Rockwell RK3568 with MT7531, BPI R2 Pro board v1.1. SD card is Samsung EVO Plus 32GB UHS-I U1 (https://www.amazon.ca/dp/B074KWJNW8)
I’m new to the R2 Pro after my R2 died, and I’m really struggling to get it to boot off the SD card while waiting for a USB male-to-male cable I ordered to come in (though I’d rather use SD if I can). I’ve tried various means of building the SD card, including using the Windows tool and images provided in the Getting Started wiki, building frank-w’s u-boot (2023-04-bpi-r2p branch) and BPI-Router-Image (6.1-main branch), and using his r2pro-ubuntu2204.tar.gz image from his Google Drive (https://drive.google.com/drive/folders/1pnTxSquZL-7n0xx4Bx1xJl7LqEKfa71Y).
U-Boot is able to load the kernel off the boot partition, but once the kernel tries to find the SD card, it fails. When booting frank-w’s r2pro-ubuntu2204.tar.gz image and holding down the MASKROOM button, I get the following output on the debug UART:
DDR Version V1.11 20211103
In
ddrconfig:0
LP4 MR14:0x4d
LPDDR4, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
tdqss: cs0 dqs0: 385ps, dqs1: 313ps, dqs2: 337ps, dqs3: 241ps,
change to: 324MHz
PHY drv:clk:38,ca:38,DQ:30,odt:0
vrefinner:41%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
change to: 528MHz
dram drv:40,odt:0
clk skew:0x78
change to: 780MHz
dram drv:40,odt:0
clk skew:0x5d
change to: 1560MHz(final freq)
PHY drv:clk:38,ca:38,DQ:30,odt:60
vrefinner:16%, vrefout:29%
dram drv:40,odt:80
vref_ca:00000068
clk skew:0x12
cs 0:
the read training result:
DQS0:0x36, DQS1:0x35, DQS2:0x37, DQS3:0x33,
min : 0xf 0x10 0x13 0xe 0x2 0x5 0x9 0x3 , 0xe 0xa 0x5 0x2 0xe 0xb 0xc 0x9 ,
0x13 0x13 0xe 0xc 0x5 0x2 0x2 0x5 , 0xf 0xb 0xc 0x3 0x12 0x11 0x11 0x13 ,
mid :0x2b 0x2b 0x2d 0x29 0x1e 0x21 0x24 0x1e ,0x27 0x26 0x1e 0x1d 0x29 0x26 0x27 0x24 ,
0x2e 0x2d 0x27 0x25 0x1f 0x1d 0x1d 0x20 ,0x28 0x27 0x24 0x1f 0x2d 0x2c 0x29 0x2e ,
max :0x47 0x46 0x47 0x44 0x3a 0x3e 0x3f 0x39 ,0x40 0x42 0x38 0x39 0x44 0x42 0x42 0x3f ,
0x49 0x48 0x41 0x3e 0x3a 0x39 0x39 0x3b ,0x42 0x43 0x3c 0x3b 0x48 0x47 0x42 0x49 ,
range:0x38 0x36 0x34 0x36 0x38 0x39 0x36 0x36 ,0x32 0x38 0x33 0x37 0x36 0x37 0x36 0x36 ,
0x36 0x35 0x33 0x32 0x35 0x37 0x37 0x36 ,0x33 0x38 0x30 0x38 0x36 0x36 0x31 0x36 ,
the write training result:
DQS0:0x5e, DQS1:0x50, DQS2:0x55, DQS3:0x42,
min :0xa6 0xaa 0xab 0xa8 0x9c 0x9e 0xa1 0x9f 0x9e ,0x96 0x97 0x8f 0x90 0x9a 0x97 0x98 0x97 0x93 ,
0x9e 0x9f 0x9a 0x98 0x91 0x8f 0x91 0x94 0x94 ,0x8c 0x8d 0x89 0x83 0x92 0x93 0x8d 0x92 0x87 ,
mid :0xc2 0xc4 0xc6 0xc2 0xb4 0xb8 0xbb 0xb9 0xb8 ,0xb1 0xb0 0xa8 0xa8 0xb3 0xb0 0xb1 0xb0 0xac ,
0xbb 0xbc 0xb5 0xb3 0xac 0xa9 0xab 0xaf 0xaf ,0xa7 0xa5 0xa2 0x9c 0xab 0xac 0xa7 0xac 0xa0 ,
max :0xde 0xdf 0xe2 0xdd 0xcd 0xd2 0xd5 0xd3 0xd3 ,0xcc 0xca 0xc2 0xc0 0xcd 0xc9 0xca 0xc9 0xc5 ,
0xd9 0xd9 0xd1 0xcf 0xc7 0xc4 0xc6 0xca 0xcb ,0xc2 0xbe 0xbb 0xb6 0xc4 0xc6 0xc2 0xc7 0xb9 ,
range:0x38 0x35 0x37 0x35 0x31 0x34 0x34 0x34 0x35 ,0x36 0x33 0x33 0x30 0x33 0x32 0x32 0x32 0x32 ,
0x3b 0x3a 0x37 0x37 0x36 0x35 0x35 0x36 0x37 ,0x36 0x31 0x32 0x33 0x32 0x33 0x35 0x35 0x32 ,
CA Training result:
cs:0 min :0x40 0x40 0x36 0x34 0x34 0x32 0x39 ,0x42 0x3c 0x37 0x36 0x36 0x32 0x3d ,
cs:0 mid :0x7f 0x7e 0x74 0x6f 0x73 0x6e 0x65 ,0x7f 0x7b 0x74 0x71 0x72 0x6f 0x67 ,
cs:0 max :0xbe 0xbd 0xb2 0xab 0xb2 0xaa 0x91 ,0xbc 0xbb 0xb2 0xac 0xaf 0xac 0x92 ,
cs:0 range:0x7e 0x7d 0x7c 0x77 0x7e 0x78 0x58 ,0x7a 0x7f 0x7b 0x76 0x79 0x7a 0x55 ,
out
rockchip_sdram_size fdc20208 1000e2c1
rank 1 cs0_col 10 bk 3 cs0_row 16 bw 2 row_3_4 0
SDRAM base=0, size=80000000
U-Boot SPL 2022.04-bpi (May 24 2022 - 13:02:35 +0200)
Trying to boot from MMC1
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-135-gcda1658bc-dirty:xsf
NOTICE: BL31: Built : 14:19:26, Jun 1 2021
INFO: GICv3 without legacy support detected.
