missing
The 6GHz band remains in a disabled state and cannot be activated.
OpenWrt version: SNAPSHOT (r28062-be3e7a84bd)
The MP4.0 image works properly, but due to various issues with the MP4.0 image, I do not plan to use it.
config wifi-device 'radio0'
option type 'mac80211'
option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0'
option band '2g'
option channel 'auto'
option htmode 'EHT40'
option cell_density '0'
option country 'JP'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option ssid 'OpenWrt_2G'
option encryption 'none'
config wifi-device 'radio1'
option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0+1'
option band '5g'
option htmode 'EHT160'
option country 'JP'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'ap'
option ssid 'OpenWrt_5G'
config wifi-device 'radio2'
option path 'soc/11300000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0+2'
option band '6g'
option htmode 'EHT320'
option country 'JP'
config wifi-iface 'default_radio2'
option device 'radio2'
option mode 'ap'
option ssid 'OpenWrt_6G'
frank-w
(Frank W.)
2
Have you tried smaller band with 6g? Maybe there is no eht320 block allowed in japan
missing
3
I tried.
no matter if it’s BE mode or AX mode, it’s always disabled.
I guess it is because of the missing password, but it is just a guess.
Try config like:
option band '2g'
option channel '8'
option txpower '20'
option country 'PL'
option mode 'ap'
option ssid 'Network_2G'
option encryption 'psk2'
option skip_inactivity_poll '1'
option max_listen_interval '86400'
option key 'Password1234'
option wnm_sleep_mode '1'
option bss_transition '1'
option band '5g'
option channel '100'
option htmode 'HE160'
option txpower '20'
option country 'PL'
option mode 'ap'
option ssid 'Network'
option encryption 'sae'
option ieee80211k '1'
option ocv '0'
option band '6g'
option channel '53'
option country 'PL'
option mode 'ap'
option ssid 'Network_6G'
option ocv '0'
and should be working fine. If 320MHz is needed, just change to JP and set 320.
Tombpi
5
WPA3 must be used when using 6G band.
Hostpad or wpad will refuse encryption modes other than WPA3 to be used with 6G when processing wifi profiles.
