Banana pi R3 fan with PWM
i’m the only one with a mt7915_phy1-isa-18000000 reporting 15°c ??
is +78.0°C a correct value ??
Sorry, i made a mistake when upstreaming the r3 thermal part dts due to my 3rd party pwm was not working with r3.
But you should be aware that mainline software support is done by only a few people,mainly daniel (also openwrt),wifi/hw offloading from lorenzo and some basic parts from me. These are development boards :slight_smile:
Argh, sorry for my harsh word actually, “shame” is a bit too strong in this context, I should have used “pity”. If you show me how to modify the dts, I’d be happy to PR the changes to OpenWRT as penitence :wink:
Thanks Frank and others to maintain/fix those systems, I totally appreciate the efforts… I bought that board, so at least, I hope that helped somehow :stuck_out_tongue_winking_eye:
I’d definitely wouldn’t take those 78degC too seriously…
Hello,
because of looking for a new PWM fan, I also thought about a new heatsink … . I know there is a fan for R3 but I may want to work with thermal paste. At the end it could be that I create a fansink which covers the whole area including SFP and 4G cellular modem. But this is just a dream…
Anyway, I tried to measure more exactly the chips height beneath the heatsink. I still have no digital caliper. But I got the information from internet and from a “piece of paper measurement”.
I know it sounds crazy, but after one day of thinking (How could I find something in my room that could measure in 0.1 mm steps), I realized and find out, that a piece of paper (HP Premium 90g/m^2) has 0.12 mm thickness . And because of the plain surface of the chips it is possible to use a ruler to get the differences between package heights. YES, crazy!
The measurement results matches really good with the information from internet. These is the summary:
The minimal thermal pad thickness is 0,5 mm (MT7531AE blue). After covering the chip packages surface with thermal pads, the heights should be 2,1 mm at all chips.
If something is wrong (heights, package, dimension), please write back to me!
Finding the dimensions of the different chip packages was not easy. It would be good if Banana pi could upload this data to the wiki.
Hallo again,
I learned some things about my fan(s) and frank’s post at R4 topic pushed me a bit:
First of all, I learnd that not only the PWM signal on the board is importand. I learnd that a PWM fan has microships inside which can effect the result.
I have two fans. This are my results overview with 5V and 12V:
The only fan which could be switched off was the PLD05010S12H @ 5V.
Next try would be a PLD06010S12L 55mm 0,2A. I have already ordered the fan. Should be here within a month …
Since everyone is messing around with them trip_point_x_temp variables, here’s a reference to the original defaults in case anyone prefers to go back.
Default trip_point_x_temp
Set Point Temp *C Dec Setting Notes
Set Point 0 Critical ? Speed Level: 5 (Top Gun)
Set Point 1 120 *C 120000 Speed Level: 4 (Very Fast)
Set Point 2 115 *C 115000 Speed Level: 3 (Fast)
Set Point 3 85 *C 85000 Speed Level: 2 (Medium)
Set Point 4 60 *C 60000 Speed Level: 1 (Normal)
echo 120000 > /sys/class/thermal/thermal_zone0/trip_point_1_temp  #Set to 120*C
echo 115000 > /sys/class/thermal/thermal_zone0/trip_point_2_temp
echo 85000 > /sys/class/thermal/thermal_zone0/trip_point_3_temp
echo 60000 > /sys/class/thermal/thermal_zone0/trip_point_4_temp
Note: You can manually go to each file if you desired
cd /sys/class/thermal/thermal_zone0/
vi trip_point_1_temp
Additional PWM Fan Control
echo 0 > /sys/class/pwm/pwmchip0/export
echo 10000 > /sys/class/pwm/pwmchip0/pwm0/period
echo 5000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
echo normal > /sys/class/pwm/pwmchip0/pwm0/polarity
echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
Reference: Getting Started with BPI-R3 - Banana Pi Wiki
As I understood, the recommendation for peak-cpu temp of the MediaTek MT7986 is <= 85°C. So I don’t understand the limits of 115 and 120°C. Shouldn’t the device already switch itself off if the CPU temperature rises above 90°C?
The 115/120°C is for emergecy switch off. But these shoild not be hanfled with fan like post above. Fan imho should only be used with temperatures below 100°C.
Hello. I’ve been trying to find the original 5V fan or a similar one (without a heatsink) for the BPI R3, but I haven’t been able to find anything. Do you know where to get one?
The original fan with heatsink can be found on aliexpress by searching for “bpi-r3 fan”
E.g. this https://de.aliexpress.com/item/1005008652506748.html
I do not know working one without heatsink (i tried 5v pwm,but pwm signal is only 3v3).
I was very curious because I have two official BPI-R3 heatsinks. One is noisy, the other is quite quiet. The reason is in the following photos:
IMG_20250818_233118656_HDR
Different voltages.
i wonder why the 12v does anything :thinking:
And it’s working pretty well. CPU temps at around 45º C. Fan is set to start at the same temperature. No noise. Maybe the sticker is fake :))
The voltage and current are the nominal ratings, it doesn’t say anything about operation outside of these nominal specs.
It is quite normal that the fan will run at lower speed (lower torque) when lower voltage is applied than nominal.
Sometimes the induced torque is not enough to get the motor to start running.
That i had expected for a 12v fan on 5v bus with 3.3v pwm signal.
