Display multiple vector fonts
draw method
draw(vector_font, s, x, y {, fg, scale, alpha})
Draw text to the display using the specified Hershey vector font with the coordinates as the lower-left corner of the text. The foreground color of the text can be set by the optional argument fg. Otherwise the foreground color defaults to WHITE. The size of the text can be scaled by specifying a scale value. The scale value must be larger than 0 and can be a floating-point or an integer value. The scale value defaults to 1.0. alpha defaults to 255.
draw_len method
draw_len(vector_font, s {, scale})
Returns the string’s width in pixels if drawn with the specified font.
Download vector font library
There is a vector font library in py file format in the GitHub:russhughes/st7789s3_esp_lcd/fonts/vector, and there are pictures of all fonts in the README.
In example lib, you can also download the converted mpy file format vector font library, taking up less flash space.
Display multiple vector fonts and refresh continuously
The width of the string to be displayed can be obtained through the draw_len method, but the height of some of the provided vector fonts will exceed the set value. If you need to keep the text box completely covering it, you need to modify the corresponding code to increase the height of the text box.
""" BPI-Centi-S3 170x320 ST7789 display """
import st7789
import tft_config
import gotheng
import italicc
import romanc
import time
import gc
from math import ceil
These default colors can be used:
BLACK BLUE CYAN GREEN
MAGENTA RED YELLOW WHITE
TRANSPARENT
Custom RGB colors:
color565(255,255,255)
class DrawRect:
def __init__(self):
self.tft = None
self.text_y = None
self.text_x = None
self.rect_x = None
self.rect_y = None
self.rect_height = None
self.rect_width = None
def rect(self, tft, vector_font, scale, text, text_coord,
fg=st7789.WHITE, bg=st7789.BLACK, alpha_text=255, alpha_rect=255):
self.tft = tft
self.rect_width = self.tft.draw_len(vector_font, text, scale)
self.rect_height = ceil(vector_font.HEIGHT * scale)
self.text_x = text_coord[0]
self.text_y = text_coord[1]
self.rect_x = ceil(self.text_x - vector_font.WIDTH * scale / 8)
self.rect_y = round(self.text_y - vector_font.HEIGHT * scale / 2 + 1)
self.tft.fill_rect(self.rect_x, self.rect_y,
self.rect_width, self.rect_height, bg, alpha_rect)
self.tft.draw(vector_font, text, self.text_x, self.text_y,
fg, scale, alpha_text)
def erase(self, bg):
buffer, _, _ = self.tft.jpg_decode(bg, self.rect_x, self.rect_y, self.rect_width, self.rect_height)
self.tft.blit_buffer(buffer, self.rect_x, self.rect_y, self.rect_width, self.rect_height)
def main():
try:
tft = tft_config.config(rotation=1)
tft.init()
jpg = 'pic_4.jpg'
text_x = 10
text_y = 20
text_list = [
"0123456789:;<=>?",
"@ABCDEFGHIJKLMNO",
"PQRSTUVWXYZ[\]^_",
"`abcdefghijklmno",
"pqrstuvwxyz{|}~",
draw_rect_1 = DrawRect()
draw_rect_2 = DrawRect()
draw_rect_3 = DrawRect()
while True:
for i in text_list:
draw_rect_1.rect(tft, gotheng, 0.8, i, (text_x, text_y),
fg=st7789.WHITE, bg=st7789.BLACK, alpha_text=255, alpha_rect=20)
draw_rect_2.rect(tft, italicc, 0.8, i, (text_x, text_y+32),
fg=st7789.WHITE, bg=st7789.BLACK, alpha_text=255, alpha_rect=40)
draw_rect_3.rect(tft, romanc, 0.8, i, (text_x, text_y + 64),
fg=st7789.WHITE, bg=st7789.BLACK, alpha_text=255, alpha_rect=60)
tft.show()
time.sleep(0.5)
draw_rect_1.erase(bg=jpg)
draw_rect_2.erase(bg=jpg)
draw_rect_3.erase(bg=jpg)
gc.collect()
except BaseException as err:
err_type = err.__class__.__name__
print('Err type:', err_type)
from sys import print_exception
print_exception(err)
finally:
tft.deinit()
print("tft deinit")
main()
Enlarge or reduce font size
You can control the font size by modifying the scale value of the draw method.
import st7789
import tft_config
import gotheng
import italicc
import romanc
import time
import gc
TRANSPARENT
Custom RGB colors:
class DrawRect:
def __init__(self):
self.tft = None
self.text_y = None
self.text_x = None
self.rect_x = None
self.rect_y = None
self.tft = tft
def main():
try:
tft.init()
jpg = 'pic_4.jpg'
text_x = 10
text_y = 20
text_list = [
"0123456789",
"ABCDEFGHI",
"PQRSTUVWX",
"abcdefghij",
"pqrstuvwxy",
while True:
for i in text_list:
draw_rect_1.rect(tft, romanc, 0.5, i, (text_x, text_y),
draw_rect_2.rect(tft, romanc, 1, i, (text_x, text_y+24),
draw_rect_3.rect(tft, romanc, 1.5, i, (text_x, text_y + 64),
tft.show()
time.sleep(0.5)
gc.collect()
finally:
tft.deinit()
print("tft deinit")
main()
