[BPI-R3]How to flash Openwrt snapshot on EMMC?
For now I can’t find a full tutorial to flash the snapshot by openwrt to EMMC ,which is very deferent from the images that Sinovoip offered.
I understand I have to flash nand image into Nand first, then boot from nand to flash emmc, but there is no clear step-by-step documentation to refer to.
For the two methods I’ve heard,there is question:
1.I plug a USB to TTL converter to PC then with 115200Hz on the right COM, nothing display on putty. How to get in bootloader menu in the serial console?
2.I follow this to flash on NAND and stuck command
ubimkvol -n 0 -N ubootenv -s 1MiB
then it shows
error:ubi device name was not specified
Is there a well documented way for noob to flash on emmc?
  1. the menu appears only at bootup before kernel is loaded. If absolutely nothing is displayed you should check tx is connected to rx and vice versa. Which kind of serial adapter do you use? Cp210x,ch340 are reported to work well, profilic has problems
  2. afair daniel put option into the nand-uboot to flash emmc,so if you boot from nand and see menu there should be an option to flash emmc
Thank you Frank for explaining. Yes, using the serial console is the easiest way.
I forgot to specify the correct parameters for the ubimkvol calls, have updated the post now.
After I change a ch340 serial adapter hardware the uboot menu appears.Huge Thanks for your hint! Old one might be broken.
you need a decent serial sofware, putty indeed works well on windows.
And just spam the left button during boot process. The menu does show up kinda fast.
let me try to summarize my steps for the next Person to try and install this… because it took me way too long…
  1. As written in the guide for the old builds, you need fo burn MicroSD card with bananapi_bpi-r3-sdcard.img.gz (with win32disk imager i.E)
  2. Plugging the MicroSD card and setting Boot jumpers to all High, boots from MicroSD and it works out of the box!
  3. Connect Serial Cable and use Putty to interupt boot (by pressing left in the right moment or any other button… preferably not enter as that selects first option right away…)
  4. In the boot menu select “8. Install bootloader, recovery and production to NAND.”
  5. Jumpers to High-Low-High_Low to boot from NAND.take out MicroSD card, type reboot into putty
  6. Now it boots from NAND and you get the Option “9. Install bootloader, recovery and production to eMMC.”
  7. Jumpers to Low-High-High-Low and you will boot from eMMC.
Sidenote1: Snapshot builds do NOT come with Luci preinstalled… you need to install it manually (just step1 is enough).
now you just need to increase storage and you’re done. To get the “Mount Points” Menu you need to install block-mount package and reboot.
More info here: [BPI-R3] Change or add partion to /overlay
Edit: Proper way to increase Storage/root
  1. Reboot into Nand. install parted resize.f2fs should be preinstalled.
  2. in Parted type print free to see free space available
  3. type resizepart 5 and end point 835
  4. reboot
  5. use resize.f2fs /dev/mmcblk0p66
root@OpenWrt:/# resize.f2fs /dev/mmcblk0p66
Info: MKFS version
  "Linux version 5.15.80 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 11.3.0 r21380-5429411f73) 11.3.0, GNU ld (GNU Binutils) 2.37) #0 SMP Fri Dec 2 15:57:48 2022"
Info: FSCK version
  from "Linux version 5.15.80 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 11.3.0 r21380-5429411f73) 11.3.0, GNU ld (GNU Binutils) 2.37) #0 SMP Fri Dec 2 15:57:48 2022"
    to "Linux version 5.15.80 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 11.3.0 r21380-5429411f73) 11.3.0, GNU ld (GNU Binutils) 2.37) #0 SMP Fri Dec 2 15:57:48 2022"
Info: superblock features = 0 :
Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
Info: Segments per section = 1
Info: Sections per zone = 1
Info: total FS sectors = 191392 (93 MB)
Info: CKPT version = 351ed6bb
[f2fs_do_mount:3587] Mount unclean image to replay log first
root@OpenWrt:/#
  1. Getting the Error message [f2fs_do_mount:3587] Mount unclean image to replay log first you need to simply mount /dev/mmcblk0p66 /mnt and umount /dev/mmcblk0p66
root@OpenWrt:/# mount /dev/mmcblk0p66 /mnt
root@OpenWrt:/# umount /dev/mmcblk0p66
Info: MKFS version
Info: FSCK version
Info: CKPT version = 351ed6c6
Info: Duplicate valid checkpoint to mirror position 1024 -> 512
Info: Write valid nat_bits in checkpoint
[FIX] (move_one_curseg_info:2857)  --> Move curseg[0] 3 -> 4 after 1000
[FIX] (move_one_curseg_info:2857)  --> Move curseg[1] 5 -> 9 after 1000
[FIX] (move_one_curseg_info:2857)  --> Move curseg[2] 6 -> a after 1000
[FIX] (move_one_curseg_info:2857)  --> Move curseg[3] 0 -> b after 1000
[FIX] (move_one_curseg_info:2857)  --> Move curseg[4] 1 -> c after 1000
[FIX] (move_one_curseg_info:2857)  --> Move curseg[5] 2 -> d after 1000
Try to do defragement: Done
[migrate_ssa: 270] Info: Done to migrate SSA blocks: sum_blkaddr = 0xe00 -> 0xe00
[migrate_nat: 387] Info: Done to migrate NAT blocks: nat_blkaddr = 0xa00 -> 0xa00
[migrate_sit: 445] Info: Done to restore new SIT blocks: 0x600
[rebuild_checkpoint: 591] Info: Done to rebuild checkpoint blocks
[update_superblock: 701] Info: Done to update superblock
Done: 0.000000 secs
root@OpenWrt:/#
  1. Reboot into eMMC by bootjumper changes.
  2. Check if it worked type df -h
root@OpenWrt:/# df -h
/dev/root                 5.5M      5.5M         0 100% /rom
tmpfs                   997.9M     68.0K    997.8M   0% /tmp
/dev/mmcblk0p66         719.8M    141.6M    578.1M  20% /overlay
overlayfs:/overlay      719.8M    141.6M    578.1M  20% /
root@OpenWrt:/#
and done!
P.S If you have used up strage space from failed installations via opkg use this script ro remove them.
Edit2: Use the rest of the Storage!
opkg update
opkg install uvol autopart
uvol create userdata $(uvol free) rw
And you get a /tmp/run/uvol/userdata directory
if that doesn’t work you can do it manually. use cfdisk to create a new partition as big as you want. mkfs.f2fs /dev/mmcblk0p7 And mount in in the Mount manager of the web interface. done
Just created an account to say thanks for this, whilst the instructions weren’t exactly perfect for my situation, I got there in the end.
I’d had forgotten in one of my previous attempts I had created a partition that was stopping from the resize working, but then also I had some strange 4M partition at the end of the disk labelled ‘BIOS’. No idea what it was, so I just backed it up, deleted the partition and hey presto I’ve finally got a 7.2G OpenWRT root.
