To modify the i2c speed of the sfp, i must add a ligne with clock-frequency to the sfp,isn’t it?
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.0-rc1-diagbox (root@workstation) (aarch64-linux-gnu-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #2 SMP Fri Nov 11 23:30:40 CET 2022
[ 0.000000] Machine model: Bananapi BPI-R3 (sdmmc)
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000011002000 (options '')
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'wmcpu-reserved@4fc00000': base 0x000000004fc00000, size 1 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
[ 0.000000] node 0: [mem 0x0000000043030000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 27 pages/cpu s71144 r8192 d31256 u110592
[ 0.000000] pcpu-alloc: s71144 r8192 d31256 u110592 alloc=27*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: board=DiagBox earlycon=uart8250,mmio32,0x11002000 debug=7 initrd=0x48000000,550M
[ 0.000000] Unknown kernel command line parameters "board=DiagBox", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Memory: 1469168K/2097152K available (13376K kernel code, 2194K rwdata, 3828K rodata, 4032K init, 421K bss, 627984K reserved, 0K cma-reserved)
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 640 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.008281] Console: colour dummy device 80x25
[ 0.012744] printk: console [tty0] enabled
[ 0.016858] printk: bootconsole [uart8250] disabled
[ 0.021785] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.021798] pid_max: default: 32768 minimum: 301
[ 0.021891] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.021906] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.022481] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.022778] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.022789] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.022886] rcu: Hierarchical SRCU implementation.
[ 0.022891] rcu: Max phase no-delay instances is 1000.
[ 0.023337] EFI services will not be available.
[ 0.023492] smp: Bringing up secondary CPUs ...
[ 0.023808] Detected VIPT I-cache on CPU1
[ 0.023861] cacheinfo: Unable to detect cache hierarchy for CPU 1
[ 0.023869] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.023902] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.024234] Detected VIPT I-cache on CPU2
[ 0.024271] cacheinfo: Unable to detect cache hierarchy for CPU 2
[ 0.024276] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.024291] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.024563] Detected VIPT I-cache on CPU3
[ 0.024596] cacheinfo: Unable to detect cache hierarchy for CPU 3
[ 0.024601] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.024612] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.024647] smp: Brought up 1 node, 4 CPUs
[ 0.024696] SMP: Total of 4 processors activated.
[ 0.024703] CPU features: detected: 32-bit EL0 Support
[ 0.024709] CPU features: detected: CRC32 instructions
[ 0.024750] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.024760] CPU: All CPU(s) started at EL2
[ 0.024765] alternatives: applying system-wide alternatives
[ 0.026549] devtmpfs: initialized
[ 0.028663] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.028695] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.028808] pinctrl core: initialized pinctrl subsystem
[ 0.029108] DMI not present or invalid.
[ 0.029518] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.029805] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.029840] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.029875] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.030283] thermal_sys: Registered thermal governor 'fair_share'
[ 0.030286] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.030293] thermal_sys: Registered thermal governor 'step_wise'
[ 0.030299] thermal_sys: Registered thermal governor 'user_space'
[ 0.030383] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.030446] ASID allocator initialised with 65536 entries
[ 0.042250] cryptd: max_cpu_qlen set to 1000
[ 0.043323] iommu: Default domain type: Translated
[ 0.043348] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.043479] SCSI subsystem initialized
[ 0.043599] libata version 3.00 loaded.
[ 0.043698] usbcore: registered new interface driver usbfs
[ 0.043723] usbcore: registered new interface driver hub
[ 0.043746] usbcore: registered new device driver usb
[ 0.043981] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
[ 0.044100] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
[ 0.044146] pps_core: LinuxPPS API ver. 1 registered
[ 0.044153] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.044167] PTP clock support registered
[ 0.045063] vgaarb: loaded
[ 0.065282] clocksource: Switched to clocksource arch_sys_counter
[ 0.069390] NET: Registered PF_INET protocol family
[ 0.069592] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.070659] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.070710] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.070725] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.070800] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.071204] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.071329] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.071376] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.071534] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.072247] PCI: CLS 0 bytes, default 64
[ 0.072425] Unpacking initramfs...
