Banana Pi R4 PCM/SPI Help
I’m trying to use the PCM/SPI in the 26 pin GPIO connector.
Using the following dts modification:
&afe {
    pinctrl-names = "default";
    pinctrl-0 = <&pcm_pins>;
    status = "okay";
    #sound-dai-cells = <1>;
&spi1 {
    status = "okay";
    spidev@0 {
        compatible = "rohm,dh2228fv";
        reg = <0>;
        spi-max-frequency = <10000000>;
&pio {
    pcm_pins: pcm-pins {
        mux {
            function = "pcm";
            groups = "pcm";
    sound {
        compatible = "simple-audio-card";
        simple-audio-card,name = "BPI-R4-SLIC";
        simple-audio-card,format = "dsp_a";  /* DSP_A = PCM Mode with Frame Sync */
        /* The MT7988 (CPU) must be the Master generating CLK and SYNC */
        simple-audio-card,bitclock-master = <&dailink0_master>;
        simple-audio-card,frame-master = <&dailink0_master>;
        simple-audio-card,mclk-fs = <256>;
        simple-audio-card,cpu {
            sound-dai = <&afe 0>;
        dailink0_master: simple-audio-card,codec {
            sound-dai = <&codec_dummy>;
    /* Dummy codec since the SLIC is controlled via SPI */
    codec_dummy: codec_dummy {
        compatible = "linux,snd-soc-dummy";
        #sound-dai-cells = <0>;
However, the following error happens on boot: [ 20.950992] platform sound: deferred probe pending: asoc-simple-card: parse error
Trying to use the latest OpenWRT, any help?
Regards, Maxime
Are you sure you can link a subnode? This looks like circular depency.
I guess you have to move this out of the sound node…not sure what this node should do
I will try! It seems correct but not sure if it can cause the issue
It did no fix the issue, anyone use PCM or I2S on the R4 before?
||/*  @GPIO(50,51,52,53,54) i2s */|
||PINCTRL_PIN_GROUP(i2s, mt7988_i2s),|
||/*  @GPIO(50,51,52,53) pcm */|
||PINCTRL_PIN_GROUP(pcm, mt7988_pcm),|
you can try the below modification
&pio {
        mux {
            function = "i2s";
            groups = "i2s";
No, using i2s instead of pcm changed nothing…
I modified the DTS to the following without success either…
&spi1 {
    status = "okay";
    spidev@0 {
        reg = <0>;
&pio {
        mux {
            function = "pcm";
            groups = "pcm";
&afe {
    compatible = "mediatek,mt7986-afe";
    status = "okay";
        status = "okay";
    sound {
        simple-audio-card,bitclock-master = <&snd_cpu>;
        simple-audio-card,frame-master = <&snd_cpu>;
        status = "okay";
        snd_cpu: simple-audio-card,cpu {
            sound-dai = <&afe 2>;
            dai-tdm-slot-num = <2>;
            dai-tdm-slot-width = <16>;
        snd_codec: simple-audio-card,codec {
