SinoVoip, one of Armbian’s Platinum Partners, has teamed up with Armbian to give away their Banana Pi CM4 with a carrier board.
Specifications: (for the full list, check vendor documentation)
- Amlogic A311D 4xARM Cortex-A73 + 2xARM Cortex-A53
- ARM G52 MP4(6EE) GPU
- Compatible with RaspberryPi CM4 baseboard
- NPU for AI 5.0 TOPS
- 4 GB LPDDR4
- 16G eMMC flash
- 1x USB 2.0 Type-A port, 1x USB Type-C port (M2S)
- 2x Gigabit Ethernet ports (M2S)
While you are here, feel free to comment below on what you would do with the board if you win! Armbian is always looking for new volunteers for many positions. If you have time to volunteer, consider applying for one of the open positions!
To enter, you need to sign-up to the Armbian Forum and wait one day (24 hours) to pass the bot check, and then you can enter the contest here!
