I run the BPI-R3 not as a router but use it for other purposes where I need multiple LAN ports.
Special thanks to @frank-w who provided the ubuntu image and the network config there was a big help to get the device running.
But I wonder if it’s possible to flash the image to emmc. All topics I found were about the openWRT image and the manuals sadly don’t work with ubuntu.
@frank-w thanks for you reply on my dm, but I’m struggling anyway.
You wrote:
“Should be same as debian…go from sd to nand/nor and flash emmc bl2 to boot0 and sd image to emmc userpart,maybe replace fip with emmc version”
I’m not getting the point how to do all that. On SD I got all I need to work and want this now on emmc.
With openWRT image everything works with the u-boot menu, but in ubuntu there it needs some other trick.
Maybe anyone can help me here set up a more detailed HowTo that can help others with the same problem:
flash the NAND with a bootable image. What’s needed, what is to do. There is the need of a .bin file, how do I create one. Also in case I have to use a bigger SD-card than the 8GB of installed emmc.
flash the image from nand to emmc. What’s needed, what’s to do. I need the image to flash, of course, butin the BPI-R§ getting started there is bl2_emmx.img needed. Can I use the one from @frank-w or do I need to recreate the images again fom the one on my SD?
My goal is here to have an image of an SD-card which I can load on any device in case of failure and not to have set it up again.
Sorry about this newbe questions, but I want to learn and to understand, what is needed here. I’ve never done that before.
If there is any other topic which describes it please point me to that, I wasn’t able to find it with the search.
For nand i do not have an image…it is only bootchain till uboot (bl2+fip).
When nand is booted you can flash unpacked sdcard-image to emmc (check with “mmc partconf” if emmc is really active). Then write bl2 to emmc boot0 partition and replace fip.
Should ve same for (my) ubuntu-image,except replacing fip after flashing image to userpart because sd fip and emmc fip have different mmc config…not sure how openwrt handles this in uboot
