Use wiki flashing steps and wiki firmware
dd if=bl2_emmc-r3mini.img of=/dev/mmcblk0boot0
dd if=mtk-bpi-r3mini-EMMC-20231115.img of=/dev/mmcblk0
mmc bootpart enable 1 1 /dev/mmcblk0
Change the lan segment IP, save and restart the network. The system will automatically restart. After the restart, the configuration will still be the original default configuration. No changes take effect
root@OpenWrt:/# vim /etc/config/network
root@OpenWrt:/# /etc/init.d/network restart
logs
cat: can't open '/etc/vendor_info': No such file or directory
[ 1597.595982] extif_put_dev(ra0)
[ 1597.599033] mtk_ppe_dev_unregister_hook : ineterface ra0 set null (1)
[ 1597.605490] extif_put_dev(rax0)
[ 1597.608622] mtk_ppe_dev_unregister_hook : ineterface rax0 set null (2)
killall: hostapd: no process killed
uci: Entry not found
[ 1597.636662] 7986@C01L2,RTMP_COM_IoctlHandle() 1502: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DOWN
[ 1597.645487] WiFi@C08L2,ap_link_down() 7170: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(0)
[ 1597.654745] 7986@C08L1,UpdateBeaconHandler() 1908: wdev(0) bss not ready (state:2, caller:ap_link_down+0x84/0x130 [mt_wifi])!!
[ 1597.666122] 7986@C01L3,wifi_sys_linkdown() 1363: wdev idx = 0
[ 1597.672029] 7986@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=0
[ 1597.681094] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 0
[ 1597.686686] 7986@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=0
[ 1597.692583] 7986@C01L2,RTMP_COM_IoctlHandle() 1525: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DEINIT
[ 1597.700837] mtk_ppe_dev_unregister_hook : ineterface ra0 set null (64)
[ 1597.707532] br-lan: port 2(ra0) entered disabled state
[ 1597.720675] mtk_ppe_dev_unregister_hook : ineterface rax0 set null (64)
[ 1597.748883] 7986@C08L2,mbss_virtual_if_close() 171: ===> rax0
[ 1597.755118] 7986@C01L2,RTMP_COM_IoctlHandle() 1502: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DOWN
[ 1597.763548] WiFi@C08L2,ap_link_down() 7170: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(1)
[ 1597.772630] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=1
[ 1597.779552] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=1
[ 1597.786689] 7986@C08L1,UpdateBeaconHandler() 1908: wdev(1) bss not ready (state:2, caller:hw_ctrl_ops_v1_register+0x258/0x870 [mt_wifi])!!
[ 1597.799241] 7986@C13L2,MacTableDeleteEntry() 1921: Del Sta:a4:cf:99:4c:76:49
[ 1597.806562] 7986@C08L1,UpdateBeaconHandler() 1908: wdev(1) bss not ready (state:2, caller:ap_link_down+0x84/0x130 [mt_wifi])!!
[ 1597.817963] 7986@C01L3,wifi_sys_linkdown() 1363: wdev idx = 1
[ 1597.823970] 7986@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=1
[ 1597.832958] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 1
[ 1597.838578] 7986@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=1
[ 1597.844471] 7986@C01L2,RTMP_COM_IoctlHandle() 1525: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DEINIT
[ 1597.852896] 7986@C08L1,UpdateBeaconHandler() 1908: wdev(0) bss not ready (state:0, caller:APStopByBss+0xec/0x498 [mt_wifi])!!
[ 1597.864186] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
[ 1597.870464] WiFi@C08L2,ap_link_down() 7170: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(0)
[ 1597.879605] 7986@C08L1,UpdateBeaconHandler() 1908: wdev(1) bss not ready (state:0, caller:APStopByBss+0xec/0x498 [mt_wifi])!!
[ 1597.891160] WiFi@C08L2,ap_link_down() 7170: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(1)
[ 1597.900346] ch_switch_monitor_exit:: Exit
[ 1597.909367] current sync CR = 0x7
[ 1597.912679] current sync CR = 0x7
[ 1597.916988] current sync CR = 0x7
[ 1597.921291] current sync CR = 0x7
[ 1597.925596] current sync CR = 0x1
[ 1598.029261] wdma_dma_ctrl(): WDMA_GLO_CFG=50804e75, txrx = 0
[ 1598.034913] wdma_dma_ctrl(): WDMA_GLO_CFG=40804e74, txrx = 0
[ 1598.040566] warp_woctrl_send_msg_and_wait_cr(), idx:0, state:DISABLE
[ 1598.046908] warp_woctrl_send_msg_and_wait_cr(): wait for wocpu
[ 1598.052726] [tmp]warp_woctrl_send_msg_and_wait_cr(): wait for wocpu, value:1, value_done:1
[ 1598.060970] warp_woctrl_send_msg_and_wait_cr(): wocpu is ready, done_value:1
[ 1598.068000] warp_woctrl_kickout(), idx: 0, state:HALT
[ 1598.073037] warp_woctrl_kickout(): wait for wocpu
[ 1598.077726] [tmp]warp_woctrl_kickout(): wait for wocpu, value:7, value_done:7
[ 1598.084842] warp_woctrl_kickout(): wocpu is ready, done_value:7
[ 1598.110427] wdma_dma_ctrl(): WDMA_GLO_CFG=40804e70, txrx = 0
[ 1598.119486] [Nop_List_Backup] NopList Channel count:0 <----
[ 1598.215694] wed_ser_task(): wed_ser exist, wed->irq=6!
[ 1598.227624] wo_exception_exit(0): wo_exception_exit done
[ 1598.232962] warp_msg_receive(),go,warp,703,0
[ 1598.237234] warp_msg_process(): module id(0), wed_idx(0), something wrong(ret = -1)
[ 1598.244887] warp_msg_unregister():done
[ 1598.248767] warp_client_remove(): warp entry clear done!!