INFO: ARM GICv3 driver initialized in EL3
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 0
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0xa00000
INFO: SPSR = 0x3c9
U-Boot 2022.04-rc5+ (May 22 2022 - 09:29:19 +0200)
Model: Rockchip RK3568 EVB1 DDR4 V10 Board
DRAM: rockchip_sdram_size fdc20208 1000e2c1
2 GiB
Core: 155 devices, 14 uclasses, devicetree: separate
MMC: mmc@fe2b0000: 1, mmc@fe310000: 0
Loading Environment from nowhere... OK
In: serial@fe660000
Out: serial@fe660000
Err: serial@fe660000
Hit any key to stop autoboot: 0
Interface: mmc
Device 1: Vendor: Man 00001b Snr 2553a301 Rev: 1.3 Prod: EB1QT0
Type: Removable Hard Disk
Capacity: 30528.0 MB = 29.8 GB (62521344 x 512)
Filesystem: FAT16 "BPI-BOOT "
Boot from SD
file not found
*** U-Boot Boot Menu ***
1. Run extlinux.
U-Boot console
Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:2...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
1: linux
Retrieving file: /extlinux/Image.gz
append: earlycon=uart8250,mmio32,0xfe660000 console=ttyS2,1500000n8 root=/dev/mmcblk0p3 rootwait rw
Retrieving file: /extlinux/r2pro.dtb
Uncompressing Kernel Image
Moving Image from 0x2080000 to 0x2200000, end=3dd0000
## Flattened Device Tree blob at 0a100000
Booting using the fdt blob at 0xa100000
Loading Device Tree to 000000007df2c000, end 000000007df3cf77 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.000000] Linux version 5.18.0-bpi-r2pro-main (frank@frank-G5-U20) (aarch64-linux-gnu-gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #2 SMP PREEMPT Tue May 24 15:04:25 CEST 2022
[ 0.000000] Machine model: Bananapi-R2 Pro (RK3568) DDR4 Board
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x000000007fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x7fba5a40-0x7fba7fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000200000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000000200000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff]
[ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[ 0.000000] cma: Reserved 32 MiB at 0x0000000079c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 28 pages/cpu s75048 r8192 d31448 u114688
[ 0.000000] pcpu-alloc: s75048 r8192 d31448 u114688 alloc=28*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 515592
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xfe660000 console=ttyS2,1500000n8 root=/dev/mmcblk0p3 rootwait rw
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Memory: 1993048K/2095104K available (14464K kernel code, 2736K rwdata, 5420K rodata, 5056K init, 581K bss, 69288K reserved, 32768K cma-reserved)
[ 0.000000] ftrace: allocating 49327 entries in 193 pages
[ 0.000000] ftrace: allocated 193 pages with 3 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 320 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: MBI range [296:319]
[ 0.000000] GICv3: Using MBI frame 0x00000000fd410000
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[ 0.000000] /interrupt-controller@fd400000/interrupt-controller@fd440000: no regs?
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] random: get_random_bytes called from start_kernel+0x77c/0x96c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001644] Console: colour dummy device 80x25
[ 0.002210] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.003229] pid_max: default: 32768 minimum: 301
[ 0.003796] LSM: Security Framework initializing
[ 0.004416] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.005165] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.008396] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.009123] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.009879] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.010852] rcu: Hierarchical SRCU implementation.
