Obviously not. But when I turn off the hostpad service, wlan0 also turns off but wlan1 remains active.
systemctl | grep hostapd
Will show you why ![]()
hostapd.service loaded active running Access point and authentication server for Wi-Fi and Ethernet
hostapd2.service loaded active running Access point and authentication server for Wi-Fi 2 and Ethernet
Hostapd service using wlan0 config,hostapd2 uses wlan1
Defined in /etc/default/hostapd
Have you considered using the template unit file [email protected]?
But anyway, back to subject, @radek.juthner , you could try changing the mac addresses as above⌠Perhaps it helps.
Thanks for the explanation. I get it. Then why wlan0 returns DUP! is a mystery to me and wlan1 does not.
I tried changing the mac address using machchanger but no luck.
Is mac really changed? Normally this needs to be done when interface is not up
@ericwoud do not know templates for systemd just added new var to default file and copied service file with some changes (use other var and different pid)
I used:
ifconfig wlan0 down #Bring wifi down
macchanger -r wlan0 #Randomly generate new MAC address
ifconfig wlan0 up #Bring wifi back up
I tried but no luck.
With file named /etc/hostapd/wlan1.conf
Do:
systemctl start [email protected]
Then no need to edit the files.
Never mind that, do:
sudo nano /etc/systemd/network/10-wlan0.link
[Match]
OriginalName=wlan0
[Link]
MACAddress=aa:bb:cc:11:22:00
Press CTRL-x and type y to save it.
And:
sudo nano /etc/systemd/network/10-wlan1.link
[Match]
OriginalName=wlan1
[Link]
MACAddress=aa:bb:cc:11:23:00
Then
reboot
Check again with:
ip a
I managed to change the MAC addresses. I checked with ip a. Unfortunately DUP! on wlan0 it didnât fix it. I think the problem will be with the files in /etc/hostapd. I donât know why there is a hostapd.conf file (doesnât it create some duplication?). When I remove it wlan0 doesnât work but wlan1 works. Another observation:
- if wlan0 and wlan1 are on, then the client on wlan0 pings DUP, but the client on wlan1 has clean pings.
- if I turn off wlan1, then the client on wlan0 has clean pings.
again:
- hostapd.conf is default file from package and should not be used as i changed DAEMONCONF in /etc/defaults/hostapd
- hostapd service should use hostapd_wlan0.conf (DAEMONCONF in /etc/defaults/hostapd)
- hostapd2 service should use hostapd_wlan1.conf (DAEMONCONF2 in /etc/defaults/hostapd)
have you dropped the bridge-setting from the configs???
What do you mean???
this settingâŚtry without it and do the local pings without the bridgeâŚyou can also enable routing to not break internet connectivity
If I remove bridge=lanbr0 from /etc/hostapd/hostapd_wlan1.conf (or wlan0), the client does not get an IP address. I still found this out. After the reboot, wlan1 is disabled. If klinet is on wlan0, it pings with DUP. Just turn on and then turn off wlan1 and then the client is on wlan0 with a clean ping.
then reenable the systemd-file from image with the ip-adress and dhcp-server
Sorry, but I donât understand what to do.
Iâm not sure if isc-dhcp has fully replaced or works well in systemd-networkd. In the folder /etc/systemd/network I have the original configurations: 05-eth0.network 15-wan.network 21-lanbr-bind.network 10-wan.link 20-lanbr.netdev
I moved the hostapd_wlan0.conf and hostapd_wlan1.conf files to the /etc/hostapd folder and added bridge=lanbr0 to them.
Other DHCP configuration is according to isc-dhcp.
not sure about the isc-dhcpâŚif you use this then add config for wlan0+1 and add ip to these interfaces
my original system uses this systemd setting
we first need to check without this bridge as i guess the dup are from there