[ 0.084327] Initialise system trusted keyrings
[ 0.084465] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.087613] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.087701] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.110634] Key type asymmetric registered
[ 0.110670] Asymmetric key parser 'x509' registered
[ 0.110761] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.110772] io scheduler mq-deadline registered
[ 0.110779] io scheduler kyber registered
[ 0.143070] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.164752] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 2500000) is a ST16650V2
[ 0.993604] printk: console [ttyS0] enabled
[ 1.019009] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 117, base_baud = 1625000) is a ST16650V2
[ 1.049535] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 118, base_baud = 1625000) is a ST16650V2
[ 1.059801] mtk_rng 1020f000.rng: registered RNG driver
[ 1.065537] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.075342] loop: module loaded
[ 1.080366] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.085721] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 2.610714] Initramfs unpacking failed: invalid magic at start of compressed archive
[ 2.814828] Freeing initrd memory: 563200K
[ 2.831788] 4 fixed-partitions partitions found on MTD device spi0.0
[ 2.838195] Creating 4 MTD partitions on "spi0.0":
[ 2.842984] 0x000000580000-0x000008000000 : "ubi"
[ 2.984497] 0x000000380000-0x000000580000 : "fip"
[ 2.991967] 0x000000080000-0x000000380000 : "reserved"
[ 3.001262] 0x000000000000-0x000000080000 : "bl2"
[ 3.008516] sfp sfp-1: Host maximum power 3.0W
[ 3.013502] sfp sfp-2: Host maximum power 3.0W
[ 3.032080] mtk_soc_eth 15100000.ethernet: generated random MAC address 2e:b9:81:a0:0c:51
[ 3.040607] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc00b380000, irq 121
[ 3.050005] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc00b380000, irq 121
[ 3.059562] usbcore: registered new interface driver usb-storage
[ 3.065795] i2c_dev: i2c /dev entries driver
[ 3.072178] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 3.080909] SMCCC: SOC_ID: ID = jep106:0426:7986 Revision = 0x00000000
[ 3.087598] usbcore: registered new interface driver usbhid
[ 3.093172] usbhid: USB HID core driver
[ 3.097994] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[ 3.104564] NET: Registered PF_INET6 protocol family
[ 3.126667] Segment Routing with IPv6
[ 3.130342] RPL Segment Routing with IPv6
[ 3.134374] In-situ OAM (IOAM) with IPv6
[ 3.138419] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.144047] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.144720] NET: Registered PF_PACKET protocol family
[ 3.156174] mmc0: new high speed SDHC card at address aaaa
[ 3.157433] Bridge firewalling registered
[ 3.163722] mmcblk0: mmc0:aaaa SA16G 14.8 GiB
[ 3.167037] 8021q: 802.1Q VLAN Support v1.8
[ 3.175521] Key type dns_resolver registered
[ 3.177532] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 3.180088] Loading compiled-in X.509 certificates
[ 3.187165] GPT:1 != 31116287
[ 3.187168] GPT:Alternate GPT header not at the end of the disk.
[ 3.200683] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 3.200959] GPT:1 != 31116287
[ 3.208268] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 3.211134] GPT: Use GNU Parted to correct GPT errors.
[ 3.217391] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 3.222528] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 3.345099] sfp sfp-1: module RAD Data Comm. SFP-30H rev 1.0 sn OP18060400248 dc 180604
[ 3.445282] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.active (0x1000001)
[ 3.454685] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 3.479661] mt7530 mdio-bus:1f: no interrupt support
[ 3.513846] mt7530 mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 3.521017] mt7530 mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 3.530216] mt7530 mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.550358] mt7530 mdio-bus:1f lan0 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.570300] mt7530 mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.590220] mt7530 mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.610159] mt7530 mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 3.621104] device eth0 entered promiscuous mode
[ 3.625779] DSA: tree 0 setup
[ 3.630171] xhci-mtk 11200000.usb: xHCI Host Controller
[ 3.635426] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 3.645814] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 3.654971] xhci-mtk 11200000.usb: irq 127, io mem 0x11200000
[ 3.660808] xhci-mtk 11200000.usb: xHCI Host Controller
[ 3.666029] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 3.673414] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 3.680936] hub 1-0:1.0: USB hub found
[ 3.684704] hub 1-0:1.0: 2 ports detected
[ 3.689090] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.697571] hub 2-0:1.0: USB hub found
[ 3.701346] hub 2-0:1.0: 1 port detected
[ 3.706428] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.722415] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.732576] Freeing unused kernel memory: 4032K
[ 3.815323] Run /init as init process
[ 3.818987] with arguments:
[ 3.821944] /init
[ 3.824205] with environment:
[ 3.827341] HOME=/
[ 3.829689] TERM=linux
[ 3.832383] board=DiagBox
[ 3.927976] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 3.951531] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Quota mode: disabled.
[ 3.973324] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Quota mode: disabled.