[ 0.011799] interrupt-controller@fd440000: unable to locate ITS domain
[ 0.012788] interrupt-controller@fd440000: Unable to locate ITS domain
[ 0.013708] EFI services will not be available.
[ 0.014900] smp: Bringing up secondary CPUs ...
[ 0.016306] Detected VIPT I-cache on CPU1
[ 0.016357] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.016427] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.017538] Detected VIPT I-cache on CPU2
[ 0.017584] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.017637] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.018733] Detected VIPT I-cache on CPU3
[ 0.018778] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.018827] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.018997] smp: Brought up 1 node, 4 CPUs
[ 0.024568] SMP: Total of 4 processors activated.
[ 0.025035] CPU features: detected: 32-bit EL0 Support
[ 0.025540] CPU features: detected: 32-bit EL1 Support
[ 0.026047] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.026948] CPU features: detected: Common not Private translations
[ 0.027569] CPU features: detected: CRC32 instructions
[ 0.028078] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.028642] CPU features: detected: LSE atomic instructions
[ 0.029189] CPU features: detected: Privileged Access Never
[ 0.029735] CPU features: detected: RAS Extension Support
[ 0.030268] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.050044] CPU: All CPU(s) started at EL2
[ 0.053171] devtmpfs: initialized
[ 0.069683] KASLR disabled due to lack of seed
[ 0.070394] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.071371] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.073191] pinctrl core: initialized pinctrl subsystem
[ 0.074310] regulator-dummy: no parameters, enabled
[ 0.075322] DMI not present or invalid.
[ 0.076384] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.079447] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.080413] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.081449] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.082360] audit: initializing netlink subsys (disabled)
[ 0.083171] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[ 0.085370] thermal_sys: Registered thermal governor 'fair_share'
[ 0.085385] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.085988] thermal_sys: Registered thermal governor 'step_wise'
[ 0.086578] thermal_sys: Registered thermal governor 'user_space'
[ 0.087167] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.088513] cpuidle: using governor menu
[ 0.089835] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.090693] ASID allocator initialised with 65536 entries
[ 0.109289] platform fe0a0000.hdmi: Fixing up cyclic dependency with fe040000.vop
[ 0.134332] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[ 0.135870] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[ 0.137366] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[ 0.138963] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[ 0.140420] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[ 0.150275] platform hdmi-con: Fixing up cyclic dependency with fe0a0000.hdmi
[ 0.173440] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.174122] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.174864] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.175529] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.177386] cryptd: max_cpu_qlen set to 1000
[ 0.178776] ACPI: Interpreter disabled.
[ 0.179897] dc_12v: 12000 mV, enabled
[ 0.180491] reg-fixed-voltage dc-12v: dc_12v supplying 12000000uV
[ 0.181337] vcc3v3_sys: will resolve supply early: vin
[ 0.181853] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[ 0.182594] vcc3v3_sys: supplied by dc_12v
[ 0.183008] dc_12v: could not add device link regulator.2: -ENOENT
[ 0.183776] vcc3v3_sys: 3300 mV, enabled
[ 0.184365] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.185255] vcc5v0_sys: will resolve supply early: vin
[ 0.185770] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[ 0.186506] vcc5v0_sys: supplied by dc_12v
[ 0.186919] dc_12v: could not add device link regulator.3: -ENOENT
[ 0.187592] vcc5v0_sys: 5000 mV, enabled
[ 0.188192] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.189065] pcie30_avdd0v9: will resolve supply early: vin
