I picked up another Banana Pi R3 mini. Tried installing rooter firmware on eMMC (like my other one) and got this message when copying the files:
root@OpenWrt:/dev# dd if=/tmp/openwrt-mediatek-filogic-bananapi_bpi-r3-mini-initramfs-recovery.itb of=/dev/mmcblk0p4
dd: error writing '/dev/mmcblk0p4': No space left on device
4097+0 records in
4096+0 records out
Not sure how to fix this? I’ll search and see if I can find anything. If anyone has a suggestion, please let me know.
Got it fixed. I started over with the eMMC install and after the first step I powered the R3 mini off, powered it back on, powered it off, booted it to eMMC, powered it off, booted it to NAND, then re-installed to eMMC and it came up.
It looks like your file ist too big for this partition. Please check (e.g. with fdisk) if it is the right partition (my image use 5/6 for boot and root,but openwrt may be different) and check the size of partition and file.
It looks like you writing to a 2MB partition…image would be much larger (afair around 30MB for openwrt). So i’m sure you use the wrong partition
Sorry I am new to this how do I check with fdisk. I am using these instructions
Making sure you're not a bot! is this the right one? Currently I am getting
NOTICE: BL2: v2.6(release):
NOTICE: BL2: Built : 15:19:16, Apr 19 2023
NOTICE: WDT: disabled
NOTICE: CPU: MT7986 (2000MHz)
root@OpenWrt:/# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 44.0M 44.0M 0 100% /rom
tmpfs 997.0M 2.9M 994.2M 0% /tmp
/dev/ubi0_2 9.1M 628.0K 8.0M 7% /overlay
overlayfs:/overlay 9.1M 628.0K 8.0M 7% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mmcblk0p6 43.8M 43.8M 0 100% /mnt/mmcblk0p6
