Hi. BPI/SBC newbie here. I have a new M5, and I’m trying to install CoreELEC. I am following the guide (@sinovoipcoreelec:bpi [CoreELEC Wiki]). All good until I use the terminal emulator to ‘reboot update’ so as to install CoreELEC form the SD card. But I get ‘permission denied’. Is there a Super User install for BPI-M5? A rooted Android image? (I don’t know why it is necessary to flash android first). I have tried ‘wiping’ the EMMC android OS by interrupting the flash process, so as to try and force it to boot from SD. No good.
Any help much appreciated. I can’t find any info on this - but there must be others who have encountered/resolved it.
I got past this by using ADB to ‘reboot update’ - but this only worked if i used a usb port on my PC that outputs enough amps. If using another one, it would not boot from SD.
Now I can boot up CoreELEC from SD. But now, how do I install it onto the eMMC? The ceemmc tool said the BPI-M5 is not supported. Using the -x option and and accepting the warning, I then get the following:…
Starting CoreELEC eMMC installation tool…
System is not supported: sm1_s905x3_bananapi_m5!
There is NO official support by Team CoreELEC
if you continue to run this tool!
Continue? [y]: y
eMMC size: 0x0003a3e00000 [16GB]
No CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
Use CoreELEC data from
[1] current used SD or USB device
[2] existing backup on current used SD or USB device
Install in single boot mode, only CoreELEC on eMMC
[3] current used SD or USB device
[4] existing backup on current used SD or USB device
Please choose one option? [1/2/3/4]: 3
Free space of ‘partition CE_FLASH’: 512MB
Warning: Could not find ‘dto’ partition!
Could not find ‘CE_STORAGE’ partition!
Failed to read size of partition ‘CE_STORAGE’!
Failed to create new partition table!
CoreELEC-BPIM5:~ #
I got past that by choosing the dual boot install option. All good. Now…to work out how to power it on with my Logitech Harmony remote. Any assistance most appreciated.
