not with the vendor kernel works for you sfp…my image is using newer kernel based on mainline 6.1 and is similar to openwrt
but mine was 5.15…
yes, vendors kernel like i said
well so now i booted on the new image.
let’s start configuring…
root@bpi-r3:~# ip a
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1504 qdisc fq_codel state UP group default qlen 1000
link/ether 8a:85:b6:bf:23:bd brd ff:ff:ff:ff:ff:ff
inet 169.254.141.154/16 brd 169.254.255.255 scope global noprefixroute eth0
inet6 fe80::c190:a54a:e437:2ea8/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 5a:5d:95:34:9b:e4 brd ff:ff:ff:ff:ff:ff
inet 169.254.82.80/16 brd 169.254.255.255 scope global noprefixroute eth1
inet6 fe80::b55a:4ed1:728:6f74/64 scope link
4: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
5: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
6: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
7: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
8: lan4@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
9: sfp2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
10: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 00:0c:43:26:60:00 brd ff:ff:ff:ff:ff:ff
11: wlan1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 82:0c:43:26:60:00 brd ff:ff:ff:ff:ff:ff
root@bpi-r3:~#
how do we create our lan bridge, wan bridge, set the ip address, set the lan dhcp, and finally the firewall
we first need to know how vendor has setup the network…but it seems completely unconfigured…
look if there is something in /etc/systemd/network and /etc/network
ls -lh /etc/systemd/network
ls -lh /etc/network
temporary you can do this like this
ip a a 192.168.0.5/24 dev wan #change to your subnet
ip r add default 192.168.0.1 #change to your routers lan-address
echo "nameserver 192.168.0.1" >> /etc/resolv.conf #also change ip
date -s "2023-09-03 12:00:00 UTC"
then apt update should work
root@bpi-r3:~# ls -lh /etc/network
total 28K
drwxr-xr-x 2 root root 4.0K Sep 22 03:54 if-down.d
drwxr-xr-x 2 root root 4.0K Sep 22 03:54 if-post-down.d
drwxr-xr-x 2 root root 4.0K Sep 22 03:54 if-pre-up.d
drwxr-xr-x 2 root root 4.0K Sep 22 03:54 if-up.d
-rw-r--r-- 1 root root 134 Sep 22 03:50 interfaces
drwxr-xr-x 2 root root 4.0K Dec 15 14:41 interfaces.d
-rw-r--r-- 1 root root 271 Sep 22 03:54 interfaces.new
root@bpi-r3:~#
root@bpi-r3:~#
root@bpi-r3:~#
root@bpi-r3:~# ls -lh /etc/systemd/network
total 0
lrwxrwxrwx 1 root root 9 Sep 22 03:51 73-usb-net-by-mac.link -> /dev/null
lrwxrwxrwx 1 root root 9 Sep 22 03:51 99-default.link -> /dev/null
root@bpi-r3:~#
yes seems unconfigured…
systemctl status systemd-networkd
if it does not return an error we can use the “new” way with systemd-networkd
you’ll find some basic files here
https://github.com/frank-w/BPI-Router-Images/tree/main/conf/generic/etc/systemd/network
or just do the manual steps and maybe put the commands into a script in your homedir for testing
root@bpi-r3:~# systemctl status systemd-networkd
● systemd-networkd.service - Network Service
Loaded: loaded (/lib/systemd/system/systemd-networkd.service; disabled; ve>
Active: inactive (dead)
TriggeredBy: ● systemd-networkd.socket
Docs: man:systemd-networkd.service(8)
lines 1-5/5 (END)
Maybe hardware-offloading should be something to worry about later.
First get to setup a simple basic router and get used to using debian through ssh.
Of course there is some speed to be gained, but take it one step at a time if you are not so much used to these things…
Nice repo of yours @frank-w !!! Im a new owner of a R3-mini. See that you’r still do not include it as a “supported” device in your scripts, even though for me is only a regular R3 without the bridge (switch). Have you ever tried to build DietPI images instead of vanilla debian…?
Thanks in advance ! ![]()
I have a r3mini since yesterday,but have not booted it yet (try to figure out order of uart pins).
Basicly it is r3,but dts is different (not only missing switch) and we need additional driver for the 2g5 phys (eric is working on it but needs official datasheet). In my kernel-repo i have a 6.6-r3mini tree prepared,but not yet tested by myself. Basicly ot uses bpi-r3 board,and packs the new dts as separate config. Atf/Uboot/gpt is currently same
Nice! Will be testing as well… Have one of those that still not on production environment but if I can help with something, count me !
Found this interesting git repo that attempts to build VyOS boot images for BPI-R3, could be interesting if kernel issues are completed and fork efforts with the developer.
