BPI-CM4 baseboard case
I made a simple case for the CM4 baseboard. STL and FreeCAD files here:
I worked off the DXF which Banana Pi released with a little bit of tolerances. Fit isn’t perfect but it works for me at least.
Getting the board in requires a little diagonal squeezing of the case.
Thnak you for sharing I will print it
