BPI-Forge1 and BPI-AIM7 Display 7 HD
BG3_72241
ArmSoM Display 7 HD
The ArmSoM Display 7 HD is a color active-matrix thin-film transistor (TFT) liquid crystal display (LCD) that uses amorphous silicon TFT as the switching device. This model consists of the following components:
  • TFT LCD Panel
  • Driving Circuit
  • Backlight System
  • Adapter Board
This TFT LCD features a 7.0-inch diagonally measured active display area with WXGA resolution (800 horizontal × 1280 vertical pixels).
Ideal for interactive projects such as tablets, entertainment systems, and information dashboards.
Compatibility​
  • Forge1
  • AIM7
Display Panel Specifications​
Basic Parameters​
  • Panel Size: 7 inches (inch)
  • Number of Pixels: 800×1280 (pixels)
  • Active Area: 94.2 mm × 150.72 mm
  • Pixel Pitch: 0.11775 mm × 0.11775 mm
  • Outline Dimension: 160.85 mm (H) × 99.65 mm (W) × 2.5 mm (D)
Display Characteristics​
  • Number of Colors: 16.7 million colors (16.7M)
  • Display Mode: Normally Black
  • Viewing Direction: IPS (In-Plane Switching)
  • Display Format: RGB Vertical Strip
  • Luminance: 300 cd/m² (Typ.)
  • Contrast Ratio: 700:1 (Typ.)
  • Surface Treatment: Anti-Glare
Interfaces & Hardware​
  • Interface: MIPI (Mobile Industry Processor Interface)
  • Backlight: White LED
  • Driver IC: GH8555BL
Environmental & Physical Properties​
  • Operation Temperature: -10°C ~ 50°C
  • Storage Temperature: -20°C ~ 60°C
  • Weight: 141.5 / g
