Hi, Im trying the mesh 802.11s with 23.05.03. BPI R3 v1.1, with sd card image.
Channel/ Frequency issue: a-)It doesnt emit beacons and can not be find by other mesh nodes, if its channel is not 36. When it is set to 36 bw 80Mhz and working, output of root@OpenWrt:/# iw dev phy1-mesh0 info is as follows:
Interface phy1-mesh0
ifindex 16
wdev 0x100000004
addr a6:a6:52:82:7e:b4
type mesh point
wiphy 1
channel 36 (5180 MHz), width: 80 MHz, center1: 5210 MHz
txpower 20.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 33 0 0 0 0 3534 33
when it switched to channel 52 bw 80, as follows: output of root@OpenWrt:/# iw dev phy1-mesh0 info
ifindex 17
wdev 0x100000005
addr a2:a6:52:82:7e:b4
type mesh point
wiphy 1
txpower 20.00 dBm
multicast TXQ:
0 0 0 0 0 0 0 0 0
as can be seen, the line starting with “channel” is missing at the second / problematic case.
b-)After trying several channels, the frequency shown does not match to channel number. see attached file - channel 52 - frequency 6210. In this case phy device(phy1-mesh0) is, can not bee seen via ifconfig or iwinfo.
What could be the issue?
