BPI-R3 2.4G adapter not present
I just bought above router and i cant run 2.4Ghz wifi. In Wireless Overview i got only MediaTek MT7986 802.11ac/ax/n which is 5Ghz. i tried few others openwrt builds but same situation over and over. Any help?
|Hostname|OpenWrt| |Model|Bananapi BPI-R3| |Architecture|ARMv8 Processor rev 4| |Target Platform|mediatek/filogic| |Firmware Version|OpenWrt SNAPSHOT r27494-2e626ae2d2 / LuCI Master 24.264.56398~844971|
Do you have any serial adapter connected to the board. Which vendor? Do you see anything in dmesg related to wifi?
no serial adapter attached.
I bought exactly this version
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    0.000000] Linux version 6.6.52 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 r27494-2e626ae2d2) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Sat Sep 21 16:03:31 2024
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Machine model: Bananapi BPI-R3
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] OF: reserved mem: 0x0000000043000000..0x000000004302ffff (192 KiB) nomap non-reusable secmon@43000000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] OF: reserved mem: 0x000000004fc00000..0x000000004fcfffff (1024 KiB) nomap non-reusable wmcpu-reserved@4fc00000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] OF: reserved mem: 0x000000004fd00000..0x000000004fd3ffff (256 KiB) nomap non-reusable wo-emi@4fd00000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] OF: reserved mem: 0x000000004fd40000..0x000000004fd7ffff (256 KiB) nomap non-reusable wo-emi@4fd40000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] OF: reserved mem: 0x000000004fd80000..0x000000004ffbffff (2304 KiB) nomap non-reusable wo-data@4fd80000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Zone ranges:
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000]   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000]   DMA32    empty
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000]   Normal   empty
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Movable zone start for each node
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Early memory node ranges
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000043000000-0x000000004302ffff]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000043030000-0x000000004fbfffff]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000]   node   0: [mem 0x000000004fc00000-0x000000004ffbffff]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000]   node   0: [mem 0x000000004ffc0000-0x00000000bfffffff]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] psci: probing for conduit method from DT.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] psci: PSCIv1.1 detected in firmware.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] psci: Using standard PSCI v0.2 function IDs
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] psci: SMC Calling Convention v1.4
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] percpu: Embedded 18 pages/cpu s35112 r8192 d30424 u73728
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    0.000000] pcpu-alloc: s35112 r8192 d30424 u73728 alloc=18*4096
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Detected VIPT I-cache on CPU0
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] CPU features: detected: GIC system register CPU interface
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] alternatives: applying boot alternatives
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    0.000000] Kernel command line: root=/dev/fit0 rootwait
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] software IO TLB: area num 4.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] software IO TLB: mapped [mem 0x00000000bf67e000-0x00000000bf87e000] (2MB)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Memory: 2037324K/2097152K available (8896K kernel code, 902K rwdata, 2588K rodata, 448K init, 302K bss, 59828K reserved, 0K cma-reserved)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] rcu: Hierarchical RCU implementation.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] GICv3: 640 SPIs implemented
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] GICv3: 0 Extended SPIs implemented
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] Root IRQ handler: gic_handle_irq
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] GICv3: GICv3 features: 16 PPIs
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] arch_timer: cp15 timer(s) running at 13.00MHz (phys).
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000067] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.000075] pid_max: default: 32768 minimum: 301
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.002070] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.002082] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.warn kernel: [    0.003641] cacheinfo: Unable to detect cache hierarchy for CPU 0
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.004024] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.004128] rcu: Hierarchical SRCU implementation.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.004130] rcu: 	Max phase no-delay instances is 1000.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.004459] smp: Bringing up secondary CPUs ...
