I upgraded my kernel to 6.6-r2pro to add in the patches of baylibre for crypto extension.
Then I got 0.6Mbps download speed on both eth0, eth1, I plugged in a PCIe NIC and the result is the same.
I initially thought this has to do with the hw offload driver, so I removed the kernel modules and re-test, but still
I guess problem is the other end of the network cable…i have not seen such issues with 6.6. btw. You can use 6.6-main tree and change board in build.conf to “bpi-r2pro”
And look in ethtool whats the advertised/applied speed/duplex setting. You can also connect to another device and run iperf3 over this before connecting to your internet modem/router.
If you compile the kernel without modules and you have the modules still on your card in modules dir with same kernel name i may load the module
When I run Frank’s ./build.sh config, then save, the NET_DSA_MT7530_MDIO and MMIO are automatically selected. I unchecked MMIO, but it does not help with my problems though.
Frank, I am still using your Ubuntu image from 5.15 → 6.1 (no problem) → 6.4-6.6 has problems.
The issue is now isolated to the DSA user ports, and the onboard eth0 or external NICs are fine.
I could ping, that means the ARP is fine. But not SSH or iperf3. The wireshark reports bunch of TCP retransmissions. I apt removed iptables and nftables, although there is no kernel modules for these regardless. But still is problematic.
tcpdump on pi could see the packet, but not the application themselves I believe.
Issue further isolated to eth1 attached to DSA switch and TCP connections only.
DHCP, MDNS, and ncat on UDP are all fine. Decided to check whether this is a TCP checksum offloading issue and IT IS!!!
ethtool -K eth1 rx 0 tx 0
This fixes the issue temporarily albeit at increased CPU usage.
Now, who should I contact to get this fixed? I know MT7531 driver changed between kernel 6.1 to 6.6, and whether the driver needs amending or some code on the RK chip side.
But with the 6.1 kernel, I don’t need to turn off the tx rx checksum offload, this points to some changes made in the Mediatek driver, or the stmmac driver?
