Building an image of openwrt seems to work to a point. Regardless if I build it locally or from the openwrt site.
Booting it, I see 3 mounted partitions, but no root or overlay. Is there any secret to get the image to bring them up on boot? Running mount_root just silently exits.
root@OpenWrt:/# df
Filesystem 1K-blocks Used Available Use% Mounted on
tmpfs 1020412 15520 1004892 2% /
tmpfs 1020412 56 1020356 0% /tmp
tmpfs 512 0 512 0% /dev
This looks like the board booted into recovery/initramfs mode.
This happens deliberately after kernel crashes if there are logs present in /sys/fs/pstore/ which you have clear using rm /sys/fs/pstore/* (and ideally also submit them here for further investigation).
Another reason can be that images above a size of ~ 20 MiB were brioken recently in OpenWrt. This has been fixed by
So make sure your build or snapshot is after this commit.