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.004719] Detected VIPT I-cache on CPU1
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.004755] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.004784] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005083] Detected VIPT I-cache on CPU2
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005103] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005114] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005370] Detected VIPT I-cache on CPU3
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005386] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005396] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005423] smp: Brought up 1 node, 4 CPUs
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005426] SMP: Total of 4 processors activated.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005429] CPU features: detected: 32-bit EL0 Support
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005431] CPU features: detected: CRC32 instructions
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005456] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005459] CPU: All CPU(s) started at EL2
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.005460] alternatives: applying system-wide alternatives
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.008582] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.008598] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.009478] pinctrl core: initialized pinctrl subsystem
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.010427] NET: Registered PF_NETLINK/PF_ROUTE protocol family
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.010681] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.010707] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.010731] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.011041] thermal_sys: Registered thermal governor 'fair_share'
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.011044] thermal_sys: Registered thermal governor 'bang_bang'
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.011046] thermal_sys: Registered thermal governor 'step_wise'
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.011048] thermal_sys: Registered thermal governor 'user_space'
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.011094] ASID allocator initialised with 65536 entries
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.011855] pstore: Using crash dump compression: deflate
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.011859] pstore: Registered ramoops as persistent store backend
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.011861] ramoops: using 0x10000@0x42ff0000, ecc: 0
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.018794] Modules: 29456 pages in range for non-PLT usage
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.018803] Modules: 520976 pages in range for PLT usage
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.019635] cryptd: max_cpu_qlen set to 1000
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    0.020525] SCSI subsystem initialized
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    0.020621] libata version 3.00 loaded.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.021665] clocksource: Switched to clocksource arch_sys_counter
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.023273] NET: Registered PF_INET protocol family
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.023392] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025009] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025026] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025034] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025102] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025445] TCP: Hash tables configured (established 16384 bind 16384)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025539] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025572] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025853] NET: Registered PF_UNIX/PF_LOCAL protocol family
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.025879] PCI: CLS 0 bytes, default 64
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.026893] workingset: timestamp_bits=46 max_order=19 bucket_order=0
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.030142] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.030147] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.051673] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.053277] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    0.053297] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.053307] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
Tue Sep 24 13:54:11 2024 kern.err kernel: [    0.053434] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
Tue Sep 24 13:54:11 2024 kern.err kernel: [    0.053443] mtk-pcie-gen3 11280000.pcie: failed to get clocks
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.056542] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.059561] printk: console [ttyS0] disabled
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.079920] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 2500000) is a ST16650V2
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.079957] printk: console [ttyS0] enabled
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.902536] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 117, base_baud = 1625000) is a ST16650V2
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.932542] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 118, base_baud = 1625000) is a ST16650V2
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.942438] mtk_rng 1020f000.rng: registered RNG driver
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.950465] loop: module loaded
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.955261] spi-nand spi0.0: Winbond SPI NAND was found.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    0.960569] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    0.968901] 2 fixed-partitions partitions found on MTD device spi0.0
Tue Sep 24 13:54:11 2024 kern.err kernel: [    0.975359] OF: Bad cell count for /soc/spi@1100a000/spi_nand@0/partitions
Tue Sep 24 13:54:11 2024 kern.err kernel: [    0.982244] OF: Bad cell count for /soc/spi@1100a000/spi_nand@0/partitions
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    0.989298] Creating 2 MTD partitions on "spi0.0":
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    0.994093] 0x000000200000-0x000008000000 : "ubi"
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    1.133993] ubi0: default fastmap pool size: 50
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    1.138522] ubi0: default fastmap WL pool size: 25
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    1.143306] ubi0: attaching mtd0
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.834405] ubi0: scanning is finished
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.879424] ubi0: attached mtd0 (name "ubi", size 126 MiB)
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.884917] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.891774] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.898540] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.905482] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.911553] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.918754] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.927084] ubi0: available PEBs: 0, total reserved PEBs: 1008, PEBs reserved for bad PEB handling: 20
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.936371] ubi0: background thread "ubi_bgt0d" started, PID 294
Tue Sep 24 13:54:11 2024 kern.info kernel: [    4.944576] block ubiblock0_2: created from ubi0:2(fit)
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    4.949877] 0x000000000000-0x000000200000 : "bl2"
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.085434] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc081880000, irq 123
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.095219] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc081880000, irq 123
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.104913] i2c_dev: i2c /dev entries driver
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.111127] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.119733] NET: Registered PF_INET6 protocol family
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.125291] Segment Routing with IPv6
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.128959] In-situ OAM (IOAM) with IPv6
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.132914] NET: Registered PF_PACKET protocol family
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.137967] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.151023] 8021q: 802.1Q VLAN Support v1.8
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.168488] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    5.175850] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.182116] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
Tue Sep 24 13:54:11 2024 kern.err kernel: [    5.190583] debugfs: File 'type' in directory 'phy-soc:t-phy.0' already present!
Tue Sep 24 13:54:11 2024 kern.err kernel: [    5.197964] debugfs: File 'efuse' in directory 'phy-soc:t-phy.0' already present!