[ 1598.254161] mtk_ppe_dev_unregister_hook : ineterface rax0 set null (64)
[ 1598.260941] br-lan: port 5(rax0) entered disabled state
[ 1598.304112] br-lan: port 1(eth0) entered disabled state
[ 1598.318097] device eth0 left promiscuous mode
[ 1598.322580] br-lan: port 1(eth0) entered disabled state
[ 1598.345057] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 1598.350945] device rax0 left promiscuous mode
[ 1598.355384] br-lan: port 5(rax0) entered disabled state
[ 1598.375871] device apclix0 left promiscuous mode
[ 1598.380537] br-lan: port 4(apclix0) entered disabled state
[ 1598.407825] device apcli0 left promiscuous mode
[ 1598.412391] br-lan: port 3(apcli0) entered disabled state
[ 1598.431816] device ra0 left promiscuous mode
[ 1598.436112] br-lan: port 2(ra0) entered disabled state
[ 1598.573742] br-wan: port 1(eth1) entered disabled state
[ 1598.587945] device eth1 left promiscuous mode
[ 1598.592403] br-wan: port 1(eth1) entered disabled state
[ 1598.612975] mtk_soc_eth 15100000.ethernet eth1: Link is Down
root@OpenWrt:/# [ 1599.707855] 7986@C12L1,rt28xx_ap_ioctl() 833: interface is down, cmd [8bee] return!!!
[ 1599.798558] 7986@C12L1,rt28xx_ap_ioctl() 833: interface is down, cmd [8bee] return!!!
[ 1599.829222] 7986@C12L1,rt28xx_ap_ioctl() 866: interface is down, cmd [8be2] return!!!
[ 1599.843265] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 1599.851799] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1599.852150] br-lan: port 1(eth0) entered blocking state
[ 1599.865647] br-lan: port 1(eth0) entered disabled state
[ 1599.871111] device eth0 entered promiscuous mode
[ 1599.878302] br-lan: port 1(eth0) entered blocking state
[ 1599.883560] br-lan: port 1(eth0) entered forwarding state
[ 1599.889444] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 1599.898699] mtk_soc_eth 15100000.ethernet eth1: configuring for fixed/2500base-x link mode
[ 1599.907489] br-wan: port 1(eth1) entered blocking state
[ 1599.911673] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
[ 1599.912745] br-wan: port 1(eth1) entered disabled state
[ 1599.926605] device eth1 entered promiscuous mode
[ 1599.933203] br-wan: port 1(eth1) entered blocking state
[ 1599.938461] br-wan: port 1(eth1) entered forwarding state
[ 1599.944238] 7986@C12L1,rt28xx_ap_ioctl() 866: interface is down, cmd [8be2] return!!!
[ 1600.023207] 7986@C01L2,RTMP_COM_IoctlHandle() 1514: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
[ 1600.031741] msta_ifname not found
[ 1600.035537] warp_cap_support(): chip_id=7986 is in WHNAT support list
[ 1600.042048] warp_entry_acquire(): bus slot:0, hook to WARP, entry id=0, entry: 00000000ec15d28c
[ 1600.050762] client_hif_specific_get(): hw->base_phy_addr 0x18000000!!
[ 1600.057340] warp_entry_get_by_pdev(): return entry[0]
[ 1600.062823] warp_msg_register():warp,pid,2932,id,0,wed_idx,0
[ 1600.068507] warp_dev19 15010000.wed: Using 32bit DMA for streaming map
[ 1600.075068] warp_dev19 15010000.wed: Using 32bit DMA for coherent map
[ 1600.081557] wed_init(0): res_start = 0x15010000, size = 1000, irq=6,base_addr=0xffffffc010dc6000
[ 1600.090864] wed_ring_init(): wed tx ring init result = 0
[ 1600.096830] wed_ring_init(): wed rx ring init result = 0
[ 1600.114561] create wed ok!!!
[ 1600.117544] wdma_init(): wdma(0) base_addr=0xffffffc010dc8800, base_phy_addr=0x15104800
[ 1600.126411] warp_woif_bus_init_hw(): bus:0000000042c77233, txring: 20, pa: 0x00000000b109c000, 0x00000000b109c000, 24, 28, 3c
[ 1600.137736] warp_woif_bus_init_hw(): bus:0000000042c77233, rxring: 50, pa: 0x00000000b408c000, 0x00000000b408c000, 54, 58, 6c
[ 1600.149106] get_region_info(): wed_idx = 0, base_addr = 0x000000008700b0d6, size = 0x40000, res.start = 0x4fd00000, shared:0
[ 1600.160351] get_region_info(): wed_idx = 0, base_addr = 0x00000000463828d3, size = 0x8000, res.start = 0x151e0000, shared:0
[ 1600.171540] get_region_info(): wed_idx = 0, base_addr = 0x00000000e4508144, size = 0x240000, res.start = 0x4fd80000, shared:1
[ 1600.182876] get_region_info(): wed_idx = 0, base_addr = 0x00000000fa505da4, size = 0x1000, res.start = 0x15194000, shared:0
[ 1600.194008] warp_fwdl_mcu_mode(): mcu mode, need fwdl
[ 1600.201807] ########## WO Firmware ##########
[ 1600.206200] Chip ID: 0x0000
[ 1600.209001] ECO version:0
[ 1600.211610] Version: DEV_000000
[ 1600.214765] Build date: 20221208175748
[ 1600.218519] Total region:3
[ 1600.221228] #################################
[ 1600.225597] Parsing tailer region 0
[ 1600.229087] Target address: 0x151e0000
[ 1600.232922] Download size: 20768
[ 1600.236261] Parsing tailer region 1
[ 1600.239754] Target address: 0x4fd00000
[ 1600.243575] Download size: 87584
[ 1600.247022] Parsing tailer region 2
[ 1600.250522] Target address: 0x4fd80000
[ 1600.254360] Download size: 2319824
[ 1600.258147] warp_fwdl_ready_check_mcu_mode(): waiting for wocpu
[ 1600.279071] warp_fwdl_ready_check_mcu_mode(): wocpu is ready
[ 1600.284750] warp_woctrl_init_state(), wo_state: WO_STATE_ENABLE
[ 1600.290698] wo_proc_init done 00000000b23b242c
[ 1600.295250] wo_exep_proc_init done 00000000b23b242c
[ 1600.300254] wo_exception_init(0): exp log= 0x0000000002c31fbb, phy_addr= 0x00000000b2198000 size= 32768
[ 1600.309798] warp_probe(): probe fail since warp is full!
