Hi, I found out that the CM4 starts the bootloader and it takes 10 seconds before it starts running the Linux OS. How can we shorten this time?
Bootloader takes a long time (10s) on BPI CM4
If this is the Grub bootloader you could change the bootloader timeout setting of grub…
See: https://linuxhint.com/change-grub-timeout-linux/
EDIT: It seems after testing myself that the boot sequence times several seconds. When booting via SD-card. Because it first tries to boot from eMMC flash, then it will try to boot from SD-card. I think you can’t change this behavior.
