Creat a script in /bin/
vim /bin/fan_control
#!/bin/ash
# Temperature sensor path
TEMP_PATH="/sys/class/thermal/thermal_zone0/temp"
# Trip Points for Fan Speed Control
TRIP_0="/sys/class/thermal/thermal_zone0/trip_point_0_temp"
TRIP_1="/sys/class/thermal/thermal_zone0/trip_point_1_temp"
TRIP_2="/sys/class/thermal/thermal_zone0/trip_point_2_temp"
TRIP_3="/sys/class/thermal/thermal_zone0/trip_point_3_temp"
TRIP_4="/sys/class/thermal/thermal_zone0/trip_point_4_temp"
# Temperature thresholds (in millidegrees Celsius)
LOW_TEMP=30000
MEDIUM_TEMP=42000
HIGH_TEMP=49000
VERY_HIGH_TEMP=70000
CRITICAL_TEMP=80000
HYSTERESIS=4000
# Previous fan level (-1 means uninitialized)
PREV_LEVEL=-1
log_message() {
logger -t fan_control "$1"
set_trip_points() {
local level=$1
case $level in
0) # Fan OFF (stop spinning)
echo $VERY_HIGH_TEMP > $TRIP_4
echo $VERY_HIGH_TEMP > $TRIP_3
echo $VERY_HIGH_TEMP > $TRIP_2
1) # Low speed
echo 0 > $TRIP_4
2) # Medium speed
echo 0 > $TRIP_4
echo 0 > $TRIP_3
3) # High speed
echo 0 > $TRIP_4
echo 0 > $TRIP_3
echo 0 > $TRIP_2
esac
PREV_LEVEL=$level
# Set emergency shutdown temperature
echo $VERY_HIGH_TEMP > $TRIP_1
echo $CRITICAL_TEMP > $TRIP_0
while true; do
# Read current temperature
if [ -f "$TEMP_PATH" ]; then
TEMP=$(cat "$TEMP_PATH")
else
log_message "Error: Unable to read temperature from $TEMP_PATH"
exit 1
fi
# Determine fan speed level based on hysteresis control
case $PREV_LEVEL in
0)
if [ "$TEMP" -ge "$LOW_TEMP" ]; then
LEVEL=1
else
LEVEL=0
fi
1)
if [ "$TEMP" -ge "$MEDIUM_TEMP" ]; then
LEVEL=2
elif [ "$TEMP" -le "$((LOW_TEMP - HYSTERESIS))" ]; then
LEVEL=0
else
LEVEL=1
fi
2)
if [ "$TEMP" -ge "$HIGH_TEMP" ]; then
LEVEL=3
elif [ "$TEMP" -le "$((MEDIUM_TEMP - HYSTERESIS))" ]; then
LEVEL=1
else
LEVEL=2
fi
3)
if [ "$TEMP" -le "$((HIGH_TEMP - HYSTERESIS))" ]; then
LEVEL=2
else
LEVEL=3
fi
LEVEL=0 # Default to fan OFF
esac
# Update fan speed only if the level changes
if [ "$LEVEL" -ne "$PREV_LEVEL" ]; then
log_message "Fan speed changed: Level $LEVEL"
set_trip_points "$LEVEL"
fi
sleep 2
done
Add exectuable permission
chmod +x /bin/fan_control
Add service in /etc/init.d
vim /etc/init.d/fan_control
#!/bin/sh /etc/rc.common
# OpenWrt init script for fan_control
USE_PROCD=1
START=99
STOP=10
start_service() {
procd_open_instance
procd_set_param command fan_control
procd_set_param respawn 3600 5 5
procd_close_instance
chmod +x /etc/init.d/fan_control
Start service
/etc/init.d/fan_control enable
/etc/init.d/fan_control start
Now, you can notice the fan is running smoothly, and you can check the status by logread
root@OpenWrt:~# lodread -e fan_control
Sun Mar 30 10:42:41 2025 user.notice fan_control: Fan speed changed: Level 0
Sun Mar 30 10:42:43 2025 user.notice fan_control: Fan speed changed: Level 1
Sun Mar 30 10:42:45 2025 user.notice fan_control: Fan speed changed: Level 2
Sun Mar 30 10:44:07 2025 user.notice fan_control: Fan speed changed: Level 3
