I have built u-boot from source (which includes files such as FSBL, u-boot proper, and bootinfo_*). I have flashed the u-boot FSBL.bin to the emmc along with bootinfo file. The FSBL is working fine. I configured the FSBL to take u-boot proper through Y-modem instead of finding it in the partition.
Once the u-boot FSBL starts, I provide it with u-boot proper through UART Y-modem. The u-boot proper is also working fine and boots to the autoboot console. Then I use tftpboot to transfer the kernel uImage to the u-boot proper at the memory address which is indicated by “Image load offset from start of RAM when load kernel to RAM” option (by default it is 0x2000000). I also load the dtb to memory at a different offset from kernel. The loaded kernel is converted to uImage using following command before transferring to u-boot:
mkimage -A riscv -O linux -T kernel -C none -a 0x2000000 -e 0x2000000 -n "Linux Kernel" -d Image uImage
Now issue is that when I boot the kernel with dtb using bootm command on the u-boot proper which I transferred using Y-modem, the kernel stuck at Starting Kernel ...:
## Booting kernel from Legacy Image at 00200000 ...
[ 332.526] Image Name: Linux Kernel
[ 332.529] Image Type: RISC-V Linux Kernel Image (uncompressed)
[ 332.535] Data Size: 34397696 Bytes = 32.8 MiB
[ 332.540] Load Address: 00200000
[ 332.543] Entry Point: 00200000
Verifying Checksum ... OK
[ 332.702] ## Flattened Device Tree blob at 08000000
[ 332.704] Booting using the fdt blob at 0x8000000
[ 332.709] Loading Kernel Image
[ 332.735] Loading Device Tree to 000000007dd7d000, end 000000007dd95167 ... OK
Starting kernel ...
This does not happen when I suspend the boot from bianbu linux and use its u-boot to boot the kernel from tftp.
Can someone tell me what am I doing wrong?
U-boot and linux which I am using are present on bianbu Linux link: Banana Pi BPI-F3 | BananaPi Docs
