Banana Pi Wifi7 router product design. we will Mass production it
Nice! Maybe add some oled screen in front case?
Now only the indicator board is added, the next version can be considered to add OLED
Better to have small e-ink screen for information like load/temperatures/fan. They can seat on the spi bus with low pin count.
Good morning @sinovoip, are you finally reconsidering having the antennas on all four sides?
By having the BE14 separated, will it reduce noise and increase power?
Currently, these are my temperatures. The highest is the 10GB SFP+RJ45 since I have 10GB symmetrical ports.
On 5GB, my temperature reaches 50 degrees, and on 2.5GB, 40 degrees. With the modifications I currently have, the pink one is the SFP+fiber XGS-PON WAS-110, which is magnificent.
Have you taken the temperatures into account, especially the 10GB SFP+RJ 45?
The rest of the antenna and CPU thermal temperatures.
I hope for your help.
The position of the antenna can be placed on both sides, freely chosen. Our actual test, put on one side has little effect. There will be antenna lines on both sides of the shell spare holes, if not used it, can be used as heat dissipation
Good morning @sinovoip and thank you for your reply.
Thanks for the antennas.
One question: Has moving the BE14 made any difference? Has the noise improved?
Now, as you mentioned in a previous post, we could choose between internal or external power supplies.
Has the UART cable, which has an external output, been taken into account?
Have you considered including the BE1900s in the project again in the future?
And most importantly, when will they be available for sale?
Have a nice day.
1,Power : yes , support the same time.
2,BE19000 design now.
a90f5299ecf62914fb7e17eed02d3bf
3, we mass production it now . maybe ready in one month.
SFP RJ45 generates a lot of heat, which can only be solved by using a fan or adding a heat sink.
We have reserved a position for 4040 fan
Good morning @sinovoip @simon, I currently have a 35x35x10 fan on both the SFP+ and the RJ-45 ports.
I’m so glad you have the BE19000 design. Let’s see how it works. I know @simon you’re in charge of this project, since I’ve been following you, and when you finish a couple of projects, you’ll probably go back to the BE19000. But if you confirm both, that’s great news.
I’m eagerly awaiting the new case and the BE19000.
Sorry, UART, has it been taken into account to be able to use it externally?
Thanks for listening.
Sorry, what do you mean by this?
Good morning @simon, I mean, has it been considered to put the UART externally so we can communicate with the board?
I currently have it like the photo, but I don’t see how to put it on the box if there’s no output for them. I’ve seen people modifying it, but I don’t know if it’s exactly this way so we can have it externally.
Is it possible for the box to have the connections external?
uart external
Thanks for your reply.
OK,you mean the debug console UART,
This is 1.25mm pitch, you should use 2.54MM
you can use somthing like this,
Good afternoon, that’s correct @simon. I wanted to know if the new case could have a dedicated external UART output, if it would come standard.
Or will we have to install it ourselves, but with an output like the first case,
since the photos don’t show any output on the new case.
Regards
Good afternoon @simon @sinovoip, could you please let us know how production is going for the new box, and for the be19000, if it will be released at the end of this month or by the end of June, or maybe earlier?
The image @simon be19000 will be released with 21.02. There will also be a variant for 24.10 in the first release.
Thanks for your response.
When will the new case be available?
Good afternoon @simon, @sinovoip, you mentioned on April 29th that you were mass producing.
Please let us know how everything is going and if it will be released roughly on what date.
Thank you.
Am i stupid or do i count 14 antennas needed for BE19000 and only 10 antenna ports are available at pro case? And would be nice to get 2 or 4 extra ports for 5g modems :smiley:
Good afternoon @simon, @sinovoip, can you please provide us with information on how the new case and the BE19000 are being manufactured?
About when it will go on sale.
Thanks for letting us know.
any news here? Would like to see the final case
