I try to make working my new pci-e board with mt7615e. Board is visible in Network-Wireless as ‘MediaTek MT7615E 802.11bgnac’ but:
- not hear any other APs in Scan,
- when i enable AP with 2.4N mode its not visible on air
- when i enable AP with 5AC mode its visible on air but clients cant obtain IP addresses
- cant set tx power higher then 6dbm
- cant set 5 and 2.4 APs in same time
root@Banana:~# dmesg | grep pci [ 1.616524] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00 [ 1.622662] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x1a160000-0x1a16ffff]) [ 1.632086] pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fffffff] [ 1.638924] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.644386] pci 0000:00:00.0: [14c3:0801] type 01 class 0x060400 [ 1.644419] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff] [ 1.644474] pci 0000:00:00.0: supports D1 [ 1.644481] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 1.644780] pci 0000:00:01.0: [14c3:0801] type 01 class 0x060400 [ 1.644808] pci 0000:00:01.0: reg 0x14: [mem 0x00000000-0x0000ffff] [ 1.644856] pci 0000:00:01.0: supports D1 [ 1.644862] pci 0000:00:01.0: PME# supported from D0 D1 D3hot [ 1.652085] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.660047] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.668117] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280 [ 1.668156] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit] [ 1.675467] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 1.675579] pci 0000:02:00.0: [1b21:0611] type 00 class 0x010185 [ 1.675608] pci 0000:02:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 1.682599] pci 0000:02:00.0: reg 0x10: [io size 0x0008] [ 1.682612] pci 0000:02:00.0: reg 0x14: initial BAR value 0x00000000 invalid [ 1.689619] pci 0000:02:00.0: reg 0x14: [io size 0x0004] [ 1.689633] pci 0000:02:00.0: reg 0x18: initial BAR value 0x00000000 invalid [ 1.696636] pci 0000:02:00.0: reg 0x18: [io size 0x0008] [ 1.696649] pci 0000:02:00.0: reg 0x1c: initial BAR value 0x00000000 invalid [ 1.703639] pci 0000:02:00.0: reg 0x1c: [io size 0x0004] [ 1.703652] pci 0000:02:00.0: reg 0x20: initial BAR value 0x00000000 invalid [ 1.710654] pci 0000:02:00.0: reg 0x20: [io size 0x0010] [ 1.710668] pci 0000:02:00.0: reg 0x24: [mem 0x00000000-0x000001ff] [ 1.710682] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref] [ 1.717943] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02 [ 1.717987] pci 0000:00:00.0: BAR 8: assigned [mem 0x60000000-0x600fffff] [ 1.724721] pci 0000:00:01.0: BAR 8: assigned [mem 0x60100000-0x601fffff] [ 1.731469] pci 0000:00:01.0: BAR 9: assigned [mem 0x60200000-0x602fffff pref] [ 1.738646] pci 0000:00:00.0: BAR 1: assigned [mem 0x60300000-0x6030ffff] [ 1.745394] pci 0000:00:01.0: BAR 1: assigned [mem 0x60310000-0x6031ffff] [ 1.752129] pci 0000:00:01.0: BAR 7: assigned [io 0x1000-0x1fff] [ 1.758189] pci 0000:01:00.0: BAR 0: assigned [mem 0x60000000-0x600fffff 64bit] [ 1.765461] pci 0000:00:00.0: PCI bridge to [bus 01] [ 1.770387] pci 0000:00:00.0: bridge window [mem 0x60000000-0x600fffff] [ 1.777145] pci 0000:02:00.0: BAR 6: assigned [mem 0x60200000-0x6020ffff pref] [ 1.784310] pci 0000:02:00.0: BAR 5: assigned [mem 0x60100000-0x601001ff] [ 1.791059] pci 0000:02:00.0: BAR 4: assigned [io 0x1000-0x100f] [ 1.797118] pci 0000:02:00.0: BAR 0: assigned [io 0x1010-0x1017] [ 1.803165] pci 0000:02:00.0: BAR 2: assigned [io 0x1018-0x101f] [ 1.809224] pci 0000:02:00.0: BAR 1: assigned [io 0x1020-0x1023] [ 1.815282] pci 0000:02:00.0: BAR 3: assigned [io 0x1024-0x1027] [ 1.821331] pci 0000:00:01.0: PCI bridge to [bus 02] [ 1.826265] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff] [ 1.832310] pci 0000:00:01.0: bridge window [mem 0x60100000-0x601fffff] [ 1.839054] pci 0000:00:01.0: bridge window [mem 0x60200000-0x602fffff pref] [ 1.846380] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [ 1.852562] pcieport 0000:00:00.0: Signaling PME with IRQ 217 [ 1.858422] pcieport 0000:00:00.0: AER enabled with IRQ 217 [ 1.864119] pcieport 0000:00:01.0: enabling device (0140 -> 0143) [ 1.870289] pcieport 0000:00:01.0: Signaling PME with IRQ 218 [ 1.876128] pcieport 0000:00:01.0: AER enabled with IRQ 218