Recently switched from Open-WRT to Gargoyle-Router firmware, which is based on Open-Wrt. The router has been working smoothly. Here are new things I learned as I was setting up a PWM fan on Gargoyle. Bpi-R3 on Open-Wrt has 5 trip points, 0 is reserved for critical and 1 is reserved for Hot, 2,3,4 can be active. Here are the changes I made:
---------------Sample rc.local file---------------
#  Set critical trip point at 95°C on thermal_zone0
# echo "critical" > /sys/class/thermal/thermal_zone0/trip_point_0_type
echo 95000 > /sys/class/thermal/thermal_zone0/trip_point_0_temp
# Set Hot trip point at 75°C on thermal_zone0
# echo "hot" > /sys/class/thermal/thermal_zone0/trip_point_1_type
echo 75000 > /sys/class/thermal/thermal_zone0/trip_point_1_temp
echo 5000 > /sys/class/thermal/thermal_zone0/trip_point_1_hyst
# Set active trip point at 49°C on thermal_zone0
# echo "active" > /sys/class/thermal/thermal_zone0/trip_point_2_type
echo 49000 > /sys/class/thermal/thermal_zone0/trip_point_2_temp
echo 2500 > /sys/class/thermal/thermal_zone0/trip_point_2_hyst
# Set active trip point at 59°C on thermal_zone0
# echo "active" > /sys/class/thermal/thermal_zone0/trip_point_3_type
echo 59000 > /sys/class/thermal/thermal_zone0/trip_point_3_temp
echo 2500 > /sys/class/thermal/thermal_zone0/trip_point_3_hyst
# Set active trip point at 69°C on thermal_zone0
# echo "active" > /sys/class/thermal/thermal_zone0/trip_point_4_type
echo 69000 > /sys/class/thermal/thermal_zone0/trip_point_4_temp
echo 2500 > /sys/class/thermal/thermal_zone0/trip_point_4_hyst
exit 0
Edit:
Note1: 3-Pin/Lead PWM fans will not work because these fans do not have PWM signal wire, the third wire on these fans is speed/tachometer wire.
Note2: Make sure to use 4Pin PWM fan. Since CN23 connector on BPi-R3 is not 4 pin connector, you will need to modify the 4pin/4lead fan to only use 3 Pins/leads. You do not need the 3rd lead in 4 pin PWM fan, which is speed/tachometer signal lead, securely tape it. Instead Connect the 4th lead of the PWM fan, which is the PWM signal wire, to the third signal pin of “CN23 PWM Fan 3Pin PH-JST connector” on the BPi-R3 PCB.
Thank you for your time. -----Navi
Hello everyone! I write scripts for control pwm
  1. Create /usr/bin/fan_control.sh nano /usr/bin/fan_control.sh
#!/bin/sh
# Automatic search for the directory with pwm1 (in case the hwmon index changes)
HWMON_DIR=""
for d in /sys/class/hwmon/hwmon*; do
    if [ -f "$d/pwm1" ]; then
        HWMON_DIR="$d"
        break
    fi
done
if [ -z "$HWMON_DIR" ]; then
    logger -t fan_control "Critical error: Interface pwm1 in /sys/class/hwmon/ not found"
    exit 1
fi
PWM_DEV="$HWMON_DIR/pwm1"
PWM_ENABLE="$HWMON_DIR/pwm1_enable"
# Manual PWM control mode (1 = manual)
if [ -f "$PWM_ENABLE" ]; then
    echo 1 > "$PWM_ENABLE" 2>/dev/null
fi
get_max_temp() {
    max_t=0
    for zone in /sys/class/thermal/thermal_zone*/temp; do
        if [ -f "$zone" ]; then
            val=$(cat "$zone" 2>/dev/null || echo 0)
            [ "$val" -gt "$max_t" ] && max_t=$val
        fi
    done
    for hwmon in /sys/class/hwmon/hwmon*/temp*_input; do
        if [ -f "$hwmon" ]; then
            val=$(cat "$hwmon" 2>/dev/null || echo 0)
        fi
    done
    echo $((max_t / 1000))
CURRENT_PWM=-1
set_fan_duty() {
    target=$1
    if [ "$target" -ne "$CURRENT_PWM" ]; then
        echo "$target" > "$PWM_DEV"
        CURRENT_PWM=$target
    fi
logger -t fan_control "The Fan Monitor service started successfully ($PWM_DEV)"
# Scale 0..255
while true; do
    TEMP=$(get_max_temp)
    if [ "$TEMP" -ge 72 ]; then
        set_fan_duty 255
    elif [ "$TEMP" -ge 62 ]; then
        set_fan_duty 180
    elif [ "$TEMP" -ge 54 ]; then
        set_fan_duty 115
    elif [ "$TEMP" -ge 48 ]; then
        set_fan_duty 65
    elif [ "$TEMP" -le 43 ]; then
        set_fan_duty 0
    fi
    sleep 4
done
  1. Create /etc/init.d/fan_control nano /etc/init.d/fan_control
#!/bin/sh /etc/rc.common
USE_PROCD=1
START=99
STOP=10
PROG=/usr/bin/fan_control.sh
start_service() {
    procd_open_instance
    procd_set_param command "$PROG"
    procd_set_param respawn 3600 5 0
    procd_set_param stdout 1
    procd_set_param stderr 1
    procd_close_instance
  1. make executable /etc/init.d/fan_control
chmod +x /etc/init.d/fan_control
/etc/init.d/fan_control enable
/etc/init.d/fan_control start
  1. Test it:
pgrep -f fan_control.sh
logread -e fan_control