Tue Sep 24 13:54:11 2024 kern.err kernel: [    5.205427] debugfs: File 'intr' in directory 'phy-soc:t-phy.0' already present!
Tue Sep 24 13:54:11 2024 kern.err kernel: [    5.212803] debugfs: File 'tx-imp' in directory 'phy-soc:t-phy.0' already present!
Tue Sep 24 13:54:11 2024 kern.err kernel: [    5.220350] debugfs: File 'rx-imp' in directory 'phy-soc:t-phy.0' already present!
Tue Sep 24 13:54:11 2024 kern.err kernel: [    5.561683] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
Tue Sep 24 13:54:11 2024 kern.warn kernel: [    5.570499] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.581356] FIT: Detected U-Boot 2024.07-OpenWrt-r27494-2e626ae2d2
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.587536] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.596570] FIT:           kernel sub-image 0x00001000..0x005a33dd "kernel-1" (ARM64 OpenWrt Linux-6.6.52)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.606295] FIT:          flat_dt sub-image 0x005a4000..0x005abca6 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.617495] FIT:          flat_dt sub-image 0x005ac000..0x005ac3dd "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.633809] FIT:          flat_dt sub-image 0x005ad000..0x005ad48d "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.650122] FIT:          flat_dt sub-image 0x005ae000..0x005ae4bd "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.666262] FIT:          flat_dt sub-image 0x005af000..0x005af343 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.682230] FIT:          flat_dt sub-image 0x005b0000..0x005b0555 "fdt-mt7986a-bananapi-bpi-r3-respeaker-2mics" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-respeaker-2mics)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.700448] FIT:       filesystem sub-image 0x005b1000..0x00ae3fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.711378] block ubiblock0_2: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.804683] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.813647] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.824123] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=128)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.846303] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=129)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.868187] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=130)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.890046] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=131)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.911921] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=132)
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.923192] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.929909] DSA: tree 0 setup
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.933332] clk: Disabling unused clocks
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.983159] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.990445] Freeing unused kernel memory: 448K
Tue Sep 24 13:54:11 2024 kern.info kernel: [    5.994940] Run /sbin/init as init process
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    5.999020]   with arguments:
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    6.002000]     /sbin/init
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    6.004697]   with environment:
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    6.007825]     HOME=/
Tue Sep 24 13:54:11 2024 kern.debug kernel: [    6.010174]     TERM=linux
Tue Sep 24 13:54:11 2024 kern.info kernel: [    6.030082] mtk-msdc 11230000.mmc: Final PAD_DS_TUNE: 0x15014
Tue Sep 24 13:54:11 2024 kern.info kernel: [    6.037043] mmc0: new HS400 MMC card at address 0001
Tue Sep 24 13:54:11 2024 kern.info kernel: [    6.042954] mmcblk0: mmc0:0001 008GB0 7.28 GiB
Tue Sep 24 13:54:11 2024 kern.warn kernel: [    6.049375] Alternate GPT is invalid, using primary GPT.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    6.054719]  mmcblk0: p1 p2 p3 p4 p5 p128
Tue Sep 24 13:54:11 2024 kern.info kernel: [    6.059763] mmcblk0boot0: mmc0:0001 008GB0 4.00 MiB
Tue Sep 24 13:54:11 2024 kern.info kernel: [    6.065512] mmcblk0boot1: mmc0:0001 008GB0 4.00 MiB
Tue Sep 24 13:54:11 2024 kern.info kernel: [    6.070620] mmcblk0rpmb: mmc0:0001 008GB0 4.00 MiB, chardev (249:0)
Tue Sep 24 13:54:11 2024 user.info kernel: [    6.575182] init: Console is alive
Tue Sep 24 13:54:11 2024 user.info kernel: [    6.578698] init: - watchdog -
Tue Sep 24 13:54:11 2024 user.info kernel: [    7.787843] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.849245] usbcore: registered new interface driver usbfs
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.854772] usbcore: registered new interface driver hub
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.860103] usbcore: registered new device driver usb
Tue Sep 24 13:54:11 2024 kern.warn kernel: [    7.865721] gpio_button_hotplug: loading out-of-tree module taints kernel.