[ 0.189613] reg-fixed-voltage pcie30-avdd0v9: Looking up vin-supply from device tree
[ 0.190383] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.190862] vcc3v3_sys: could not add device link regulator.4: -ENOENT
[ 0.191604] pcie30_avdd0v9: 900 mV, enabled
[ 0.192217] reg-fixed-voltage pcie30-avdd0v9: pcie30_avdd0v9 supplying 900000uV
[ 0.193169] pcie30_avdd1v8: will resolve supply early: vin
[ 0.193716] reg-fixed-voltage pcie30-avdd1v8: Looking up vin-supply from device tree
[ 0.194486] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.194966] vcc3v3_sys: could not add device link regulator.5: -ENOENT
[ 0.195672] pcie30_avdd1v8: 1800 mV, enabled
[ 0.196296] reg-fixed-voltage pcie30-avdd1v8: pcie30_avdd1v8 supplying 1800000uV
[ 0.197268] vcc3v3_pcie: 3300 mV, disabled
[ 0.197861] reg-fixed-voltage vcc3v3-pi6c-05-regulator: Looking up vin-supply from device tree
[ 0.198721] vcc3v3_pcie: supplied by vcc5v0_sys
[ 0.199256] reg-fixed-voltage vcc3v3-pi6c-05-regulator: vcc3v3_pcie supplying 3300000uV
[ 0.200323] vcc3v3_minipcie: 3300 mV, disabled
[ 0.200979] reg-fixed-voltage vcc3v3-minipcie-regulator: Looking up vin-supply from device tree
[ 0.201850] vcc3v3_minipcie: supplied by vcc3v3_pcie
[ 0.202412] reg-fixed-voltage vcc3v3-minipcie-regulator: vcc3v3_minipcie supplying 3300000uV
[ 0.203499] vcc3v3_ngff: 3300 mV, disabled
[ 0.204078] reg-fixed-voltage vcc3v3-ngff-regulator: Looking up vin-supply from device tree
[ 0.204940] vcc3v3_ngff: supplied by vcc3v3_pcie
[ 0.205485] reg-fixed-voltage vcc3v3-ngff-regulator: vcc3v3_ngff supplying 3300000uV
[ 0.206462] vbus: will resolve supply early: vin
[ 0.206924] reg-fixed-voltage vbus: Looking up vin-supply from device tree
[ 0.207610] vbus: supplied by dc_12v
[ 0.207973] dc_12v: could not add device link regulator.9: -ENOENT
[ 0.208644] vbus: 5000 mV, enabled
[ 0.209193] reg-fixed-voltage vbus: vbus supplying 5000000uV
[ 0.209987] vcc5v0_usb: will resolve supply early: vin
[ 0.210501] reg-fixed-voltage vcc5v0_usb: Looking up vin-supply from device tree
[ 0.211237] vcc5v0_usb: supplied by dc_12v
[ 0.211648] dc_12v: could not add device link regulator.10: -ENOENT
[ 0.212363] vcc5v0_usb: 5000 mV, enabled
[ 0.212939] reg-fixed-voltage vcc5v0_usb: vcc5v0_usb supplying 5000000uV
[ 0.213984] vcc5v0_usb_host: 5000 mV, disabled
[ 0.214615] reg-fixed-voltage vcc5v0-usb-host: Looking up vin-supply from device tree
[ 0.215405] vcc5v0_usb_host: supplied by vcc5v0_usb
[ 0.215967] reg-fixed-voltage vcc5v0-usb-host: vcc5v0_usb_host supplying 5000000uV
[ 0.217046] vcc5v0_usb_otg: 5000 mV, disabled
[ 0.217685] reg-fixed-voltage vcc5v0-usb-otg: Looking up vin-supply from device tree
[ 0.218468] vcc5v0_usb_otg: supplied by vcc5v0_usb
[ 0.219018] reg-fixed-voltage vcc5v0-usb-otg: vcc5v0_usb_otg supplying 5000000uV
[ 0.220279] iommu: Default domain type: Passthrough
[ 0.221178] SCSI subsystem initialized
[ 0.221874] libata version 3.00 loaded.
[ 0.222534] usbcore: registered new interface driver usbfs
[ 0.223143] usbcore: registered new interface driver hub
[ 0.223727] usbcore: registered new device driver usb
[ 0.225481] pps_core: LinuxPPS API ver. 1 registered
[ 0.226002] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.226920] PTP clock support registered
[ 0.227356] EDAC MC: Ver: 3.0.0
[ 0.228796] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[ 0.229727] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 0.230483] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[ 0.232244] Advanced Linux Sound Architecture Driver Initialized.
[ 0.234158] vgaarb: loaded
[ 0.235066] clocksource: Switched to clocksource arch_sys_counter
[ 0.324827] pnp: PnP ACPI: disabled
[ 0.338433] NET: Registered PF_INET protocol family
[ 0.339191] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.341480] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.342438] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.343396] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.344360] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.345144] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.345852] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.346768] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.348002] RPC: Registered named UNIX socket transport module.
[ 0.348594] RPC: Registered udp transport module.
[ 0.349061] RPC: Registered tcp transport module.