[ 1600.315147] warp_dev19: probe of 15010000.wed2 failed with error -1
[ 1600.321610] 7986@C01L3,mt_wifi_open() 345: whnat_en=1
[ 1600.334356] 7986@C00L1,hc_init_ChCtrl() 2164: Skip Clear ChCtrl Band[0] (caller:UserCfgInit+0x710/0x1a18 [mt_wifi])
[ 1600.345213] 7986@C00L1,hc_init_ChCtrl() 2164: Skip Clear ChCtrl Band[1] (caller:UserCfgInit+0x710/0x1a18 [mt_wifi])
[ 1600.406420] 7986@C00L1,hc_init_ChCtrl() 2164: Skip Clear ChCtrl Band[0] (caller:RTMPSetProfileParameters+0x90/0x11498 [mt_wifi])
[ 1600.418231] 7986@C00L1,hc_init_ChCtrl() 2164: Skip Clear ChCtrl Band[1] (caller:RTMPSetProfileParameters+0x90/0x11498 [mt_wifi])
[ 1600.431387] 7986@C12L1,RTMPWirelessModeCfg() 610: Init: BSS0 PhyMode=78
[ 1600.438031] 7986@C12L1,RTMPWirelessModeCfg() 610: Init: BSS1 PhyMode=177
[ 1600.444942] 7986@C23L3,auto_ch_select_set_cfg() 3466: BandIdx0, AutoChannelAtBootup=0, AutoChannelAlg = 0
[ 1600.454528] 7986@C23L3,auto_ch_select_set_cfg() 3466: BandIdx1, AutoChannelAtBootup=0, AutoChannelAlg = 0
[ 1600.471978] 7986@C12L1,SCS_Enable_set_cfg() 734: SCSEnable [0]= 1
[ 1600.478086] 7986@C12L1,SCS_Enable_set_cfg() 734: SCSEnable [0]= 1
[ 1600.502802] 7986@C15L1,Set_PMFMFPC_Proc() 1722: [PMF] :: apidx=0, Desired MFPC=1
[ 1600.510209] 7986@C15L1,Set_PMFMFPC_Proc() 1722: [PMF] :: apidx=1, Desired MFPC=1
[ 1600.518873] 7986@C12L1,RTMPSetProfileParameters() 8646: ra0, QoSMgmtCapa=0
[ 1600.525765] 7986@C12L1,RTMPSetProfileParameters() 8646: rax0, QoSMgmtCapa=0
[ 1600.535449] 7986@C12L1,rtmp_read_ap_client_from_file() 1638: APCLI[0] ApCliMuMimoDlEnable = 0
[ 1600.543965] 7986@C12L1,rtmp_read_ap_client_from_file() 1638: APCLI[1] ApCliMuMimoDlEnable = 0
[ 1600.552575] 7986@C12L1,rtmp_read_ap_client_from_file() 1657: APCLI[0] ApCliMuMimoUlEnable = 0
[ 1600.561081] 7986@C12L1,rtmp_read_ap_client_from_file() 1657: APCLI[1] ApCliMuMimoUlEnable = 0
[ 1600.570732] 7986@C03L1,AndesSendCmdMsg() 754: Could not send in band command due to diablefRTMP_ADAPTER_MCU_SEND_IN_BAND_CMD
[ 1600.581927] 7986@C03L2,AndesSendCmdMsg() 765: Command type = ed, Extension command type = 48
[ 1600.590350] 7986@C03L1,AndesSendCmdMsg() 754: Could not send in band command due to diablefRTMP_ADAPTER_MCU_SEND_IN_BAND_CMD
[ 1600.601543] 7986@C03L2,AndesSendCmdMsg() 765: Command type = ed, Extension command type = 48
[ 1600.659723] wdma_dma_ctrl(): WDMA_GLO_CFG=40804e70, txrx = 0
[ 1600.671048] wdma_dma_ctrl(): WDMA_GLO_CFG=40804e70, txrx = 0
[ 1600.685744] warp_tx_ring_init_hw(): configure ring 0 setting
[ 1600.691419] warp_tx_ring_init_hw(): wed:00000000bb737e7c wifi:00000000d2239fc9: 24420=6d580000,24424=2048,24428=0
[ 1600.701669] warp_tx_ring_init_hw(): configure ring 1 setting
[ 1600.707315] warp_tx_ring_init_hw(): wed:00000000bb737e7c wifi:00000000d2239fc9: 24430=b2128000,24434=2048,24438=0
[ 1600.717668] set_rrocfg,0
[ 1600.743075] wdma_dma_ctrl(): WDMA_GLO_CFG=40804e74, txrx = 3
[ 1600.748735] sku:0x7, ADIE=MT7976
[ 1600.753082] using E1 ROM patch
[ 1600.756124] using E1 RAM
[ 1600.758646] current sync CR = 0x1
[ 1600.762060] Built date: 20221216134650a
[ 1600.765981] Platform: ALPS
[ 1600.768766] HW/SW version: 0x8a108a10
[ 1600.772504] Patch version: 0xffffffff
[ 1600.776423] current sync CR = 0x1
[ 1600.783777] Chip ID: 0x0f
[ 1600.786481] Eco version: 0x00
[ 1600.789531] Region number: 0x0b
[ 1600.792748] Format version: 0x02
[ 1600.796053] Format flag: 0x01
[ 1600.799092] Ram version: ____000000
[ 1600.802658] Built date: 20221216134711
[ 1600.806487] Common crc: 0xf62b0b61
[ 1600.809968] Release info: header tag = 0, total length = 80
[ 1600.815612] tag 1, padding length = 1, tag length = 75
[ 1600.820821] payload: t-neptune-main-2111-7986-imp-MT7986_E1_ASIC_ROM_RAM_REBB_IMP-20221216134601
[ 1600.848036] Chip ID: 0x00
[ 1600.850740] Eco version: 0x00
[ 1600.853795] Region number: 0x03
[ 1600.857012] Format version: 0x02
[ 1600.860316] Format flag: 0x01
[ 1600.863355] Ram version: DEV_000000
[ 1600.866921] Built date: 20221216134910
[ 1600.870755] Common crc: 0xd2876be7
[ 1600.874235] Release info: header tag = 0, total length = 0
[ 1600.974763] current sync CR = 0x7
[ 1600.978197] efuse_probe: efuse = deaddead
[ 1600.984257] sku:0x7, ADIE=MT7976
[ 1600.988623] Use default BIN from:/lib/firmware/MT7986_ePAeLNA_EEPROM_ONEADIE_DBDC.bin.