Tue Sep 24 13:54:11 2024 kern.warn kernel: [    7.876562] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
Tue Sep 24 13:54:11 2024 kern.warn kernel: [    7.883973] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.892317] xhci-mtk 11200000.usb: xHCI Host Controller
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.897547] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.908015] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.917172] xhci-mtk 11200000.usb: irq 134, io mem 0x11200000
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.923061] xhci-mtk 11200000.usb: xHCI Host Controller
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.928272] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.935655] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.943072] hub 1-0:1.0: USB hub found
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.946824] hub 1-0:1.0: 2 ports detected
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.951090] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.959430] hub 2-0:1.0: USB hub found
Tue Sep 24 13:54:11 2024 kern.info kernel: [    7.963209] hub 2-0:1.0: 1 port detected
Tue Sep 24 13:54:11 2024 user.info kernel: [    7.970380] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Tue Sep 24 13:54:11 2024 user.info kernel: [    7.983475] init: - preinit -
Tue Sep 24 13:54:11 2024 kern.notice kernel: [    8.131678] random: crng init done
Tue Sep 24 13:54:11 2024 kern.info kernel: [    8.431161] usb 1-1: new high-speed USB device number 2 using xhci-mtk
Tue Sep 24 13:54:11 2024 kern.info kernel: [    8.612421] hub 1-1:1.0: USB hub found
Tue Sep 24 13:54:11 2024 kern.info kernel: [    8.616239] hub 1-1:1.0: 4 ports detected
Tue Sep 24 13:54:11 2024 kern.info kernel: [    8.732539] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Sep 24 13:54:11 2024 kern.info kernel: [    8.740985] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Tue Sep 24 13:54:11 2024 kern.info kernel: [   12.541397] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   14.788464] UBIFS (ubi0:6): Mounting in unauthenticated mode
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   14.794206] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 881
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   15.022718] UBIFS (ubi0:6): recovery needed
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   15.427436] UBIFS (ubi0:6): recovery completed
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   15.431932] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "rootfs_data"
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   15.439740] UBIFS (ubi0:6): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   15.449632] UBIFS (ubi0:6): FS size: 91803648 bytes (87 MiB, 723 LEBs), max 734 LEBs, journal size 4571136 bytes (4 MiB, 36 LEBs)
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   15.461256] UBIFS (ubi0:6): reserved for root: 4336112 bytes (4234 KiB)
Tue Sep 24 13:54:11 2024 kern.notice kernel: [   15.467852] UBIFS (ubi0:6): media format: w5/r0 (latest is w5/r0), UUID 289D58F2-BBD1-4029-AEF8-95E4E55EE9D0, small LPT model
Tue Sep 24 13:54:11 2024 user.info kernel: [   15.528695] mount_root: switching to ubifs overlay
Tue Sep 24 13:54:11 2024 kern.warn kernel: [   15.567716] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
Tue Sep 24 13:54:11 2024 user.debug kernel: [   15.611518] urandom-seed: Seeding with /etc/urandom.seed
Tue Sep 24 13:54:11 2024 user.info kernel: [   15.821448] procd: - early -
Tue Sep 24 13:54:11 2024 user.info kernel: [   15.824458] procd: - watchdog -
Tue Sep 24 13:54:11 2024 user.info kernel: [   16.401948] procd: - watchdog -
Tue Sep 24 13:54:11 2024 user.info kernel: [   16.405442] procd: - ubus -
Tue Sep 24 13:54:11 2024 user.info kernel: [   16.543740] procd: - init -
Tue Sep 24 13:54:11 2024 user.info kernel: [   17.094746] kmodloader: loading kernel modules from /etc/modules.d/*
Tue Sep 24 13:54:11 2024 kern.info kernel: [   17.157789] i2c-gpio i2c-gpio-0: using lines 528 (SDA) and 529 (SCL)
Tue Sep 24 13:54:11 2024 kern.info kernel: [   17.164390] i2c-gpio i2c-gpio-1: using lines 530 (SDA) and 531 (SCL)
Tue Sep 24 13:54:11 2024 kern.info kernel: [   17.174517] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
Tue Sep 24 13:54:11 2024 user.info kernel: [   17.182897] urngd: v1.0.2 started.
