BPI-Leaf S2 with ESP32-S2 design for STEAM education,support arduino,micropython,Webduino
The Banana Pi BPI-Leaf Series is a low-powered microcontroller designed for IoT development purposes. The Leaf-S2 has Xtensa® 32 bit LX7 single core processor on board with frequency up to 240 MHz. It features Wi-Fi connection and supports various peripherals. The board can be powered via USB or 3.7V lithium battery. The compact size, an abundance of IO, and user-friendly interface are a great fit for low-power consumption IoT projects. It is also compatible with the Arduino IDE. Programming-wise, it supports Arduino, idf(linux), and MicroPython. These features combined with marked IOs makes this all in all very user-friendly.
N otice : The ESP32 is aimed towards developers, not all peripherals are provided with example codes. Potential bugs are yet to be tackled. In the Arduino IDE environment, IO pins and I2C/SPI are enabled and can be used directly, other features are still under development.
main spac:
- Processor: Xtensa® 32-bit LX7 single-core processor, Main frequency: 240MHz. SRAM: 320 KB, Flash: 32 mbit,PSRAM: 16 mbit
- Wi-Fi: IEEE 802.11b/G/N, Frequency range: 2.4 to 2.5 GHz
- Bluetooth protocol: Complies with Bluetooth V4.2 BR/EDR and BLE standards
- bluetooth audio: CVSD and SBC audio low power consumption: 10uA
- Operating current: 80mA (average)
- Frequency range: 2.4 to 2.5GHz
- Support Arduino downloads
- Support micropython
- Operating voltage: 3.3V, Input voltage: 3.3V to 5.5V, low power consumption: 10uA, Maximum ,discharge current: [email protected] LDO, maximum charging current: 500mA
- Support USB charging
- On-chip clock:40MHz oscillator
- SPI:1, I2C:1,I2S:1
- LED_BUILTIN:13
- Docking support:breadboard compatible
- Operating temperature:-40℃~+85℃
- Package size:26 × 65(mm)/1.02 x 2.57(inches)
- Mounting hole size:inner ring 2mm/ outer ring 3mm
Hardware interface:
BoardDimensions
- Each pin distance:2.54mm
- Mounting hole distance: 23mm/ 62.25mm
- Mounting hole size: Inner ring 2mm/ outer ring 3mm
- Board size: 26 × 65(mm)/ 1.02 x 2.57(inches)
- Board depth: 1.2mm
Source code on github:
https://github.com/BPI-STEAM/BPI-Leaf-S2-Doc
Banana Pi for STEAM education BPI-Steam website: https://bpi-steam.com/
welcome for OEM&ODM project , please contace [email protected]