[ 1600.996736] 7986@C02L1,rtmp_ee_flash_init() 444: The EEPROM in Flash is wrong, use default
[ 1601.005019] sku:0x7, ADIE=MT7976
[ 1601.011029] 7986@C02L1,is_cal_free_ic() 1009: is_cal_free_ic(1009) offset:0, c,0
[ 1601.019250] sku:0x7, ADIE=MT7976
[ 1601.037617] 7986@C02L1,is_cal_free_ic() 1028: iCal free
[ 1601.043628] sku:0x7, ADIE=MT7976
[ 1604.112850] 7986@C17L1,RTMPReadTxPwrPerRate() 450: (450): Don't Support this now!
[ 1604.120360] 7986@C01L1,AntCfgInit() 3126: Not support for HIF_MT yet!
[ 1604.140745] ch_switch_monitor_state_machine_init:: enter
[ 1604.146054] ch_switch_monitor_cfg_reset:: enter
[ 1604.150577] ch_switch_monitor_cfg_reset:: enter
[ 1604.155405] 7986@C17L1,tx_pwr_comp_init() 641: NotSupportYet!
[ 1604.161171] 7986@C12L1,SCS_init() 880: INIT SCSEnable [0]= 1
[ 1604.166825] 7986@C12L1,SCS_init() 887: INIT SCSEnable [1]= 1
[ 1604.172570] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1604.178045] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1604.183472] WiFi@C14L1,IPMacTable_init() 348: IPMacTable already inited!
[ 1604.210276] wdma_dma_ctrl(): WDMA_GLO_CFG=50804e75, txrx = 3
[ 1604.216007] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1604.221514] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1604.226933] 7986@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[ 1604.236829] 7986@C00L1,set_datcfg_ack_cts_timeout() 13535: DAT config band(0) cck_timeout Fail!
[ 1604.245508] 7986@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[ 1604.255400] 7986@C00L1,set_datcfg_ack_cts_timeout() 13546: DAT config band(0) ofdm_timeout Fail!
[ 1604.264165] 7986@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[ 1604.274057] 7986@C00L1,set_datcfg_ack_cts_timeout() 13557: DAT config band(0) ofdma_timeout Fail!
[ 1604.282909] 7986@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[ 1604.292800] 7986@C00L1,set_datcfg_ack_cts_timeout() 13535: DAT config band(1) cck_timeout Fail!
[ 1604.301478] 7986@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[ 1604.311369] 7986@C00L1,set_datcfg_ack_cts_timeout() 13546: DAT config band(1) ofdm_timeout Fail!
[ 1604.320135] 7986@C00L1,set_ack_timeout_mode_byband() 13447: CTS/ACK Timeout Range should between [0xFFFF:0]!!
[ 1604.330025] 7986@C00L1,set_datcfg_ack_cts_timeout() 13557: DAT config band(1) ofdma_timeout Fail!
[ 1604.539264] :(op = 1)
[ 1604.546339] 7986@C00L1,FastPathCheckMIC() 1010: (ret = 0)(op:1)
[ 1604.552266] 7986@C00L2,red_tail_drop_init() 83: red_tail_drop_init: available token:8192, whnat_en:1
[ 1604.561419] 7986@C00L1,MtCmdCr4RedSet() 914: MtCmdCr4RedSet: (ret = 0)
[ 1604.567938] 7986@C00L1,SendRedCmd() 1049: SendRedCmd:(ret = 1)
[ 1604.573825] 7986@C01L2,RTMP_COM_IoctlHandle() 1491: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
[ 1604.581818] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 0
[ 1604.587354] 7986@C18L3,BuildChannelList() 484:
[ 1604.591898] 7986@C23L3,RadarStateCheck() 250: Zero Wait State: 0
[ 1604.597892] 7986@C23L3,DfsRadarChannelCheck() 3228: [DfsRadarChannelCheck]: wdev is not 5G
[ 1604.606158] 7986@C23L3,operate_loader_phy() 360: oper_cfg: prim_ch(6), ht_bw(1), extcha(1), vht_bw(0), cen_ch_2(0), PhyMode=78!
[ 1604.617619] 7986@C23L3,operate_loader_phy() 374: oper_dev after adjust: bw(1), prim_ch(6), cen_ch_1(8), cen_ch_2(0),ext_cha(1)!
[ 1604.629073] 7986@C23L3,operate_loader_phy() 393: oper_dev after decision: bw(1), prim_ch(6), cen_ch_1(8), cen_ch_2(0)!
