Hi guys
I need some help here please, this issue is kinda unexplainable to me.
So since the internal wifi chip is basically unusable in a proper production environment (it just stops authenticating after being on for a longer time) I tried getting 2.4GHz and 5GHz working on my MT7615 PCIe card.
I can get either 2.4GHz or 5GHz working wihout issue when NOT in DBDC mode, all good there.
I can ONLY get 2.4GHz working properly when in DBDC mode for some reason.
5GHz âworksâ in the sense that I can see the SSID in my list and try to connect to it, I even get an IP address but then then client just disconnects after a few seconds and I canât reconnect again. If I want to try to reconnect again and be âsuccessfulâ then I need to wait for the station to be recognized from hostapd to be disconnected ro restart hostapd.
Does anyone got a working hostapd config or something that I could check if Iâm missing something?
The same config works in non-DBDC mode btw. so itâs just odd for me that it doesnât work for some reason in DBDC mode with the appropiate interface. wlan0 for 2.4GHz and wlan1 for 5GHz as seen in the âiw listâ capabilities.
My config:
interface=wlan1
bridge=br1
driver=nl80211
hw_mode=a
ctrl_interface=/var/run/wlan1
ctrl_interface_group=0
logger_syslog=-1
logger_syslog_level=1
logger_stdout=-1
logger_stdout_level=1
beacon_int=100
dtim_period=2
ssid=xxx
utf8_ssid=1
auth_algs=3
wpa=2
wpa_key_mgmt=WPA-PSK WPA-PSK-SHA256
rsn_pairwise=CCMP
rsn_preauth=1
ieee80211w=2
wpa_psk=xxx
channel=44
vht_oper_centr_freq_seg0_idx=50
acs_exclude_dfs=0
max_num_sta=255
ieee80211d=1
ieee80211h=1
spectrum_mgmt_required=1
local_pwr_constraint=3
country_code=xx
ieee80211n=1
ht_capab=[LDPC][HT40+][HT40-][GF][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-3839]
ieee80211ac=1
vht_capab=[MAX-A-MPDU-LEN-EXP3][MAX-MPDU-7991][RXLDPC][SHORT-GI-80][TX-STBC-2BY1][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][BF-ANTENNA-2][SOUNDING-DIMENSION-2]
vht_oper_chwidth=1
wmm_enabled=1
wmm_ac_bk_cwmin=4
wmm_ac_bk_cwmax=10
wmm_ac_bk_aifs=7
wmm_ac_bk_txop_limit=0
wmm_ac_bk_acm=0
wmm_ac_be_aifs=3
wmm_ac_be_cwmin=4
wmm_ac_be_cwmax=10
wmm_ac_be_txop_limit=0
wmm_ac_be_acm=0
wmm_ac_vi_aifs=2
wmm_ac_vi_cwmin=3
wmm_ac_vi_cwmax=4
wmm_ac_vi_txop_limit=94
wmm_ac_vi_acm=0
wmm_ac_vo_aifs=2
wmm_ac_vo_cwmin=2
wmm_ac_vo_cwmax=3
wmm_ac_vo_txop_limit=47
wmm_ac_vo_acm=0
I replaced some values with âxâ because of⌠well obvious reasons.
To pre-answer some possible questions that may come: There are two phys and two wlan interfaces when in DBDC mode. There are three seperate configs to be used with the appropiate mode and interface with appropiate adjusted capabilities.
I really donât know what else to try hereâŚ