Tue Sep 24 13:54:11 2024 kern.info kernel: [   17.189038] Loading modules backported from Linux version v6.9.9-0-g28fdf4518483
Tue Sep 24 13:54:11 2024 kern.info kernel: [   17.196440] Backport generated by backports.git v6.1.97-1-29-gf1d24a3683b2
Tue Sep 24 13:54:11 2024 kern.info kernel: [   17.207118] sfp sfp-1: Host maximum power 3.0W
Tue Sep 24 13:54:11 2024 kern.info kernel: [   17.212526] sfp sfp-2: Host maximum power 3.0W
Tue Sep 24 13:54:11 2024 kern.info kernel: [   17.738722] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20240823160739a
Tue Sep 24 13:54:11 2024 kern.info kernel: [   18.229722] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20240823160804
Tue Sep 24 13:54:11 2024 kern.info kernel: [   18.445123] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20240823160840
Tue Sep 24 13:54:11 2024 kern.info kernel: [   18.550793] mt798x-wmac 18000000.wifi: registering led 'mt76-phy0'
Tue Sep 24 13:54:11 2024 kern.info kernel: [   18.609991] PPP generic driver version 2.4.2
Tue Sep 24 13:54:11 2024 kern.info kernel: [   18.615074] NET: Registered PF_PPPOX protocol family
Tue Sep 24 13:54:11 2024 user.info kernel: [   18.622103] kmodloader: done loading kernel modules from /etc/modules.d/*
Tue Sep 24 13:54:12 2024 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Tue Sep 24 13:54:12 2024 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: started, version 2.90 cachesize 1000
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Tue Sep 24 13:54:12 2024 daemon.warn dnsmasq[1]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Tue Sep 24 13:54:12 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 0 names
Tue Sep 24 13:54:12 2024 authpriv.info dropbear[1623]: Not backgrounding
Tue Sep 24 13:54:14 2024 daemon.notice procd: /etc/rc.d/S25packet_steering: pid 412's current affinity list: 0-3
Tue Sep 24 13:54:14 2024 daemon.notice procd: /etc/rc.d/S25packet_steering: pid 412's new affinity list: 0
Tue Sep 24 13:54:14 2024 daemon.notice procd: /etc/rc.d/S25packet_steering: pid 413's current affinity list: 0-3
Tue Sep 24 13:54:14 2024 daemon.notice procd: /etc/rc.d/S25packet_steering: pid 413's new affinity list: 0
Tue Sep 24 13:54:14 2024 user.notice : Added device handler type: bonding
Tue Sep 24 13:54:14 2024 user.notice : Added device handler type: 8021ad
Tue Sep 24 13:54:14 2024 user.notice : Added device handler type: 8021q
Tue Sep 24 13:54:14 2024 user.notice : Added device handler type: macvlan
Tue Sep 24 13:54:14 2024 user.notice : Added device handler type: veth
Tue Sep 24 13:54:14 2024 user.notice : Added device handler type: bridge
Tue Sep 24 13:54:14 2024 user.notice : Added device handler type: Network device
Tue Sep 24 13:54:14 2024 user.notice : Added device handler type: tunnel
Tue Sep 24 13:54:14 2024 daemon.notice procd: /etc/rc.d/S50uhttpd: 4+0 records in
Tue Sep 24 13:54:14 2024 daemon.notice procd: /etc/rc.d/S50uhttpd: 4+0 records out
Tue Sep 24 13:54:14 2024 user.notice ucitrack: Setting up /etc/config/luci-splash reload dependency on /etc/config/firewall
Tue Sep 24 13:54:14 2024 user.notice ucitrack: Setting up /etc/config/qos reload dependency on /etc/config/firewall
Tue Sep 24 13:54:14 2024 user.notice ucitrack: Setting up /etc/config/miniupnpd reload dependency on /etc/config/firewall
Tue Sep 24 13:54:14 2024 user.notice ucitrack: Setting up /etc/config/odhcpd reload dependency on /etc/config/dhcp
Tue Sep 24 13:54:14 2024 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/network
Tue Sep 24 13:54:15 2024 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/wireless
Tue Sep 24 13:54:15 2024 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.013594] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Tue Sep 24 13:54:15 2024 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.032263] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.040725] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.047215] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.061359] br-lan: port 1(lan1) entered blocking state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.066646] br-lan: port 1(lan1) entered disabled state
Tue Sep 24 13:54:15 2024 user.notice ucitrack: Setting up /etc/config/luci_statistics reload dependency on /etc/config/system
Tue Sep 24 13:54:15 2024 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/system
