Hello I nhave a BPI-R2 (4.4.70-BPI-R2-Kernel) I am colletting data from LAN port over eth0. I want to know the physical data port(LAN0,LAN1,LAN2,LAN3) from which the tcp data comes. Could you give me a start point or information ? Best Regards
Bpi-r2 get information of lan port
Afaik this is only possible with newer kernel and dsa driver. There each port has its own interface that can be read using tcpdump or ethtool
How can i get newer kernel and dsa driver ?could you recommend a download image link Best Regards
You could try my debian or ubuntu images i posted in this forum,they already contain a newer kernel. You can compile newer one from my github repo
You could also try OpenSuse’s Tumbleweed on the bpi-r2
https://en.opensuse.org/HCL:BananaPi_R2
Linux banana 5.18.11-1-default #1 SMP Fri Jul 15 05:36:11 UTC 2022 (4fcb983) armv7l armv7l armv7l GNU/Linux
Hopefully it would do what you would need.
Is internal wifi supported? I wonder about hdmi audio…is there any kernel source for it?
I used kernel 4.14. is it enuogh for my purpose ?
4.14 should have dsa driver which gives you an separate interface for each port (wan,lan0…lan3). You have to put eth0 up only and set ip-address to the dsa userport (wan,lanX) then you can check traffic on these ports and read out information you need (ethtool,tcpdump,…)
it works thank you. Best regards