[ 1604.639745] 7986@C23L3,DfsRadarChannelCheck() 3228: [DfsRadarChannelCheck]: wdev is not 5G
[ 1604.647996] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:1 vht_bw:0 bw:1 extcha:1
[ 1604.658495] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:6 cench1:8 cench2:0 rxstream:2 ap_bw:0 apCenCh:0 Scan:0
[ 1604.670208] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1604.679330] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=6, ctrl_ch2=0, cent_ch=8 DBDCIdx=0, ChBand=0, BW=1, TXStream=2, RXStream=2, scan(0)
[ 1604.836297] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=6, ctrl_ch2=0, cent_ch=8, RxPath=3, BandIdx=0, ChBand=0, BW=1,TXStream=2, RXStream=3, scan(0)
[ 1604.849857] 7986@C12L1,EDCCAInit() 21068: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
[ 1604.860808] 7986@C23L3,DfsCacNormalStart() 3716: wdev is not 5G
[ 1604.866716] 7986@C23L3,DfsRadarChannelCheck() 3228: [DfsRadarChannelCheck]: wdev is not 5G
[ 1604.875178] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xa4/0x148 [mt_wifi]
[ 1604.883170] wdev_attr_update(): wdevId0 = 00:0c:43:26:60:60
[ 1604.888744] WiFi@C12L1,wifi_sys_open() 907: wifi_sys_open():band0 group_idx[0]=0, bw_grp=16 omac=0
[ 1604.897708] 7986@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=0
[ 1604.903513] 7986@C02L2,AsicRadioOnOffCtrl() 2355: DbdcIdx=0 RadioOn
[ 1604.910339] 7986@C00L2,ApAutoChannelAtBootUp() 333: ----------------->
[ 1604.916944] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1604.922418] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1604.927807] 7986@C00L1,ApAutoChannelAtBootUp() 498: not A band
[ 1604.933628] 7986@C08L1,ap_run_at_boot() 624: ACS is disable !!
[ 1604.940414] 7986@C08L2,APStartUpForMbss() 984: ===>(caller:ap_inf_open+0x158/0x560 [mt_wifi]), mbss_idx:0, CfgMode:0
[ 1604.950933] 7986@C15L2,APPMFInit() 121: [PMF] Security is not WPA2/WPA2PSK AES
[ 1604.958147] 7986@C15L2,APPMFInit() 133: [PMF] apidx=0, MFPC=0, MFPR=0, SHA256=0
[ 1604.965446] 7986@C18L3,BuildChannelList() 484:
[ 1604.970165] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
[ 1604.977692] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1604.983086] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1604.993585] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:2 cench1:2 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1605.005272] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1605.014391] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=2, ctrl_ch2=0, cent_ch=2 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1605.063713] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=2, ctrl_ch2=0, cent_ch=2, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1605.077387] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1605.411784] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1605.417171] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1605.427674] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:3 cench1:3 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1605.439326] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1605.448450] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=3, ctrl_ch2=0, cent_ch=3 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1605.496800] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=3, ctrl_ch2=0, cent_ch=3, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1605.510471] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1605.827796] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1605.833190] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1605.843698] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:4 cench1:4 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1605.855374] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1605.864495] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=4, ctrl_ch2=0, cent_ch=4 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1605.912826] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=4, ctrl_ch2=0, cent_ch=4, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1605.926497] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1606.243790] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1606.249185] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1606.259691] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:5 cench1:5 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1606.271364] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1606.280486] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=5, ctrl_ch2=0, cent_ch=5 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1606.328813] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=5, ctrl_ch2=0, cent_ch=5, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1606.342483] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1606.659786] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1606.665173] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1606.675674] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:6 cench1:6 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1606.687654] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1606.696780] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=6, ctrl_ch2=0, cent_ch=6 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1606.745125] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=6, ctrl_ch2=0, cent_ch=6, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1606.758796] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1607.075783] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1607.081171] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1607.091672] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:7 cench1:7 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1607.103345] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1607.112464] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=7, ctrl_ch2=0, cent_ch=7 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1607.160807] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=7, ctrl_ch2=0, cent_ch=7, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1607.174480] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1607.491783] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1607.497169] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1607.507671] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:8 cench1:8 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1607.519412] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1607.528532] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=8, ctrl_ch2=0, cent_ch=8 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1607.576881] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=8, ctrl_ch2=0, cent_ch=8, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1607.590552] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1607.907785] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1607.913173] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1607.923675] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:9 cench1:9 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1607.935338] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1607.944458] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=9, ctrl_ch2=0, cent_ch=9 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1607.992790] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=9, ctrl_ch2=0, cent_ch=9, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1608.006494] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1608.323784] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1608.329174] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1608.339675] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:10 cench1:10 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1608.351518] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1608.360640] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=10, ctrl_ch2=0, cent_ch=10 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1608.409163] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=10, ctrl_ch2=0, cent_ch=10, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1608.423007] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1608.739784] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1608.745171] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:0 vht_bw:0 bw:0 extcha:0
[ 1608.755673] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:11 cench1:11 cench2:0 rxstream:0 ap_bw:0 apCenCh:0 Scan:1
[ 1608.767812] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1608.776940] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=11, ctrl_ch2=0, cent_ch=11 DBDCIdx=0, ChBand=0, BW=0, TXStream=2, RXStream=2, scan(1)
[ 1608.825454] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=11, ctrl_ch2=0, cent_ch=11, RxPath=3, BandIdx=0, ChBand=0, BW=0,TXStream=2, RXStream=3, scan(1)
[ 1608.839298] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1609.155705] 7986@C23L3,operate_loader_phy() 360: oper_cfg: prim_ch(6), ht_bw(1), extcha(1), vht_bw(0), cen_ch_2(0), PhyMode=78!
[ 1609.167164] 7986@C23L3,operate_loader_phy() 374: oper_dev after adjust: bw(1), prim_ch(6), cen_ch_1(8), cen_ch_2(0),ext_cha(1)!
[ 1609.178619] 7986@C23L3,operate_loader_phy() 393: oper_dev after decision: bw(1), prim_ch(6), cen_ch_1(8), cen_ch_2(0)!
