text method
text(font, s, x, y {, fg, bg, alpha})
Write text to the display using the specified bitmap font with the coordinates as the upper-left corner of the text.
The optional arguments fg and bg can set the foreground and background colors of the text; otherwise the foreground color defaults to WHITE, and the background color defaults to BLACK.
alpha defaults to 255.
See the README.md in the fonts/bitmap directory for example fonts.
bitmap font
The BPI-Centi-S3 factory firmware contains two bitmap font files.
vga1_8x16.mpy
vga1_bold_16x32.mpy
They come from https://github.com/russhughes/st7789s3_esp_lcd/tree/main/fonts/bitmap.
From this I selected these two most commonly used, using [MPY-CROSS Tool] (https://pypi.org/project/mpy- cross/) to transform them into a .mpy format to reduce the volume of files.
download font file
If you mistakenly delete the font file or erase the Flash, you need to download the font file again. You can download it from the previous text link, or you can download the fonts in the link below to the font of the .mpy format, including the example below.
[From here to download fonts and examples] (https://github.com/bpi-team/bpi-s3-doc/micropython_example/04_display_text)
Display text
""" BPI-Centi-S3 170x320 ST7789 display """
import st7789
import tft_config
import vga1_8x16
import vga1_bold_16x32
These default colors can be used:
BLACK BLUE CYAN GREEN
MAGENTA RED YELLOW WHITE
TRANSPARENT
Custom RGB colors:
color565(255,255,255)
fg = st7789.BLACK
bg = st7789.WHITE
text_x = 10
text_y = 10
def main():
try:
tft = tft_config.config(rotation=1)
tft.init()
tft.fill(st7789.WHITE)
tft.text(vga1_8x16, "Hello World!", text_x, text_y, fg, bg, 255)
tft.text(vga1_bold_16x32, "MicroPython!", text_x, text_y+16, fg, bg, 255)
tft.text(vga1_8x16, "vga1_8x16", text_x, text_y+16+32, fg, bg, 255)
tft.text(vga1_bold_16x32, "vga1_bold_16x32",
text_x, text_y+16+32+16, fg, bg, 255)
tft.show()
except BaseException as err:
err_type = err.__class__.__name__
print('Err type:', err_type)
from sys import print_exception
print_exception(err)
finally:
tft.deinit()
print("tft deinit")
main()
Use a transparent background and Alpha channel to make shadow fonts
The reasonable use of st7789.TRANSPARENT as the background color of the text can make the background of the text not change.
By setting the alpha parameter in the text method, the overall transparency of the text can be changed, with a range of 0 ~ 255.
import st7789
import tft_config
import vga1_8x16
TRANSPARENT
Custom RGB colors:
fg = st7789.BLACK
bg = st7789.TRANSPARENT
text_x = 10
text_y = 50
def main():
try:
tft.init()
tft.text(vga1_8x16, "Hello World!", text_x-1, text_y-1, fg, bg, 205)
tft.text(vga1_bold_16x32, "MicroPython!", text_x-2, text_y+16-2, fg, bg, 205)
tft.show()
finally:
tft.deinit()
print("tft deinit")
main()