[ 0.349524] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.351198] PCI: CLS 0 bytes, default 64
[ 0.353013] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[ 0.354927] kvm [1]: IPA Size Limit: 40 bits
[ 0.355419] kvm [1]: GICv3: no GICV resource entry
[ 0.355898] kvm [1]: disabling GICv2 emulation
[ 0.356357] kvm [1]: GIC system register CPU interface enabled
[ 0.357153] kvm [1]: vgic interrupt IRQ9
[ 0.357844] kvm [1]: VHE mode initialized successfully
[ 0.361602] Initialise system trusted keyrings
[ 0.362348] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[ 0.374430] NFS: Registering the id_resolver key type
[ 0.374971] Key type id_resolver registered
[ 0.375424] Key type id_legacy registered
[ 0.375948] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.376616] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.377745] ksmbd: The ksmbd server is experimental
[ 0.432255] Key type asymmetric registered
[ 0.432671] Asymmetric key parser 'x509' registered
[ 0.433224] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.433958] io scheduler mq-deadline registered
[ 0.434408] io scheduler kyber registered
[ 0.438276] phy phy-fe8a0000.usb2phy.0: Looking up phy-supply from device tree
[ 0.439195] vcc5v0_usb_host: could not add device link phy-fe8a0000.usb2phy.0: -ENOENT
[ 0.440262] phy phy-fe8a0000.usb2phy.1: Looking up phy-supply from device tree
[ 0.441006] vcc5v0_usb_otg: could not add device link phy-fe8a0000.usb2phy.1: -ENOENT
[ 0.443969] phy phy-fe8b0000.usb2phy.2: Looking up phy-supply from device tree
[ 0.444700] phy phy-fe8b0000.usb2phy.2: Looking up phy-supply property in node /usb2phy@fe8b0000/host-port failed
[ 0.445858] phy phy-fe8b0000.usb2phy.3: Looking up phy-supply from device tree
[ 0.446580] phy phy-fe8b0000.usb2phy.3: Looking up phy-supply property in node /usb2phy@fe8b0000/otg-port failed
[ 0.449544] phy phy-fe830000.phy.4: Looking up phy-supply from device tree
[ 0.450243] phy phy-fe830000.phy.4: Looking up phy-supply property in node /phy@fe830000 failed
[ 0.451819] phy phy-fe840000.phy.5: Looking up phy-supply from device tree
[ 0.452509] phy phy-fe840000.phy.5: Looking up phy-supply property in node /phy@fe840000 failed
[ 0.454159] phy phy-fe820000.phy.6: Looking up phy-supply from device tree
[ 0.454849] phy phy-fe820000.phy.6: Looking up phy-supply property in node /phy@fe820000 failed
[ 0.457034] rockchip-snps-pcie3-phy fe8c0000.phy: failed to find rockchip,pipe_grf regmap
[ 0.457862] phy phy-fe8c0000.phy.7: Looking up phy-supply from device tree
[ 0.458547] phy phy-fe8c0000.phy.7: Looking up phy-supply property in node /phy@fe8c0000 failed
[ 0.463899] rockchip-dw-pcie 3c0400000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.731283] phy phy-fe8c0000.phy.7: lane number 0, val 1
[ 0.731822] phy phy-fe8c0000.phy.7: lane number 1, val 2
[ 0.732349] phy phy-fe8c0000.phy.7: bifurcation enabled
[ 0.733030] rockchip-dw-pcie 3c0400000.pcie: host bridge /pcie@fe270000 ranges:
[ 0.733785] rockchip-dw-pcie 3c0400000.pcie: Parsing ranges property...
[ 0.734458] rockchip-dw-pcie 3c0400000.pcie: IO 0x0341000000..0x03410fffff -> 0x0001000000
[ 0.735374] rockchip-dw-pcie 3c0400000.pcie: MEM 0x0341100000..0x037fffffff -> 0x0002000000
[ 0.744849] rockchip-dw-pcie 3c0400000.pcie: iATU unroll: enabled
[ 0.745458] rockchip-dw-pcie 3c0400000.pcie: Detected iATU regions: 8 outbound, 8 inbound
[ 1.851375] rockchip-dw-pcie 3c0400000.pcie: Phy link never came up
[ 1.852231] rockchip-dw-pcie 3c0400000.pcie: PCI host bridge to bus 0001:00
[ 1.852927] pci_bus 0001:00: root bus resource [bus 00-0f]
[ 1.853476] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x1000000-0x10fffff])
[ 1.854400] pci_bus 0001:00: root bus resource [mem 0x341100000-0x37fffffff] (bus address [0x02000000-0x40efffff])
[ 1.855462] pci_bus 0001:00: scanning bus
[ 1.855915] pci 0001:00:00.0: [1d87:3566] type 01 class 0x060400
[ 1.856551] pci 0001:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 1.857340] pci 0001:00:00.0: supports D1 D2
[ 1.857768] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 1.858342] pci 0001:00:00.0: PME# disabled
[ 1.858996] pci 0001:00:00.0: vgaarb: pci_notify
[ 1.864929] pci_bus 0001:00: fixups for bus
[ 1.865360] pci 0001:00:00.0: scanning [bus 01-ff] behind bridge, pass 0
[ 1.866177] pci_bus 0001:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[ 1.867277] pci_bus 0001:01: scanning bus
[ 1.872579] pci_bus 0001:01: fixups for bus
[ 1.873001] pci_bus 0001:01: bus scan returning with max=01
[ 1.873562] pci 0001:00:00.0: scanning [bus 01-ff] behind bridge, pass 1
[ 1.874235] pci_bus 0001:00: bus scan returning with max=ff
[ 1.874807] pci 0001:00:00.0: BAR 6: assigned [mem 0x341100000-0x34110ffff pref]
[ 1.875573] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 1.876612] rockchip-dw-pcie 3c0800000.pcie: Looking up vpcie3v3-supply from device tree
[ 1.935415] rockchip-dw-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 1.936171] rockchip-dw-pcie 3c0800000.pcie: Parsing ranges property...