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.071937] mt7530-mdio mdio-bus:1f lan1: entered allmulticast mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.078209] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.087826] mt7530-mdio mdio-bus:1f lan1: entered promiscuous mode
Tue Sep 24 13:54:15 2024 daemon.notice netifd: Interface 'lan' is enabled
Tue Sep 24 13:54:15 2024 daemon.notice netifd: Interface 'lan' is setting up now
Tue Sep 24 13:54:15 2024 daemon.notice netifd: Interface 'lan' is now up
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.107116] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.118920] br-lan: port 2(lan2) entered blocking state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.124226] br-lan: port 2(lan2) entered disabled state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.129515] mt7530-mdio mdio-bus:1f lan2: entered allmulticast mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.137770] mt7530-mdio mdio-bus:1f lan2: entered promiscuous mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.153664] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.161443] br-lan: port 3(lan3) entered blocking state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.166768] br-lan: port 3(lan3) entered disabled state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.172090] mt7530-mdio mdio-bus:1f lan3: entered allmulticast mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.180422] mt7530-mdio mdio-bus:1f lan3: entered promiscuous mode
Tue Sep 24 13:54:15 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.196428] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
Tue Sep 24 13:54:15 2024 daemon.notice wpa_supplicant[1765]: Successfully initialized wpa_supplicant
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.715829] br-lan: port 4(lan4) entered blocking state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.721069] br-lan: port 4(lan4) entered disabled state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.726382] mt7530-mdio mdio-bus:1f lan4: entered allmulticast mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.734666] mt7530-mdio mdio-bus:1f lan4: entered promiscuous mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.743940] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.753475] br-lan: port 5(sfp2) entered blocking state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.758691] br-lan: port 5(sfp2) entered disabled state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.763935] mt7530-mdio mdio-bus:1f sfp2: entered allmulticast mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.772313] mt7530-mdio mdio-bus:1f sfp2: entered promiscuous mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.781820] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.792026] br-wan: port 1(eth1) entered blocking state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.797252] br-wan: port 1(eth1) entered disabled state
Tue Sep 24 13:54:15 2024 kern.info kernel: [   23.802513] mtk_soc_eth 15100000.ethernet eth1: entered allmulticast mode
Tue Sep 24 13:54:16 2024 kern.info kernel: [   23.809443] mtk_soc_eth 15100000.ethernet eth1: entered promiscuous mode
Tue Sep 24 13:54:16 2024 daemon.notice netifd: Interface 'wan' is enabled
Tue Sep 24 13:54:16 2024 daemon.notice netifd: Interface 'wan6' is enabled
Tue Sep 24 13:54:16 2024 kern.info kernel: [   23.824842] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
Tue Sep 24 13:54:16 2024 kern.info kernel: [   24.343747] br-wan: port 2(wan) entered blocking state
Tue Sep 24 13:54:16 2024 kern.info kernel: [   24.348891] br-wan: port 2(wan) entered disabled state
Tue Sep 24 13:54:16 2024 kern.info kernel: [   24.354087] mt7530-mdio mdio-bus:1f wan: entered allmulticast mode
Tue Sep 24 13:54:16 2024 daemon.notice netifd: Interface 'loopback' is enabled
Tue Sep 24 13:54:16 2024 daemon.notice netifd: Interface 'loopback' is setting up now
Tue Sep 24 13:54:16 2024 daemon.notice netifd: Interface 'loopback' is now up
Tue Sep 24 13:54:16 2024 kern.info kernel: [   24.362639] mt7530-mdio mdio-bus:1f wan: entered promiscuous mode
Tue Sep 24 13:54:16 2024 daemon.notice netifd: Network device 'eth0' link is up
Tue Sep 24 13:54:16 2024 daemon.notice netifd: Network device 'lo' link is up
Tue Sep 24 13:54:16 2024 daemon.notice netifd: Interface 'loopback' has link connectivity
Tue Sep 24 13:54:16 2024 daemon.notice netifd: radio0 (2583): WARNING: Variable 'data' does not exist or is not an array/object
