I would like to apply for one BPI-M7 with 32 GB RAM for an open-source, offline USB protocol observatory. I own an original EINSTAR handheld scanner and have started EINSTAR USB Observatory, which currently includes a Python tool for summarizing USB trace metadata and tests using synthetic records. I have not captured real scanner traffic or validated this workflow on Banana Pi hardware yet.
My plan is to bring up the BPI-M7 as a dedicated Linux capture and analysis host, check USB 2 enumeration and trace collection using a device I own, and compare sanitized trace summaries with captures from my existing PC. I would publish exact setup steps, code changes, reproducible synthetic examples, and measured CPU, memory, power, and sustained-capture behavior. If practical, I would also test offline small-model summarization of sanitized metadata and report model size, latency, memory use, and failures rather than claiming NPU support in advance. No vendor binaries, raw private captures, or identifying device data would be published.
I will share an honest board bring-up and project results on this forum and in the public repository. Please confirm whether the 32 GB variant is available for this program, whether power/cooling accessories are included, and whether the board can be shipped to Virginia, USA with no cost to me for the board, shipping, taxes, or duties, and that I may keep the board without a required return. I would share my mailing address only in a private message after those terms are clear.
Hi - Iām lead developer of Frugal IoT which is a fully open-source project to make IoT solutions affordable in highly resource constrained environments. Its a full stack from hardware designs; firmware; server; client. One of the elements is a server that can run locally when the backbone to the internet is down, and typically runs on a Raspberry Pi. Some of the people in the Community Networks / Remote Internet access space are experimenting with bring services to newly connected remote communities, including IoT and also are experimenting with the Banana Pi, and have asked me if the Frugal-IoT server could run on the Banana Pi. I really donāt know - its Linux based - but would have to work within the constrained OpenWRT environment, which is probably do-able, but hard without anything to test on. Hence this request.
I see you have a bunch of router products, its the Open WRT One that Iām getting requests for support for, and would like to get a sample to test.
A lot of the applications I imagine being used for would be as a GSM->WiFi router, and notice it doesnāt have a SIM card, is that an add-on, or something planned for a later version? I notice you also have BPI-R3 that has a SIM slot, but if I read the web page correctly it doesnāt support OpenWRT?
Iām not familiar with your Zero range, if Iām reading the website correctly, the BPI-P2 Zero, BPI-M2 Zero, BPI-M4 Zero all support Linux. Iāve tested the frugal-iot-server against some of the Raspberry PI range, with success on the RPI4. The Pi-Zero-W, sometimes works, but the installer fails more than 50% of the time for no detectable reason so we donāt recommend it. And we donāt have a Pi-Zero-2W to see if that is reliable. It would be interesting to see which of your lower end boards were viable servers, though I think the combination with the router in OpenWRT-One makes more sense if that works.
Generally the node code of Frugal IoT works on any ESP32 variant, so I have no reason to think it wouldnāt work on your ESP32-S2 and ESP32-S3 boards, but if you wanted to send me any at the same time, Iāll check them and add them to the supported list on the Wiki.
Iām Aditya Upadhye, a software engineer and recent MS Computer Science graduate from Stony Brook University. My experience includes building AI agents, real-time speech-processing systems, and LLM-powered applications.
Board requested: Banana Pi BPI-M7 (preferably 32GB RAM, but flexible).
Iām interested in exploring a practical question: How well can modern AI models actually run on affordable edge hardware?
Iād like to develop an open-source project, EdgeProof, to evaluate small language models, speech recognition, and computer vision workloads on the BPI-M7.
My focus would be on:
Benchmarking inference speed, latency, memory usage, and thermal performance.
Exploring CPU vs. NPU acceleration using RKNN/RKLLM.
Demonstrating a practical, privacy-preserving offline AI application.
Iāll publish the source code, reproducible benchmarks, and setup guides on GitHub. Iāll also write a detailed technical post on the Banana Pi community forum, sharing my experiments, performance results, challenges, and practical recommendations for developers exploring on-device AI.
The BPI-M7ās RK3588 platform is particularly interesting to me because Iād like to investigate the gap between advertised NPU capabilities and real-world AI performance.
Iād be excited to contribute useful, independently tested resources to the Banana Pi ecosystem!
Good day!
Thank you for your support!
This is Klaus , from Banana Pi. You can contact me : [email protected]
I will follow up on this matter.
@sinovoip@aditya
Thank you, Klaus! I appreciate your response and willingness to follow up. Iāve reached out to you via email regarding my BPI-M7 developer board request. Looking forward to hearing from you!
