We have designed a program to display the voltage of potentiometer and progress bar on the OLED screen in the previous page. What if we use SSD1306 OLED screen in combination with some sensors, like DHT11?
DHT11 is a basic and low cost digital temperature and humidity sensor. It uses capacitive humidity sensor and thermistor to measure the humidity in the surrounding area, and converts it to the digital signal. Then the signal will be transimitted to the microcontroller from the data pins, which can receive the humidity data through the single line communication protocol.
How to connect
| DHT11 | Board |
| GND | GND |
| DAT | GPIO1 |
| VCC | 5V |
| SSD1306 OLED | Board |
| GND | GND |
| VCC | 5V |
| SCL | 16 |
| SDA | 15 |
Micropython
Micropython establishment of operating environment - Banana Pi Wiki (banana-pi.org)
Micropython framebuf documents
Micropython ssd1306.py on Github
Micropython DHT driver documents
Program code
from machine import Pin,I2C
from ssd1306 import SSD1306_I2C
import time
import dht
dht11 = dht.DHT11(Pin(1))
sda_pin=Pin(15,Pin.PULL_UP)
scl_pin=Pin(16,Pin.PULL_UP)
i2c = I2C(1,sda=sda_pin, scl=scl_pin, freq=800_000)
print(i2c.scan())
oled = SSD1306_I2C(128, 64, i2c, addr=0x3c)
#Init, white background
oled.fill(1)
oled.rect(0,22,128,10,0)
oled.rect(0,53,128,10,0)
while True:
#Read DHT11
dht11.measure() # Measure and read data once.
temperature = dht11.temperature() # -20℃ ~ 60℃
humidity = dht11.humidity() # 5%RH ~ 95%RH
#Set temperature text, centered
text_1 = str(temperature) + " C"
start_x_1 = 64 - len(text_1)*4
oled.fill_rect(0,14,128,8,1)
oled.text(text_1,start_x_1,14,0)
#Set temperature bar
bar_1 = round ((temperature+20)/80 * 128)
oled.fill_rect(bar_1,23,128-bar_1,8,0)
oled.fill_rect(0,23,bar_1,8,1)
#Set humidity text, centered
text_2 = str(humidity) + " %RH"
start_x_2 = 64 - len(text_2)*4
oled.fill_rect(0,45,128,8,1)
oled.text(text_2,start_x_2,45,0)
#Set humidity bar
humidity_bar = round (humidity/100 * 128)
oled.fill_rect(humidity_bar,54,128-humidity_bar,8,0)
oled.fill_rect(0,54,humidity_bar,8,1)
#Show
oled.show()
print("Temperature={0}℃,Humidity={1}%RH".format(temperature,humidity))
Video demo:
Banana Pi BPI-Leaf-S3 wiki page: https://wiki.banana-pi.org/BPI-Leaf-S3
