I have a BPI R4 4GB PoE (I soldered myself like 6 month ago) which I bought December 2024. I was using it with the OpenWRT images but just used the official poe 4gb sd card image to test this. Everything seems normal to me until the last line:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 5.4.260 ([email protected]) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 unknown)) #0 SMP Fri Jan 19 02:26:09 2024
[ 0.000000] Machine model: Bananapi BPI-R4
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000011000000 (options '')
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 0.000000] On node 0 totalpages: 1045952
[ 0.000000] DMA32 zone: 12288 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 783808 pages, LIFO batch:63
[ 0.000000] Normal zone: 4096 pages used for memmap
[ 0.000000] Normal zone: 262144 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 20 pages/cpu s44376 r8192 d29352 u81920
[ 0.000000] pcpu-alloc: s44376 r8192 d29352 u81920 alloc=20*4096
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1029568
[ 0.000000] Kernel command line: console=ttyS0,115200n1 loglevel=8 earlycon=uart8250,mmio32,0x11000000 2
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] software IO TLB: mapped [mem 0xfb7ed000-0xff7ed000] (64MB)
[ 0.000000] Memory: 4025132K/4183808K available (8382K kernel code, 600K rwdata, 2460K rodata, 512K init, 295K bss, 158676K reserved, 0K cma-reserved)
[ 0.000000] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000002] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.008280] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=52000)
[ 0.018676] pid_max: default: 32768 minimum: 301
[ 0.023405] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.030900] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.039448] ASID allocator initialised with 65536 entries
[ 0.044959] rcu: Hierarchical SRCU implementation.
[ 0.050059] smp: Bringing up secondary CPUs ...
My System crashed sometime yesterday or so (I wasn’t home for 1 day). Does this mean my cpu is fried? Since I can’t even get into anything (except the web recovery ui, which isn’t helpful to this I think).
Something similar also happens with the OpenWRT images, but there it halts at “Starting Kernel…”.
If anyone knows something, would be great to know if I need to contact the vendor and pray.