[ 1609.189295] 7986@C23L3,DfsRadarChannelCheck() 3228: [DfsRadarChannelCheck]: wdev is not 5G
[ 1609.197543] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:0 ch_band:0 htbw:1 vht_bw:0 bw:1 extcha:1
[ 1609.208043] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:6 cench1:8 cench2:0 rxstream:2 ap_bw:0 apCenCh:0 Scan:0
[ 1609.219728] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1609.228845] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=6, ctrl_ch2=0, cent_ch=8 DBDCIdx=0, ChBand=0, BW=1, TXStream=2, RXStream=2, scan(0)
[ 1609.380658] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=6, ctrl_ch2=0, cent_ch=8, RxPath=3, BandIdx=0, ChBand=0, BW=1,TXStream=2, RXStream=3, scan(0)
[ 1609.394232] 7986@C12L1,EDCCAInit() 21068: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
[ 1609.405197] 7986@C23L3,DfsCacNormalStart() 3716: wdev is not 5G
[ 1609.411107] 7986@C23L3,DfsRadarChannelCheck() 3228: [DfsRadarChannelCheck]: wdev is not 5G
[ 1609.419589] WiFi@C08L2,ap_link_up() 7152: (caller:wdev_do_linkup+0x20/0x38 [mt_wifi]), wdev(0)
[ 1609.428191] 7986@C01L3,wifi_sys_linkup() 1231: wdev idx = 0
[ 1609.433913] 7986@C00L3,wtc_acquire_groupkey_wcid() 84: Found a non-occupied wtbl_idx:543 for WDEV_TYPE:1
[ 1609.433913] LinkToOmacIdx = 0, LinkToWdevType = 1
[ 1609.448260] 7986@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=0
[ 1609.460978] 7986@C08L3,UpdateBeaconHandler() 1928: BCN_UPDATE_INIT, OmacIdx = 0 (ra0)
[ 1609.468791] 7986@C08L2,bcn_buf_init() 170: BcnPkt is allocated!, bcn offload=1
[ 1609.475998] 7986@C08L3,UpdateBeaconHandler() 1941: Band0 BcnInitedRnd = 46
[ 1609.482980] 7986@C00L1,TxCCKStreamCtrl() 20530: set wrong parameters
[ 1609.497809] PrintSrCmd:
[ 1609.497809] u1CmdSubId = 1, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
[ 1609.497809] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
[ 1609.511784] PrintSrCmd:
[ 1609.511784] u1CmdSubId = 5, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
[ 1609.511784] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
[ 1609.525755] PrintSrCmd:
[ 1609.525755] u1CmdSubId = 3, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
[ 1609.525755] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
[ 1609.539724] PrintSrCmd:
[ 1609.539724] u1CmdSubId = 23, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
[ 1609.539724] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
[ 1609.553781] PrintSrCmd:
[ 1609.553781] u1CmdSubId = 31, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
[ 1609.553781] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
[ 1609.567836] PrintSrCmd:
[ 1609.567836] u1CmdSubId = 33, u1ArgNum = 0, u1DbdcIdx = 0, u1Status = 0
[ 1609.567836] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
[ 1609.581902] 7986@C12L1,EDCCAInit() 21068: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
[ 1609.592841] 7986@C03L3,MtCmdTxPwrShowInfo() 13748: ucTxPowerInfoCatg: 2, BandIdx: 0
[ 1609.600572] 7986@C03L3,MtCmdTxPwrShowInfo() 13777: (ret = 0)
[ 1609.600666] [mtf_txpower_all_rate_info] band_idx:0 pwr:47 ChBand:2G ePAGain:0
[ 1609.606235] extif_set_dev(ra0)
[ 1609.616366] mtk_ppe_dev_register_hook : ineterface ra0 register (1)
[ 1609.626545] Mac: 02:0c:43:36:60:10 was aleady existed.
[ 1609.627282] br-lan: port 2(ra0) entered blocking state
[ 1609.631770] Mac: 00:0c:43:26:60:60 was aleady existed.
[ 1609.636887] br-lan: port 2(ra0) entered disabled state
[ 1609.637106] device ra0 entered promiscuous mode
[ 1609.651874] br-lan: port 2(ra0) entered blocking state
[ 1609.657030] br-lan: port 2(ra0) entered forwarding state
[ 1609.684366] br-lan: port 3(apcli0) entered blocking state
[ 1609.689801] br-lan: port 3(apcli0) entered disabled state
[ 1609.695505] device apcli0 entered promiscuous mode
[ 1609.713624] br-lan: port 4(apclix0) entered blocking state
[ 1609.719177] br-lan: port 4(apclix0) entered disabled state
[ 1609.724932] device apclix0 entered promiscuous mode
[ 1609.755111] 7986@C08L2,mbss_virtual_if_open() 134: ===> rax0
[ 1609.761027] 7986@C01L2,RTMP_COM_IoctlHandle() 1514: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
[ 1609.769156] 7986@C01L2,RTMP_COM_IoctlHandle() 1491: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
[ 1609.777190] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 1
[ 1609.782875] 7986@C18L3,BuildChannelList() 484:
[ 1609.787538] 7986@C23L3,RadarStateCheck() 250: Zero Wait State: 0
[ 1609.793576] 7986@C23L3,RadarStateCheck() 277: RD_SILENCE_MODE
[ 1609.800461] 7986@C23L3,operate_loader_phy() 360: oper_cfg: prim_ch(36), ht_bw(1), extcha(1), vht_bw(2), cen_ch_2(0), PhyMode=177!
[ 1609.812107] 7986@C23L3,operate_loader_phy() 374: oper_dev after adjust: bw(3), prim_ch(36), cen_ch_1(50), cen_ch_2(0),ext_cha(1)!
[ 1609.823757] 7986@C23L3,operate_loader_phy() 393: oper_dev after decision: bw(3), prim_ch(36), cen_ch_1(50), cen_ch_2(0)!
[ 1609.834615] 7986@C23L3,DfsCacNormalStart() 3750: [RDM] CAC 65 seconds start . Disable MAC TX
[ 1609.843063] 7986@C08L1,AsicSwitchChannel() 334: AsicSwitchChannel::bandIdx:1 ch_band:1 htbw:1 vht_bw:2 bw:3 extcha:1
[ 1609.853573] BcnCheck start after 4600 ms (ra0)
[ 1609.858373] 7986@C08L1,AsicSwitchChannel() 339: AsicSwitchChannel::primch:36 cench1:50 cench2:0 rxstream:3 ap_bw:0 apCenCh:0 Scan:0
[ 1609.870174] 7986@C23L3,DfsSwitchCheck() 4040: DFS ByPass TX calibration.
