I have followed instructions and now my boot freeze on
[ 41.468489] IPv6: ADDRCONF(NETDEV_CHANGE): br-wan: link becomes ready
Do you know what can cause this?
Full log on attempt to boot:
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.167 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.3.0 r24106-10cc5fcd00) 12.3.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Mon Sep 23 12:34:46 2024
[ 0.000000] Machine model: Bananapi BPI-R3
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
[ 0.000000] node 0: [mem 0x0000000043030000-0x000000004fbfffff]
[ 0.000000] node 0: [mem 0x000000004fc00000-0x000000004ffbffff]
[ 0.000000] node 0: [mem 0x000000004ffc0000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 18 pages/cpu s33112 r8192 d32424 u73728
[ 0.000000] pcpu-alloc: s33112 r8192 d32424 u73728 alloc=18*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: root=/dev/mmcblk0p65
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Memory: 2040952K/2097152K available (8448K kernel code, 904K rwdata, 1488K rodata, 448K init, 302K bss, 56200K reserved, 0K cma-reserved)
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 640 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: 0xffffffc008010090
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000001] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000123] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000131] pid_max: default: 32768 minimum: 301
[ 0.000335] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000348] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001372] rcu: Hierarchical SRCU implementation.
[ 0.001660] smp: Bringing up secondary CPUs ...
[ 0.001912] Detected VIPT I-cache on CPU1
[ 0.001936] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.001961] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.002220] Detected VIPT I-cache on CPU2
[ 0.002233] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.002243] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.002477] Detected VIPT I-cache on CPU3
[ 0.002488] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.002497] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.002523] smp: Brought up 1 node, 4 CPUs
[ 0.002537] SMP: Total of 4 processors activated.
[ 0.002541] CPU features: detected: 32-bit EL0 Support
[ 0.002544] CPU features: detected: CRC32 instructions
[ 0.002571] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.002622] CPU: All CPU(s) started at EL2
[ 0.002632] alternatives: patching kernel code
[ 0.005509] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.005530] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.005671] pinctrl core: initialized pinctrl subsystem
[ 0.006292] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.006533] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.006563] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.006588] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.006840] thermal_sys: Registered thermal governor 'fair_share'
[ 0.006843] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.006846] thermal_sys: Registered thermal governor 'step_wise'
[ 0.006849] thermal_sys: Registered thermal governor 'user_space'
[ 0.007046] ASID allocator initialised with 65536 entries
[ 0.007355] pstore: Registered ramoops as persistent store backend
[ 0.007359] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 0.017139] cryptd: max_cpu_qlen set to 1000
[ 0.018707] 1.8vd: supplied by 12vd
[ 0.018869] 3.3vd: supplied by 12vd
[ 0.019124] SCSI subsystem initialized
[ 0.019211] libata version 3.00 loaded.
[ 0.020080] clocksource: Switched to clocksource arch_sys_counter
[ 0.020525] NET: Registered PF_INET protocol family
[ 0.020631] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.021288] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.021308] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.021316] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.021383] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.021550] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.021625] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.021652] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.021780] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.021800] PCI: CLS 0 bytes, default 64
[ 0.023901] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.026555] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.026568] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.049137] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.050245] pwm-mediatek 10048000.pwm: clock: top fail: -517
[ 0.050510] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 0.050530] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 0.050541] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 0.050634] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
[ 0.050644] mtk-pcie-gen3 11280000.pcie: failed to get clocks
[ 0.053439] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.055104] printk: console [ttyS0] disabled
[ 0.075262] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
[ 0.762863] printk: console [ttyS0] enabled
[ 0.787596] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
[ 0.817303] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 124, base_baud = 1625000) is a ST16650V2
[ 0.827116] mtk_rng 1020f000.rng: registered RNG driver
[ 0.827176] hwrng: no data available
[ 0.835930] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.844052] loop: module loaded
[ 0.847200] Loading iSCSI transport class v2.0-870.
