In /boot/env.txt, there are two settings: max_freq_a53 and max_freq_a73. These are marked with a default value in the comment, but the values in the file do not match.
More importantly, no matter what value I set here, the CPUs are both limited to 1704.
For example, I tried setting them both to 1800, yet:
% cat /sys/devices/system/cpu/cpu[02]/cpufreq/cpuinfo_max_freq
1704000
1704000
% cat /sys/devices/system/cpu/cpu[02]/cpufreq/scaling_available_frequencies
500000 667000 1000000 1200000 1398000 1512000 1608000 1704000
In other words, both the A53 and A72 cores are limited to 1.704GHz, even though I set 1.800GHz for both.
You can see the setting in the file took effect by looking at /proc/cmdline:
% cat /proc/cmdline
root=/dev/mmcblk0p2 rootfstype=ext4 rw console=tty1 console=ttyS0,115200n8 board=bananapi_cm4 loglevel=7 fsck.mode=force fsck.repair=yes logo=osd0,loaded,0x3d800000,panel vout=panel,enable hdmimode=1080p60hz fbcon=rotate:0 net.ifnames=0 wol_enable= max_freq_a53=1800 max_freq_a73=1800 serial=290b1000011e04000006373837504350 systemd.machine_id=290b1000011e04000006373837504350 jtag=disable coherent_pool=2M pci=pcie_bus_safe
How do I set the CPU frequencies to the other values? Thanks!
