The purpose of this Tutorial is to communication how I was able to boot OpenBSD on a BananaPI BPI-R3.
Nice board! Ultimately, I failed, but I got quite far! So, here is a little help for the next poor soul attempting to do so. The board requires a multistage boot with ARM trusted Firmware. Which is not trivial.
And when booting from an SD Card, it requires a certian partition layout.
So what I did was to start of with a working image, and compiled U-Boot, ARM Trusted Firmware from scratch, and set up an OpenBSD partition.
Afterwards, I loaded the EFI loader into memory, and ran it to start the bsd.rd kernel.
BEWARE: I wrote most of this from memory, so there might be some hickups.
CAVEATS There are three major problems with my approach:
a. I had to use a template image for the SD card from Frank W. I was not able to create my own (setting up the partition table etc). b. One step in building the second stage bootloader bl2.img involved a black box: there is a binary-only tool in the arm-trusted-firmware repository, which adds a header and a 256 Bit signature to the bl2.bin file. c. I was unable to compile a useable .dtb file myself, so I had to borrow one. (Even though I know now how it came to be.
PREREQUISITES
1.1 Hardware I used a BananaPI BPI-R3, a PL2303 TTL for UART connection, a 32GByte SD card and an SD Card writer. I compiled everything on a Laptop which has a Ubuntu/OpenBSD dualboot.
1.2 Software I used Ubuntu 22.04 for this, as well as OpenBSD 7.5. On my Linux machine, I installed the following packages:
sudo apt install opencu
sudo apt install build-esstential
sudo apt install dtc
sudo apt install bison
sudo apt install ncurses-dev
sudo apt install gcc-aarch64-linux-gnu
sudo apt install gcc-aarch64-linux-binutils
- DOWNLOADING I downloaded the following:
wget -c https://raw.githubusercontent.com/frank-w/u-boot/r3-atf/gpt_sdmmc_100m6g.img
git clone https://github.com/u-boot/u-boot
git clone https://github.com/mtk-openwrt/arm-trusted-firmware
wget -c https://cdn.kernel.org/pub/linux/kernel/v6.x/linux-6.5.tar.xz
tar xvfJ linux-6.5.tar.xz
mkdir Boot
cd Boot/
wget -c https://ftp.debian.org/debian/dists/stable/main/installer-arm64/current/images/netboot/netboot.tar.gz
wget -c https://ftp.openbsd.org/pub/OpenBSD/7.5/arm64/bsd.rd
wget -c https://ftp.openbsd.org/pub/OpenBSD/7.5/arm64/BOOTAA64.EFI
- BUILDING
Before you build you need to unpack the configuration. I took the liberty of adding them to the appendix of this file.
cd u-boot
cp ../config-u-boot .config
make CROSS_COMPILE=aarch64-linux-gnu- V=1 clean
yes "" | make CROSS_COMPILE=aarch64-linux-gnu- V=1
cp u-boot/u-boot.bin arm-trusted-firmware
cd arm-trusted-firmware
mkdir build
cp ../config-arm-trusted-firmware build/.config
cpp -I linux-6.5/include/ -I linux-6.5/arch/arm64/boot/dts/mediatek/ linux-6.5/arch/arm64/boot/dts/mediatek/mt7986a-bananapi-bpi-r3.dts | dtc -I dts - -O dtb -o mt7986a-bananapi-bpi-r3.dtb
THE LAST STEP FAILS, btw. The .dtb IS NOT CORRECT. I downloaded a better dtb file from the OpenBSD packages later. (See chapter 6)
- COLLECTING THE ARTIFACTS
Now I almost had everything
mkdir -p Sdcard Boot
cp gpt_sdmmc_100m6g.img Sdcard/
cp arm-trusted-firmware/build/mt7986/release/bl2.img Sdcard/
cp arm-trusted-firmware/build/mt7986/release/fip.bin Sdcard/
cp u-boot/arch/arm/dts/mt7986a-bpi-r3-sd.dtb Boot/
cp mt7986a-bananapi-bpi-r3.dtb Boot/
- WRITING IT ON THE SDCARD (Danger!!)
SDCARD="/dev/sdc"
dd if=Sdcard/gpt_sdmmc_100m6g.img of=$SDCARD bs=1M
gdisk $SDCARD
(Change the type of partition 6 to A600)
dd if=Sdcard/bl2.img of=$SDCARD"1" bs=1M
dd if=Sdcard/fip.bin of=$SDCARD"4" bs=1M
yes | mkfs.msdos $SDCARD"5"
yes | mkfs.ext4 $SDCARD"6"
mount $SDCARD"5" /mnt/
cp Boot/BOOTAA64.EFI /mnt/
cp Boot/bsd.rd /mnt/
cp Boot/mt7986a-bpi-r3-sd.dtb /mnt/
cp Boot/mt7986a-bananapi-bpi-r3.dtb /mnt/
cp Boot/
cat Boot/netboot.tar.gz | ( cd /mnt ; tar xvfz - )
umount /mnt/
********** BOTH OF THE .dtb FILES ARE WRONG! ******
I used the one from the OpenBSD dtb package.
- PREPARING OPENBSD
I rebooted my computer into OpenBSD. There, dmesg told me that my SD Card was device sd4. So I ran disklabel -E /dev/sd4
add a a
w
q
Now I had a 6GB partition.
newfs /dev/rsd4a
mount /dev/sd4a /mnt
wget -O /mnt/bsd.rd https://ftp.openbsd.org/pub/OpenBSD/7.5/arm64/bsd.rd
umount /mnt
Then I patched the Device Tree Binary with a working one:
mount.msdos /dev/sd4l /mnt
(I am not sure if it was sd4l or sd4m⦠The one with the MSDOS file system!)
pkg_add dtb
cp /usr/local/share/dtb/mediatek/mt7986a-bananapi-bpi-r3.dtb /mnt/mt7986a-bananapi-bpi-r3.okay.dtb
umount /mnt
- BOOTING THE INSTALLER
I connected the PL2303 to the BananaPI, (GND Black to GND, TX green to RX, RX white to TX). Put the SD Card in, moved all the DIP switches to the upper position.
On the console, I ran
cu -l /dev/ttyU0 -s 115200
Switched on the BananaPI and waited for the BPI prompt.
fatload mmc 0:5 0x46000000 /BOOTAA64.EFI
fatload mmc 0:5 0x47000000 /mt7986a-bananapi-bpi-r3.okay.dtb
bootefi 0x46000000 0x47000000
Then came the boot prompt.
boot bsd.rd
The last line was garbage, because the booted installer changed the baud rate. So I closed the terminal, and started a new one
cu -l /dev/ttyU0 -s 230400
Pressed enter, and was greeted by the familiar
(I)nstall, (U)pgrade, (A)utoinstall or (S)hell?
dettus AT dettus DOT net
-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x
APPENDIX: CONFIGURATION (base64 encoded)
echo "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" | \
base64 -d >config-u-boot.xz
echo "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" | \
base64 -d >config-arm-trusted-firmware.xz
xz -d config-u-boot.xz
xz -d config-arm-trusted-firmware.xz
You can verify that it was decoded correctly:
md5sum config-u-boot config-arm-trusted-firmware
68851815fc3343889558072ca3b1c82d config-u-boot
b55786845230bba7786fa3dee532896f config-arm-trusted-firmware