[ 0.853292] spi spi0.0: setup: ignoring unsupported mode bits a00
[ 0.859618] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.864929] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.873160] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.879496] Creating 4 MTD partitions on "spi0.0":
[ 0.884316] 0x000000580000-0x000008000000 : "ubi"
[ 1.016255] 0x000000380000-0x000000580000 : "fip"
[ 1.023341] 0x000000080000-0x000000380000 : "reserved"
[ 1.031790] 0x000000000000-0x000000080000 : "bl2"
[ 1.171303] mtk_soc_eth 15100000.ethernet: generated random MAC address 6e:13:68:b2:37:24
[ 1.182022] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009780000, irq 136
[ 1.191782] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009780000, irq 136
[ 1.201321] i2c_dev: i2c /dev entries driver
[ 1.207065] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.215608] NET: Registered PF_INET6 protocol family
[ 1.221231] Segment Routing with IPv6
[ 1.224903] In-situ OAM (IOAM) with IPv6
[ 1.228838] NET: Registered PF_PACKET protocol family
[ 1.233906] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.246955] 8021q: 802.1Q VLAN Support v1.8
[ 1.251969] pstore: Using crash dump compression: deflate
[ 1.263064] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[ 1.270410] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[ 1.276663] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
[ 1.292273] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.302233] mmc0: new high speed SDHC card at address 0001
[ 1.308439] mmcblk0: mmc0:0001 00000 29.0 GiB
[ 1.316393] Alternate GPT is invalid, using primary GPT.
[ 1.322487] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
[ 1.331523] FIT: kernel sub-image 0x00001000..0x004f0da7 "kernel-1" (ARM64 OpenWrt Linux-5.15.167)
[ 1.341440] FIT: flat_dt sub-image 0x004f1000..0x004f8b66 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 1.352641] FIT: flat_dt sub-image 0x004f9000..0x004f91dc "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
[ 1.368957] FIT: flat_dt sub-image 0x004fa000..0x004fa392 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
[ 1.385271] FIT: flat_dt sub-image 0x004fb000..0x004fb38f "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 1.401415] FIT: flat_dt sub-image 0x004fc000..0x004fc146 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
[ 1.417382] FIT: filesystem sub-image 0x004fd000..0x00a58fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 1.427969] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 1.435261] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p65(rootfs-1) p66(rootfs_data)
[ 1.501433] mtk-pcie-gen3 11280000.pcie: PCIe link down, ltssm reg val: 0x1000001
[ 1.508932] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[ 1.544344] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[ 1.553476] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 1.562162] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=144)
[ 1.582483] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=145)
[ 1.602510] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=146)
[ 1.622541] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=147)
[ 1.642563] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=148)
[ 1.653658] DSA: tree 0 setup
[ 1.658783] UBI: auto-attach mtd0
[ 1.662128] ubi0: default fastmap pool size: 45
[ 1.666641] ubi0: default fastmap WL pool size: 22
[ 1.671418] ubi0: attaching mtd0
[ 5.286653] ubi0: scanning is finished
[ 5.331780] ubi0: attached mtd0 (name "ubi", size 122 MiB)
[ 5.337262] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 5.344125] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 5.350898] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 5.357837] ubi0: good PEBs: 980, bad PEBs: 0, corrupted PEBs: 0
[ 5.363826] ubi0: user volume: 5, internal volumes: 1, max. volumes count: 128
[ 5.371029] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[ 5.379355] ubi0: available PEBs: 725, total reserved PEBs: 255, PEBs reserved for bad PEB handling: 20
[ 5.388727] ubi0: background thread "ubi_bgt0d" started, PID 541
[ 5.400688] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
[ 5.409721] FIT: kernel sub-image 0x00001000..0x004f0da7 "kernel-1" (ARM64 OpenWrt Linux-5.15.167)
[ 5.419634] FIT: flat_dt sub-image 0x004f1000..0x004f8b66 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
[ 5.430835] FIT: flat_dt sub-image 0x004f9000..0x004f91dc "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
[ 5.447149] FIT: flat_dt sub-image 0x004fa000..0x004fa392 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
[ 5.463462] FIT: flat_dt sub-image 0x004fb000..0x004fb38f "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
[ 5.479602] FIT: flat_dt sub-image 0x004fc000..0x004fc146 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
[ 5.495566] FIT: filesystem sub-image 0x004fd000..0x00a58fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
[ 5.506152] FIT: selecting configured loadable "rootfs-1" to be root filesystem
[ 5.513440] ubiblock0_2: p1(rootfs-1)
[ 5.513551] block ubiblock0_2: created from ubi0:2(fit)
[ 5.522677] clk: Disabling unused clocks
[ 5.530909] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
[ 5.538174] Freeing unused kernel memory: 448K
[ 5.542651] Run /sbin/init as init process
[ 5.546729] with arguments:
[ 5.549679] /sbin/init
[ 5.552373] with environment:
[ 5.555497] HOME=/
[ 5.557841] TERM=linux
[ 5.678323] init: Console is alive
[ 5.681831] init: - watchdog -