[ 1.936847] rockchip-dw-pcie 3c0800000.pcie: IO 0x0381000000..0x03810fffff -> 0x0001000000
[ 1.937734] rockchip-dw-pcie 3c0800000.pcie: MEM 0x0381100000..0x03bfffffff -> 0x0002000000
[ 1.946741] rockchip-dw-pcie 3c0800000.pcie: iATU unroll: enabled
[ 1.947370] rockchip-dw-pcie 3c0800000.pcie: Detected iATU regions: 8 outbound, 8 inbound
[ 3.055387] rockchip-dw-pcie 3c0800000.pcie: Phy link never came up
[ 3.056193] rockchip-dw-pcie 3c0800000.pcie: PCI host bridge to bus 0002:00
[ 3.056888] pci_bus 0002:00: root bus resource [bus 00-0f]
[ 3.057438] pci_bus 0002:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x1000000-0x10fffff])
[ 3.058389] pci_bus 0002:00: root bus resource [mem 0x381100000-0x3bfffffff] (bus address [0x02000000-0x40efffff])
[ 3.059450] pci_bus 0002:00: scanning bus
[ 3.059899] pci 0002:00:00.0: [1d87:3566] type 01 class 0x060400
[ 3.060518] pci 0002:00:00.0: reg 0x10: [mem 0x00000000-0x3fffffff]
[ 3.061149] pci 0002:00:00.0: reg 0x14: [mem 0x00000000-0x3fffffff]
[ 3.061778] pci 0002:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 3.062567] pci 0002:00:00.0: supports D1 D2
[ 3.062996] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[ 3.063596] pci 0002:00:00.0: PME# disabled
[ 3.064248] pci 0002:00:00.0: vgaarb: pci_notify
[ 3.069825] pci_bus 0002:00: fixups for bus
[ 3.070257] pci 0002:00:00.0: scanning [bus 01-ff] behind bridge, pass 0
[ 3.071106] pci_bus 0002:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[ 3.072176] pci_bus 0002:01: scanning bus
[ 3.077432] pci_bus 0002:01: fixups for bus
[ 3.077856] pci_bus 0002:01: bus scan returning with max=01
[ 3.078417] pci 0002:00:00.0: scanning [bus 01-ff] behind bridge, pass 1
[ 3.079113] pci_bus 0002:00: bus scan returning with max=ff
[ 3.079688] pci 0002:00:00.0: BAR 0: no space for [mem size 0x40000000]
[ 3.080345] pci 0002:00:00.0: BAR 0: failed to assign [mem size 0x40000000]
[ 3.081035] pci 0002:00:00.0: BAR 1: no space for [mem size 0x40000000]
[ 3.081688] pci 0002:00:00.0: BAR 1: failed to assign [mem size 0x40000000]
[ 3.082377] pci 0002:00:00.0: BAR 6: assigned [mem 0x381100000-0x38110ffff pref]
[ 3.083138] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
[ 3.084974] EINJ: ACPI disabled.
[ 3.092251] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 3.093017] dma-pl330 fe530000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 3.097274] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 3.098032] dma-pl330 fe550000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 3.101286] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[ 3.107541] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.111520] printk: console [ttyS2] disabled
[ 3.112041] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 36, base_baud = 1500000) is a 16550A
[ 3.113189] printk: console [ttyS2] enabled
[ 3.113977] printk: bootconsole [uart8250] disabled
[ 3.119540] rockchip-vop2 fe040000.vop: Adding to iommu group 0
[ 3.120112] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 3.126691] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 3.139879] brd: module loaded
[ 3.148947] loop: module loaded
[ 3.149988] zram: Added device: zram0
[ 3.151960] ahci fc800000.sata: Looking up ahci-supply from device tree
[ 3.152568] ahci fc800000.sata: Looking up ahci-supply property in node /sata@fc800000 failed
[ 3.153366] ahci fc800000.sata: supply ahci not found, using dummy regulator
[ 3.154190] ahci fc800000.sata: Looking up phy-supply from device tree
[ 3.154782] ahci fc800000.sata: Looking up phy-supply property in node /sata@fc800000 failed
[ 3.155602] ahci fc800000.sata: supply phy not found, using dummy regulator
[ 3.156437] ahci fc800000.sata: Looking up target-supply from device tree
[ 3.157051] ahci fc800000.sata: Looking up target-supply property in node /sata@fc800000 failed
[ 3.157847] ahci fc800000.sata: supply target not found, using dummy regulator
[ 3.158702] ahci fc800000.sata: forcing port_map 0x0 -> 0x1
[ 3.159278] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 3.160044] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 3.160844] ahci fc800000.sata: port 0 is not capable of FBS
[ 3.162970] scsi host0: ahci
[ 3.163708] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 18
[ 3.168878] tun: Universal TUN/TAP device driver, 1.6
[ 3.170880] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[ 3.171761] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[ 3.172469] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[ 3.173388] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 3.173919] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output).