root@Banana:~# dmesg | grep mt76 [ 51.140713] mt7615e 0000:01:00.0: enabling device (0140 -> 0142) [ 51.148163] mt7615e 0000:01:00.0: Invalid MAC address, using random address 6a:a9:c0:69:04:f0 [ 51.252805] mt7615e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a [ 51.480407] mt7615e 0000:01:00.0: N9 Firmware Version: 2.0, Build Time: 20200131181812 [ 51.517454] mt7615e 0000:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20190121161307
root@Banana:~# opkg list-installed | grep mt kmod-block2mtd - 4.19.108-1 kmod-mt76 - 4.19.108+2020-03-10-a94e43f2-1 kmod-mt76-core - 4.19.108+2020-03-10-a94e43f2-1 kmod-mt7603 - 4.19.108+2020-03-10-a94e43f2-1 kmod-mt7615e - 4.19.108+2020-03-10-a94e43f2-1 kmod-mt76x02-common - 4.19.108+2020-03-10-a94e43f2-1 kmod-mt76x2 - 4.19.108+2020-03-10-a94e43f2-1 kmod-mt76x2-common - 4.19.108+2020-03-10-a94e43f2-1 mtd - 25
root@Banana:~# uname -r 4.19.108
root@Banana:~# iw list Wiphy phy1 max # scan SSIDs: 4 max scan IEs length: 2243 bytes max # sched scan SSIDs: 0 max # match sets: 0 max # scan plans: 1 max scan plan interval: -1 max scan plan iterations: 0 Retry short limit: 7 Retry long limit: 4 Coverage class: 0 (up to 0m) Available Antennas: TX 0xf RX 0xf Configured Antennas: TX 0xf RX 0xf Supported interface modes: * IBSS * managed * AP * AP/VLAN * monitor * mesh point Band 1: Capabilities: 0x1ff RX LDPC HT20/HT40 SM Power Save disabled RX Greenfield RX HT20 SGI RX HT40 SGI TX STBC RX STBC 1-stream Max AMSDU length: 3839 bytes No DSSS/CCK HT40 Maximum RX AMPDU length 65535 bytes (exponent: 0x003) Minimum RX AMPDU time spacing: 4 usec (0x05) HT TX/RX MCS rate indexes supported: 0-31 Frequencies: * 2412 MHz [1] (6.0 dBm) * 2417 MHz [2] (6.0 dBm) * 2422 MHz [3] (6.0 dBm) * 2427 MHz [4] (6.0 dBm) * 2432 MHz [5] (6.0 dBm) * 2437 MHz [6] (6.0 dBm) * 2442 MHz [7] (6.0 dBm) * 2447 MHz [8] (6.0 dBm) * 2452 MHz [9] (6.0 dBm) * 2457 MHz [10] (6.0 dBm) * 2462 MHz [11] (6.0 dBm) * 2467 MHz [12] (6.0 dBm) * 2472 MHz [13] (6.0 dBm) * 2484 MHz [14] (disabled) Band 2: Capabilities: 0x1ff RX LDPC HT20/HT40 SM Power Save disabled RX Greenfield RX HT20 SGI RX HT40 SGI TX STBC RX STBC 1-stream Max AMSDU length: 3839 bytes No DSSS/CCK HT40 Maximum RX AMPDU length 65535 bytes (exponent: 0x003) Minimum RX AMPDU time spacing: 4 usec (0x05) HT TX/RX MCS rate indexes supported: 0-31 VHT Capabilities (0x338001fa): Max MPDU length: 11454 Supported Channel Width: 160 MHz, 80+80 MHz RX LDPC short GI (80 MHz) short GI (160/80+80 MHz) TX STBC RX antenna pattern consistency TX antenna pattern consistency VHT RX MCS set: 1 streams: MCS 0-9 2 streams: MCS 0-9 3 streams: MCS 0-9 4 streams: MCS 0-9 5 streams: not supported 6 streams: not supported 7 streams: not supported 8 streams: not supported VHT RX highest supported: 0 Mbps VHT TX MCS set: 1 streams: MCS 0-9 2 streams: MCS 0-9 3 streams: MCS 0-9 4 streams: MCS 0-9 5 streams: not supported 6 streams: not supported 7 streams: not supported 8 streams: not supported VHT TX highest supported: 0 Mbps Frequencies: * 5180 MHz [36] (6.0 dBm) * 5200 MHz [40] (6.0 dBm) * 5220 MHz [44] (6.0 dBm) * 5240 MHz [48] (6.0 dBm) * 5260 MHz [52] (6.0 dBm) (radar detection) * 5280 MHz [56] (6.0 dBm) (radar detection) * 5300 MHz [60] (6.0 dBm) (radar detection) * 5320 MHz [64] (6.0 dBm) (radar detection) * 5500 MHz [100] (disabled) * 5520 MHz [104] (disabled) * 5540 MHz [108] (disabled) * 5560 MHz [112] (disabled) * 5580 MHz [116] (disabled) * 5600 MHz [120] (disabled) * 5620 MHz [124] (disabled) * 5640 MHz [128] (disabled) * 5660 MHz [132] (6.0 dBm) (radar detection) * 5680 MHz [136] (6.0 dBm) (radar detection) * 5700 MHz [140] (6.0 dBm) (radar detection) * 5745 MHz [149] (6.0 dBm) * 5765 MHz [153] (6.0 dBm) * 5785 MHz [157] (6.0 dBm) * 5805 MHz [161] (6.0 dBm) * 5825 MHz [165] (6.0 dBm) valid interface combinations: * #{ IBSS } <= 1, #{ managed, AP, mesh point } <= 4, total <= 4, #channels <= 1, STA/AP BI must match, radar detect widths: { 20 MHz (no HT), 20 MHz, 40 MHz, 80 MHz, 80+80 MHz, 160 MHz } HT Capability overrides: * MCS: ff ff ff ff ff ff ff ff ff ff * maximum A-MSDU length * supported channel width * short GI for 40 MHz * max A-MPDU length exponent * min MPDU start spacing Supported extended features: * [ VHT_IBSS ]: VHT-IBSS * [ RRM ]: RRM * [ CQM_RSSI_LIST ]: multiple CQM_RSSI_THOLD records * [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211 * [ TXQS ]: FQ-CoDel-enabled intermediate TXQs * [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
whats wrong?
