Hi All,
I have 2 banana pi r4s both running latest openwrt mainline build. Both are connected to each other using the 10G SFP+ module from the official store (link). One board acts as a client and other as server.
The sfp+ module is getting detected as well. But when I run iperf3 tests, it can only reach 5Gbps speed. Even in the ethtool, it shows max 5000baseT/Full. Also, hw forward offloading option doesnt work with the firewall.
ethtool output:
root@OpenWrt:~# ethtool sfp-lan
Settings for sfp-lan:
Supported ports: [ ]
Supported link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
2500baseT/Full
5000baseT/Full
Advertised link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
2500baseT/Full
5000baseT/Full
Link partner advertised link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
2500baseT/Full
5000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Speed: 10000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 11
Transceiver: external
MDI-X: Unknown
Link detected: yes
dmesg logs:
root@OpenWrt:~# dmesg | grep sfp
[ 3.947083] mtk_soc_eth 15100000.ethernet sfp-lan: renamed from eth1
[ 3.962654] mtk_soc_eth 15100000.ethernet sfp-wan: renamed from eth2
[ 11.499684] sfp sfp1: Host maximum power 2.0W
[ 11.504580] sfp sfp2: Host maximum power 2.0W
[ 11.826513] sfp sfp2: module OEM SFP-10G-T rev 1 sn 2409090010 dc 240909
[ 16.521303] mtk_soc_eth 15100000.ethernet sfp-lan: configuring for inband/10gbase-r link mode
[ 16.553200] br-lan: port 4(sfp-lan) entered blocking state
[ 16.558719] br-lan: port 4(sfp-lan) entered disabled state
[ 16.564263] mtk_soc_eth 15100000.ethernet sfp-lan: entered allmulticast mode
[ 16.571523] mtk_soc_eth 15100000.ethernet sfp-lan: entered promiscuous mode
[ 16.638991] mtk_soc_eth 15100000.ethernet sfp-wan: configuring for inband/10gbase-r link mode
[ 16.671495] br-wan: port 2(sfp-wan) entered blocking state
[ 16.677052] br-wan: port 2(sfp-wan) entered disabled state
[ 16.682601] mtk_soc_eth 15100000.ethernet sfp-wan: entered allmulticast mode
[ 16.690254] mtk_soc_eth 15100000.ethernet sfp-wan: entered promiscuous mode
[ 43.351331] mtk_soc_eth 15100000.ethernet sfp-lan: PHY [i2c:sfp2:11] driver [Aquantia AQR113C] (irq=POLL)
[ 80.280325] mtk_soc_eth 15100000.ethernet sfp-lan: left allmulticast mode
[ 80.287126] mtk_soc_eth 15100000.ethernet sfp-lan: left promiscuous mode
[ 80.293859] br-lan: port 4(sfp-lan) entered disabled state
[ 80.681761] mtk_soc_eth 15100000.ethernet sfp-wan: left allmulticast mode
[ 80.688569] mtk_soc_eth 15100000.ethernet sfp-wan: left promiscuous mode
[ 80.695299] br-wan: port 2(sfp-wan) entered disabled state
[ 82.493217] mtk_soc_eth 15100000.ethernet sfp-lan: configuring for inband/10gbase-r link mode
[ 82.524478] br-lan: port 4(sfp-lan) entered blocking state
[ 82.529962] br-lan: port 4(sfp-lan) entered disabled state
[ 82.535455] mtk_soc_eth 15100000.ethernet sfp-lan: entered allmulticast mode
[ 82.542586] mtk_soc_eth 15100000.ethernet sfp-lan: entered promiscuous mode
[ 82.617943] mtk_soc_eth 15100000.ethernet sfp-wan: configuring for inband/10gbase-r link mode
[ 82.649209] br-wan: port 2(sfp-wan) entered blocking state
[ 82.654692] br-wan: port 2(sfp-wan) entered disabled state
[ 82.660191] mtk_soc_eth 15100000.ethernet sfp-wan: entered allmulticast mode
[ 82.667353] mtk_soc_eth 15100000.ethernet sfp-wan: entered promiscuous mode
[ 109.388312] mtk_soc_eth 15100000.ethernet sfp-lan: PHY [i2c:sfp2:11] driver [Aquantia AQR113C] (irq=POLL)
[ 115.693211] mtk_soc_eth 15100000.ethernet sfp-lan: Link is Up - 10Gbps/Full - flow control rx/tx
[ 115.693239] br-lan: port 4(sfp-lan) entered blocking state
[ 115.707473] br-lan: port 4(sfp-lan) entered forwarding state
And iperf3 output:
root@OpenWrt:~# iperf3 -c 192.168.1.1 -b10G
Connecting to host 192.168.1.1, port 5201
[ 5] local 192.168.1.104 port 39032 connected to 192.168.1.1 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 576 MBytes 4.83 Gbits/sec 0 209 KBytes
[ 5] 1.00-2.00 sec 569 MBytes 4.77 Gbits/sec 0 216 KBytes
[ 5] 2.00-3.00 sec 564 MBytes 4.73 Gbits/sec 0 331 KBytes
[ 5] 3.00-4.00 sec 562 MBytes 4.71 Gbits/sec 0 320 KBytes
[ 5] 4.00-5.00 sec 561 MBytes 4.70 Gbits/sec 0 314 KBytes
[ 5] 5.00-6.00 sec 483 MBytes 4.05 Gbits/sec 0 211 KBytes
[ 5] 6.00-7.00 sec 564 MBytes 4.73 Gbits/sec 0 195 KBytes
[ 5] 7.00-8.00 sec 564 MBytes 4.73 Gbits/sec 0 233 KBytes
[ 5] 8.00-9.00 sec 563 MBytes 4.72 Gbits/sec 0 209 KBytes
[ 5] 9.00-10.00 sec 563 MBytes 4.72 Gbits/sec 0 198 KBytes
[ 5] 0.00-10.00 sec 5.44 GBytes 4.67 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 5.44 GBytes 4.67 Gbits/sec receiver
iperf Done.
Could you all please let me know what could be the issue? Also, let me know if additional information is required.
Thanks, Rajas