[ 5.946430] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 5.968416] usbcore: registered new interface driver usbfs
[ 5.973943] usbcore: registered new interface driver hub
[ 5.979271] usbcore: registered new device driver usb
[ 5.987626] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[ 5.995036] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[ 6.003185] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.008403] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[ 6.018857] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
[ 6.028004] xhci-mtk 11200000.usb: irq 128, io mem 0x11200000
[ 6.033834] xhci-mtk 11200000.usb: xHCI Host Controller
[ 6.039044] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[ 6.046427] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[ 6.053809] hub 1-0:1.0: USB hub found
[ 6.057567] hub 1-0:1.0: 2 ports detected
[ 6.061826] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.070152] hub 2-0:1.0: USB hub found
[ 6.073902] hub 2-0:1.0: 1 port detected
[ 6.080114] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.091937] init: - preinit -
[ 6.309555] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 6.318037] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 6.319054] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6.333423] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 6.410382] random: procd: uninitialized urandom read (4 bytes read)
[ 6.540077] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[ 6.720730] hub 1-1:1.0: USB hub found
[ 6.724513] hub 1-1:1.0: 4 ports detected
[ 8.641779] mount_root: overlay filesystem in /dev/mmcblk0p66 has not been formatted yet
[ 11.024572] F2FS-fs (mmcblk0p66): Found nat_bits in checkpoint
[ 11.039411] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = d70cacb
[ 11.047324] mount_root: overlay filesystem has not been fully initialized yet
[ 11.054706] mount_root: switching to f2fs overlay
[ 11.059868] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 11.072445] urandom-seed: Seed file not found (/etc/urandom.seed)
[ 11.106796] procd: - early -
[ 11.109717] procd: - watchdog -
[ 11.350307] random: crng init done
[ 11.635118] procd: - watchdog -
[ 11.638462] procd: - ubus -
[ 11.694174] procd: - init -
[ 11.823233] kmodloader: loading kernel modules from /etc/modules.d/*
[ 11.834074] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
[ 11.840702] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
[ 11.849568] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
[ 11.863553] Loading modules backported from Linux version v6.1.110-0-g5f55cad62cc9d
[ 11.871216] Backport generated by backports.git v6.1.110-1-0-g965f73fc
[ 11.881221] sfp sfp-1: Host maximum power 3.0W
[ 11.886389] sfp sfp-2: Host maximum power 3.0W
[ 11.960038] urngd: v1.0.2 started.
[ 12.303498] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
[ 12.303498]
[ 12.430500] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805
[ 12.508588] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937
[ 33.110057] mt798x-wmac 18000000.wifi: Message 00000002 (seq 9) timeout
[ 33.116668] mt798x-wmac 18000000.wifi: Failed to start WA firmware
[ 33.122921] mt798x-wmac: probe of 18000000.wifi failed with error -110
[ 33.141068] PPP generic driver version 2.4.2
[ 33.145940] NET: Registered PF_PPPOX protocol family
[ 33.152833] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 38.698673] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[ 38.715621] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[ 38.724109] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 38.724198] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 38.742957] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[ 38.753190] br-lan: port 1(lan1) entered blocking state
[ 38.758420] br-lan: port 1(lan1) entered disabled state
[ 38.765089] device lan1 entered promiscuous mode
[ 38.769708] device eth0 entered promiscuous mode
[ 38.785861] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[ 38.795777] br-lan: port 2(lan2) entered blocking state
[ 38.801065] br-lan: port 2(lan2) entered disabled state
[ 38.808063] device lan2 entered promiscuous mode
[ 38.820376] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[ 38.830353] br-lan: port 3(lan3) entered blocking state
[ 38.835590] br-lan: port 3(lan3) entered disabled state
[ 38.842986] device lan3 entered promiscuous mode
[ 38.855384] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
[ 38.865643] br-lan: port 4(lan4) entered blocking state
[ 38.870968] br-lan: port 4(lan4) entered disabled state
[ 38.878944] device lan4 entered promiscuous mode
[ 38.887695] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
[ 38.897698] br-lan: port 5(sfp2) entered blocking state
[ 38.902973] br-lan: port 5(sfp2) entered disabled state
[ 38.910409] device sfp2 entered promiscuous mode
[ 38.919159] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
[ 38.929247] br-wan: port 1(eth1) entered blocking state
[ 38.934519] br-wan: port 1(eth1) entered disabled state
[ 38.939911] device eth1 entered promiscuous mode
[ 38.950616] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
[ 38.960507] br-wan: port 2(wan) entered blocking state
[ 38.965640] br-wan: port 2(wan) entered disabled state
[ 38.972302] device wan entered promiscuous mode
[ 41.449973] mt7530-mdio mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control off
[ 41.449993] br-wan: port 2(wan) entered blocking state
[ 41.462755] br-wan: port 2(wan) entered forwarding state
