Banana-Pi R64 not booting
I have tried about half a dozen times to re-flash openwrt on and get running the my Banana-Pi R64. The formatting and the flashing of the image on to the sd card go as expected. However, during the boot process the uart logs report:
Thanks,
Aaron
Any help? I am confuse as to what is causing the pi to not boot.
I only see uboot menu multiple times in the log…
That is the only thing that I could get! Maybe trying a different operating system might help?
What happens if you select the boot option (when automatic boot does not work). Any errors?
How do I do that? I can’t even ssh in to the device.
You see it on serial and you should change it too with your pc…
Ah ok! Will need to read the logs again.