Tue Sep 24 13:54:16 2024 daemon.notice hostapd: Set new config for phy phy0:
Tue Sep 24 13:54:16 2024 daemon.notice wpa_supplicant[1765]: Set new config for phy phy0
Tue Sep 24 13:54:16 2024 daemon.info procd: - init complete -
Tue Sep 24 13:54:17 2024 daemon.notice wpa_supplicant[1765]: Set new config for phy phy0
Tue Sep 24 13:54:17 2024 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Tue Sep 24 13:54:17 2024 daemon.notice hostapd: Restart interface for phy phy0
Tue Sep 24 13:54:17 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 hw_mode=a beacon_int=100 chanlist=36 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935] ieee80211ac=1 vht_oper_chwidth=1 vht_oper_centr_freq_seg0_idx=42 vht_capab=[RXLDPC][SHORT-GI-80][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-4][BF-ANTENNA-4][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7] ieee80211ax=1 he_oper_chwidth=1 he_oper_centr_freq_seg0_idx=42 he_su_beamformer=1 he_su_beamformee=1 he_mu_beamformer=1 he_bss_color=128 he_spr_sr_control=3 he_default_pe_duration=4 he_rts_threshold=1023 he_mu_edca_qos_info_param_count=0 he_mu_edca_qos_info_q_ack=0 he_mu_edca_qos_info_queue_request=0 he_mu_edca_qos_info_txop_request=0 he_mu_edca_ac_be_aifsn=8 he_mu_edca_ac_be_aci=0 he
Tue Sep 24 13:54:17 2024 daemon.notice netifd: Wireless device 'radio0' is now up
Tue Sep 24 13:54:17 2024 kern.info kernel: [   24.973396] br-lan: port 6(phy0-ap0) entered blocking state
Tue Sep 24 13:54:17 2024 kern.info kernel: [   24.978970] br-lan: port 6(phy0-ap0) entered disabled state
Tue Sep 24 13:54:17 2024 kern.info kernel: [   24.984610] mt798x-wmac 18000000.wifi phy0-ap0: entered allmulticast mode
Tue Sep 24 13:54:17 2024 kern.info kernel: [   24.991554] mt798x-wmac 18000000.wifi phy0-ap0: entered promiscuous mode
Tue Sep 24 13:54:17 2024 kern.info kernel: [   24.998403] br-lan: port 6(phy0-ap0) entered blocking state
Tue Sep 24 13:54:17 2024 kern.info kernel: [   25.003967] br-lan: port 6(phy0-ap0) entered forwarding state
Tue Sep 24 13:54:17 2024 daemon.notice hostapd: phy0-ap0: interface state UNINITIALIZED->HT_SCAN
Tue Sep 24 13:54:17 2024 daemon.notice netifd: bridge 'br-lan' link is up
Tue Sep 24 13:54:17 2024 daemon.notice netifd: Interface 'lan' has link connectivity
Tue Sep 24 13:54:17 2024 daemon.notice hostapd: Switch own primary and secondary channel to get secondary channel with no Beacons from other BSSes
Tue Sep 24 13:54:17 2024 kern.info kernel: [   25.371721] br-lan: port 6(phy0-ap0) entered disabled state
Tue Sep 24 13:54:17 2024 daemon.notice netifd: Network device 'phy0-ap0' link is up
Tue Sep 24 13:54:17 2024 kern.info kernel: [   25.698626] br-lan: port 6(phy0-ap0) entered blocking state
Tue Sep 24 13:54:17 2024 kern.info kernel: [   25.704196] br-lan: port 6(phy0-ap0) entered forwarding state
Tue Sep 24 13:54:17 2024 daemon.notice hostapd: phy0-ap0: interface state HT_SCAN->ENABLED
Tue Sep 24 13:54:17 2024 daemon.notice hostapd: phy0-ap0: AP-ENABLED
Tue Sep 24 13:54:18 2024 kern.info kernel: [   26.689121] mt7530-mdio mdio-bus:1f lan4: Link is Up - 1Gbps/Full - flow control rx/tx
Tue Sep 24 13:54:18 2024 kern.info kernel: [   26.689145] br-lan: port 4(lan4) entered blocking state
Tue Sep 24 13:54:18 2024 daemon.notice netifd: Network device 'lan4' link is up
Tue Sep 24 13:54:18 2024 kern.info kernel: [   26.702252] br-lan: port 4(lan4) entered forwarding state
Tue Sep 24 13:54:19 2024 kern.info kernel: [   27.129604] mt7530-mdio mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control off
Tue Sep 24 13:54:19 2024 kern.info kernel: [   27.129627] br-wan: port 2(wan) entered blocking state
Tue Sep 24 13:54:19 2024 daemon.notice netifd: Network device 'wan' link is up
Tue Sep 24 13:54:19 2024 daemon.notice netifd: bridge 'br-wan' link is up
Tue Sep 24 13:54:19 2024 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Sep 24 13:54:19 2024 daemon.notice netifd: Interface 'wan' is setting up now
Tue Sep 24 13:54:19 2024 daemon.notice netifd: Interface 'wan6' has link connectivity
Tue Sep 24 13:54:19 2024 daemon.notice netifd: Interface 'wan6' is setting up now
Tue Sep 24 13:54:19 2024 kern.info kernel: [   27.142386] br-wan: port 2(wan) entered forwarding state
Tue Sep 24 13:54:19 2024 daemon.notice netifd: wan (2856): udhcpc: started, v1.36.1
Tue Sep 24 13:54:19 2024 daemon.err odhcp6c[2858]: Failed to send RS (Address not available)
Tue Sep 24 13:54:19 2024 daemon.warn odhcpd[1903]: No default route present, overriding ra_lifetime to 0!