[ 3.174554] rk_gmac-dwmac fe010000.ethernet: TX delay(0x3c).
[ 3.175087] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2f).
[ 3.175606] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 3.181252] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 3.182073] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 3.182720] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 3.183226] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 3.183893] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 3.184553] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 3.185178] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 3.185844] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 3.186337] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 3.187084] rk_gmac-dwmac fe010000.ethernet: device MAC address ba:a6:e4:48:e8:48
[ 3.187758] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[ 3.188394] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 3.188929] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width
[ 3.326802] rk_gmac-dwmac fe2a0000.ethernet: IRQ eth_lpi not found
[ 3.328002] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply from device tree
[ 3.328730] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply property in node /ethernet@fe2a0000 failed
[ 3.329645] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 3.330177] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 3.330805] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x4f).
[ 3.331347] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0xf).
[ 3.331858] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 3.332500] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 3.338060] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 3.338876] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 3.339557] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 3.340024] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 3.340689] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 3.341348] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 3.341973] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 3.342630] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 3.343146] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 3.343867] rk_gmac-dwmac fe2a0000.ethernet: device MAC address c6:24:7f:06:e1:44
[ 3.344539] rk_gmac-dwmac fe2a0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 3.345173] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 3.345709] rk_gmac-dwmac fe2a0000.ethernet: Using 32 bits DMA width
[ 3.477707] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.482414] VFIO - User Level meta-driver version: 0.3
[ 3.492351] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.492950] ehci-pci: EHCI PCI platform driver
[ 3.493418] ehci-platform: EHCI generic platform driver
[ 3.496344] ehci-platform fd800000.usb: EHCI Host Controller
[ 3.496881] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 3.497729] ehci-platform fd800000.usb: irq 21, io mem 0xfd800000
[ 3.511117] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 3.512678] hub 1-0:1.0: USB hub found
[ 3.513074] hub 1-0:1.0: 1 port detected
[ 3.516360] ehci-platform fd880000.usb: EHCI Host Controller
[ 3.516893] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 3.517725] ehci-platform fd880000.usb: irq 23, io mem 0xfd880000
[ 3.531111] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 3.532548] hub 2-0:1.0: USB hub found
[ 3.532950] hub 2-0:1.0: 1 port detected
[ 3.534240] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.534822] ohci-pci: OHCI PCI platform driver
[ 3.535367] ohci-platform: OHCI generic platform driver
[ 3.536271] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 3.536893] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 3.537772] ohci-platform fd840000.usb: irq 22, io mem 0xfd840000
[ 3.600020] hub 3-0:1.0: USB hub found
[ 3.600412] hub 3-0:1.0: 1 port detected
[ 3.601619] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 3.602239] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 3.603133] ohci-platform fd8c0000.usb: irq 24, io mem 0xfd8c0000
[ 3.668037] hub 4-0:1.0: USB hub found
[ 3.668426] hub 4-0:1.0: 1 port detected
[ 3.670783] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.671345] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[ 3.672208] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[ 3.673124] xhci-hcd xhci-hcd.0.auto: irq 19, io mem 0xfcc00000
[ 3.674905] hub 5-0:1.0: USB hub found
[ 3.675348] hub 5-0:1.0: 1 port detected
[ 3.676173] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.676681] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[ 3.677374] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 3.678062] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.679680] hub 6-0:1.0: USB hub found
[ 3.680069] hub 6-0:1.0: 1 port detected
[ 3.681236] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 3.681754] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
[ 3.682608] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[ 3.683558] xhci-hcd xhci-hcd.1.auto: irq 20, io mem 0xfd000000
[ 3.685264] hub 7-0:1.0: USB hub found
[ 3.685655] hub 7-0:1.0: 1 port detected
[ 3.686484] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 3.686991] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
[ 3.687742] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 3.688431] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.690001] hub 8-0:1.0: USB hub found
[ 3.690391] hub 8-0:1.0: 1 port detected
[ 3.691571] usbcore: registered new interface driver usb-storage
[ 3.692935] i2c_dev: i2c /dev entries driver
[ 3.696704] rk808 0-0020: failed to read the chip id at 0x17
[ 3.702212] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 0
[ 4.707108] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 4.719099] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 1
[ 5.731148] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 5.743100] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 2
[ 6.755104] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 6.767098] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 3
[ 7.779128] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 7.791098] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 4
[ 8.803103] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 8.815099] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 5
[ 9.827103] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 9.839098] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 6
[ 10.851104] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 10.863097] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 7
[ 11.875103] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 11.887098] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 8
[ 12.899102] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 12.911099] rtc-hym8563 3-0051: hym8563_init_device: probe attempt 9
[ 13.923105] rk3x-i2c fe5c0000.i2c: timeout, ipd: 0x00, state: 1
[ 13.935098] rtc-hym8563 3-0051: could not init device, -110
[ 13.939322] rtc-hym8563: probe of 3-0051 failed with error -110
[ 13.941182] arm-scmi firmware:scmi: Failed. SCMI protocol 21 not active.