[ 4.050760] udevd[1108]: starting version 3.2.9
[ 4.165280] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 4.345989] hub 1-1:1.0: USB hub found
[ 4.349807] hub 1-1:1.0: 4 ports detected
[ 4.765275] usb 1-1.1: new high-speed USB device number 3 using xhci-mtk
[ 11.365550] random: crng init done
[ 11.377402] udevd[1123]: starting eudev-3.2.9
[ 11.407299] usbcore: registered new interface driver usbserial_generic
[ 11.415954] usbserial: USB Serial support registered for generic
[ 11.436352] usbcore: registered new interface driver cdc_wdm
[ 11.444296] usbcore: registered new interface driver option
[ 11.450118] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
[ 11.451169] usbserial: USB Serial support registered for GSM modem (1-port)
[ 11.457717] qmi_wwan 1-1.1:1.4 wwan0: register 'qmi_wwan' at usb-11200000.usb-1.1, WWAN/QMI device, 86:7e:39:1b:f3:d3
[ 11.473759] usbcore: registered new interface driver qmi_wwan
[ 11.474085] option 1-1.1:1.0: GSM modem (1-port) converter detected
[ 11.496687] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
[ 11.503841] option 1-1.1:1.1: GSM modem (1-port) converter detected
[ 11.510615] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
[ 11.517850] option 1-1.1:1.2: GSM modem (1-port) converter detected
[ 11.525756] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
[ 11.532955] option 1-1.1:1.3: GSM modem (1-port) converter detected
[ 11.539786] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
[ 11.572702] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[ 11.574089] mtdblock: MTD device 'fip' is NAND, please consider using UBI block devices instead.
[ 11.574322] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[ 11.581841] mtdblock: MTD device 'reserved' is NAND, please consider using UBI block devices instead.
[ 12.301364] br0: port 1(lan0) entered blocking state
[ 12.306362] br0: port 1(lan0) entered disabled state
[ 12.327767] device lan0 entered promiscuous mode
[ 12.334676] br0: port 2(lan1) entered blocking state
[ 12.339643] br0: port 2(lan1) entered disabled state
[ 12.356364] device lan1 entered promiscuous mode
[ 12.362437] br0: port 3(lan2) entered blocking state
[ 12.367414] br0: port 3(lan2) entered disabled state
[ 12.386360] device lan2 entered promiscuous mode
[ 12.392434] br0: port 4(lan3) entered blocking state
[ 12.397397] br0: port 4(lan3) entered disabled state
[ 12.416364] device lan3 entered promiscuous mode
[ 12.422419] br0: port 5(lan4) entered blocking state
[ 12.427384] br0: port 5(lan4) entered disabled state
[ 12.446360] device lan4 entered promiscuous mode
[ 12.712993] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 12.721381] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 12.735589] mt7530 mdio-bus:1f lan0: configuring for phy/gmii link mode
[ 12.892305] mt7530 mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 13.062333] mt7530 mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 13.232321] mt7530 mdio-bus:1f lan3: configuring for phy/gmii link mode
[ 13.402255] mt7530 mdio-bus:1f lan4: configuring for inband/2500base-x link mode
[ 14.875526] mt7986-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20220113162701a
[ 14.875526]
[ 14.902051] mt7986-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20220113162756
[ 14.951884] mt7986-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20220113163034
[ 19.226462] br0: port 6(wlan0) entered blocking state
[ 19.231531] br0: port 6(wlan0) entered disabled state
[ 19.236747] device wlan0 entered promiscuous mode
[ 19.241517] br0: port 6(wlan0) entered blocking state
[ 19.246568] br0: port 6(wlan0) entered forwarding state
[ 19.265347] br0: port 6(wlan0) entered disabled state
[ 19.539440] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.545936] br0: port 6(wlan0) entered blocking state
[ 19.550980] br0: port 6(wlan0) entered forwarding state
[ 19.960978] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
[ 19.967482] br0: port 7(wlan1) entered blocking state
[ 19.972538] br0: port 7(wlan1) entered disabled state
[ 19.977747] device wlan1 entered promiscuous mode
[ 19.982542] br0: port 7(wlan1) entered blocking state
[ 19.987593] br0: port 7(wlan1) entered forwarding state
[ 20.046828] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Here the bootlog
I noticed that the Error comes when i wake up the eth1 :
# ifup eth1
[ 136.346304] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
udhcpc: started, v1.32.0
[ 136.412346] mtk_soc_eth 15100000.ethernet eth1: validation with support 00000000,00000000,00000000 failed: -EINVAL
[ 136.422804] sfp sfp-1: sfp_add_phy failed: -EINVAL
