Hello,
Now I know how to boot BPI-R2. Just pressing Power button about 10 seconds.
But… how can I safely shutdown it? I searched some articles but I failed to find answer.
Thanks!
Hello,
Thanks!
You can use my kernels (4.14,4.19,5.4) and simply use poweroff command
If you use lede,you need to extract patches from my repo and include in your building-process
https://github.com/frank-w/BPI-R2-4.14/commits/5.3-poweroff-new (5.4-mainline contains 6 patches so use 5.3 patches for lower kernel versions)
Really thank you for your answer and sorry for poor problem description.
I’m using your 4.4.160 Kernel (https://github.com/frank-w/BPI-R2-4.4/) (also thank you for the kernel!
When I typed sudo poweroff, the SSH connection was closed and the display (HDMI) went out.
But I don’t know it’s really shutting downed or not, because all the LEDs are still brightly on.
Yesterday, I got a SDcard filesystem error during boot after I unpluged DC power to completely turn off it. (It was about 30 minutes after I typed poweroff command.)
Is it safe to unplug the power cable after the display turned off in normal cases?
4.4 does not contain poweroff drivers,it is only a updated version (for security,but still old) of official repo.Just use the 4.14 repo
For the bpi-r2, the only sane OS I have found for it is the Armbian image. It’s working great as a Tor relay and as a time server. I would have liked to do yet more with it, but I could not figure out how to do it.
Otherwise, to quickly power down your bpi-r2, just use ‘init 0’.
How about my ubuntu/debian image? Real poweroff only works with poweroff patches. I guess armbian does not have them so it does only a halt,but board stays on (~5w power consumption)