[ 13.943817] rockchip-thermal fe710000.tsadc: Missing tshut mode property, using default (gpio)
[ 13.944591] rockchip-thermal fe710000.tsadc: Missing tshut-polarity property, using default (low)
[ 13.951323] arm-scmi firmware:scmi: Failed. SCMI protocol 19 not active.
[ 13.953942] sdhci: Secure Digital Host Controller Interface driver
[ 13.954505] sdhci: Copyright(c) Pierre Ossman
[ 13.955671] Synopsys Designware Multimedia Card Interface Driver
[ 13.957203] sdhci-pltfm: SDHCI platform and OF driver helper
[ 13.959584] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply from device tree
[ 13.960263] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply property in node /mmc@fe310000 failed
[ 13.961132] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply from device tree
[ 13.961705] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 13.961798] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply property in node /mmc@fe310000 failed
[ 13.962459] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 13.964455] usbcore: registered new interface driver usbhid
[ 13.964960] usbhid: USB HID core driver
[ 13.966208] SPI driver st-accel-spi has no spi_device_id for st,lis302dl-spi
[ 13.966838] SPI driver st-accel-spi has no spi_device_id for st,lis3lv02dl-accel
[ 13.967527] SPI driver st-accel-spi has no spi_device_id for st,lis3dh-accel
[ 13.968153] SPI driver st-accel-spi has no spi_device_id for st,lsm330d-accel
[ 13.968782] SPI driver st-accel-spi has no spi_device_id for st,lsm330dl-accel
[ 13.969419] SPI driver st-accel-spi has no spi_device_id for st,lsm330dlc-accel
[ 13.970063] SPI driver st-accel-spi has no spi_device_id for st,lis331dlh-accel
[ 13.970707] SPI driver st-accel-spi has no spi_device_id for st,lsm330-accel
[ 13.971342] SPI driver st-accel-spi has no spi_device_id for st,lsm303agr-accel
[ 13.971984] SPI driver st-accel-spi has no spi_device_id for st,lis2dh12-accel
[ 13.972616] SPI driver st-accel-spi has no spi_device_id for st,lng2dm-accel
[ 13.973232] SPI driver st-accel-spi has no spi_device_id for st,h3lis331dl-accel
[ 13.973877] SPI driver st-accel-spi has no spi_device_id for st,lis331dl-accel
[ 13.981341] NET: Registered PF_INET6 protocol family
[ 13.982891] Segment Routing with IPv6
[ 13.983275] In-situ OAM (IOAM) with IPv6
[ 13.983661] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 13.984541] NET: Registered PF_PACKET protocol family
[ 13.985207] Key type dns_resolver registered
[ 13.985900] registered taskstats version 1
[ 13.986267] Loading compiled-in X.509 certificates
[ 13.991465] zswap: loaded using pool zstd/zsmalloc
[ 13.995125] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[ 14.052923] mmc1: error -84 whilst initialising MMC card
[ 14.073658] mt7530 stmmac-0:00: no interrupt support
[ 14.097064] mt7530 stmmac-0:00: configuring for fixed/rgmii link mode
[ 14.100312] mt7530 stmmac-0:00: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.139860] mt7530 stmmac-0:00 lan0 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 14.141560] mmc1: error -84 whilst initialising MMC card
[ 14.184351] mt7530 stmmac-0:00 lan1 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 14.233692] mt7530 stmmac-0:00 lan2 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 14.234770] mmc1: error -84 whilst initialising MMC card
[ 14.277026] mt7530 stmmac-0:00 lan3 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=POLL)
[ 14.281343] DSA: tree 0 setup
[ 14.293272] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 14.295594] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 14.296913] ALSA device list:
[ 14.297187] No soundcards found.
[ 14.297705] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[ 14.298470] Waiting for root device /dev/mmcblk0p3...
[ 14.299032] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 14.299833] cfg80211: failed to load regulatory.db
[ 14.324823] mmc1: error -84 whilst initialising MMC card
I’ve tried two different SD cards (both Samsung EVO Plus) with the same results. Is this a board issue, or am I missing something? Is it possible it’s the brand of SD card I’m using and, if so, can someone recommend a better SD card?
- its and some changes to build.sh were missing…pushed it and put itb on my card…also added sysboot to uboot defconfig
