BananaPi-M7 u-boot image
Does anyone have an uptodate or older u-boot image for the BananaPi-M7 or Sige7 if that will work please ?
The mainline U-Boot should already be compatible with booting SIG/GE7. You can find the Rockchip U-Boot here: GitHub - ArmSoM/u-boot
For long-term development needs, you can use our BSP: GitHub - ArmSoM/manifests: ARMSOM series board source code repository
Here is the documentation: 1. ArmSom-SDK Release | ArmSoM docs
We will maintain this service long-term. Please feel free to provide any feedback.
Hi Lou,
Do you have an existing built u-boot image for the BananaPi-M7 ?
I am wondering if it would be possible to add a GitHub build action and releases ? I could help with this if needed.
Aaron
@luo I have got to :- 4.2 Update Individual Source Code Repositories Using Git
cd debain12
debian is spelt wrong ! Correcting this
cd debian12
Next … I am getting
aaronngray@ubuntu:~/armsom-sdk$ cd debian12
aaronngray@ubuntu:~/armsom-sdk/debian12$ # Checkout to corresponding repository's default branch
git checkout lbc-develop-5.10
# Pull git repository
git pull
error: pathspec 'lbc-develop-5.10' did not match any file(s) known to git
remote: Enumerating objects: 15, done.
remote: Counting objects: 100% (15/15), done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 9 (delta 5), reused 9 (delta 5), pack-reused 0 (from 0)
Unpacking objects: 100% (9/9), 4.39 MiB | 2.53 MiB/s, done.
From https://github.com/armsom/debian12
 * [new branch]      main       -> origin/main
You are not currently on a branch.
Please specify which branch you want to merge with.
See git-pull(1) for details.
    git pull <remote> <branch>
aaronngray@ubuntu:~/armsom-sdk/debian12$ git branch
* (no branch)
ls .git is giving :-
aaronngray@ubuntu:~/armsom-sdk/debian12$ ls .git
branches  description  HEAD   index  logs     packed-refs  rr-cache
config    FETCH_HEAD   hooks  info   objects  refs         shallow
I am confused as .git directory is a link :-
aaronngray@ubuntu:~/armsom-sdk/debian12$ ls -al .git
lrwxrwxrwx 1 aaronngray aaronngray 30 Dec 30 15:15 .git -> ../.repo/projects/debian12.git
Even trying :-
aaronngray@ubuntu:~/armsom-sdk/debian12$ git clone --bare ../.repo/projects/debian12.git
Cloning into bare repository 'debian12.git'...
remote: Enumerating objects: 1550, done.
remote: Counting objects: 100% (1550/1550), done.
remote: Compressing objects: 100% (1288/1288), done.
remote: Total 1550 (delta 159), reused 1550 (delta 159), pack-reused 0
Receiving objects: 100% (1550/1550), 921.81 MiB | 101.15 MiB/s, done.
Resolving deltas: 100% (159/159), done.
* (no branch)
I am getting no branch !
My setup :-
aaronngray@ubuntu:~/armsom-sdk/debian12$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 24.04.3 LTS
Release:	24.04
Codename:	noble
aaronngray@ubuntu:~/armsom-sdk/debian12$ git --version
git version 2.43.0
I overwrite Debian12 with :-
git clone https://github.com/ArmSoM/debian12.git
Ran
./build.sh armsom-sige7_rk3588_debian_xfce_linux6.1_defconfig
./build.sh uboot asked me to install Python 2 :-
wget https://www.python.org/ftp/python/2.7.18/Python-2.7.18.tgz
tar xf Python-2.7.18.tgz
cd Python-2.7.18
sudo apt-get install libsqlite3-dev
./configure --enable-optimizations
sudo make install -j8
./build.sh uboot
./build debian did not work it asked me to install :-
sudo apt-get remove live-build
git clone https://salsa.debian.org/live-team/live-build.git --depth 1 -b debian/1%20230131
and build
cd live-build
rm -rf manpages/po/
cd ..
./build.sh debian
built
I have the following which is what I think I need to create a mmcblk0 bootstrap for booting NVMe :-
aaronngray@ubuntu:~/armsom-sdk$ ls output/firmware
MiniLoaderAll.bin  rootfs.img  uboot.img
Are there any instructions for burning them to the mmcblk0 eMMC flash please ?
It would be good to get this corrected and make it as a GitHub Action generating releases on any updates.
./build.sh armsom-sige7_rk3588_debian_xfce_linux6.1_defconfig After executing this command, it is best to execute it /Build. sh to generate complete firmware, and then consider compiling partitions