[ 1609.876927] 7986@C00L1,mt7986_apply_dpd_flatness_data() 622: eeprom 0x19a bit 0 is 0, do runtime cal
[ 1609.886062] 7986@C03L3,MtCmdChannelSwitch() 2539: ctrl_chl=36, ctrl_ch2=0, cent_ch=50 DBDCIdx=1, ChBand=1, BW=3, TXStream=3, RXStream=3, scan(0)
[ 1609.955459] 7986@C03L3,MtCmdSetTxRxPath() 2799: ctrl_chl=36, ctrl_ch2=0, cent_ch=50, RxPath=7, BandIdx=1, ChBand=1, BW=3,TXStream=3, RXStream=7, scan(0)
[ 1609.974140] 7986@C12L1,EDCCAInit() 21068: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
[ 1609.985325] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xa4/0x148 [mt_wifi]
[ 1609.993324] wdev_attr_update(): wdevId1 = 02:0c:43:36:60:60
[ 1609.998898] WiFi@C12L1,wifi_sys_open() 907: wifi_sys_open():band1 group_idx[1]=4, bw_grp=16 omac=0
[ 1610.007857] 7986@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=1
[ 1610.014668] 7986@C02L2,AsicRadioOnOffCtrl() 2355: DbdcIdx=1 RadioOn
[ 1610.021457] 7986@C00L2,ApAutoChannelAtBootUp() 333: ----------------->
[ 1610.028063] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1610.033537] 7986@C03L1,MtCmdSetMacTxRx() 10244: (ret = 0)
[ 1610.038924] 7986@C00L1,ApAutoChannelAtBootUp() 492: zero-wait DFS is not enabled
[ 1610.046303] 7986@C08L1,ap_run_at_boot() 624: ACS is disable !!
[ 1610.053092] 7986@C08L2,APStartUpForMbss() 984: ===>(caller:ap_inf_open+0x158/0x560 [mt_wifi]), mbss_idx:1, CfgMode:0
[ 1610.063607] 7986@C15L2,APPMFInit() 121: [PMF] Security is not WPA2/WPA2PSK AES
[ 1610.070817] 7986@C15L2,APPMFInit() 133: [PMF] apidx=1, MFPC=0, MFPR=0, SHA256=0
[ 1610.078115] 7986@C18L3,BuildChannelList() 484:
[ 1610.082807] WiFi@C00L2,dump_ht_cap() 29: Caller: dump_ht_cap+0x10/0x20 [mt_wifi]
[ 1610.090316] WiFi@C08L2,ap_link_up() 7152: (caller:wdev_do_linkup+0x20/0x38 [mt_wifi]), wdev(1)
[ 1610.098925] 7986@C01L3,wifi_sys_linkup() 1231: wdev idx = 1
[ 1610.104602] 7986@C00L3,wtc_acquire_groupkey_wcid() 84: Found a non-occupied wtbl_idx:542 for WDEV_TYPE:1
[ 1610.104602] LinkToOmacIdx = 0, LinkToWdevType = 1
[ 1610.118944] 7986@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=1
[ 1610.131584] 7986@C08L3,UpdateBeaconHandler() 1928: BCN_UPDATE_INIT, OmacIdx = 0 (rax0)
[ 1610.139485] 7986@C08L2,bcn_buf_init() 170: BcnPkt is allocated!, bcn offload=1
[ 1610.146691] 7986@C08L3,UpdateBeaconHandler() 1941: Band1 BcnInitedRnd = 52
[ 1610.164822] PrintSrCmd:
[ 1610.164822] u1CmdSubId = 1, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
[ 1610.164822] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
[ 1610.178795] PrintSrCmd:
[ 1610.178795] u1CmdSubId = 5, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
[ 1610.178795] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
[ 1610.192767] PrintSrCmd:
[ 1610.192767] u1CmdSubId = 3, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
[ 1610.192767] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 1
[ 1610.206741] PrintSrCmd:
[ 1610.206741] u1CmdSubId = 23, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
[ 1610.206741] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
[ 1610.220799] PrintSrCmd:
[ 1610.220799] u1CmdSubId = 31, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
[ 1610.220799] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
[ 1610.234854] PrintSrCmd:
[ 1610.234854] u1CmdSubId = 33, u1ArgNum = 0, u1DbdcIdx = 1, u1Status = 0
[ 1610.234854] u1DropTaIdx = 0, u1StaIdx = 0, u4Value = 0
[ 1610.248920] 7986@C12L1,EDCCAInit() 21068: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
[ 1610.259858] 7986@C03L3,MtCmdTxPwrShowInfo() 13748: ucTxPowerInfoCatg: 2, BandIdx: 1
[ 1610.267590] 7986@C03L3,MtCmdTxPwrShowInfo() 13777: (ret = 0)
[ 1610.267684] [mtf_txpower_all_rate_info] band_idx:1 pwr:45 ChBand:5G ePAGain:0
[ 1610.273252] extif_set_dev(rax0)
[ 1610.283467] mtk_ppe_dev_register_hook : ineterface rax0 register (2)
[ 1610.295410] br-lan: port 5(rax0) entered blocking state
[ 1610.300645] br-lan: port 5(rax0) entered disabled state
[ 1610.306084] device rax0 entered promiscuous mode
[ 1610.310782] br-lan: port 5(rax0) entered blocking state
[ 1610.315998] br-lan: port 5(rax0) entered forwarding state
[ 1610.579955] -->update_qos_map()
[ 1612.491700] BcnCheck start after 2100 ms (ra0)
[ 1612.661661] 7986@C12L1,rt28xx_ap_ioctl() 833: interface is down, cmd [8be1] return!!!
[ 1612.669913] 7986@C12L1,rt28xx_ap_ioctl() 833: interface is down, cmd [8be1] return!!!