Tue Sep 24 13:54:19 2024 daemon.err odhcp6c[2858]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Tue Sep 24 13:54:19 2024 daemon.notice netifd: wan (2856): udhcpc: broadcasting discover
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: started, version 2.90 cachesize 1000
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.7.100 -- 192.168.7.249, lease time 12h
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Tue Sep 24 13:54:19 2024 daemon.warn dnsmasq[1]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue Sep 24 13:54:19 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Tue Sep 24 13:54:20 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Tue Sep 24 13:54:20 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue Sep 24 13:54:20 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Tue Sep 24 13:54:20 2024 daemon.err odhcp6c[2858]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Tue Sep 24 13:54:21 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.7.203 44:8a:5b:67:0d:42
Tue Sep 24 13:54:21 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.7.203 44:8a:5b:67:0d:42 HOST_PIT
Tue Sep 24 13:54:22 2024 daemon.notice netifd: wan (2856): udhcpc: broadcasting discover
Tue Sep 24 13:54:26 2024 daemon.notice netifd: wan (2856): udhcpc: broadcasting discover
Tue Sep 24 13:54:30 2024 daemon.notice netifd: wan (2856): udhcpc: broadcasting select for 192.168.1.104, server 192.168.1.1
Tue Sep 24 13:54:32 2024 daemon.notice netifd: wan (2856): udhcpc: lease of 192.168.1.104 obtained from 192.168.1.1, lease time 86400
Tue Sep 24 13:54:32 2024 daemon.notice netifd: Interface 'wan' is now up
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using nameserver 192.168.1.1#53
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using nameserver 192.168.0.1#53
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using nameserver 194.204.152.34#53
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using nameserver 194.204.159.1#53
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Tue Sep 24 13:54:32 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Tue Sep 24 13:54:32 2024 user.notice firewall: Reloading firewall due to ifup of wan (br-wan)
Tue Sep 24 13:54:33 2024 daemon.warn odhcpd[1903]: No default route present, overriding ra_lifetime to 0!
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Tue Sep 24 13:54:33 2024 daemon.err procd: Got unexpected signal 1
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: started, version 2.90 cachesize 1000
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: DNS service limited to local subnets
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.7.100 -- 192.168.7.249, lease time 12h
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using only locally-known addresses for test
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using nameserver 192.168.1.1#53
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using nameserver 192.168.0.1#53
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using nameserver 194.204.152.34#53
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: using nameserver 194.204.159.1#53
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue Sep 24 13:54:33 2024 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Wed Sep 25 08:50:28 2024 daemon.warn odhcpd[1903]: No default route present, overriding ra_lifetime to 0!
Wed Sep 25 08:51:26 2024 daemon.err uhttpd[2029]: [info] luci: accepted login on /admin/network/wireless for root from 192.168.7.203
Wed Sep 25 08:53:07 2024 authpriv.info dropbear[3583]: Child connection from 192.168.7.203:53527
Wed Sep 25 08:53:09 2024 authpriv.notice dropbear[3583]: Auth succeeded with blank password for 'root' from 192.168.7.203:53527
Wed Sep 25 08:57:38 2024 daemon.warn odhcpd[1903]: No default route present, overriding ra_lifetime to 0!
