(wc -c < openwrt-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb)
ubimkvol /dev/ubi0 -n 4 -N recovery -s $volsize && \
ubiupdatevol /dev/ubi0_4 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb
# Install system
volsize=$(wc -c < openwrt-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itb)
ubimkvol /dev/ubi0 -n 5 -N fit -s $volsize && \
ubiupdatevol /dev/ubi0_5 openwrt-mediatek-filogic-bananapi_bpi-r3-mini-squashfs-sysupgrade.itb
# Create rootfs_data partition
ubimkvol /dev/ubi0 -n 6 -N rootfs_data -m
Vitalii
(Vitalii)
July 16, 2024, 5:50am
6
Have you used UART-USB in your solution to this problem?
Nope. I did this from emmc OS as it was alive
dmrbdlln
(Damir Abdullin)
November 1, 2024, 9:41pm
8
Guys, where do you get initramfs ? I downloaded files from OpenWRT’s selector page, but there is no initramfs image to download.
frank-w
(Frank W.)
November 10, 2024, 9:12am
9
Have you tried compiling yourself? i guess it is created but not uploaded to firmware-selector.
dmrbdlln
(Damir Abdullin)
November 11, 2024, 11:21pm
10
You mean have I tried to build it using firmware-selector? Yes, but there was no initramfs
frank-w
(Frank W.)
November 12, 2024, 6:38am
11
I mean building openwrt from source,not the firmware-selector…it seems not getting the file you want from build-pipeline
nino_0
(nino)
January 20, 2025, 5:55pm
12
The error that I got when I had to go searching was:
[93705.974989] block ubiblock0_5: created from ubi0:5(fit)
F0: 102B 0000
FA: 1040 0000
FA: 1040 0000 [0200]
F9: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 2400 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [1000]
T0: 0000 021E [010F]
Jump to BL
NOTICE: BL2: v2.6(release):
NOTICE: BL2: Built : 20:18:14, May 7 2023
NOTICE: WDT: disabled
NOTICE: CPU: MT7986 (2000MHz)
NOTICE: SPI_NAND parses attributes from parameter page.
NOTICE: SPI_NAND Detected ID 0xef
NOTICE: Page size 2048, Block size 131072, size 134217728
NOTICE: Initializing NMBM ...
NOTICE: NMBM management region starts at block 960 [0x07800000]
NOTICE: NMBM has been initialized in read-only mode
Wrong partition layout, /dev/mmcblk0p4 is too small.
I had missed the MTD not being writable when running the install commands I found on the SNAND openwrt wiki instructions [OpenWrt Wiki] Sinovoip BananaPi BPi-R3 mini
Here’s the steps for alpine openwrt and also some added checks
# 0. Alpine install the kernel module mtd-rw
apk add kmod-mtd-rw
# 1. MTD erase and write preloader to bl2
# 2. Clean and prepare UBI
mtd erase ubi
# 3. Create volumes in order:
ubimkvol /dev/ubi0 -n 0 -N ubootenv -s 128KiB # uboot env
ubimkvol /dev/ubi0 -n 1 -N ubootenv2 -s 128KiB # uboot env backup
# 4. Install uboot
# 5. Install en8811h firmware
# 6. Install recovery
# 7. Install system
# 8. Create rootfs_data partition
# 9. Check overall UBI info
ubinfo /dev/ubi0
# 10. List all volumes
ubinfo -a
# 11. Check each volume specifically
for i in 0 1 2 3 4 5 6; do
echo "=== Checking volume $i ==="
ubinfo /dev/ubi0_$i
done
You are my hero. I end-up with same broken state when following OpenWrt instructions. Your guide working like a charm. Thank you so much.
LZY
June 19, 2025, 3:47pm
14
I also have some problems while flashing NAND. I use emmc OS to flash NAND but it can’t use.
the mtd partitions I saw in emmc system is above. I tried to mtd erase bl2 and fip and mtd write the bl2 and bl31-uboot downloaded from immortalwrt firmware selector.
I tried to boot via NAND and boot from tftp but the mtd partitions are different from what I saw in emmc.
If I choose to Load recovery system via TFTP then write to NAND it turns out ECC error and can’t find fip
I’m exhausted about this. Help!!!