[ 1612.679168] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:8
[ 1612.685522] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:0
[ 1612.691732] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:1
[ 1612.697852] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:2
[ 1612.704036] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:3
[ 1612.800825] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:8
[ 1612.806936] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:0
[ 1612.813035] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:1
[ 1612.819138] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:2
[ 1612.825234] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:3
[ 1612.831352] 7986@C12L1,Set_AP_VENDOR_SPECIFIC_IE() 3776: Unknown OUIType = 16
[ 1612.838489] 7986@C12L1,Set_AP_VENDOR_SPECIFIC_IE() 3776: Unknown OUIType = 9
[ 1612.845557] 7986@C12L1,set_wapp_cmm_ie() 3672: Unknown IE(EID = 111)
[ 1612.851915] 7986@C12L1,set_wapp_cmm_ie() 3672: Unknown IE(EID = 110)
[ 1612.858273] 7986@C12L1,Set_AP_VENDOR_SPECIFIC_IE() 3776: Unknown OUIType = 16
[ 1612.865408] 7986@C12L1,Set_AP_VENDOR_SPECIFIC_IE() 3776: Unknown OUIType = 9
[ 1612.872472] 7986@C12L1,set_wapp_cmm_ie() 3672: Unknown IE(EID = 111)
[ 1612.878829] 7986@C12L1,set_wapp_cmm_ie() 3672: Unknown IE(EID = 110)
[ 1612.889331] Set_Fh_Bss_Proc ra0 wdev->MAPCfg.DevOwnRole 0x0
[ 1612.896303] Set_Fh_Bss_Proc ra0 wdev->MAPCfg.DevOwnRole 0x20
[ 1612.904160] Set_Fh_Bss_Proc rax0 wdev->MAPCfg.DevOwnRole 0x0
[ 1612.911164] Set_Fh_Bss_Proc rax0 wdev->MAPCfg.DevOwnRole 0x20
[ 1615.610755] mt753x-nl: failed to find switch dev
[ 1615.615433] mt753x-nl: failed to find switch dev
[ 1615.816524] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 1615.822432] br-lan: port 1(eth0) entered disabled state
[ 1615.832951] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 1615.841301] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1615.850061] br-lan: port 1(eth0) entered blocking state
[ 1615.855327] br-lan: port 1(eth0) entered forwarding state
[ 1615.888874] Set_MapR2_Proc MAP R2 is already disabled
[ 1615.894847] Set_MapTS_Proc MAP TS is already disabled
[ 1615.903033] Set_MapR2_Proc MAP R2 is already disabled
[ 1615.909054] Set_MapTS_Proc MAP TS is already disabled
[ 1615.919195] Set_Enable_Dpp_Proc DPP is already disabled
[ 1615.925454] Set_MapTS_Proc MAP TS is already disabled
[ 1615.934512] Set_Enable_Dpp_Proc DPP is already disabled
[ 1615.940731] Set_MapTS_Proc MAP TS is already disabled
[ 1615.974907] Set_Map_Proc current MAP MODE is 0
[ 1615.982480] Set_Map_Proc current MAP MODE is 0
[ 1615.995035] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 1616.000895] br-lan: port 1(eth0) entered disabled state
[ 1616.010184] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 1616.018521] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1616.018606] br-lan: port 1(eth0) entered blocking state
[ 1616.032327] br-lan: port 1(eth0) entered forwarding state
[ 1616.136408] -->update_qos_map()
[ 1618.176047] 7986@C12L1,rt28xx_ap_ioctl() 833: interface is down, cmd [8be1] return!!!
[ 1618.184095] 7986@C12L1,rt28xx_ap_ioctl() 833: interface is down, cmd [8be1] return!!!
[ 1618.193206] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:8
[ 1618.199435] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:0
[ 1618.205617] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:1
[ 1618.211753] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:2
[ 1618.217895] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:3
[ 1618.314868] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:8
[ 1618.320984] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:0
[ 1618.327076] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:1
[ 1618.333164] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:2
[ 1618.339247] 7986@C14L1,set_wapp_param() 3528: Unknown Parameter:3
[ 1618.345358] 7986@C12L1,Set_AP_VENDOR_SPECIFIC_IE() 3776: Unknown OUIType = 16
[ 1618.352483] 7986@C12L1,Set_AP_VENDOR_SPECIFIC_IE() 3776: Unknown OUIType = 9
[ 1618.359539] 7986@C12L1,set_wapp_cmm_ie() 3672: Unknown IE(EID = 111)
[ 1618.365889] 7986@C12L1,set_wapp_cmm_ie() 3672: Unknown IE(EID = 110)
[ 1618.372236] 7986@C12L1,Set_AP_VENDOR_SPECIFIC_IE() 3776: Unknown OUIType = 16
[ 1618.379359] 7986@C12L1,Set_AP_VENDOR_SPECIFIC_IE() 3776: Unknown OUIType = 9
[ 1618.386408] 7986@C12L1,set_wapp_cmm_ie() 3672: Unknown IE(EID = 111)
[ 1618.392755] 7986@C12L1,set_wapp_cmm_ie() 3672: Unknown IE(EID = 110)
[ 1618.402988] Set_Fh_Bss_Proc ra0 wdev->MAPCfg.DevOwnRole 0x0
[ 1618.410130] Set_Fh_Bss_Proc ra0 wdev->MAPCfg.DevOwnRole 0x20
[ 1618.417861] Set_Fh_Bss_Proc rax0 wdev->MAPCfg.DevOwnRole 0x0
[ 1618.424862] Set_Fh_Bss_Proc rax0 wdev->MAPCfg.DevOwnRole 0x20
[ 1678.547943] 7986@C23L3,DfsCacEndUpdate() 3309: [RDM] CAC end. Enable MAC TX.
[ 1678.554999] 7986@C12L1,EDCCAInit() 21068: EDCCA compensation: uni_compensation=0, bw_compensation=0, final compensation=0
root@OpenWrt:/#
