Banana Pi BPI-R2 Pro new sample ready.switch chip change to mt7531be, support DSA. and add eDP interface, change SATA interface.
With sda you mean dsa (distributed switch arch - all ports accesible in linux)?
attention
everyone receiving the new version make sure iodomain is right in dts before booting the board, some parts of my repo (5.16-next2,5.17-hdmi{,v5,v6}, maybe more) and mainline still using the old iodomain which may damage your board.
when anyone can test the changes (iodomain + network) i prepared in the 5.17-r2pro tree i send it upstream
if using this tree, make sure you use the dtb without -rtl8367
@sinovoip @wei.zuo can you confirm changes are correct (took settings from your repo) and complete? was anything else changed that i had already upstreamed?
tried to get rtc working on new board…dts settings like in official repo
# dmesg | grep -i hym
[ 1.391108] rtc-hym8563 3-0051: could not init device, -6
# i2cdetect -y 3
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- 51 -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
so device is visible on i2c-bus, but driver cannot initialize…does it work in vendor-kernel?
